Hi there, a friend of mine has a laptop of which the sound is not working on Linux.
From the application ‘Speccy’ in Windows it seems like the laptop has two different sound cards. Neither he or I is specialized in sound cards or sound in Linux in general, so we don’t really know what we’re doing.
Things we’ve tried:
pacmd list-sinks
driver: <module-alsa-card.c>
flags HARDWARE HW_MUTE_CTRL HW_VOLUME CTRL DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority 9039
volume: front-left: 30419 / 46% / -20.00 dB, front-right: 30419 / 46% / -20.00 dB balance 0.00
base volume: 65536 / 100% / 0.00 dB
volume steps: 65537
muted: no
current latency: 0.00 ms
max request: 0 KiB
max rewind: 0 KiB
monitor source: 0
sample spec: s161e 2ch 44100Hz
channel map: front-left, front-right Stereo
used by: 0
linked by: 0
configured latency: 0.00ms; range is 0.50 .. 2000.00 ms
card: 0 <alsa_card.pci-0000_00_1f.3>
module: 6
priorities:
alsa.resolution._bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class "generic"
alsa.subclass = "generic-mix"
alsa.name "ALC298 Analog"
alsa.id "ALC298 Analog"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "0"
alsa.card = "0"
alsa.long_card_name = "HDA Intel PCH at 0xdf638000 irq 132"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
device.bus = "pci"
device.vendor.id = "8086"
device.product.id = "9d71"
device.product.name = "Sunrise Point-LP HD Audio"
device.string = "front:0"
device.buffering.buffer_size = "352800"
device.buffering.fragment_size = "176400"
device.access_mode = "mmap+timer"
device.profile.name = "analog-stereo"
device.profile.description = "Analog Stereo"
device.description = "Built-in Audio Analog Stereo"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
ports:
analog-output-speaker: Speakers (priority 100000, latency offset 0 usec, available: unknown)
properties:
active port: <analog-output-speaker>
arecord -l
**** List of CAPTURE Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC298 Analag [ALC298 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
In Pavucontrol there are no devices listed at all
Output of lspci | grep -i audio
00:1f.3 Multimedia audio controller: Intel Corporation Sunrise Point-LP HD Audio (rev 21)
We’ve tried putting the following lines in /etc/modprobe.d/50-alsa.conf (one by one, rebooting after each):
options snd-hda-intel index=1,0
options snd-hda-intel index=2,0
options snd-hda-intel index=3,0
options snd_hda_intel enable=1 index=0
options snd_hda_intel index=1
And a lot of other things we found online that I can’t remember anymore.
Does anybody know how to make this work? Thanks!
Fabby
6 August 2021 01:50
2
Welcome to Manjaro!
Please read this:
How to provide good information
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text .
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which exact CPU/GPU or Kernel, … you have without typing it every time
As it’s a friend’s laptop, I’d prefer not to put system information in my profile
Information from within Windows:
Sound Cards
Realtek High Definition Audio(SST)
Intel Display Audio
Playback Device
Speakers (Realtek High Definition Audio(SST))
Recording Device
Microphone Array (Realtek High Definition Audio(SST))
Output of the inxi command:
Kernel: 5.10.53-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=<filtered> rw quiet splash apparmor=1
Desktop: GNOME 40.3 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
Type: Detachable System: SAMSUNG product: Galaxy Book 12 v: P04HAC
serial: <filter> Chassis: type: 32 serial: <filter>
Mobo: SAMSUNG model: SM-W720NTKBXAR v: SGL8766A2F-C01-G001-S0001+10.0.14393
serial: <filter> UEFI: American Megatrends v: P04HAC.000.180220.WY.1219
date: 02/20/2018
ID-1: BAT1 charge: 27.5 Wh (83.1%) condition: 33.1/39.0 Wh (84.8%)
volts: 8.4 min: 7.7 model: SAMSUNG Electronics SR Real Battery type: Li-ion
serial: <filter> status: Charging cycles: 591
RAM: total: 3.74 GiB used: 1.78 GiB (47.6%)
Info: Dual Core model: Intel Core i5-7200U bits: 64 type: MT MCP
arch: Amber/Kaby Lake note: check family: 6 model-id: 8E (142) stepping: 9
microcode: EA cache: L2: 3 MiB bogomips: 21607
Speed: 800 MHz min/max: 400/3100 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel HD Graphics 620 vendor: Samsung Co driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5916 class-ID: 0300
Display: wayland server: X.org 1.20.11 compositor: gnome-shell driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: 0
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.1.5
direct render: Yes
Device-1: Intel Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Imaging
Unit
vendor: Samsung Co driver: ipu3-imgu alternate: ipu3_imgu bus-ID: 00:05.0
chip-ID: 8086:1919 class-ID: 0480
Device-2: Intel CSI-2 Host vendor: Samsung Co driver: ipu3-cio2
alternate: ipu3_cio2 bus-ID: 00:14.3 chip-ID: 8086:9d32 class-ID: 0480
Device-3: Intel Sunrise Point-LP HD Audio vendor: Samsung Co
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0401
Sound Server-1: ALSA v: k5.10.53-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.32 running: no
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Samsung Co driver: ath10k_pci v: kernel port: f040 bus-ID: 01:00.0
chip-ID: 168c:003e class-ID: 0280
Device-1: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: USB driver: btusb
v: 0.8 bus-ID: 1-3:3 chip-ID: 0cf3:e300 class-ID: e001
Local Storage: total: 148.97 GiB used: 22.95 GiB (15.4%)
ID-1: /dev/mmcblk0 maj-min: 179:0 model: SS32G size: 29.72 GiB block-size:
physical: 512 B logical: 512 B type: SSD serial: <filter> scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: LITE-ON model: CV3-8D128
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 003 scheme: GPT
ID-1: / raw-size: 46.85 GiB size: 45.82 GiB (97.79%) used: 8.87 GiB (19.3%)
fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: <filtered>
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 32 MiB (6.3%)
fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A uuid: <filtered>
ID-3: /run/media/nightwind/Local Disk raw-size: 29.72 GiB
size: 29.72 GiB (100.00%) used: 14.06 GiB (47.3%) fs: ntfs
dev: /dev/mmcblk0p1 maj-min: 179:1 label: Local Disk uuid: <filtered>
ID-1: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: ext4 label: N/A
uuid: <filtered>
ID-2: /dev/sda3 maj-min: 8:3 size: 47.04 GiB fs: ntfs label: N/A
uuid: <filtered>
ID-3: /dev/sda4 maj-min: 8:4 size: 24.83 GiB fs: ntfs label: Local DIsc
uuid: <filtered>
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-2:2 info: Samsung type: Mouse,Keyboard,HID
driver: hid-generic,hid-multitouch,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 04e8:a00a class-ID: 0300
Device-2: 1-3:3 info: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 36.0 C mobo: 34.0 C
Processes: 262 Uptime: 20h 20m wakeups: 11 Init: systemd v: 248
tool: systemctl Compilers: gcc: N/A Packages: pacman: 1138 lib: 296
flatpak: 0 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.06
Thank you!
InvertedSquare:
SM-W720NTKBXAR
Thank you for the response! In no way felt it rogue, don’t feel bad…
Anyways, it’s not hooked up to a docking station. It’s a tablet-like computer, just look up Galaxy Book
There is no UEFI firmware update available. We’ve used alsamixer to turn up the volume.
This is a screenshot of tho hdjackretask command:
https://paste.pics/1a339052aa23098c04523407fba60c02
This is what it looks like when ‘Show unconnected pins’ is toggled on:
https://paste.pics/643b00ade413746e5e381d0112cfd2ab
Thank you for your replies!
Fabby
7 August 2021 20:21
6
The first screenshot seems to have been deleted???
But from the second one I can see that your internal speaker is connected!
So now my advice gets a bit more fuzzy as I don’t have your exact hardware:
Uncheck the Advanced override mode
Check Override on pin 0x13 (The first unconnected pin)
use the drop-down menu and choose the first thing that contains speaker except Internal speaker as that is already connected to 0x17
go down the list of unconnected pins and take the second, thirs, … hardware item that contains any speaker not connected yet.
When done with all speakers, click Apply now
If you get an error message:
Click Install boot override
Reboot
Test again.
I suggest you install v5.13 kernel. It might have been patched to detect this audio device correctly
Use either Manjaro Settings Manager GUI - manjaro-settings-manager -m msm_kernel
or this command
sudo mhwd-kernel -i linux513
If a later kernel does not help you might be able to get information about the working audio codec configuration using this guide:
How to sniff verbs from a Windows sound driver · ryanprescott/realtek-verb-tools Wiki · GitHub
Data from a working audio codec will help developers to create a kernel patch
Hi there, sorry for the late response.
Weird that the link isn’t working, here is a new one: https://paste.pics/4283b56d496ec0087ca28029036b9df5
Tried what you said, no luck sadly…
Any other ideas?
Fabby
11 August 2021 08:29
9
InvertedSquare:
Any other ideas?
Follow @nikgnomic 's advice and report back, please.
