Hi, I’m running lates Manjaro with Plasma environment on my NUC6i7kyk. From begging audio has worked fine, with my SPDIF output being fully functional. But the same day I installed my os audio switched off and return some time later. After this audio continues switching off after random periods of time. I noticed that when audio switches off not only my optical output stops working, but also HDMI gives no sound. Another thing I managed to spot is that light inside SPDIF port normally stays on, but when audio cuts off the red light also disappears.
Hi and welcome to the Forum ![]()
Help others to help you better by:
- Providing system info about your hardware by posting program output instead of describing your hardware.
- Use new lines when a sentence ends, so it is better readable and followable by others.
- If english is not your native language please see:
English [HowTo] Become multi-language on internet-
Türkçe [Nasıl] İnternette çok dilli olun
Deutsch [Wie man] Werden Sie im Internet mehrsprachig
Français [Comment] Devenir multilingue sur internet
Española [Cómo] Conviértete en multilenguaje en Internet
中文 [如何] 成为互联网上的多语言
Italiana [Come] Diventa multilingua su internet
русский язык [Как] Стать многоязычным в Интернете
Please read and follow all advice in this thread:
Especially:
To remove PulseAudio module that suspends unused audio devices:
[ PulseAudio - ArchWiki /Troubleshooting#Pops_when_starting_and_stopping_playback ]
To turn off power management for onboard audio device (ALC233):
[ Advanced Linux Sound Architecture/Troubleshooting - ArchWiki ]
Sorry for responding so late, but i haven’t got time to check your propositions. Unfortunately none of them seems to work for me. Even restarting audio using this command systemctl --user restart pulseaudio.service or rebooting pc helps. It does not look like os problem for me. ![]()
If pulseaudio.service only is restarted, pulseaudio.socket is likely to fail
Simpler command to restart both PulseAudio systemd units (pulseaudio.socket and pulseaudio.service):
@nikgnomic
That is exactly the same as systemctl --user restart pulseaudio.service because “.service” is added by default to the unit name…
In face pulseaudio.socket is using the pulseaudio.service for it’s functionality, that is how sockets work in systemd…
See this previous discussion where another user reported different outcomes when using similar commands
post #2 in previous discussion quote part of /usr/lib/systemd/user/pulseaudio.service comment and the Requires=pulseaudio.socket dependency
systemd.socket(5) — Arch manual pages
No implicit WantedBy= or RequiredBy= dependency from the socket to the service is added. This means that the service may be started without the socket, in which case it must be able to open sockets by itself. To prevent this, an explicit Requires= dependency may be added.
I guess you have problems understanding what i wrote…
I have used command suggested in the manpage for many years with no issues, so no need to consider anything more
If only reading was same as understanding…
Keep Copy&Paste code without understanding…
I’m redirtecting you to /dev/null now.
