Slow opening applications after update
Hi
This morning I updated the system after an update prompt and after that to open an app takes for ever. It used to be fast, now it takes around 30 seconds to open Firefox, Brave, telegram, Thunderbird.
However, terminal and chromium on the other hand opens fast.
I looked around in the forum and found suggestions to clear out .cache and reboot. That did not make any difference. Then I tried to create a new user, but the new user had the same issues.
Any suggestions?
inxi -Fazy
  Kernel: 6.1.31-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=777c477a-f86e-459e-b526-da0095b9349c rw quiet apparmor=1
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
    v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
  Type: Desktop Mobo: ASRock model: Z370 Pro4 serial: <superuser required>
    UEFI-[Legacy]: American Megatrends v: P4.30 date: 10/31/2019
  Device-1: hidpp_battery_0 model: Logitech Marathon Mouse/Performance Plus
    M705 serial: <filter> charge: 55% (should be ignored) rechargeable: yes
    status: discharging
  Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard
    status: discharging
  Info: model: Intel Core i5-8400 bits: 64 type: MCP arch: Coffee Lake
    gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF2
  Topology: cpus: 1x cores: 6 smt: <unsupported> cache: L1: 384 KiB
    desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB L3: 9 MiB
    desc: 1x9 MiB
  Speed (MHz): avg: 3549 high: 3999 min/max: 800/4000 scaling:
    driver: intel_pstate governor: powersave cores: 1: 3897 2: 3899 3: 3999
    4: 2800 5: 2800 6: 3900 bogomips: 33613
    disabled
  Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: disabled, RSB
    filling, PBRSB-eIBRS: Not affected
  Device-1: AMD Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X]
    vendor: XFX Pine driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
    process: GF 14nm built: 2016-20 pcie: gen: 3 speed: 8 GT/s lanes: 4
    link-max: lanes: 8 ports: active: DP-1,HDMI-A-1 empty: DVI-D-1
    bus-ID: 03:00.0 chip-ID: 1002:699f class-ID: 0300 temp: 40.0 C
  Display: x11 server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
    loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
    gpu: amdgpu display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.00x11.22")
    s-diag: 1055mm (41.54")
  Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,left model: Dell S2340L
    serial: <filter> built: 2014 res: 1920x1080 hz: 60 dpi: 96 gamma: 1.2
    size: 509x286mm (20.04x11.26") diag: 584mm (23") ratio: 16:9 modes:
    max: 1920x1080 min: 720x400
  Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: right model: Dell S2340L
  API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
  Device-1: Intel 200 Series PCH HD Audio vendor: ASRock driver: snd_hda_intel
    v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0 class-ID: 0403
  Device-2: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / 560/560X]
    vendor: XFX Pine driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
    lanes: 4 link-max: lanes: 8 bus-ID: 03:00.1 chip-ID: 1002:aae0
    class-ID: 0403
  Device-3: Logitech Headset H390 driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:5
    chip-ID: 046d:0a44 class-ID: 0300
  API: ALSA v: k6.1.31-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.70 status: off tools: pw-cli
    type: plugin tools: pacat,pactl,pavucontrol
  Device-1: Intel Ethernet I219-V vendor: ASRock driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
  Local Storage: total: 2.05 TiB used: 1.09 TiB (53.1%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EZEX-00ZF5A0
    tech: N/A serial: <filter> fw-rev: 0A80 scheme: MBR
  ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 250GB
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 1B6Q scheme: MBR
  ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 870 QVO 1TB
    tech: SSD serial: <filter> fw-rev: 2B6Q
  ID-1: / raw-size: 232.88 GiB size: 228.17 GiB (97.98%)
    used: 42.06 GiB (18.4%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17
  ID-2: /home raw-size: 931.51 GiB size: 915.82 GiB (98.31%)
    used: 646.54 GiB (70.6%) fs: ext4 dev: /dev/sdc maj-min: 8:32
  ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
    file: /swapfile
  System Temperatures: cpu: 42.0 C mobo: N/A gpu: amdgpu temp: 40.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 125
  Processes: 318 Uptime: 14m wakeups: 4 Memory: available: 31.28 GiB
  used: 4.39 GiB (14.0%) Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: 1451
  pm: pacman pkgs: 1405 libs: 449 tools: pamac pm: appimage pkgs: 0 pm: flatpak
  pkgs: 23 pm: snap pkgs: 23 Shell: Bash v: 5.1.16 running-in: alacritty
  inxi: 3.3.27
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
Did you know that the forum has a search function? :arrow_down:
Had you used it, then you would have found this:arrow_down:
