Was able to complete the update, however reboot used kernel 5.10, and I had an unresponsive keyboard and mouse at the login screen. I switched over to a terminal, tried to start a server with no luck. Rebooted into kernel 5.4, all is working again.
I removed “quiet”, I did a shutdown, it took only a few seconds, not sure really what changed. maybe it was just a temporary issue and manjaro fixed itself
Here I’m yet just to report another minor glitch, I found when Zoom today launched its new flatpak version: While Pamac has actually successfully finished the update and gave me the corresponding “Your system is updated” message, the Cinnamon system tray icon didn’t move to the corresponding “Your system is updated” shield till I made a reboot. Yesterday’s big update went well at that regard, even though it was done from Pacman.
X Error of failed request: GLXBadFBConfig
Major opcode of failed request: 153 (GLX)
Minor opcode of failed request: 0 ()
Serial number of failed request: 26178
Current serial number in output stream: 26178
After uprade I had no audiodevices anymore in Gnome Settings → Sound. Also connecting a new bluetooth headset did not appear in Input/Output device Pulldowns. The pulldowns where simply empty and no application was able to play sound.
> systemctl --user status pipewire-media-session
Apr 10 19:48:31 T540p-20bfs2ec00 pipewire-media-session[3265]: core 0x563bfdb066f0: can't find protocol 'PipeWire:Protocol:Native': Operation not supported
Apr 10 19:48:31 T540p-20bfs2ec00 pipewire-media-session[3265]: can't start monitor: Operation not supported
Apr 10 19:48:31 T540p-20bfs2ec00 systemd[1314]: pipewire-media-session.service: Main process exited, code=exited, status=161/n/a
Apr 10 19:48:31 T540p-20bfs2ec00 systemd[1314]: pipewire-media-session.service: Failed with result 'exit-code'.
Apr 10 19:48:31 T540p-20bfs2ec00 systemd[1314]: pipewire-media-session.service: Scheduled restart job, restart counter is at 5.
Apr 10 19:48:31 T540p-20bfs2ec00 systemd[1314]: Stopped Multimedia Service Session Manager.
Apr 10 19:48:31 T540p-20bfs2ec00 systemd[1314]: pipewire-media-session.service: Start request repeated too quickly.
Apr 10 19:48:31 T540p-20bfs2ec00 systemd[1314]: Failed to start Multimedia Service Session Manager.
After deleting /etc/pipewire and reinstalling “pacman -S pipewire pipewire-media-session pipewire-pulse” it was working again.
Maybe pamac should get an option to reinstall?
^Same, override doesn’t work with all Wine programs tho.
Some games open and keeps on a black screen, Proton still works for me, although i barely used it.
Apparently the same problem here. In updated Gnome Files context menu access to administrator rights for opening folders and editing files returns the errors seen in @VictorSproot post.
