Well, that might then be an upstream bug, in which case you could report it at bugs.kde.org, but what you did makes no sense at all, and it is therefore just as likely that the KDE developers will shrug it off as a usage error.
Thatâs pretty normal in GNU/Linux. The Windows Explorer is a core component of the Microsoft Windows operating system. GNU/Linux distributions are by law forbidden to include parts of Microsoft Windows.
Well idk what Itâs called âwindows explorerâ in manjaro so I just use the windows version, What I meant is there are no task manager, windows manager
In other words, you are unfamiliar with the system and how it works, and yet you start doing illogical things that lead to some unexpected behavior. That would be like driving your car against a wall at high speed in order to test whether the airbag will inflate.
Donât you think that you could at least familiarize yourself with GNU/Linux first before starting to test whether you can break it?
Iâve just started in using manjaro a few days ago, I use to interact alot with other distros on virtual machines and vps for a long time so I do know some basics. And Iâm not âtestingâ, I just eventually meet the problems when my brother switch user.
You could first and foremost check whether the bug has already been reported, because if it hasnât been, then chances are that the KDE developers themselves arenât even aware of it. However, considering that the login screen does on occasion seem to hang â which, mind you, is only temporary, because if you wait a bit and move the mouse a bit, then it does eventually log you in â I suspect that theyâll already know.
And that said, if they do indeed already know, then itâs a matter of how important they think it is. There are still bugs in Plasma now that were already in the previous release, and that they do certainly know about, but which they still havenât bothered to fix.
Eventually, it will get fixed, but nobody can predict when that is the case.
I could see a situation where that would make sense, for example to reload groups permission after adding/changing them, correctly apply themes, things like that. Sometimes you need to log again for things to be applied.
Fair enough, however in my opinion, logout then switching user to the previously logged in user is basically the same as a logout then login, so this is probably a KDE bug.
I recall the KillUserProcess=yes setting in one of the system config file that was required to simply be able to log back in after a logout, long time ago, maybe there is still some kind of issue unresolved in KDE.
I use my system as single user and never logout so I donât really know these issues.
I was unable to login after resuming from sleep. Just kept saying âLogin failed.â I tried switching user to no avail. Was reading in this post and another post about a KDE bug and was going to try lightdm as a work around but decided to boot with the 5.4 kernel instead of the 5.15 to check that first and the behavior was not there.
Iâve experienced a similar/same issue. Iâve accidentally clicked switch user, but want to immediately log back into my account, the system would freezes and a hard reboot was required, but after enabling REISUB, I can avoid a hard reboot but I still need to use alt+sysrq+k to unfreeze and log back into my user.
Here I thought it was a bug but rather a âfeatureâ. LOL.
I donât understand why the default would be set in such a way as to leave a user hanging (I suppose itâs some kind of theoretical security issue theyâre trying to prevent?). Anyway if a manjaro dev reads this, may I suggest switching this setting this to true?
