Some RAM Problem using kde plasma
Hello everyone, thanks a lot for this forum, it save a lot of time for me.
But i can`t find same problem as my, when im using the system, for some time, my ram was increase very fast(check screenshot after reboot and after ~10 minutes) i open the pycharm, dbeaver, telegram, chrome, pamac and close everythink and it increase ram +2G
ibb. co/q9JBCMq
ibb. co/3fKp5xd
Did some one have the same?
and when my ram was full on ~90% i got freezes
The increased RAM usage after booting is normal with KDE Plasma due to the Baloo file indexer running upon logging in. You can disable that, as you can see in the screenshot below. :arrow_down:
You should also be advised that a web browser — any web browser, but especially Chrome — uses up a lot of your RAM, and especially so if you have multiple tabs open.
Furthermore, it is perfectly normal for the memory usage to increase over time, because GNU/Linux makes use of caching in order to be able to open files and start applications faster. The RAM used for caching will normally decrease if more memory is needed by another application. The Linux kernel manages memory very dynamically and efficiently.
This is normal too, depending on whether you’ve created a swap partition (or alternatively, a swap file) or not, and how much RAM is in your machine.
On a machine with less than 8 GiB of RAM, I recommend creating a swap partition of about 10-12 GiB — if you ever plan on hibernating the machine, then you’re going to need that anyway. If your machine has 16 GiB or more and you don’t ever hibernate, then you don’t need swap. :arrow_down:
Thank you for your attention, i`m using 16G ram and 4G swap, but its not enought for me some times.
once my screen was freez when i see ~90 ram on system monitor. Only reboot solve that problem.
But when i check ram usage with ps_mem its not like 90% but anyway freezings
I would also highly suggest to check the dreaded baloo indexer, which gives more headaches as benefits imho.
balooctl status
Issue the command without any arguments to see what other options you can use…
i check status now and its disable
Then next thing to check is what is using so much RAM while it increases before you get a freeze, eg. use the Applications tab inside system monitor which will show you this info per running app.
i attach screnshots, and they dont show anythink that can help to understand that
I’m talking about ā€œMenu→Applications→System→System Monitorā€
he is show same as htop
Attention: please follow the instructions linked below. a simple disable isn’t enough to kill this total nonsense, ugly and resource-wasting piece of crap
Disabling the indexer
To disable the Baloo file indexer:
$ balooctl suspend
$ balooctl disable
The indexer will be disabled on next login.
Alternatively, disable Enable File Search in System settings under Search > File search.
To permanently delete the index database, run:
$ balooctl purge
This will also resolve the following error message in file dialogs and other applications (KDE bug 437176):
$ balooctl suspend
$ balooctl disable
$ balooctl purge
kf.kio.core: "Could not enter folder tags:/."
$ balooctl suspend
$ balooctl disable
$ balooctl purge
kf.kio.core: "CoDisabling the indexer
$ balooctl suspend
$ balooctl disable
$ balooctl purge
$ balooctl suspend
$ balooctl disable
$ balooctl purgehttps://wiki.archlinux.org/title/Baloo#Disabling_the_indexer
So to recap, am i correct to say you are freezing after ~10 minutes while no process is using so much ram (~90%)? :thinking:
Because that would be something completely different…
But if it freezes when your RAM usage hit ~90%, it should be listed in that info you monitor…
not, on screens just a test, freezing when im using the system for 4 or more hours
TY man, im trying to do this instruction and answer for results
Anyway have some problem
i close every app and still 5.5G RAM usage
https://ibb.co/w7Y5p6v
And according to that screenshot, you have 16GB RAM, so I don’t think you have anything to worry about. I also have about the same constant usage and I also have 16GB of RAM.
Linux is extremely efficient, or whatever you want to call it’s managing of RAM. See:
https://www.linuxatemyram.com/
But problem with freezes when ~90% RAM is still with me
I’m thinking about the fact that it’s plasma, but I can’t be sure for sure
Having plasma myself, fully updated to version 5.26.3 with absolutely 0 freezes myself, I’m thinking perhaps it’s something else then. Please provide the output of the following:
journalctl --boot=-1 --priority=3 --no-pager
Where:
  • The --boot= is the boot that previously had an occurrance of a hang. It can be adjusted to fit as neccessary. So -1 for the previous boot, -2 for the one before it, -3 for the one before that, and so on, and so forth;
  • The --priority=3 argument will limit the output to Errors and Warnings only;
  • The --no-pager argument will cause the output not to be scrollable, which is neccessary for providing it here.
Let’s try and rather find the cause of your system hanging, rather than speculate about what it might be, and when there’s nothing because the problem is somewhere else, you get frustrated.
I might not be the one to help, my day is about ending this side of the world, but the information would be required for anyone to be able to be of assistance.
:bangbang: Tip: :bangbang:
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
For more information, please see:
:bangbang: Also, if your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
LC_ALL=C journalctl --boot=-3 --priority=3 --no-pager
Nov 23 03:26:16 junk-pc kernel: ACPI BIOS Error (bug): Could not resolve symbol [^^^GPP0.PEGP], AE_NOT_FOUND (20210730/psargs-330)
Nov 23 03:26:16 junk-pc kernel: ACPI Error: Aborting method \_SB.PCI0.LPC0.EC0._QC6 due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Nov 23 03:26:16 junk-pc kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GP17.MP2], AE_NOT_FOUND (20210730/psargs-330)
Nov 23 03:26:16 junk-pc kernel: ACPI Error: Aborting method \_SB.GPIO._EVT due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Nov 23 03:26:17 junk-pc bluetoothd[540]: src/plugin.c:plugin_init() Failed to init vcp plugin
Nov 23 03:26:17 junk-pc bluetoothd[540]: src/plugin.c:plugin_init() Failed to init mcp plugin
Nov 23 03:26:17 junk-pc bluetoothd[540]: src/plugin.c:plugin_init() Failed to init bap plugin
Nov 23 03:26:28 junk-pc kernel: rtw_8822ce 0000:01:00.0: failed to do dpk calibration
Nov 23 03:52:09 junk-pc systemd-coredump[3776]: Failed to connect to coredump service: Connection refused
Nov 23 03:52:09 junk-pc pulseaudio[1327]: Lost I/O connection in module "module-gsettings"
Nov 23 03:52:09 junk-pc pulseaudio[1327]: Error opening PCM device _ucm0003.hw:Generic_1: ŠŠµŃ‚ такого ŃƒŃŃ‚Ń€Š¾Š¹ŃŃ‚Š²Š°
Nov 23 03:52:09 junk-pc pulseaudio[1327]: Error opening PCM device _ucm0003.hw:acp: ŠŠµŃ‚ такого ŃƒŃŃ‚Ń€Š¾Š¹ŃŃ‚Š²Š°
ŠŠµŃ‚ такого ŃƒŃŃ‚Ń€Š¾Š¹ŃŃ‚Š²Š° = There is no such device
maybe someone know how to clean that cache ram?
Please do not post images of text, use copy+paste and proper formatting.
RAM is there to be used, clearing caches is counterproductive.
You were already given a link to https://www.linuxatemyram.com/ , please do read it.
I don’t know what you did to your system, but mine always has only 1 plasmashell --no-respawn process for my user.
