Hi all!
Just working on personalizing my first Linux environment and I would love to show my CPU Name in System Monitor (e.g. like the GPU is shown as “Nvidia GeForce RTX 2060”). Is this somehow possible?
Thank you
Hi all!
Thank you
Welcome to Manjaro!
would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)ksysguard
):Hi, thank you for your help!
below is my output
Kernel: 5.10.49-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=a69ef131-f555-42d2-be96-305d87f71d4e rw quiet apparmor=1
Desktop: KDE Plasma 5.22.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: ASUS product: N/A v: N/A serial: <filter>
Mobo: ASUSTeK model: ROG STRIX B550-A GAMING v: Rev X.0x serial: <filter>
UEFI: American Megatrends v: 1205 date: 11/17/2020
RAM: total: 31.3 GiB used: 2.89 GiB (9.2%)
Info: 6-Core model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3
family: 19 (25) model-id: 21 (33) stepping: 0 microcode: A201009 cache:
L2: 3 MiB bogomips: 88670
Speed: 2109 MHz min/max: 2200/3700 MHz boost: enabled Core speeds (MHz):
1: 2109 2: 2031 3: 2049 4: 1918 5: 1917 6: 2631 7: 1883 8: 2040 9: 2034
10: 1995 11: 2031 12: 2741
cr8_legacy cx16 cx8 de decodeassists erms extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt pse pse36 rdpid rdpru
rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall
vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
STIBP: always-on, RSB filling
Device-1: NVIDIA TU106 [GeForce RTX 2060 Rev. A] vendor: ZOTAC
driver: nvidia v: 470.42.01 alternate: nouveau,nvidia_drm bus-ID: 06:00.0
chip-ID: 10de:1f08 class-ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
Screen-1: 0 s-res: 3839x1080 s-dpi: 91 s-size: 1069x301mm (42.1x11.9")
s-diag: 1111mm (43.7")
Monitor-1: DP-3 res: 1920x1080 hz: 60 dpi: 92 size: 531x299mm (20.9x11.8")
diag: 609mm (24")
Monitor-2: DP-4 res: 1920x1080 dpi: 82 size: 598x336mm (23.5x13.2")
diag: 686mm (27")
OpenGL: renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2
v: 4.6.0 NVIDIA 470.42.01 direct render: Yes
Device-1: NVIDIA TU106 High Definition Audio vendor: ZOTAC
driver: snd_hda_intel v: kernel bus-ID: 06:00.1 chip-ID: 10de:10f9
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 08:00.4 chip-ID: 1022:1487
class-ID: 0403
Device-3: Razer USA Kraken Tournament Edition type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-1:2 chip-ID: 1532:0520
class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.10.49-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.31 running: yes
Device-1: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel
port: N/A bus-ID: 05:00.0 chip-ID: 8086:15f3 class-ID: 0200
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Permissions: Unable to run lvs. Root privileges required.
Local Storage: total: 3.87 TiB used: 294.28 GiB (7.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 500GB
rotation: SSD serial: <filter> rev: 1B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1500DL003-9VT16L
size: 1.36 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: 5900 rpm serial: <filter> rev: CC32 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 vendor: Samsung model: SSD 860 QVO 2TB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
ID-1: / raw-size: 465.75 GiB size: 457.37 GiB (98.20%)
used: 294.25 GiB (64.3%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: a69ef131-f555-42d2-be96-305d87f71d4e
used: 25.2 MiB (26.3%) fs: vfat dev: /dev/sdc1 maj-min: 8:33 label: N/A
uuid: 745E-D2B9
ID-1: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sdb1 maj-min: 8:17 size: 1.36 TiB fs: <superuser required>
label: HDD uuid: 90307E7D307E69DC
ID-3: /dev/sdb2 maj-min: 8:18 size: 449 MiB fs: <superuser required>
label: N/A uuid: EA3E0B513E0B15EB
ID-4: /dev/sdc2 maj-min: 8:34 size: 16 MiB fs: <superuser required>
ID-5: /dev/sdc3 maj-min: 8:35 size: 232.27 GiB fs: <superuser required>
label: N/A uuid: B65C629C5C6256E1
ID-6: /dev/sdc4 maj-min: 8:36 size: 515 MiB fs: <superuser required>
label: N/A uuid: A08CFCC68CFC984C
ID-7: /dev/sdd1 maj-min: 8:49 size: 16 MiB fs: <superuser required>
ID-8: /dev/sdd2 maj-min: 8:50 size: 1.82 TiB fs: <superuser required>
label: SSD uuid: CEE2DB6EE2DB58F3
Device-1: 1-1:2 info: Razer USA Kraken Tournament Edition type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 6 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 1532:0520 class-ID: 0300
serial: <filter>
Device-2: 1-3:3
info: SHARKOON 2.4GHz Wireless rechargeable vertical mouse [More&Better]
type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 1ea7:0064 class-ID: 0301
Device-3: 1-6:4 info: ASUSTek AURA LED Controller type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
chip-ID: 0b05:1939 class-ID: 0300 serial: <filter>
Hub-2: 1-7:5 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-6: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 5-1:2 info: Razer USA Basilisk type: Mouse,Keyboard
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 1532:0064 class-ID: 0300
Device-2: 5-4:3 info: Corsair CORSAIR K55 RGB PRO Gaming Keyboard
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s power: 500mA chip-ID: 1b1c:1ba4 class-ID: 0300
serial: <filter>
Hub-7: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 54.0 C mobo: N/A gpu: nvidia temp: 44 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 33%
Processes: 277 Uptime: 34m wakeups: 0 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 Packages: 1429 pacman: 1420 lib: 419 flatpak: 0
snap: 9 Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.05
and my “problem” is, that I can show the GPU name with text only sensors but I cannot show the CPU Name. When I choose CPU, i can further choose individual cores, the group of all cores or “all”. When i go to all, I can choose name, but it will only show “name” and not - as I would like - e.g. AMD Ryzen 5 5600X… etc.
Here I would like to have the CPU Name instead of the word all:
Hope it helps and it is now clearer, what I want to achieve
That looks like an application I don’t have, so I can’t help you any further I’m afraid…
For monitoring I use Conky and was under the impression you used standard ksysguard
@Fabby “We gradually improve the applications which ship with Plasma too, and have transitioned to Plasma System Monitor from the older KSysguard as the default system monitoring app.”
Do you have an executable name because:
and I can’t find it…
The package is called plasma-systemmonitor
and has a menu entry when it’s installed.
@Synfoxic I don’t think CPU name is supported (yet), since it would have an entry like “GPU Name” has if it was.
Very nice. That is the first I have seen of the new system monitor. I don’t use those things very much, but that is a nice looking application.
thank you for the reply
I already assumed, that it just isn’t available yet. Hope it will be in the future (so I can flex to myself haha)
Just hoped, there may be a trick for that
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or
if you agree)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
yeah, I love it as you can customize so much and make your very own “Task-Manager” with graphs, text, pie charts and other charts!
Can totally recommend, although I have not used the older version
