Slow Kde launch, upower?
Hi
Since some time, boot has become slow.
May be at the time of switching from x11 to wayland.
The boot is fast until it reach the kde screen where it turns for a good 20s before going to the desktop.
    ~  systemd-analyze blame         ✔
21.382s upower.service
 2.347s plymouth-quit-wait.service
 2.347s plymouth-quit.service
  985ms systemd-binfmt.service
  862ms systemd-timesyncd.service
  747ms NetworkManager.service
  361ms dev-nvme0n1p2.device
  339ms systemd-tmpfiles-clean.service
  183ms ldconfig.service
  174ms systemd-udev-trigger.service
  160ms user@1000.service
  144ms systemd-tmpfiles-setup-dev-early.service
  109ms lvm2-monitor.service
  106ms systemd-remount-fs.service
   88ms systemd-random-seed.service
   80ms systemd-tmpfiles-setup.service
   77ms systemd-userdbd.service
   73ms systemd-journald.service
   69ms systemd-journal-flush.service
   66ms power-profiles-daemon.service
   64ms dbus-broker.service
   55ms wpa_supplicant.service
   50ms systemd-vconsole-setup.service
   48ms boot-efi.mount
   40ms systemd-journal-catalog-update.service
   39ms systemd-rfkill.service
   39ms home.mount
   39ms swap.mount
   38ms var-cache.mount
   36ms systemd-modules-load.service
   35ms proc-sys-fs-binfmt_misc.mount
   35ms ModemManager.service
   34ms polkit.service
   34ms systemd-udevd.service
   33ms udisks2.service
   32ms systemd-sysusers.service
   30ms systemd-udev-load-credentials.service
   27ms sys-fs-fuse-connections.mount
   27ms systemd-hostnamed.service
   27ms systemd-logind.service
   20ms plymouth-start.service
   20ms user-runtime-dir@1000.service
   19ms systemd-fsck@dev-disk-by\x2duuid-2A28\x2d3D25.service
   18ms bluetooth.service
   14ms systemd-tmpfiles-setup-dev.service
   12ms plymouth-read-write.service
   12ms cups.service
    9ms dev-hugepages.mount
    9ms dev-mqueue.mount
    8ms sys-kernel-debug.mount
    8ms rtkit-daemon.service
    8ms sys-kernel-tracing.mount
    8ms kmod-static-nodes.service
    7ms modprobe@configfs.service
    6ms modprobe@drm.service
    6ms modprobe@fuse.service
    6ms systemd-update-utmp.service
    5ms systemd-sysctl.service
    4ms modprobe@dm_mod.service
    4ms alsa-restore.service
    4ms modprobe@loop.service
    4ms systemd-user-sessions.service
    4ms swap-swapfile.swap
    4ms systemd-update-done.service
    3ms var-log.mount
    3ms sys-kernel-config.mount
    2ms tmp.mount
    ~  systemd-analyze critical-chain upower.service         ✔  7s 
The time when unit became active or started is printed after the "@" character.
The time the unit took to start is printed after the "+" character.
upower.service +21.382s
└─basic.target @2.583s
  └─dbus-broker.service @2.517s +64ms
    └─dbus.socket @2.515s
      └─sysinit.target @2.513s
        └─systemd-timesyncd.service @1.651s +862ms
          └─systemd-tmpfiles-setup.service @1.569s +80ms
            └─run-credentials-systemd\x2dtmpfiles\x2dsetup.service.mount @2.455s
    ~  journalctl -b -u upower.service         ✔
janv. 10 13:58:51 dw-pc systemd[1]: Starting Daemon for power management...
janv. 10 13:59:12 dw-pc systemd[1]: Started Daemon for power management.
    ~  journalctl -p3 -b         ✔
janv. 10 13:58:45 dw-pc kernel: hub 8-0:1.0: config failed, hub doesn't have any ports! (err -19)
janv. 10 13:58:45 dw-pc (udev-worker)[511]: event10: Failed to call EVIOCSKEYCODE with scan code 0x7c, and key code 190: Invalid argument
janv. 10 13:58:51 dw-pc kernel: usb 1-6: parse_audio_format_rates_v2v3(): unable to retrieve sample rate range (clock 1)
janv. 10 13:59:12 dw-pc kernel: usb 1-6: parse_audio_format_rates_v2v3(): unable to retrieve number of sample rates (clock 1)
    ~  systemctl status upower         ✔
● upower.service - Daemon for power management
     Loaded: loaded (/usr/lib/systemd/system/upower.service; disabled; preset: disabled)
     Active: active (running) since Fri 2025-01-10 13:59:12 CET; 1h 36min ago
 Invocation: b1ab18c747844233a25e14f0cf0b465c
       Docs: man:upowerd(8)
   Main PID: 835 (upowerd)
      Tasks: 4 (limit: 37307)
     Memory: 3.7M (peak: 4.2M)
        CPU: 490ms
     CGroup: /system.slice/upower.service
             └─835 /usr/lib/upowerd
Here is what I have.
I’m logging automatically with plasma.
Cant really go back to x11, using 2 displays with different resolution and scalling.
I have seen issues with usb devices. In usb I have plugged in mouse and keyboard and usb A to C adapter.
Tried unpowered and booting without usb in with no change.
What can I do?
    ~  inxi -zv8         ✔
  Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=71ff11f9-ec6f-478c-b502-b2566447b368 rw rootflags=subvol=@
  Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
  Mobo: ASUSTeK model: ROG STRIX B650-A GAMING WIFI v: Rev 1.xx
    UEFI: American Megatrends v: 3042 date: 09/30/2024
  System RAM: total: 32 GiB available: 30.5 GiB used: 7.51 GiB (24.6%)
  Device-1: Channel-A DIMM 0 type: no module installed
  Device-2: Channel-A DIMM 1 type: DDR5 detail: synchronous unbuffered
    (unregistered) size: 16 GiB speed: spec: 4800 MT/s actual: 6000 MT/s
    volts: note: check curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
    manufacturer: G Skill Intl part-no: F5-6000J3038F16G serial: <filter>
  Device-3: Channel-B DIMM 0 type: no module installed
  Device-4: Channel-B DIMM 1 type: DDR5 detail: synchronous unbuffered
  Info: model: AMD Ryzen 7 7800X3D bits: 64 type: MT MCP arch: Zen 4 gen: 4
    level: v4 note: check built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25)
    model-id: 0x61 (97) stepping: 2 microcode: 0xA601209
    smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB
    desc: 8x1024 KiB L3: 96 MiB desc: 1x96 MiB
  Speed (MHz): avg: 4682 min/max: 545/5050 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 4682 2: 4682 3: 4682
    4: 4682 5: 4682 6: 4682 7: 4682 8: 4682 9: 4682 10: 4682 11: 4682 12: 4682
    13: 4682 14: 4682 15: 4682 16: 4682 bogomips: 134451
    apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
    avx512ifma avx512vbmi avx512vl bmi1 bmi2 bpext cat_l3 cdp_l3 clflush
    clflushopt clwb clzero cmov cmp_legacy constant_tsc cpb cppc cpuid cqm
    cqm_llc cqm_mbm_local cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de
    decodeassists erms extapic extd_apicid f16c flush_l1d flushbyasid fma fpu
    fsgsbase fsrm fxsr fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs
    invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
    movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
    overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
    perfctr_llc perfctr_nb perfmon_v2 pfthreshold pge pku pni popcnt pse
    pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
    succor svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk
    v_spec_ctrl vaes vgif vmcb_clean vme vmmcall vnmi vpclmulqdq wbnoinvd wdt
    x2avic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
    conditional; STIBP: always-on; RSB filling; PBRSB-eIBRS: Not affected;
    BHI: Not affected
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 [Radeon RX 7900 XT/7900
    XTX/7900 GRE/7900M] vendor: Sapphire PULSE driver: amdgpu v: kernel
    arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie:
    gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1,DP-2
    empty: HDMI-A-1,HDMI-A-2,Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:744c
    class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: ASUSTeK
    driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
    built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
    empty: DP-3,HDMI-A-3,Writeback-2 bus-ID: 0e:00.0 chip-ID: 1002:164e
    class-ID: 0300 temp: 43.0 C
  Display: wayland server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
    compositor: kwin_wayland driver: X: loaded: amdgpu
    gpu: amdgpu d-rect: 5760x3240 display-ID: 0
  Monitor-1: DP-1 pos: primary,top-left model: MSI MAG321UX OLED built: 2023
    res: mode: 3840x2160 hz: 240 scale: 130% (1.3) to: 2954x1662 dpi: 140
    gamma: 1.2 chroma: red: x: 0.686 y: 0.306 green: x: 0.243 y: 0.710 blue:
    x: 0.141 y: 0.055 white: x: 0.314 y: 0.329 size: 699x395mm (27.52x15.55")
    diag: 803mm (31.6") ratio: 16:9 modes: 3840x2160, 2560x1440, 1920x1200,
    1920x1080, 1600x1200, 1680x1050, 1280x1024, 1440x900, 1280x960, 1280x800,
    1152x864, 1280x720, 1024x768, 800x600, 640x480, 720x400
  EDID-Warnings: 1: parse_edid: unknown tag 112
  Monitor-2: DP-2 pos: bottom-r model: Idek Iiyama PLG2488H built: 2013 res:
    mode: 1920x1080 hz: 144 scale: 100% (1) dpi: 92 gamma: 1.2 chroma: red:
    x: 0.647 y: 0.329 green: x: 0.310 y: 0.620 blue: x: 0.153 y: 0.071 white:
    x: 0.314 y: 0.329 size: 531x299mm (20.91x11.77") diag: 609mm (24")
    ratio: 16:9 modes: 1920x1080, 1600x1200, 1680x1050, 1280x1024, 1440x900,
    1280x960, 1280x800, 1152x864, 1280x720, 1024x768, 832x624, 800x600,
    720x576, 720x480, 640x480, 720x400
    device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: kms_swrast
    surfaceless: drv: radeonsi wayland: drv: radeonsi x11: drv: radeonsi
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.8-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7900 GRE (radeonsi
    navi31 LLVM 18.1.8 DRM 3.59 6.12.4-1-MANJARO) device-ID: 1002:744c
    memory: 15.62 GiB unified: no display-ID: :0.0
  API: Vulkan v: 1.4.303 layers: 11 device: 0 type: discrete-gpu
    name: AMD Radeon RX 7900 GRE driver: N/A device-ID: 1002:744c
    surfaces: xcb,xlib,wayland device: 1 type: integrated-gpu
    name: AMD Radeon Graphics driver: N/A device-ID: 1002:164e
    de: kscreen-console,kscreen-doctor gpu: corectrl,lact wl: wayland-info
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP Audio
    bus-ID: 03:00.1 chip-ID: 1002:ab30 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High
    Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0e:00.1 chip-ID: 1002:1640
    class-ID: 0403
  Device-3: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:2
    chip-ID: 0b05:1a52 class-ID: 0300
  API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
  Device-1: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel pcie:
    gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 0a:00.0 chip-ID: 8086:15f3
    class-ID: 0200
  Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
    vendor: Foxconn driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
    lanes: 1 bus-ID: 0b:00.0 chip-ID: 14c3:0616 class-ID: 0280
  IF: wlp11s0 state: up mac: <filter>
  Device-1: Foxconn / Hon Hai Wireless_Device driver: btusb v: 0.8 type: USB
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:6
    chip-ID: 0489:e0e2 class-ID: e001 serial: <filter>
  Local Storage: total: 2.27 TiB used: 1.21 TiB (53.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 38.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 500GB
    tech: SSD serial: <filter> fw-rev: 3B6Q scheme: GPT
  ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 1.21 TiB (66.8%)
    fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 71ff11f9-ec6f-478c-b502-b2566447b368
    used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 2A28-3D25
  ID-3: /home raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
    used: 1.21 TiB (66.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: 71ff11f9-ec6f-478c-b502-b2566447b368
  ID-4: /swap raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
  ID-5: /var/cache raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
  ID-6: /var/log raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
  ID-1: swap-1 type: file size: 10 GiB used: 45.6 MiB (0.4%) priority: -2
    file: /swap/swapfile
  ID-1: /dev/sda1 maj-min: 8:1 size: 78.12 GiB fs: ext4 label: N/A
    uuid: 4d3a1791-95af-4a78-9c2d-b2cf22f6a9c2
  ID-2: /dev/sda2 maj-min: 8:2 size: 387.15 GiB fs: ext4 label: N/A
    uuid: 9577acaa-297b-4761-a031-3314ad14fc08
  ID-3: /dev/sda3 maj-min: 8:3 size: 501 MiB fs: vfat label: NO_LABEL
    uuid: 59CB-B8C9
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-6:2 info: ASUSTek USB Audio type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 8 rev: 2.0
  Device-2: 1-7:3 info: ASUSTek AURA LED Controller type: HID
    lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:19af class-ID: 0300
    serial: <filter>
  Hub-2: 1-8:4 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-10:5 info: Logitech G502 Proteus Spectrum Optical Mouse
    type: mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 300mA
    chip-ID: 046d:c332 class-ID: 0300 serial: <filter>
  Device-2: 1-11:6 info: Foxconn / Hon Hai Wireless_Device type: bluetooth
    mode: 2.0 power: 100mA chip-ID: 0489:e0e2 class-ID: e001 serial: <filter>
  Device-3: 1-12:7 info: DesignedbyGG Ironclad v3 type: keyboard,HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 320f:511e class-ID: 0300
  Hub-3: 2-0:1 info: super-speed hub ports: 5 rev: 3.1
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-6: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-7: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-8: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-9: 8-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
  System Temperatures: cpu: 59.4 C mobo: 44.0 C
  Fan Speeds (rpm): N/A
  GPU: device: amdgpu temp: 42.0 C device: amdgpu temp: 47.0 C mem: 66.0 C
    fan: 610 watts: 48.00
  Packages: pm: pacman pkgs: 1535 libs: 491 tools: pamac pm: flatpak pkgs: 0
    1: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
    2: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    3: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    4: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    5: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    6: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    7: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    8: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
Processes:
  CPU top: 5 of 427
  1: cpu: 7.9% command: thunderbird pid: 2974 mem: 735.4 MiB (2.3%)
  2: cpu: 7.6% command: firefox pid: 3059 mem: 787.0 MiB (2.5%)
  3: cpu: 5.4% command: kwin_wayland pid: 797 mem: 745.9 MiB (2.3%)
  4: cpu: 2.5% command: steamwebhelper pid: 2591 mem: 561.0 MiB (1.7%)
  5: cpu: 2.2% command: firefox pid: 3511 mem: 284.8 MiB (0.9%)
  Memory top: 5 of 427
  1: mem: 787.0 MiB (2.5%) command: firefox pid: 3059 cpu: 7.6%
  2: mem: 745.9 MiB (2.3%) command: kwin_wayland pid: 797 cpu: 5.4%
  3: mem: 735.4 MiB (2.3%) command: thunderbird pid: 2974 cpu: 7.9%
  4: mem: 629.9 MiB (2.0%) command: plasmashell pid: 1047 cpu: 0.1%
  5: mem: 561.0 MiB (1.7%) command: steamwebhelper pid: 2591 cpu: 2.5%
  Processes: 427 Power: uptime: 1h 56m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.18 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.37 running-in: konsole inxi: 3.3.37
20 seconds is not excessive.
Have you tried changing your Session Restore settings?
1. Open System Settings:
2. Go to SessionDesktop SessionSession Restore
3. Change “On login, launch apps that were open” to:
  • Start with an empty session :eyes:
4. Logout (or reboot if you can)
Naturally, if Start with an empty session is already set, this can be safely ignored.
You may also wish to check any other applications that start on login; these can sometimes become a bottleneck.
Power Tip: As you are using BTRFS, please always state that prominently in your Support topic’s first post, and make it clear for those wishing to help.
I have removed the boot tag (booting has finished by the time Plasma begins to launch) and moved your topic to the SupportKDE Plasma category.
I was using Session Restore on last logout
but switched to Start with an empty session after switching to wayland because it was flawed. my 2 firefox windows was messed up amond others.
I have another issue, maybe related since wayland it seems. often ( > 75%) waking up from sleep the pc is freezed. keyboard, mouse and display are powered, but no signal on sreen.
From your description, it could be any of several recent issues listed under Known Issues and Solutions.
You might look at some of these headings and their accompanying descriptions in the Update announcements to see if any apply to you:
  • Plasma 6.2 might create a black screen when using X11 and default theme (Note that the workaround for this one is to switch to using Wayland, which it seems you’ve already done).
  • KDE Plasma hangs on Shutdown, Restart and Logout
  • System freeze on suspend
You could also try creating a new User account (for testing) to see if you experience the same; this could help determine whether or not the issue is limited to your current User account.
This is not my area of ​​expertise,
but it could have something to do with the “odd” scaling on Monitor_1
odd means:
not a simple fraction (1/2, 2/3, 3/4, 4/5, 5/4, 4/3, 3/2, 2/1) but 13/10 (maybe 125% = 5/4 is faster?)
This is my area of ​​expertise: btrfs
  • the fill level is OK (<85%)
  • please also show the unused memory to assess whether a balance would be helpful (usually it is unnecessary)
    btrfs filesystem usage /
  • recommended mount options for btrfs: “noatime,compress=zstd,
    are shown with mount -t btrfs
But any changes on the btrfs-part will only bring small improvements
:footprints:
I seem to recall mentioned in another thread (fairly recently) that setting both monitors to 125% zoom was an effective strategy (this was when using Wayland) and with both at the same refresh rate (whichever is mutually compatible with each monitor).
But this is effectively hearsay, at this point. You could try experimenting a little though.
I have also had the problem with upower since
see my post
no solution
I’ve gone from 5s to be on the desktop to 25s. 5 time slower, very noticeable.
Tested 125%, no improvement
Tested booting to x11, no improvement
Tested Hdr off, no improvement
Tested kernels.
With the 6,12,4-1
boot is slow.
20-22 s for the upower.service
With the 6,11,11-1
boot is slow.
With the 6,6,65-1 lts
boot is fast.
616ms upower.service
Can I pinpoint more precicely the issue, do I need to post it somewhere else?
For my sleep issue, I used this: [SOLVED] System freezes after sleep since update / Newbie Corner / Arch Linux Forums
With kernel 6,6 LTS, no issues, but with the (6,10) 6,12 and 6,11 there is.
Disabling the bluetooth before sleep is working so far.
Do I need to post this somewhere else?
Mod Note: Posts merged to save Forum space.
Since 6.6 is an LTS, why not stick to it?
  • Two reboots would fix this question.
  • Creating another USER and another two reboots would answer this question whilst removing the original USER’s ~/home folder from the equation.
(this would also remove any autostart and session interference).
Since both kernels 6.10 and 6.11 have reached EOL, and if 6.12 also exhibits a similar experience, reverting to kernel 6.6 (LTS) seems the logical resolution; at least for the time being.
Unless there is a significant reason to change to the latest and greatest kernel iteration(s), remaining with 6.1 (LTS) would likely be my choice.
You could try kernel 6.12 or 6.13 every month or two, after a (kernel) update, and see if there’s any change.
I am on 6,6 for now yes.
Seems the sleep issue is resolved with newer kernel.
But I didn’t found the why an similar issues for this slow upower.service
I start with an empty Session… I’m using Wayland.
Any Applications I want to open automatically I set them up in System → Autostart.
I have the following applications Autostarting…
Firefox
Mullvad VPN GUI
Kwallet Manager
Dolphin
Konsole
That way Plasma loads before any applications starts loading.
If I expect to return to a previous Session, I use Hibernate, when I shut down at night.
Hope that helps.
What about …
grep . /sys/class/power_supply/*/*
udevadm info -e
upower -d
So, after the stable-update-2025-05-14 upower.service is back to 70 ms from 20+ s
With the 6,14 kernel
order is different
2.126s plymouth-quit-wait.service
2.125s plymouth-quit.service
 438ms dev-nvme0n1p2.device
 298ms systemd-tmpfiles-setup-dev-early.service
 285ms systemd-remount-fs.service
 279ms systemd-userdbd.service
 123ms systemd-udev-trigger.service
  99ms user@1000.service
  93ms NetworkManager.service
  72ms upower.service
  71ms systemd-journald.service
  58ms systemd-journal-flush.service
  54ms lvm2-monitor.service
  54ms systemd-tmpfiles-setup.service
  52ms systemd-tmpfiles-clean.service
  43ms polkit.service
  42ms plymouth-start.service
  37ms ModemManager.service
  36ms systemd-udevd.service
  36ms dbus-broker.service
  34ms udisks2.service
  34ms wpa_supplicant.service
  33ms systemd-random-seed.service
  32ms systemd-vconsole-setup.service
  30ms power-profiles-daemon.service
  29ms systemd-logind.service
  28ms systemd-hostnamed.service
  26ms bluetooth.service
  26ms systemd-update-utmp.service
  23ms systemd-timesyncd.service
  20ms rtkit-daemon.service
  19ms boot-efi.mount
  17ms cups.service
  17ms modprobe@dm_mod.service
  17ms modprobe@loop.service
  16ms systemd-fsck@dev-disk-by\x2duuid-2A28\x2d3D25.service
  15ms systemd-modules-load.service
  15ms systemd-rfkill.service
  13ms systemd-tmpfiles-setup-dev.service
  13ms alsa-restore.service
  13ms user-runtime-dir@1000.service
  11ms home.mount
  10ms swap.mount
  10ms dev-hugepages.mount
  10ms dev-mqueue.mount
  10ms var-cache.mount
  10ms sys-kernel-debug.mount
   9ms sys-kernel-tracing.mount
   9ms kmod-static-nodes.service
   8ms systemd-binfmt.service
   8ms modprobe@configfs.service
   7ms modprobe@drm.service
No necro-bumping please. See: Forum Rules - Manjaro
