Good evening,
For some unknown reason, my USB headset (Steelseries Arctis 5) is no longer detected at all by the Sound settings (Cinnamon DE). When I look in pavucontrol, it doesn’t detect it either. However, I am able to see it in alsamixer as a playback device – but nothing happens when I try to enable it from there.
When I grep for pulseaudio, it returns:
-rw-r–r-- 1 root root 2572 May 13 19:50 pulseaudio-alsa-1:1.2.2-2-x86_64.pkg.tar.zst
When I browse inxi, it displays:
System: Host: nychitman1-x570-custom Kernel: 5.7.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
Desktop: Cinnamon 4.6.7 tk: GTK 3.24.22 info: plank dm: LightDM 1.30.0 Distro: Manjaro Linux
Machine: Type: Desktop System: Gigabyte product: X570 AORUS MASTER v: -CF serial: <superuser/root required>
Mobo: Gigabyte model: X570 AORUS MASTER v: x.x serial: <superuser/root required> UEFI: American Megatrends v: F20
date: 07/07/2020
CPU: Topology: 12-Core model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2 L2 cache: 6144 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 182484
Speed: 2201 MHz min/max: 2200/3800 MHz boost: enabled Core speeds (MHz): 1: 2263 2: 1899 3: 2199 4: 2199 5: 2477
6: 2149 7: 1985 8: 2043 9: 3715 10: 2035 11: 2200 12: 2192 13: 2032 14: 2193 15: 2196 16: 2196 17: 2195 18: 2057
19: 4052 20: 2043 21: 2202 22: 2199 23: 2195 24: 2198
Graphics: Device-1: NVIDIA TU104 [GeForce RTX 2070 SUPER] vendor: Gigabyte driver: nvidia v: 440.100 bus ID: 0c:00.0
chip ID: 10de:1e84
Display: x11 server: X.Org 1.20.8 driver: nvidia resolution: 2560x1440~144Hz s-dpi: 96
OpenGL: renderer: GeForce RTX 2070 SUPER/PCIe/SSE2 v: 4.6.0 NVIDIA 440.100 direct render: Yes
Audio: Device-1: NVIDIA TU104 HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel bus ID: 0c:00.1 chip ID: 10de:10f8
Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
bus ID: 0e:00.4 chip ID: 1022:1487
Device-3: SteelSeries ApS Controller type: USB driver: hid-generic,snd-usb-audio,usbhid bus ID: 3-6.3:7
chip ID: 1038:12aa serial: 00000000
Sound Server: ALSA v: k5.7.15-1-MANJARO
Network: Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus ID: 06:00.0 chip ID: 8086:2723
IF: wlp6s0 state: down mac: 1a:1b:d5:2b:f8:c9
Device-2: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: 5.6.0-k port: e000 bus ID: 07:00.0
chip ID: 8086:1539
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: b4:2e:99:a3:55:d4
Device-3: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel port: d000 bus ID: 08:00.0
chip ID: 10ec:8125
IF: enp8s0 state: down mac: b4:2e:99:a3:55:d3
Drives: Local Storage: total: 1.82 TiB used: 475.01 GiB (25.5%)
ID-1: /dev/nvme0n1 vendor: Corsair model: Force MP600 size: 1.82 TiB speed: 63.2 Gb/s lanes: 4
serial: 20138230000128565075 rev: EGFM11.3 scheme: GPT
ID-2: /dev/nvme1n1 vendor: Sabrent model: Rocket 4.0 1TB size: 931.51 GiB speed: 63.2 Gb/s lanes: 4
serial: A5CD070102B301209183 rev: RKT401.2 scheme: GPT
ID-3: /dev/nvme2n1 vendor: Sabrent model: Rocket 4.0 1TB size: 931.51 GiB speed: 63.2 Gb/s lanes: 4
serial: A5CD07050DB303138693 rev: RKT401.2 scheme: GPT
Partition: ID-1: / size: 52.62 GiB used: 18.05 GiB (34.3%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: /home size: 1.74 TiB used: 456.96 GiB (25.7%) fs: ext4 dev: /dev/nvme0n1p3
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 40.8 C mobo: N/A gpu: nvidia temp: 53 C
Info: Processes: 439 Uptime: 13h 42m Memory: 31.37 GiB used: 5.13 GiB (16.3%) Init: systemd v: 246 Compilers: gcc: 10.1.0
clang: 10.0.1 Packages: pacman: 1430 Shell: Bash v: 5.0.18 running in: xfce4-terminal inxi: 3.1.05
dmesg grep for snd:
[ 3.518232] snd_hda_intel 0000:0c:00.1: Disabling MSI
[ 3.518242] snd_hda_intel 0000:0c:00.1: Handle vga_switcheroo audio client
[ 3.518337] snd_hda_intel 0000:0e:00.4: enabling device (0000 -> 0002)
[ 3.648775] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC1220: line_outs=3 (0x1b/0x15/0x16/0x0/0x0) type:line
[ 3.648778] snd_hda_codec_realtek hdaudioC1D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 3.648780] snd_hda_codec_realtek hdaudioC1D0: hp_outs=1 (0x14/0x0/0x0/0x0/0x0)
[ 3.648781] snd_hda_codec_realtek hdaudioC1D0: mono: mono_out=0x0
[ 3.648782] snd_hda_codec_realtek hdaudioC1D0: dig-out=0x1e/0x0
[ 3.648783] snd_hda_codec_realtek hdaudioC1D0: inputs:
[ 3.648784] snd_hda_codec_realtek hdaudioC1D0: Front Mic=0x19
[ 3.648785] snd_hda_codec_realtek hdaudioC1D0: Rear Mic=0x18
[ 3.648787] snd_hda_codec_realtek hdaudioC1D0: Line=0x1a
[ 7.074053] usbcore: registered new interface driver snd-usb-audio
pacmd dump:
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
load-module module-augment-properties
load-module module-switch-on-port-available
load-module module-udev-detect
load-module module-alsa-card device_id=“0” name=“pci-0000_0c_00.1” card_name=“alsa_card.pci-0000_0c_00.1” namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties=“module-udev-detect.discovered=1”
load-module module-alsa-card device_id=“1” name=“pci-0000_0e_00.4” card_name=“alsa_card.pci-0000_0e_00.4” namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties=“module-udev-detect.discovered=1”
load-module module-jackdbus-detect channels=2
load-module module-bluetooth-policy
load-module module-bluetooth-discover
load-module module-bluez5-discover
load-module module-dbus-protocol
load-module module-native-protocol-unix
load-module module-gsettings
load-module module-default-device-restore
load-module module-rescue-streams
load-module module-always-sink
load-module module-intended-roles
load-module module-suspend-on-idle
load-module module-console-kit
load-module module-systemd-login
load-module module-position-event-sounds
load-module module-role-cork
load-module module-filter-heuristics
load-module module-filter-apply
load-module module-x11-publish display=:0
load-module module-x11-xsmp display=:0 session_manager=local/nychitman1-x570-custom:@/tmp/.ICE-unix/1746,unix/nychitman1-x570-custom:/tmp/.ICE-unix/1746
load-module module-cli-protocol-unixset-sink-volume alsa_output.pci-0000_0e_00.4.iec958-stereo 0x10000
set-sink-mute alsa_output.pci-0000_0e_00.4.iec958-stereo no
suspend-sink alsa_output.pci-0000_0e_00.4.iec958-stereo yes
set-sink-volume alsa_output.pci-0000_0c_00.1.hdmi-stereo 0x10000
set-sink-mute alsa_output.pci-0000_0c_00.1.hdmi-stereo no
suspend-sink alsa_output.pci-0000_0c_00.1.hdmi-stereo yesset-source-volume alsa_output.pci-0000_0e_00.4.iec958-stereo.monitor 0x10000
set-source-mute alsa_output.pci-0000_0e_00.4.iec958-stereo.monitor no
suspend-source alsa_output.pci-0000_0e_00.4.iec958-stereo.monitor yes
set-source-volume alsa_output.pci-0000_0c_00.1.hdmi-stereo.monitor 0xfffe
set-source-mute alsa_output.pci-0000_0c_00.1.hdmi-stereo.monitor no
suspend-source alsa_output.pci-0000_0c_00.1.hdmi-stereo.monitor yesset-card-profile alsa_card.pci-0000_0c_00.1 output:hdmi-stereo
set-card-profile alsa_card.pci-0000_0e_00.4 output:iec958-stereoset-default-sink alsa_output.pci-0000_0c_00.1.hdmi-stereo
set-default-source alsa_output.pci-0000_0c_00.1.hdmi-stereo.monitor
alsa-info: http://alsa-project.org/db/?f=859b307e2c01c2b100eb9b338fe18448dfe6b2bd
Is anyone else experiencing something similar? If so, have you fixed it? If you have fixed it, can you please provide some tips – I would greatly appreciate it.
Thanks in advance,
Josh aka NYCHitman1
