Sleep/hibernate mode battery consumption
Using my 4 years old asus laptop and noticed that every night my laptop battery drains with 10-20% of the battery.
Tried using sleep and hibernate mode and the drain percentage same.
I checked energy consumption and noticed that at first hours of sleep mode my laptop consuming 5W and after some time it starts consume 18W.
Installed “laptop mode tools” and see no changes.
Specs:
nvidia GTX 950M
intel i7-6700hq 2.6ghz
Kernel: 5.7.17-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64
root=UUID=5ed2e5cd-cd2d-42c4-96f0-6092389b4cb0 rw quiet apparmor=1
security=apparmor resume=UUID=39e6cb61-aa17-4863-86de-8526c1512bf2
udev.log_priority=3
Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0 info: latte-dock wm: kwin_x11
dm: SDDM Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: N552VX v: 1.0 serial:
Mobo: ASUSTeK model: N552VX v: 1.0 serial:
UEFI: American Megatrends v: N552VX.206 date: 11/13/2015
ID-1: BAT0 charge: 16.9 Wh condition: 27.4/48.0 Wh (57%) volts: 15.0/15.0
model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Discharging
cycles: 270
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 2S
serial: charge: 100% (should be ignored) rechargeable: yes
status: Discharging
RAM: total: 7.68 GiB used: 2.44 GiB (31.7%)
Topology: Quad Core model: Intel Core i7-6700HQ bits: 64 type: MT MCP
arch: Skylake-S family: 6 model-id: 5E (94) stepping: 3 microcode: D6
L2 cache: 6144 KiB bogomips: 41621
Speed: 1185 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 1198 2: 1170
3: 1096 4: 1144 5: 1107 6: 1121 7: 1060 8: 1123
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
f16c flexpriority flush_l1d fma fpu fsgsbase fxsr hle ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good rtm sdbg sep smap smep ss ssbd sse sse2
xsaves xtopology xtpr
Type: l1tf
Type: srbds status: Vulnerable: No microcode
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: Intel HD Graphics 530 vendor: ASUSTeK driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:191b
Device-2: NVIDIA GM107M [GeForce GTX 950M] vendor: ASUSTeK driver: nvidia
v: 440.100 alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:139a
Device-3: Chicony HD WebCam (Asus N-series) type: USB driver: uvcvideo
bus ID: 1-4:3 chip ID: 04f2:b3fd serial:
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11
driver: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: Mesa Intel HD Graphics 530 (SKL GT2) v: 4.6 Mesa 20.1.6
direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:a170
Sound Server: ALSA v: k5.7.17-2-MANJARO
Device-1: Qualcomm Atheros AR9462 Wireless Network Adapter
vendor: AzureWave driver: ath9k v: kernel port: e000 bus ID: 02:00.0
chip ID: 168c:0034
IF: wlp2s0 state: up mac:
IP v4: type: dynamic noprefixroute scope: global
broadcast:
IP v6: type: noprefixroute scope: global
IP v6: type: noprefixroute scope: link
vendor: ASUSTeK driver: r8169 v: kernel port: d000 bus ID: 03:00.1
chip ID: 10ec:8168
IF: enp3s0f1 state: down mac:
WAN IP:
Local Storage: total: 931.51 GiB used: 21.79 GiB (2.3%)
ID-1: /dev/sda vendor: Toshiba model: MQ02ABD100H size: 931.51 GiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: rev: 1J scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GUE1N rev: AS00
dev-links: N/A
ID-1: / raw size: 922.42 GiB size: 906.94 GiB (98.32%)
used: 21.04 GiB (2.3%) fs: ext4 dev: /dev/sda2 label: N/A
uuid: 5ed2e5cd-cd2d-42c4-96f0-6092389b4cb0
ID-2: /boot/efi raw size: 300.0 MiB size: 299.4 MiB (99.80%)
used: 280 KiB (0.1%) fs: vfat dev: /dev/sda1 label: N/A uuid: 9BC9-0E40
ID-1: swap-1 type: partition size: 8.80 GiB used: 769.8 MiB (8.5%)
priority: -2 dev: /dev/sda3 label: N/A
uuid: 39e6cb61-aa17-4863-86de-8526c1512bf2
Hub: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 1-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
chip ID: 046d:c52b
Device-2: 1-4:3 info: Chicony HD WebCam (Asus N-series) type: Video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 04f2:b3fd
serial:
Device-3: 1-9:26 info: IMC Networks type: Bluetooth driver: btusb
interfaces: 2 rev: 1.1 speed: 12 Mb/s chip ID: 13d3:3487
Hub: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003
Hub: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Hub: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003
System Temperatures: cpu: 36.5 C mobo: N/A
Fan Speeds (RPM): cpu: 2000
Processes: 321 Uptime: 1d 20h 44m Init: systemd v: 246 Compilers:
gcc: 10.2.0 Packages: pacman: 1245 lib: 346 flatpak: 0 Shell: Bash
v: 5.0.18 running in: konsole inxi: 3.1.05
A bit more system info might help potential responders e.g.
inxi --full --admin --verbosity=7 --filter --no-host
… and: How to provide good information
Also, are any devices connected to the USB ports, or is the system set to wake on a keypress or mouse movement etc.? Or does the system require a press of the power button to wake it?
Cheers :relaxed:
udev.log_priority=3
cycles: 270
status: Discharging
Type: l1tf
diag: 394mm (15.5")
direct render: Yes
chip ID: 168c:0034
broadcast:
chip ID: 10ec:8168
WAN IP:
dev-links: N/A
chip ID: 046d:c52b
serial:
chip ID: 1d6b:0003
chip ID: 1d6b:0002
chip ID: 1d6b:0003
Try some others: Power Management - Manjaro Linux
The one that has sane default configuration for me is TLP, though I still configure it a little more, while PowerTOP doesn’t really survive across sleep/hibernate. Upon wake, it has to be rerun manually for it to correctly manage power consumption of all devices.
I used tlp but it was the same.
My laptop battery health is 56% could it be my problem?
Do it standart when my laptop uses 18w energy consumption on sleep mode?
It is not good, and likely to fail soon. May have been caused by the regular battery drain each time the machine is supposed to be in sleep or, particularly, hibernate mode.
When (supposedly) in Hibernate, what happens if you pull the battery & then re-insert it, and attempt to resume?
No, the “normal” sleep may suck only 1-5W depending manufacturer’s implementation.
Do my laptop should be connected to power?
I’d certainly recommend it. My ThinkPad is set to maintain the battery at around 95-97% of full capacity to avoid possible overcharging.
I always have my machines connected to AC wherever possible. I only run on battery when I have no access to an AC outlet.
But keeping it connected to power doesnt solution for me.
I am trying to locate my sleep battery drain problem.
True, but it will help preserve your battery for a bit longer whilst we try to find a solution. :wink:
Could it be the issue that I using video-hybrid-intel-nvidia-450xx-prime driver?
I suppose that’s possible but I’d consider it unlikely. I’d rather suspect that the machine is in fact not going into full hibernate mode which is why I suggested the battery-pull test (I wouldn’t normally as there is a risk of disk corruption, but should be easily fixable).
If the machine resumes normally or does a cold boot might provide a clue. I don’t have knowoledge of NVidia unfortunately.
I should’ve experienced the same issue if that is true.
