Add the package to one of the “#IgnorePkg =” lines in your /etc/pacman.conf and remove the # at the front.
On the other computer also with manjaro LXQt, almost the same problem in the pamac update
or pacman -Syyu
pamac update ✔
Preparando...
Sincronizando banco de dados de pacotes...
Resolvendo dependências...
Verificando conflito entre pacotes...
Aviso: dependência cíclica detectada:
Aviso: bashrc-manjaro será instalado antes de sua dependência bash
Will you have any problems while continuing the update?
===== Edit ======
Another user here reports the same problem
T+ = See you later
@freggel.doe what are the steps/commands to do that, as I have the same issue on my update too.
conflicting files:
- plasma-workspace: /usr/share/locale/ta/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
You can add the packages to “#IgnorePkg =” lines in your /etc/pacman.conf
. Also uninstall any linux5xx-nvidia or linux4xx-nvidia driver and get the dkms package from here, as we updated also the kernels, and precompiled kernel modules don’t work with the new kernels.
There was a downgrade of pamac at some point, since one of our package maintainers didn’t talked with the release team. The other things you posted are Warnings. As long as it works you can ignore them, especially dependency cycle warnings.
Continuing to update anything I will report again
T+ = See you later
After this update the clipboard spotted working. Unable to paste anything, although the copied content shows up in the “clipboard contents” system tray thingy.
Manjaro KDE, Nvidia proprietary graphics.
EDIT: Bug fixed itself after a reboot. Not sure what the problem was
Generally new user, I get the following issues when trying to update my manjaro system:
conflicting files:
Any step by step instructions on how to fix the issue?
I get only the warnings (local version is newer than extra), but I have no problem with dependences. I use -Syu.
To fix:
sudo pacman -Rdd plasma-desktop-primex
sudo pacman -Syu plasma-desktop
When I try to update, I’m shown the following error
:: installing nvidia-utils (460.80-1) breaks dependency ‘nvidia-utils=460.73.01’ required by linux59-nvidia
The following are my current kernel details (not sure if its relevant, added it nonetheless)
Currently running: 5.10.34-1-MANJARO (linux510)
- linux510
- linux59
Kindly help me figure out how to deal with this.
Thank you
PS: I figured that I had to uninstall linux59. I’d just like to confirm if running
sudo mhwd-kernel -r linux59
is sufficient.
Thank you, that fixed the issue and I was able to update my System.
what is the cause of this bug ? When I run the second line, a huge amount of things get installed, is there any side effects of this ?
got the same, No idea what to do here. Pretty annoying bug.
This is what I’ve tried 3 times now, as I said in my post. However, it always ends the same way:
- First, when I get prompted to reboot after the update, my screen blurs out and then nothing happens. So I use the console to do “shutdown now”.
- Then when I boot up again, I have seemingly no desktop. Just a black background that I can’t interact with. No taskbar or start menu and alt + space to launch applications won’t work. I can move my cursor to the top left corner of the screen to switch activities and I can use alt + tab, so some things seem to work.
I guess I’m doing something wrong when I try to replace plasma-desktop-primex with plasma-desktop, but I don’t know what. I honestly don’t know how I’m “supposed” to do it. I just start up the Pamac GUI, check uninstall on plasma-desktop-primex and install on plasma-desktop.
EDIT:
I tried using the console commands posted here, but still having the same issues:
Edit 2:
Not sure if it matters, but the blurred screen I get stuck at when trying to reboot is called “ksmserver-logout-greeter”. I can still switch acitivities etc. It’s just that the reboot doesn’t hapopen unless I run “shutdown now”
When I updated, then restarted my pc, it would not boot up. I had to reinstall the system. Tried this twice.
Third time, I did NOT update the NVDIA driver information and things went smoothly. The system booted.
I’m not sure what would have caused this.
working great here! ty
After restarting, the desktop effects stopped working, but re-enabling the compositor and restarting the pc again fixed it.
You may be getting getting hit by a known bug? Under the Known Issues
New issues:
- Some Nvidia cards don’t work with the current 460.80 drivers when used with Display Port and/or 4k Monitors. More about the issue at the Nvidia Developer Forum. We recommend to switch to Nouveau driver as needed. If you however need the Nvidia driver, you can get the
PKGBUILD
s of the 460.73.01 version and build your driver locally withmakepkg
or use the pre-compiled packages: nvida-utils, dkms and lib32 + precompiled .
Boots(or rather fails to boot) to blackscreen
Networking never loads, It just does fschk and then blackscreens at the point it would normally load in. I dont know if its an nvidia thing or something else. It is nvidia with my main monitor on display port.
Was able to rescue system with arch-chroot from a liveUSB with timeshift-autosnap backup
Ill be not updating my system until this nvidia thing is sorted out, or there is some way to get it functioning with an updated driver, thats a deal breaker for me.
I have an Nvidia GTX 960 with the proprietary driver and two 1080p monitors, one connected to HDMI and the other to DVI. Will I be okay applying this update?
I updated anyways and it all seems to be okay with my configuration and both my monitors seem to be working.
It was also my first stable update after installing Pipewire and it works alright.
So, no problems on my part with:
- KDE Plasma
- i5-4460
- GTX 960
- 16GB DDR3 RAM
- Two 1080p monitors(HDMI, DVI)
