After a recent Stable update (2022-09-12 or 2022-10-05 or 2022-10-10) my webcam stopped being recognized by the system. It was working fine before.
I have also traveled with the laptop during this time, so might be a hardware issue.
The webcam is built into the laptop.
What happens is that the webcam is being recognized by the system, but after about 5 seconds an error happens ('/dev/video0' VIDIOC_QUERYCTRL: Protocol error; Cannot open '/dev/video0': 2, No such file or directory) and the recognition process starts anew.
I have tried googling the problem & tried several fixes (adding my user to video group, loading uvcvideo in quirks mode, adding custom config to udev/rules.d). I’m not sure if I did it right, but it didn’t help.
Any suggestions on how to debug/fix it are greatly appreciated.
Below is the different diagnostic output that I gathered.
inxi
Host: computer1 Kernel: 6.0.6-1-MANJARO arch: x86_64 bits: 64
Desktop: KDE Plasma v: 5.26.2 Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A17 FA706IU_FX706IU
v: 1.0 serial: M4NRCX04813616D
Mobo: ASUSTeK model: FA706IU v: 1.0 serial: M416NRCX00CHTKMB
UEFI: American Megatrends v: FA706IU.315 date: 01/29/2021
ID-1: BAT1 charge: 81.8 Wh (98.3%) condition: 83.2/90.2 Wh (92.2%)
volts: 16.4 min: 15.9
Info: 8-core AMD Ryzen 7 4800H with Radeon Graphics [MT MCP] speed (MHz):
avg: 1493 min/max: 1400/2900
Device-1: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] driver: nvidia
v: 520.56.06
Device-2: AMD Renoir driver: amdgpu v: kernel
Device-3: Sonix USB2.0 HD UVC WebCam type: USB driver: uvcvideo
Display: x11 server: X.Org v: 21.1.4 driver: X: loaded: amdgpu,nvidia
unloaded: modesetting,nouveau dri: radeonsi gpu: amdgpu
resolution: 1920x1080~120Hz
API: OpenGL v: 4.6 Mesa 22.2.1 renderer: RENOIR (renoir LLVM 14.0.6 DRM
3.48 6.0.6-1-MANJARO)
driver: r8169
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
driver: rtw_8822ce
Local Storage: total: 476.94 GiB used: 329.84 GiB (69.2%)
Processes: 405 Uptime: 21h 20m Memory: 15.05 GiB used: 6.86 GiB (45.6%)
Shell: Bash inxi: 3.3.23
journald
There logs repeat themselves every 5 seconds. In each iteration there is different input number input6660 and different device number device 13
05.11.2022 09:36:36:659 pipewire spa.v4l2: '/dev/video0' VIDIOC_QUERYCTRL: Protocol error
05.11.2022 09:36:36:659 pipewire spa.v4l2: Cannot open '/dev/video0': 2, No such file or directory
05.11.2022 09:36:36:659 kernel usb 3-4: USB disconnect, device number 12
05.11.2022 09:36:36:660 kernel usb 3-4: Failed to query (GET_DEF) UVC control 2 on unit 2: -71 (exp. 2).
05.11.2022 09:36:36:660 pipewire-media-session ms.core: error id:76 seq:346665 res:-71 (Protocol error): enum params id:1 (Spa:Enum:ParamId:PropInfo) failed
05.11.2022 09:36:36:996 kernel usb 3-4: new high-speed USB device number 13 using xhci_hcd
05.11.2022 09:36:37:166 kernel usb 3-4: New USB device found, idVendor=322e, idProduct=202c, bcdDevice= 1.03
05.11.2022 09:36:37:167 kernel usb 3-4: New USB device strings: Mfr=2, Product=1, SerialNumber=0
05.11.2022 09:36:37:167 kernel usb 3-4: Product: USB2.0 HD UVC WebCam
05.11.2022 09:36:37:167 kernel usb 3-4: Manufacturer: Sonix Technology Co., Ltd.
05.11.2022 09:36:37:176 kernel usb 3-4: Found UVC 1.00 device USB2.0 HD UVC WebCam (322e:202c)
05.11.2022 09:36:37:189 kernel input: USB2.0 HD UVC WebCam: USB2.0 HD as /devices/pci0000:00/0000:00:08.1/0000:05:00.3/usb3/3-4/3-4:1.0/input/input6660
05.11.2022 09:36:37:194 mtp-probe checking bus 3, device 13: "/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.3/usb3/3-4"
05.11.2022 09:36:37:195 mtp-probe bus: 3, device: 13 was not an MTP device
05.11.2022 09:36:37:867 mtp-probe checking bus 3, device 13: "/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.3/usb3/3-4"
05.11.2022 09:36:37:870 mtp-probe bus: 3, device: 13 was not an MTP device
dmesg
[computer1 ~]# dmesg
[38292.892912] usb 3-4: USB disconnect, device number 106
[38292.893210] usb 3-4: Failed to query (GET_DEF) UVC control 2 on unit 2: -71 (exp. 2).
[38293.245896] usb 3-4: new high-speed USB device number 107 using xhci_hcd
[38293.409853] usb 3-4: New USB device found, idVendor=322e, idProduct=202c, bcdDevice= 1.03
[38293.409863] usb 3-4: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[38293.409868] usb 3-4: Product: USB2.0 HD UVC WebCam
[38293.409871] usb 3-4: Manufacturer: Sonix Technology Co., Ltd.
[38293.418034] usb 3-4: Found UVC 1.00 device USB2.0 HD UVC WebCam (322e:202c)
[38293.432397] input: USB2.0 HD UVC WebCam: USB2.0 HD as /devices/pci0000:00/0000:00:08.1/0000:05:00.3/usb3/3-4/3-4:1.0/input/input6379
[38298.926679] usb 3-4: USB disconnect, device number 107
[38298.926943] usb 3-4: Failed to query (GET_DEF) UVC control 2 on unit 2: -71 (exp. 2).
[38299.272502] usb 3-4: new high-speed USB device number 108 using xhci_hcd
[38299.440241] usb 3-4: New USB device found, idVendor=322e, idProduct=202c, bcdDevice= 1.03
[38299.440245] usb 3-4: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[38299.440247] usb 3-4: Product: USB2.0 HD UVC WebCam
[38299.440248] usb 3-4: Manufacturer: Sonix Technology Co., Ltd.
[38299.450394] usb 3-4: Found UVC 1.00 device USB2.0 HD UVC WebCam (322e:202c)
[38299.464952] input: USB2.0 HD UVC WebCam: USB2.0 HD as /devices/pci0000:00/0000:00:08.1/0000:05:00.3/usb3/3-4/3-4:1.0/input/input6380
[38304.958929] usb 3-4: USB disconnect, device number 108
[38304.959203] usb 3-4: Failed to query (GET_DEF) UVC control 2 on unit 2: -71 (exp. 2).
[38305.282584] usb 3-4: new high-speed USB device number 109 using xhci_hcd
[38305.446900] usb 3-4: New USB device found, idVendor=322e, idProduct=202c, bcdDevice= 1.03
[38305.446910] usb 3-4: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[38305.446914] usb 3-4: Product: USB2.0 HD UVC WebCam
[38305.446917] usb 3-4: Manufacturer: Sonix Technology Co., Ltd.
[38305.454392] usb 3-4: Found UVC 1.00 device USB2.0 HD UVC WebCam (322e:202c)
[38305.468865] input: USB2.0 HD UVC WebCam: USB2.0 HD as /devices/pci0000:00/0000:00:08.1/0000:05:00.3/usb3/3-4/3-4:1.0/input/input6381
v4l2-ctl --list-devices
[computer1 ~]# v4l2-ctl --list-devices
USB2.0 HD UVC WebCam: USB2.0 HD (usb-0000:05:00.3-4):
/dev/video0
/dev/video1
/dev/media0
Or alternatively:
/dev/video0
/dev/video1
/dev/media0
VIDIOC_QUERYCAP: failed: No such device
/dev/video0: not a v4l2 node
Or alternatively:
Cannot open device /dev/video0, exiting.
v4l2-ctl -d /dev/video0 --list-ctrls
Sometimes command below will give empty output, probably when device is being rediscovered (see dmesg logs above)
[computer1 ~]# v4l2-ctl -d /dev/video0 --list-ctrls
ls -la /dev/video*
[computer1 ~]# ls -la /dev/video*
crw-rw----+ 1 root video 81, 0 Nov 5 09:57 /dev/video0
crw-rw----+ 1 root video 81, 1 Nov 5 09:57 /dev/video1
lsusb
[computer1 ~]# lsusb
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 002: ID 04ca:4005 Lite-On Technology Corp. Bluetooth Radio
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 076: ID 322e:202c Sonix Technology Co., Ltd. USB2.0 HD UVC WebCam
Bus 003 Device 002: ID 046d:c092 Logitech, Inc. G102/G203 LIGHTSYNC Gaming Mouse
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
[computer1 ~]# lsusb -vt
/: Bus 06.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 10000M
/: Bus 05.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 480M
|__ Port 1: Dev 2, If 0, Class=Wireless, Driver=btusb, 12M
|__ Port 1: Dev 2, If 1, Class=Wireless, Driver=btusb, 12M
/: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 10000M
/: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 480M
|__ Port 3: Dev 2, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 3: Dev 2, If 1, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 4: Dev 13, If 0, Class=Video, Driver=uvcvideo, 480M
ID 322e:202c
|__ Port 4: Dev 13, If 1, Class=Video, Driver=uvcvideo, 480M
ID 322e:202c
usb-devices
[computer1 ~]# usb-devices
T: Bus=03 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 4
D: Ver= 2.00 Cls=09(hub ) Sub=00 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=1d6b ProdID=0002 Rev=06.00
S: Manufacturer=Linux 6.0.6-1-MANJARO xhci-hcd
S: Product=xHCI Host Controller
S: SerialNumber=0000:05:00.3
C: #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=0mA
I: If#= 0 Alt= 0 #EPs= 1 Cls=09(hub ) Sub=00 Prot=00 Driver=hub
E: Ad=81(I) Atr=03(Int.) MxPS= 4 Ivl=256ms
T: Bus=03 Lev=01 Prnt=01 Port=02 Cnt=01 Dev#= 2 Spd=12 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=046d ProdID=c092 Rev=52.00
S: Manufacturer=Logitech
S: Product=G102 LIGHTSYNC Gaming Mouse
S: SerialNumber=207D31785542
C: #Ifs= 2 Cfg#= 1 Atr=a0 MxPwr=300mA
I: If#= 0 Alt= 0 #EPs= 1 Cls=03(HID ) Sub=01 Prot=02 Driver=usbhid
E: Ad=81(I) Atr=03(Int.) MxPS= 8 Ivl=1ms
I: If#= 1 Alt= 0 #EPs= 1 Cls=03(HID ) Sub=00 Prot=00 Driver=usbhid
E: Ad=82(I) Atr=03(Int.) MxPS= 20 Ivl=1ms
T: Bus=04 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=10000 MxCh= 2
D: Ver= 3.10 Cls=09(hub ) Sub=00 Prot=03 MxPS= 9 #Cfgs= 1
P: Vendor=1d6b ProdID=0003 Rev=06.00
T: Bus=05 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 4
S: SerialNumber=0000:05:00.4
T: Bus=05 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=12 MxCh= 0
D: Ver= 1.00 Cls=e0(wlcon) Sub=01 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=04ca ProdID=4005 Rev=00.00
S: Manufacturer=Realtek
S: Product=Bluetooth Radio
S: SerialNumber=00e04c000001
C: #Ifs= 2 Cfg#= 1 Atr=e0 MxPwr=500mA
I: If#= 0 Alt= 0 #EPs= 3 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=81(I) Atr=03(Int.) MxPS= 16 Ivl=1ms
E: Ad=82(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
I: If#= 1 Alt= 0 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 0 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 0 Ivl=1ms
T: Bus=06 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=10000 MxCh= 2
lspci
[computer1 ~]# lspci
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne Root Complex
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne IOMMU
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:02.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:02.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:02.4 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus
00:08.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 51)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 3
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 7
01:00.0 VGA compatible controller: NVIDIA Corporation TU116M [GeForce GTX 1660 Ti Mobile] (rev a1)
01:00.1 Audio device: NVIDIA Corporation TU116 High Definition Audio Controller (rev a1)
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
03:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8822CE 802.11ac PCIe Wireless Network Adapter
04:00.0 Non-Volatile memory controller: Micron Technology Inc Device 5404 (rev 03)
05:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Renoir (rev c6)
05:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Renoir Radeon High Definition Audio Controller
05:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor
05:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne USB 3.1
05:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne USB 3.1
05:00.5 Multimedia controller: Advanced Micro Devices, Inc. [AMD] ACP/ACP3X/ACP6x Audio Coprocessor (rev 01)
05:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h/19h HD Audio Controller
06:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 81)
06:00.1 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 81)
[computer1 ~]# lspci -nnnkkkvt
-[0000:00]-+-00.0 Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne Root Complex [1022:1630]
+-00.2 Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne IOMMU [1022:1631]
+-01.0 Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge [1022:1632]
+-01.1-[01]--+-00.0 NVIDIA Corporation TU116M [GeForce GTX 1660 Ti Mobile] [10de:2191]
| \-00.1 NVIDIA Corporation TU116 High Definition Audio Controller [10de:1aeb]
+-02.0 Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge [1022:1632]
+-02.1-[02]----00.0 Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168]
+-02.2-[03]----00.0 Realtek Semiconductor Co., Ltd. RTL8822CE 802.11ac PCIe Wireless Network Adapter [10ec:c822]
+-02.4-[04]----00.0 Micron Technology Inc Device [1344:5404]
+-08.0 Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge [1022:1632]
+-08.1-[05]--+-00.0 Advanced Micro Devices, Inc. [AMD/ATI] Renoir [1002:1636]
| +-00.1 Advanced Micro Devices, Inc. [AMD/ATI] Renoir Radeon High Definition Audio Controller [1002:1637]
| +-00.2 Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor [1022:15df]
| +-00.3 Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne USB 3.1 [1022:1639]
| +-00.4 Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne USB 3.1 [1022:1639]
| +-00.5 Advanced Micro Devices, Inc. [AMD] ACP/ACP3X/ACP6x Audio Coprocessor [1022:15e2]
| \-00.6 Advanced Micro Devices, Inc. [AMD] Family 17h/19h HD Audio Controller [1022:15e3]
+-08.2-[06]--+-00.0 Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] [1022:7901]
| \-00.1 Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] [1022:7901]
+-14.0 Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller [1022:790b]
+-14.3 Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge [1022:790e]
+-18.0 Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 0 [1022:1448]
+-18.1 Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 1 [1022:1449]
+-18.2 Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 2 [1022:144a]
+-18.3 Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 3 [1022:144b]
+-18.4 Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 4 [1022:144c]
+-18.5 Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 5 [1022:144d]
+-18.6 Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 6 [1022:144e]
\-18.7 Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 7 [1022:144f]
lsmod | grep uvcvideo
[computer1 ~]# lsmod | grep uvcvideo
uvcvideo 163840 1
videobuf2_vmalloc 20480 1 uvcvideo
videobuf2_v4l2 40960 1 uvcvideo
videobuf2_common 86016 4 videobuf2_vmalloc,videobuf2_v4l2,uvcvideo,videobuf2_memops
videodev 315392 4 videobuf2_v4l2,uvcvideo,videobuf2_common
mc 73728 4 videodev,videobuf2_v4l2,uvcvideo,videobuf2_common
ffplay (and related commands)
[computer1 ~]# ffplay /dev/video0
ffplay version n5.1.2 Copyright (c) 2003-2022 the FFmpeg developers
built with gcc 12.2.0 (GCC)
configuration: --prefix=/usr --disable-debug --disable-static --disable-stripping --enable-amf --enable-avisynth --enable-cuda-llvm --enable-lto --enable-fontconfig --enable-gmp --enable-gnutls --enable-gpl --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libdav1d --enable-libdrm --enable-libfreetype --enable-libfribidi --enable-libgsm --enable-libiec61883 --enable-libjack --enable-libmfx --enable-libmodplug --enable-libmp3lame --enable-libopencore_amrnb --enable-libopencore_amrwb --enable-libopenjpeg --enable-libopus --enable-libpulse --enable-librav1e --enable-librsvg --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libsvtav1 --enable-libtheora --enable-libv4l2 --enable-libvidstab --enable-libvmaf --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxcb --enable-libxml2 --enable-libxvid --enable-libzimg --enable-nvdec --enable-nvenc --enable-opencl --enable-opengl --enable-shared --enable-version3 --enable-vulkan
libavutil 57. 28.100 / 57. 28.100
libavcodec 59. 37.100 / 59. 37.100
libavformat 59. 27.100 / 59. 27.100
libavdevice 59. 7.100 / 59. 7.100
libavfilter 8. 44.100 / 8. 44.100
libswscale 6. 7.100 / 6. 7.100
libswresample 4. 7.100 / 4. 7.100
libpostproc 56. 6.100 / 56. 6.100
[video4linux2,v4l2 @ 0x7f56e0000c80] Cannot open video device /dev/video0: No such file or directory
nan : 0.000 fd= 0 aq= 0KB vq= 0KB sq= 0B f=0/0
Or alternatively:
/dev/video0: Input/output error 0KB vq= 0KB sq= 0B f=0/0
[computer1 ~]# fuser /dev/video0
/dev/video0: 5180
[computer1 ~]# readlink /proc/5180/exe
/usr/bin/pipewire
External links
Similar problems I’ve been able to find.
- Bug #1962223 “uvcvideo Failed to query (GET_DEF) UVC control 2 o...” : Bugs : linux-meta-hwe-5.13 package : Ubuntu, similar issue with one of the packages on Ubuntu, 2022, unresolved
- 1956305 – Astro HD Camera not functioning and hangs audio, similar issue on Redhat, 2021, unresolved
- Issue with USB webcam (uvcvideo) - Linux Mint Forums, similar issue on Mint, 2021, suggested loading uvcvideo in quirks mode, didn’t help
[Risolto] Webcam non riconosciuta su DELL XPS 15 7590 • Forum Ubuntu-it, (Italian) similar issue on Ubuntu, 2022, suggested adding config to
udev/rules.d, didn’t help, however additional config works, because after adding it in dmseg
there would be similar lines as if the webcam is being recognized two times on each 5-second iteration. - Logitech c920e -- v4l2-ctl --list-devices\ Cannot open device /dev/video0, exiting, similar issue, 2021, unresolved
- Razer built-in webcam not working - #3 by anon62096739, similar issue, 2020, suggestion unapplicable
- pipewire installation on Manjaro breaks USB camera (#2278) · Issues · PipeWire / pipewire · GitLab, similar issue, 2022, unresolved
- My webcam doesn't work - #5 by toniovr, 2021, unresolved
