Yesterday I did try to install libaspell or libhspell (names as written in the error reports), but that resulted in an error. Therefore I gave up. It’s just your mentioning of these words without the prefixing lib that let me try it again - successfully (enchant was already installed).
I’m not sure whether it’s usual that arch names library packages without lib-prefix (then in contrast to Debian/Ubuntu packages).
The question now is: why are this libs not already part of the default Manjaro installation?
Well, I intended to insert the output of nxi -zv8 into my profile but than it is warned that the 3,000 character count is exceeded. However I can’t imagine that it’s helpful to insert the output in the posting itself. I’ll do it now here (can be removed if it makes sense)
$ lsb_release -sirc
ManjaroLinux 25.0.0 Zetar
$ inxi -zv8
Kernel: 6.12.12-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
clocksource: hpet avail: acpi_pm
root=UUID=4ad50bf4-5d81-48bc-99ca-b098cfe6e553 rw quiet splash
Desktop: GNOME v: 47.4 tk: GTK v: 3.24.43 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 47.0 Distro: Manjaro
base: Arch Linux
Type: Laptop System: LENOVO product: 21MV v: ThinkBook 14 G7 ARP
serial: <superuser required> Chassis: type: 10 v: ThinkBook 14 G7 ARP
Mobo: LENOVO model: LNVNB161216 v: SDK0T76530 WIN
serial: <superuser required> part-nu: LENOVO_MT_21MV_BU_idea_FM_ThinkBook
14 G7 ARP uuid: <superuser required> UEFI: LENOVO v: P6CN17WW
date: 04/18/2024
ID-1: BAT0 charge: 31.3 Wh (70.2%) condition: 44.6/45.0 Wh (99.1%)
power: 5.3 W volts: 12.1 min: 11.5 model: Sunwoda L22D3PE0 type: Li-poly
serial: <filter> status: discharging cycles: 39
System RAM: total: 8 GiB available: 6.33 GiB used: 3.85 GiB (60.7%)
Array-1: capacity: 64 GiB slots: 2 modules: 1 EC: None
Device-1: Channel-A DIMM 0 type: no module installed
Device-2: Channel-B DIMM 0 type: DDR5 detail: synchronous unbuffered
(unregistered) size: 8 GiB speed: spec: 5600 MT/s actual: 4800 MT/s
volts: note: check curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
manufacturer: Samsung part-no: M425R1GB4PB0-CWMOL serial: <filter>
Info: model: AMD Ryzen 5 7535HS with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3+ gen: 3 level: v3 note: check built: 2022
process: TSMC n6 (7nm) family: 0x19 (25) model-id: 0x44 (68) stepping: 1
microcode: 0xA404107
desc: 6x512 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1108 min/max: 400/4603 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1108 2: 1108 3: 1108
4: 1108 5: 1108 6: 1108 7: 1108 8: 1108 9: 1108 10: 1108 11: 1108
12: 1108 bogomips: 79080
misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx ospke osvw overflow_recov pae pat pausefilter pclmulqdq
popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good
sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3
xsaves xtopology
Type: spec_store_bypass mitigation: Speculative Store Bypass disabled
via prctl
affected
Device-1: Advanced Micro Devices [AMD/ATI] Rembrandt [Radeon 680M]
vendor: Lenovo driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, DP-5,
DP-6, HDMI-A-1, Writeback-1 bus-ID: 75:00.0 chip-ID: 1002:1681
class-ID: 0300 temp: 25.0 C
Device-2: Syntek Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2 chip-ID: 174f:1820
Display: wayland server: X.org v: 1.21.1.15 with: Xwayland v: 24.1.5
compositor: gnome-shell driver: gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: AU Optronics 0x20a7 built: 2022 res: 1920x1200
dpi: 162 gamma: 1.2 chroma: red: x: 0.569 y: 0.341 green: x: 0.353 y: 0.569
blue: x: 0.161 y: 0.110 white: x: 0.314 y: 0.329
size: 301x188mm (11.85x7.4") diag: 355mm (14") ratio: 16:10
modes: 1920x1200, 1920x1080, 1600x1200, 1680x1050, 1280x1024, 1440x900,
1280x800, 1280x720, 1024x768, 800x600, 640x480
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon 660M (radeonsi
rembrandt LLVM 19.1.7 DRM 3.59 6.12.12-2-MANJARO) device-ID: 1002:1681
memory: 500 MiB unified: no display-ID: :0.0
Info: Tools: api: eglinfo,glxinfo x11: xprop
Device-1: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High
Definition Audio vendor: Lenovo driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 75:00.1 chip-ID: 1002:1640
class-ID: 0403
Device-2: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
vendor: Lenovo driver: snd_pci_acp6x v: kernel alternate: snd_pci_acp3x,
snd_rn_pci_acp3x, snd_pci_acp5x, snd_acp_pci, snd_rpl_pci_acp6x,
snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
snd_sof_amd_vangogh, snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 75:00.5 chip-ID: 1022:15e2
class-ID: 0480
vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 75:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.12.12-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 5000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: down mac: <filter>
Device-2: Realtek RTL8852CE PCIe 802.11ax Wireless Network vendor: Lenovo
driver: rtw89_8852ce v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
port: 4000 bus-ID: 02:00.0 chip-ID: 10ec:c852 class-ID: 0280
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:2 chip-ID: 0bda:5852
Report: rfkill ID: hci0 rfk-id: 6 state: up address: see --recommends
Local Storage: total: 238.47 GiB used: 28.55 GiB (12.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD PC
SN740 SDDPMQD-256G-1101 size: 238.47 GiB block-size: physical: 512 B
fw-rev: 73116001 temp: 20.9 C scheme: GPT
ID-1: / raw-size: 185.11 GiB size: 181.14 GiB (97.86%)
used: 28.52 GiB (15.7%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
label: N/A uuid: 4ad50bf4-5d81-48bc-99ca-b098cfe6e553
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 36.2 MiB (14.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: SYSTEM_DRV uuid: 2E21-9C0F
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 51.14 GiB fs: bitlocker
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 1.95 GiB fs: ntfs
label: WINRE_DRV uuid: 0ED22317D2230297
Device-1: 1-3:2 info: Elan Micro ELAN:ARM-M4 type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 100mA chip-ID: 04f3:0c8c class-ID: 0000
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 3 rev: 2.0
Device-1: 3-3:2 info: Realtek Bluetooth Radio type: bluetooth
driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 500mA chip-ID: 0bda:5852 class-ID: e001 serial: <filter>
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Device-1: 5-1:2 info: Syntek Integrated Camera type: video
driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 174f:1820 class-ID: fe01
serial: <filter>
Hub-6: 6-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
Hub-7: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-8: 8-0:1 info: super-speed hub ports: 1 rev: 3.1
Hub-9: 9-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-10: 10-0:1 info: super-speed hub ports: 1 rev: 3.1
System Temperatures: cpu: 26.6 C mobo: 22.2 C gpu: amdgpu temp: 26.0 C
Fan Speeds (rpm): N/A
Packages: 1302 pm: pacman pkgs: 1297 libs: 363
tools: gnome-software,pamac,yay pm: flatpak pkgs: 5
1: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
2: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 369
1: cpu: 2.3% command: gnome-shell pid: 1050 mem: 463.0 MiB (7.1%)
2: cpu: 1.4% command: vivaldi-bin pid: 8433 mem: 297.6 MiB (4.5%)
3: cpu: 1.2% command: chromium pid: 11461 mem: 228.1 MiB (3.5%)
4: cpu: 1.0% command: chromium pid: 11638 mem: 218.4 MiB (3.3%)
5: cpu: 0.8% command: vivaldi-bin pid: 10714 mem: 244.6 MiB (3.7%)
Memory top: 5 of 369
1: mem: 787.5 MiB (12.1%) command: thunderbird pid: 8589 cpu: 0.3%
2: mem: 463.0 MiB (7.1%) command: gnome-shell pid: 1050 cpu: 2.3%
3: mem: 297.6 MiB (4.5%) command: vivaldi-bin pid: 8433 cpu: 1.4%
4: mem: 293.4 MiB (4.5%) command: vivaldi-bin pid: 8388 cpu: 0.6%
5: mem: 271.6 MiB (4.1%) command: vivaldi-bin pid: 8464 cpu: 0.3%
Processes: 369 Power: uptime: 15h 8m states: freeze,mem,disk
suspend: s2idle wakeups: 3 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 2.51 GiB services: gsd-power,
tool: systemctl
Compilers: gcc: 14.2.1 Shell: Bash v: 5.2.37 running-in: gnome-terminal
inxi: 3.3.37
