Here is a link to my previous issue:
The issue still occurs after reboot and I need to type the same command in to unmute the speakers.
Hi @KnowingMe145889,
This isn’t a solution, merely a workaround, but you can write a systemd service unit that executes the command to unmute the speakers automatically on startup.
See:
Unmuting Speakers in pipewire-pulse might be a persistent solution
pactl set-sink-mute alsa_output.pci-0000:00:1f.3-platform-skl_hda_dsp_generic.analog-stereo 0
Sink/Source Port Volume/Mute/Port-Latency · Wiki · PipeWire GitLab
Is this a command that can be typed directly into the terminal?
The first part was, but the second wasn’t.
Guessing (because you haven’t told us) that you are using KDE Plasma, try this from terminal:
1. Use the first command given
2. Open Kate (editor) from the terminal.
kate ~/.config/autostart/speaker-unmute.desktop
3. Paste the .desktop file content (previously given by @nikgnomic) into the new empty Kate window when Kate opens:
[Desktop Entry]
Version=1.0
Type=Application
Name=speaker-unmute
Comment=unmute speaker 5s after login
Exec=/usr/bin/sleep 5 && /usr/bin/amixer -qc sofhdadsp sset 'Speaker' unmute
Icon=
Path=
Terminal=false
StartupNotify=false
4. Close and save the file.
5. Logout/login or reboot.
That should cover it. Cheers.
tee ~/.config/autostart/speaker-unmute.desktop <<< '[Desktop Entry]
Version=1.0
Type=Application
Name=speaker-unmute
Icon=
Path=
Terminal=false
StartupNotify=false'
Please don’t post images of text. Instead:
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
For more information, please see:
Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Is there a point you’re trying to make with the screenshot?
I used kate as an example because I’m using KDE Plasma, and kate is therefore the default text editor.
If you are not using KDE, then of course it won’t be installed if you try to use it. Substitute for the default text editor in the Manjaro version you use, whatever that may be; you have still not shared that with us.
…or…
Use the alternate method provided by @nikgnomic, which you can use directly from your terminal app.
Cheers.
Also, as @Mirdarthos noted:
OP posted a screenshot of audio GUI controls in previous topic and another topic about Gnome boxes, but DE is not significant for ALSA
If DE is not known I would suggest using nano text editor
