!!ALSA Information Script v 0.5.3
!!Script ran on: Sat Aug 17 12:53:30 UTC 2024
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer: Acer
Product Name: Aspire A517-52G
Product Version: V1.26
Firmware Version: V1.26
System SKU: 0000000000000000
Board Vendor: TGL
Board Name: Jasmine_TL
!!ACPI Device Status Information
/sys/bus/acpi/devices/10251229:00/status 15
/sys/bus/acpi/devices/ACPI000C:00/status 15
/sys/bus/acpi/devices/ELAN0515:01/status 15
/sys/bus/acpi/devices/INT33A1:00/status 15
/sys/bus/acpi/devices/INT340E:00/status 15
/sys/bus/acpi/devices/INT34C5:00/status 15
/sys/bus/acpi/devices/INT3F0D:00/status 15
/sys/bus/acpi/devices/INTC1051:00/status 15
/sys/bus/acpi/devices/INTC6000:00/status 15
/sys/bus/acpi/devices/LNXPOWER:01/status 1
/sys/bus/acpi/devices/LNXPOWER:02/status 1
/sys/bus/acpi/devices/LNXPOWER:03/status 1
/sys/bus/acpi/devices/LNXPOWER:04/status 1
/sys/bus/acpi/devices/LNXPOWER:05/status 1
/sys/bus/acpi/devices/LNXPOWER:06/status 1
/sys/bus/acpi/devices/LNXPOWER:07/status 1
/sys/bus/acpi/devices/LNXPOWER:08/status 1
/sys/bus/acpi/devices/LNXVIDEO:00/status 15
/sys/bus/acpi/devices/MSFT0001:00/status 15
/sys/bus/acpi/devices/PNP0103:00/status 15
/sys/bus/acpi/devices/PNP0B00:00/status 15
/sys/bus/acpi/devices/PNP0C02:02/status 11
/sys/bus/acpi/devices/PNP0C02:04/status 11
/sys/bus/acpi/devices/PNP0C0A:00/status 31
/sys/bus/acpi/devices/PNP0C0C:00/status 15
/sys/bus/acpi/devices/PNP0C0D:00/status 15
/sys/bus/acpi/devices/PNP0C0E:00/status 11
/sys/bus/acpi/devices/PRP00001:00/status 11
/sys/bus/acpi/devices/PRP00001:01/status 11
/sys/bus/acpi/devices/SONY488A:00/status 15
/sys/bus/acpi/devices/device:00/status 15
/sys/bus/acpi/devices/device:9a/status 15
/sys/bus/acpi/devices/device:9b/status 15
/sys/bus/acpi/devices/device:9c/status 15
/sys/bus/acpi/devices/device:9e/status 15
/sys/bus/acpi/devices/device:9f/status 15
/sys/bus/acpi/devices/device:a0/status 15
!!ACPI SoundWire Device Status Information
Realtek 0x000010025d070100
Realtek 0x000110025d070100
Realtek 0x000210025d070100
Realtek 0x000310025d070100
Realtek 0x000010025d070000
Realtek 0x000110025d070000
Realtek 0x000210025d070000
Realtek 0x000310025d070000
!!Kernel Information
Kernel release: #1 SMP PREEMPT_DYNAMIC Sat Jul 27 14:46:06 UTC 2024
Operating System: GNU/Linux
Architecture: x86_64
Processor: unknown
SMP Enabled: Yes
!!ALSA Version
Driver version: k6.9.12-1-MANJARO
Library version: 1.2.12
Utilities version: 1.2.12
!!Loaded ALSA modules
snd_soc_skl_hda_dsp (card 0)
!!Sound Servers on this system
PipeWire:
Installed - Yes (/usr/bin/pipewire)
Running - Yes
Jack:
Installed - Yes (/usr/bin/jackd)
Running - No
!!Soundcards recognised by ALSA
0 [sofhdadsp ]: sof-hda-dsp - sof-hda-dsp
TGL-AspireA517_52G-V1.26-Jasmine_TL
!!PCI Soundcards installed in the system
0000:00:1f.3 Multimedia audio controller [0401]: Intel Corporation Tiger Lake-LP Smart Sound Technology Audio Controller [8086:a0c8] (rev 20)
Subsystem: Acer Incorporated [ALI] Device [1025:149f]
!!Loaded sound module options
!!Module: snd_soc_skl_hda_dsp
!!Sysfs card info
!!Card: /sys/class/sound/card0
Driver: /sys/bus/platform/drivers/skl_hda_dsp_generic
Tree:
!!Sysfs ctl-led info
!!CTL-LED: /sys/class/sound/ctl-led/mic/card0
List: 41
!!CTL-LED: /sys/class/sound/ctl-led/speaker/card0
List:
!!HDA-Intel Codec information
--startcollapse--
Codec: Realtek ALC255
Address: 0
AFG Function Id: 0x1 (unsol 1)
Vendor Id: 0x10ec0255
Subsystem Id: 0x1025149f
Revision Id: 0x100002
No Modem Function Group found
Default PCM:
rates [0x560]: 44100 48000 96000 192000
bits [0xe]: 16 20 24
formats [0x1]: PCM
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
Power states: D0 D1 D2 D3 D3cold CLKSTOP EPSS
Power: setting=D0, actual=D0
GPIO: io=3, o=0, i=0, unsolicited=1, wake=0
IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[2]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 0x02 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Control: name="Speaker Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=Out, idx=0, ofs=0
Amp-Out caps: ofs=0x57, nsteps=0x57, stepsize=0x02, mute=0
Amp-Out vals: [0x57 0x57]
Converter: stream=0, channel=0
PCM:
rates [0x60]: 44100 48000
formats [0x1]: PCM
Power states: D0 D1 D2 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Control: name="Headphone Playback Volume", index=0, device=0
Amp-Out vals: [0x34 0x34]
PCM:
formats [0x1]: PCM
Node 0x04 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x05 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x06 [Audio Output] wcaps 0x611: Stereo Digital
Digital:
Digital category: 0x0
IEC Coding Type: 0x0
PCM:
rates [0x5e0]: 44100 48000 88200 96000 192000
formats [0x1]: PCM
Node 0x07 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x08 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Amp-In caps: ofs=0x17, nsteps=0x3f, stepsize=0x02, mute=1
Amp-In vals: [0x97 0x97]
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x23
Node 0x09 [Audio Input] wcaps 0x10051b: Stereo Amp-In
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x22
Node 0x0a [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0b [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Control: name="Beep Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=4, ofs=0
Control: name="Beep Playback Switch", index=0, device=0
Amp-In caps: ofs=0x17, nsteps=0x1f, stepsize=0x05, mute=1
Amp-In vals: [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 5
0x18 0x19 0x1a 0x1b 0x1d
Node 0x0c [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-In vals: [0x00 0x00] [0x80 0x80]
Connection: 2
0x02 0x0b
Node 0x0d [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Connection: 2
0x03 0x0b
Node 0x0e [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0f [Audio Mixer] wcaps 0x20010a: Mono Amp-In
Connection: 1
0x0d
Node 0x10 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x11 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x12 [Pin Complex] wcaps 0x40040b: Stereo Amp-In
Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0
Pincap 0x00000020: IN
Pin Default 0x411111f0: [N/A] Speaker at Ext Rear
Conn = 1/8, Color = Black
DefAssociation = 0xf, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x00:
Node 0x13 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x14 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Control: name="Speaker Playback Switch", index=0, device=0
Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-Out vals: [0x80 0x80]
Pincap 0x00010014: OUT EAPD Detect
EAPD 0x2: EAPD
Pin Default 0x90171120: [Fixed] Speaker at Int N/A
Conn = Analog, Color = Black
DefAssociation = 0x2, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Unsolicited: tag=00, enabled=0
Connection: 1
0x0c
Node 0x15 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x16 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x17 [Pin Complex] wcaps 0x40050c: Mono Amp-Out
Amp-Out vals: [0x80]
Pincap 0x00000010: OUT
Pin Default 0x40000000: [N/A] Line Out at Ext N/A
Conn = Unknown, Color = Unknown
DefAssociation = 0x0, Sequence = 0x0
Pin-ctls: 0x00:
Connection: 1
0x0f
Node 0x18 [Pin Complex] wcaps 0x40048b: Stereo Amp-In
Pincap 0x00003724: IN Detect
Vref caps: HIZ 50 GRD 80 100
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN VREF_HIZ
Node 0x19 [Pin Complex] wcaps 0x40048b: Stereo Amp-In
Misc = NO_PRESENCE
Node 0x1a [Pin Complex] wcaps 0x40048b: Stereo Amp-In
Misc = NO_PRESENCE
Pin-ctls: 0x00: VREF_HIZ
Node 0x1b [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Pincap 0x0001373c: IN OUT HP EAPD Detect
EAPD 0x2: EAPD
Misc = NO_PRESENCE
Connection: 2
0x0c* 0x0d
Node 0x1c [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x1d [Pin Complex] wcaps 0x400400: Mono
Pin Default 0x40700001: [N/A] Modem Hand at Ext N/A
DefAssociation = 0x0, Sequence = 0x1
Pin-ctls: 0x20: IN
Node 0x1e [Pin Complex] wcaps 0x400781: Stereo Digital
Pincap 0x00000014: OUT Detect
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 1
0x06
Node 0x1f [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x20 [Vendor Defined Widget] wcaps 0xf00040: Mono
Processing caps: benign=0, ncoeff=76
Node 0x21 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Control: name="Headphone Playback Switch", index=0, device=0
Pincap 0x0001001c: OUT HP EAPD Detect
EAPD 0x2: EAPD
Pin Default 0x02211030: [Jack] HP Out at Ext Front
DefAssociation = 0x3, Sequence = 0x0
Pin-ctls: 0xc0: OUT HP
Unsolicited: tag=01, enabled=1
Connection: 2
0x0c 0x0d*
Node 0x22 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In vals: [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 6
0x18 0x19 0x1a 0x1b 0x1d 0x0b
Node 0x23 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In vals: [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 7
0x18 0x19 0x1a 0x1b 0x1d 0x0b 0x12
Codec: Intel Tigerlake HDMI
Address: 2
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x80862812
Subsystem Id: 0x80860101
Revision Id: 0x100000
Default PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
Power states: D0 D3 CLKSTOP EPSS
Power: setting=D0, actual=D0, Clock-stop-OK
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x03 [Audio Output] wcaps 0x6611: 8-Channels Digital
Digital: Enabled KAE
PCM:
rates [0x7f0]: 32000 44100 48000 88200 96000 176400 192000
bits [0x1a]: 16 24 32
formats [0x5]: PCM AC3
Power states: D0 D3 EPSS
Node 0x04 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Amp-Out vals: [0x00 0x00]
Pincap 0x0b000094: OUT Detect HBR HDMI DP
Pin Default 0x18560010: [Jack] Digital Out at Int HDMI
Conn = Digital, Color = Unknown
DefAssociation = 0x1, Sequence = 0x0
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x05 [Audio Output] wcaps 0x6611: 8-Channels Digital
PCM:
Node 0x06 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x07 [Audio Output] wcaps 0x6611: 8-Channels Digital
PCM:
Node 0x08 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x09 [Audio Output] wcaps 0x6611: 8-Channels Digital
PCM:
Node 0x0a [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x0b [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x0c [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x0d [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x0e [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x0f [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
--endcollapse--
!!ALSA Device nodes
crw-rw---- 1 root audio 116, 12 Aug 17 13:32 /dev/snd/controlC0
crw-rw---- 1 root audio 116, 11 Aug 17 13:32 /dev/snd/hwC0D0
crw-rw---- 1 root audio 116, 10 Aug 17 13:32 /dev/snd/hwC0D2
crw-rw---- 1 root audio 116, 5 Aug 17 13:33 /dev/snd/pcmC0D0c
crw-rw---- 1 root audio 116, 4 Aug 17 13:47 /dev/snd/pcmC0D0p
crw-rw---- 1 root audio 116, 6 Aug 17 13:33 /dev/snd/pcmC0D31p
crw-rw---- 1 root audio 116, 7 Aug 17 13:33 /dev/snd/pcmC0D3p
crw-rw---- 1 root audio 116, 8 Aug 17 13:33 /dev/snd/pcmC0D4p
crw-rw---- 1 root audio 116, 9 Aug 17 13:33 /dev/snd/pcmC0D5p
crw-rw---- 1 root audio 116, 2 Aug 17 13:34 /dev/snd/pcmC0D6c
crw-rw---- 1 root audio 116, 3 Aug 17 13:33 /dev/snd/pcmC0D7c
crw-rw---- 1 root audio 116, 1 Aug 17 13:32 /dev/snd/seq
crw-rw---- 1 root audio 116, 33 Aug 17 13:32 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 60 Aug 17 13:32 .
drwxr-xr-x 3 root root 320 Aug 17 13:32 ..
lrwxrwxrwx 1 root root 12 Aug 17 13:32 pci-0000:00:1f.3-platform-skl_hda_dsp_generic -> ../controlC0
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: sofhdadsp [sof-hda-dsp], device 0: HDA Analog (*) []
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: sofhdadsp [sof-hda-dsp], device 3: HDMI1 (*) []
Subdevices: 1/1
card 0: sofhdadsp [sof-hda-dsp], device 4: HDMI2 (*) []
Subdevices: 1/1
card 0: sofhdadsp [sof-hda-dsp], device 5: HDMI3 (*) []
Subdevices: 1/1
card 0: sofhdadsp [sof-hda-dsp], device 31: HDA Analog Deep Buffer (*) []
Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
Subdevices: 1/1
card 0: sofhdadsp [sof-hda-dsp], device 6: DMIC (*) []
Subdevices: 1/1
card 0: sofhdadsp [sof-hda-dsp], device 7: DMIC16kHz (*) []
Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card sofhdadsp
Card sysdefault:0 'sofhdadsp'/'TGL-AspireA517_52G-V1.26-Jasmine_TL'
Mixer name : 'Realtek ALC255'
Components : 'HDA:80862812,80860101,00100000 HDA:10ec0255,1025149f,00100002 cfg-dmics:2'
Controls : 46
Simple ctrls : 18
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Limits: Playback 0 - 87
Mono: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'Headphone',0
Capabilities: pvolume pswitch
Mono:
Front Left: Playback 52 [60%] [-26.25dB] [off]
Front Right: Playback 52 [60%] [-26.25dB] [off]
Simple mixer control 'Speaker',0
Mono:
Front Left: Playback 87 [100%] [0.00dB] [off]
Front Right: Playback 87 [100%] [0.00dB] [off]
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined
Mono: Playback [off]
Simple mixer control 'IEC958',1
Simple mixer control 'IEC958',2
Simple mixer control 'Beep',0
Limits: Playback 0 - 31
Mono:
Front Left: Playback 0 [0%] [-34.50dB] [off]
Front Right: Playback 0 [0%] [-34.50dB] [off]
Simple mixer control 'Auto-Mute Mode',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Disabled'
Simple mixer control 'Dmic0',0
Capabilities: cvolume cswitch
Limits: Capture 0 - 70
Front Left: Capture 60 [86%] [10.00dB] [on]
Front Right: Capture 60 [86%] [10.00dB] [on]
Simple mixer control 'Dmic1 2nd',0
Front Left: Capture 50 [71%] [0.00dB]
Front Right: Capture 50 [71%] [0.00dB]
Simple mixer control 'Loopback Mixing',0
Capabilities: enum
Item0: 'Disabled'
Simple mixer control 'PGA1.0 1 Master',0
Limits: Playback 0 - 32
Mono:
Front Left: Playback 32 [100%] [0.00dB]
Front Right: Playback 32 [100%] [0.00dB]
Simple mixer control 'PGA2.0 2 Master',0
Limits: Capture 0 - 80
Front Left: Capture 50 [62%] [0.00dB]
Front Right: Capture 50 [62%] [0.00dB]
Simple mixer control 'PGA30.0 30',0
Mono:
Simple mixer control 'PGA31.0 31',0
Mono:
Simple mixer control 'PGA7.0 7 Master',0
Mono:
Simple mixer control 'PGA8.0 8 Master',0
Mono:
Simple mixer control 'PGA9.0 9 Master',0
Mono:
!!Alsactl output
--startcollapse--
state.sofhdadsp {
control.1 {
iface MIXER
name 'Headphone Playback Volume'
value.0 52
value.1 52
comment {
access 'read write'
type INTEGER
count 2
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 -2625
dbvalue.1 -2625
control.2 {
iface MIXER
name 'Headphone Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.3 {
iface MIXER
name 'Speaker Playback Volume'
value.0 87
value.1 87
comment {
access 'read write'
type INTEGER
count 2
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.4 {
iface MIXER
name 'Speaker Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.5 {
iface MIXER
name 'Loopback Mixing'
value Disabled
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Disabled
item.1 Enabled
control.6 {
iface MIXER
name 'Auto-Mute Mode'
value Disabled
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Disabled
item.1 Enabled
control.7 {
iface MIXER
name 'Beep Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 -3450
dbvalue.1 -3450
control.8 {
iface MIXER
name 'Beep Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.9 {
iface MIXER
name 'Master Playback Volume'
value 87
comment {
access 'read write'
type INTEGER
count 1
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 0
control.10 {
iface MIXER
name 'Master Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.11 {
iface CARD
name 'Front Headphone Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.12 {
iface CARD
name 'Speaker Phantom Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.13 {
iface CARD
name 'HDMI/DP,pcm=3 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.14 {
iface MIXER
name 'IEC958 Playback Con Mask'
value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.15 {
iface MIXER
name 'IEC958 Playback Pro Mask'
value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.16 {
iface MIXER
name 'IEC958 Playback Default'
value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access 'read write'
type IEC958
count 1
control.17 {
iface MIXER
name 'IEC958 Playback Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.18 {
iface PCM
device 3
name ELD
value ''
comment {
access 'read volatile'
type BYTES
count 0
control.19 {
iface CARD
name 'HDMI/DP,pcm=4 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.20 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.21 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.22 {
iface MIXER
index 1
comment {
access 'read write'
type IEC958
count 1
control.23 {
iface MIXER
index 1
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.24 {
iface PCM
device 4
name ELD
value ''
comment {
type BYTES
count 0
control.25 {
iface CARD
name 'HDMI/DP,pcm=5 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.26 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.27 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.28 {
iface MIXER
index 2
comment {
access 'read write'
type IEC958
count 1
control.29 {
iface MIXER
index 2
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.30 {
iface PCM
device 5
name ELD
value ''
comment {
type BYTES
count 0
control.31 {
iface PCM
device 3
name 'Playback Channel Map'
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.32 {
iface PCM
device 4
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.33 {
iface PCM
device 5
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.34 {
iface MIXER
name 'PGA1.0 1 Master Playback Volume'
value.0 32
value.1 32
comment {
access 'read write'
type INTEGER
count 2
range '0 - 32'
dbmin -9999999
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.35 {
iface MIXER
name 'PGA2.0 2 Master Capture Volume'
value.0 50
value.1 50
comment {
access 'read write'
type INTEGER
count 2
range '0 - 80'
dbmin -9999999
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.37 {
iface MIXER
name 'PGA7.0 7 Master Playback Volume'
value.0 32
value.1 32
comment {
access 'read write'
type INTEGER
count 2
range '0 - 32'
dbmin -9999999
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.38 {
iface MIXER
name 'PGA8.0 8 Master Playback Volume'
value.0 32
value.1 32
comment {
access 'read write'
type INTEGER
count 2
range '0 - 32'
dbmin -9999999
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.39 {
iface MIXER
name 'PGA9.0 9 Master Playback Volume'
value.0 32
value.1 32
comment {
access 'read write'
type INTEGER
count 2
range '0 - 32'
dbmin -9999999
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.40 {
iface MIXER
name 'Dmic0 Capture Volume'
value.0 60
value.1 60
comment {
access 'read write'
type INTEGER
count 2
range '0 - 70'
dbmin -9999999
dbmax 2000
dbvalue.0 1000
dbvalue.1 1000
control.41 {
iface MIXER
name 'Dmic0 Capture Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.43 {
iface MIXER
name 'Dmic1 2nd Capture Volume'
value.0 50
value.1 50
comment {
access 'read write'
type INTEGER
count 2
range '0 - 70'
dbmin -9999999
dbmax 2000
dbvalue.0 0
dbvalue.1 0
control.45 {
iface MIXER
name 'PGA30.0 30 Playback Volume'
value.0 32
value.1 32
comment {
access 'read write'
type INTEGER
count 2
range '0 - 32'
dbmin -9999999
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.46 {
iface MIXER
name 'PGA31.0 31 Playback Volume'
value.0 32
value.1 32
comment {
access 'read write'
type INTEGER
count 2
range '0 - 32'
dbmin -9999999
dbmax 0
dbvalue.0 0
dbvalue.1 0
--endcollapse--
!!All Loaded Modules
ac97_bus
acer_wireless
acer_wmi
acpi_pad
aesni_intel
af_alg
algif_hash
algif_skcipher
asn1_encoder
atkbd
bluetooth
bnep
btbcm
btintel
btmtk
btrtl
btusb
cbc
ccm
cec
cfg80211
cmac
coretemp
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
crypto_user
dm_crypt
dm_mod
drm_buddy
drm_display_helper
drm_exec
drm_gpuvm
drm_suballoc_helper
drm_ttm_helper
ecdh_generic
ee1004
encrypted_keys
ext4
fat
gf128mul
ghash_clmulni_intel
gpu_sched
hid_generic
hid_multitouch
i2c_algo_bit
i2c_hid
i2c_hid_acpi
i2c_i801
i2c_smbus
i8042
i915
iTCO_vendor_support
iTCO_wdt
idma64
igen6_edac
intel_cstate
intel_gtt
intel_hid
intel_lpss
intel_lpss_pci
intel_pmc_bxt
intel_pmc_core
intel_powerclamp
intel_rapl_common
intel_rapl_msr
intel_uncore
intel_uncore_frequency
intel_uncore_frequency_common
intel_vsec
ip6_tables
ip6table_filter
ip_tables
iptable_filter
jbd2
joydev
kvm
kvm_intel
ledtrig_audio
libarc4
libphy
libps2
loop
mac80211
mac_hid
mbcache
mc
mdio_devres
mei
mei_hdcp
mei_me
mei_pxp
mousedev
mt76
mt76_connac_lib
mt7921_common
mt7921e
mt792x_lib
mtd
nfnetlink
nvidia
nvidia_drm
nvidia_modeset
nvidia_uvm
nvme
nvme_auth
nvme_core
pcspkr
pinctrl_tigerlake
platform_profile
pmt_class
pmt_telemetry
polyval_clmulni
polyval_generic
qrtr
r8169
rapl
realtek
rfcomm
rfkill
serio
serio_raw
sg
sha1_ssse3
sha256_ssse3
sha512_ssse3
snd
snd_compress
snd_ctl_led
snd_hda_codec
snd_hda_codec_generic
snd_hda_codec_hdmi
snd_hda_codec_realtek
snd_hda_core
snd_hda_ext_core
snd_hda_intel
snd_hda_scodec_component
snd_hrtimer
snd_hwdep
snd_intel_dspcfg
snd_intel_sdw_acpi
snd_pcm
snd_pcm_dmaengine
snd_seq
snd_seq_device
snd_seq_dummy
snd_soc_acpi
snd_soc_acpi_intel_match
snd_soc_avs
snd_soc_core
snd_soc_dmic
snd_soc_hda_codec
snd_soc_hdac_hda
snd_soc_hdac_hdmi
snd_soc_intel_hda_dsp_common
snd_soc_skl_hda_dsp
snd_sof
snd_sof_intel_hda
snd_sof_intel_hda_common
snd_sof_intel_hda_mlink
snd_sof_pci
snd_sof_pci_intel_tgl
snd_sof_probes
snd_sof_utils
snd_sof_xtensa_dsp
snd_timer
soundcore
soundwire_bus
soundwire_cadence
soundwire_generic_allocation
soundwire_intel
sparse_keymap
spi_intel
spi_intel_pci
spi_nor
squashfs
tee
trusted
ttm
tun
usbhid
uvc
uvcvideo
vboxdrv
vboxnetadp
vboxnetflt
vfat
video
videobuf2_common
videobuf2_memops
videobuf2_v4l2
videobuf2_vmalloc
videodev
vivaldi_fmap
vmd
wmi
wmi_bmof
x86_pkg_temp_thermal
x_tables
xe
xhci_pci
xhci_pci_renesas
xt_cgroup
xt_comment
xt_mark
xt_tcpudp
!!Sysfs Files
/sys/class/sound/hwC0D0/init_pin_configs:
0x12 0x411111f0
0x14 0x90171120
0x17 0x40000000
0x18 0x411111f0
0x19 0x411111f0
0x1a 0x411111f0
0x1b 0x411111f0
0x1d 0x40700001
0x1e 0x411111f0
0x21 0x02211030
/sys/class/sound/hwC0D0/driver_pin_configs:
/sys/class/sound/hwC0D0/user_pin_configs:
/sys/class/sound/hwC0D0/init_verbs:
/sys/class/sound/hwC0D0/hints:
/sys/class/sound/hwC0D2/init_pin_configs:
0x04 0x18560010
0x06 0x18560010
0x08 0x18560010
0x0a 0x18560010
0x0b 0x18560010
0x0c 0x18560010
0x0d 0x18560010
0x0e 0x18560010
0x0f 0x18560010
/sys/class/sound/hwC0D2/driver_pin_configs:
/sys/class/sound/hwC0D2/user_pin_configs:
/sys/class/sound/hwC0D2/init_verbs:
/sys/class/sound/hwC0D2/hints:
!!ALSA/HDA dmesg
[ 9.008442] iTCO_wdt iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 9.137970] snd_hda_intel 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040100
[ 9.138121] snd_hda_intel 0000:00:1f.3: Digital mics found on Skylake platform, using SOF driver
[ 9.138337] usbcore: registered new interface driver btusb
[ 9.203270] intel_tcc_cooling: TCC Offset locked
[ 9.215272] snd_soc_avs 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040100
[ 9.215398] snd_soc_avs 0000:00:1f.3: Digital mics found on Skylake platform, using SOF driver
[ 9.252744] input: ELAN0515:01 04F3:3142 Mouse as /devices/pci0000:00/0000:00:15.3/i2c_designware.1/i2c-12/i2c-ELAN0515:01/0018:04F3:3142.0003/input/input18
[ 9.298634] mt7921e 0000:03:00.0: ASIC revision: 79610010
[ 9.318229] sof-audio-pci-intel-tgl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040100
[ 9.318330] sof-audio-pci-intel-tgl 0000:00:1f.3: Digital mics found on Skylake platform, using SOF driver
[ 9.318344] sof-audio-pci-intel-tgl 0000:00:1f.3: enabling device (0000 -> 0002)
[ 9.318510] sof-audio-pci-intel-tgl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if 0x040100
[ 9.318558] sof-audio-pci-intel-tgl 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 9.325264] sof-audio-pci-intel-tgl 0000:00:1f.3: use msi interrupt mode
[ 9.365685] sof-audio-pci-intel-tgl 0000:00:1f.3: hda codecs found, mask 5
[ 9.365689] sof-audio-pci-intel-tgl 0000:00:1f.3: using HDA machine driver skl_hda_dsp_generic now
[ 9.365692] sof-audio-pci-intel-tgl 0000:00:1f.3: DMICs detected in NHLT tables: 2
[ 9.368410] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware paths/files for ipc type 0:
[ 9.368412] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware file: intel/sof/sof-tgl.ri
[ 9.368414] sof-audio-pci-intel-tgl 0000:00:1f.3: Topology file: intel/sof-tplg/sof-hda-generic-2ch.tplg
[ 9.368919] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware info: version 2:2:0-57864
[ 9.368920] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware: ABI 3:22:1 Kernel ABI 3:23:0
[ 9.368923] sof-audio-pci-intel-tgl 0000:00:1f.3: unknown sof_ext_man header type 3 size 0x30
[ 9.376781] mt7921e 0000:03:00.0: HW/SW Version: 0x8a108a10, Build Time: 20240219110958a
[ 9.461472] nvidia: module license taints kernel.
[ 9.464216] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware info: version 2:2:0-57864
[ 9.464220] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware: ABI 3:22:1 Kernel ABI 3:23:0
[ 9.479813] sof-audio-pci-intel-tgl 0000:00:1f.3: Topology: ABI 3:22:1 Kernel ABI 3:23:0
[ 9.480041] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: Parent card not yet available, widget card binding deferred
[ 9.517438] snd_hda_codec_realtek ehdaudio0D0: autoconfig for ALC255: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 9.517443] snd_hda_codec_realtek ehdaudio0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 9.517445] snd_hda_codec_realtek ehdaudio0D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 9.517446] snd_hda_codec_realtek ehdaudio0D0: mono: mono_out=0x0
[ 9.517447] snd_hda_codec_realtek ehdaudio0D0: inputs:
[ 9.568960] skl_hda_dsp_generic skl_hda_dsp_generic: hda_dsp_hdmi_build_controls: no PCM in topology for HDMI converter 3
[ 9.592351] input: sof-hda-dsp Front Headphone as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input21
[ 9.592385] input: sof-hda-dsp HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input22
[ 9.592411] input: sof-hda-dsp HDMI/DP,pcm=4 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input23
[ 9.592439] input: sof-hda-dsp HDMI/DP,pcm=5 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input24
[ 9.632638] mt7921e 0000:03:00.0: WM Firmware Version: ____010000, Build Time: 20240219111038
