Segfault trying to start the cinnamon desktop
heads up that on cinnamon AMD at least I am getting a segfault trying to start the cinnamon desktop. gnome classic works fine, and downgrading xorg-server xorg-server-common fixes cinnamon
[ 164.952] (II) Initializing extension MIT-SCREEN-SAVER[ 165.141] (**) Option "config_info" "udev:/sys/devices/pci0000:00/PNP0C14:00/wmi_bus/wmi_bus-PNP0C14:00/46C93E13-EE9B-4262-8488-563BCA757FEF-0/input/input9/event8"
[ 165.170] (EE) event7 - GXT7863:00 27C6:01E0 Touchpad: kernel bug: clickpad advertising right button. See https://wayland.freedesktop.org/libinput/doc/1.32.0/clickpad-with-right-button.html for details
[ 165.197] (EE) event7 - GXT7863:00 27C6:01E0 Touchpad: kernel bug: clickpad advertising right button. See https://wayland.freedesktop.org/libinput/doc/1.32.0/clickpad-with-right-button.html for details
[ 194.098] (EE) AMDGPU(0): drmmode_do_crtc_dpms cannot get last vblank counter
[ 195.828] (EE)[ 195.828] (EE) Backtrace:[ 195.828] (EE) unw_get_proc_name failed: no unwind info found [-10]
[ 195.828] (EE) 0: /usr/lib/Xorg (?+0x0) [0x564e43548f84]
[ 195.829] (EE) unw_get_proc_name failed: no unwind info found [-10]
[ 195.829] (EE) 1: /usr/lib/libc.so.6 (?+0x0) [0x7fc07103e6f0]
[ 195.829] (EE) 2: /usr/lib/xorg/modules/drivers/amdgpu_drv.so (?+0x0) [0x7fc070a9498f]
[ 195.829] (EE) 3: /usr/lib/Xorg (?+0x0) [0x564e434a9915]
[ 195.829] (EE) 4: /usr/lib/Xorg (?+0x0) [0x564e434aae5a]
[ 195.829] (EE) 5: /usr/lib/Xorg (?+0x0) [0x564e434cd18e]
[ 195.829] (EE) 6: /usr/lib/Xorg (?+0x0) [0x564e4340e37e]
[ 195.830] (EE) unw_get_proc_name failed: no unwind info found [-10]
[ 195.830] (EE) 7: /usr/lib/libc.so.6 (?+0x0) [0x7fc071027781]
[ 195.830] (EE) 8: /usr/lib/libc.so.6 (__libc_start_main+0x89) [0x7fc0710278b9]
[ 195.830] (EE) 9: /usr/lib/Xorg (_start+0x25) [0x564e4340e995]
[ 195.830] (EE)
[ 195.830] (EE) Segmentation fault at address 0x0
[ 195.830] (EE)
[ 195.830] (EE) Caught signal 11 (Segmentation fault). Server aborting
[ 195.830] (EE)
Welcome to the forum! :wave:
Your reply has been moved to a dedicated support topic for further discussion & troubleshooting. I just updated & rebooted my Cinnamon VM with no issues.
Please post your system info as outlined here:
See also:
Just updated xorg-server and xorg-server-common again, and the problem reappears. Cinnamon segfaults (cinnamon wayland experimental does not)
cat /var/log/Xorg.0.log.old | grep -E "EE"
[    10.632] Current Operating System: Linux sdm-redmibook16 7.2.9-1-MANJARO #1 SMP PREEMPT_DYNAMIC Sat, 03 Oct 2026 15:02:22 +0000 x86_64
[    10.724] (EE) Failed to load module "fbdev" (module does not exist, 0)
[    10.724] (EE) Failed to load module "vesa" (module does not exist, 0)
[    10.844] (EE) open /dev/dri/card0: No such file or directory
[    11.376] (II) Initializing extension MIT-SCREEN-SAVER
[    11.721] (**) Option "config_info" "udev:/sys/devices/pci0000:00/PNP0C14:00/wmi_bus/wmi_bus-PNP0C14:00/46C93E13-EE9B-4262-8488-563BCA757FEF-0/input/input9/event8"
[    11.751] (EE) event10 - GXT7863:00 27C6:01E0 Touchpad: kernel bug: clickpad advertising right button. See https://wayland.freedesktop.org/libinput/doc/1.32.0/clickpad-with-right-button.html for details
[    11.777] (EE) event10 - GXT7863:00 27C6:01E0 Touchpad: kernel bug: clickpad advertising right button. See https://wayland.freedesktop.org/libinput/doc/1.32.0/clickpad-with-right-button.html for details
[    20.885] (EE) AMDGPU(0): drmmode_do_crtc_dpms cannot get last vblank counter
[    23.051] (EE)
[    23.051] (EE) Backtrace:
[    23.052] (EE) unw_get_proc_name failed: no unwind info found [-10]
[    23.052] (EE) 0: /usr/lib/Xorg (?+0x0) [0x55aa07332f84]
[    23.053] (EE) unw_get_proc_name failed: no unwind info found [-10]
[    23.053] (EE) 1: /usr/lib/libc.so.6 (?+0x0) [0x7f548563e6f0]
[    23.053] (EE) 2: /usr/lib/xorg/modules/drivers/amdgpu_drv.so (?+0x0) [0x7f54850a898f]
[    23.053] (EE) 3: /usr/lib/Xorg (?+0x0) [0x55aa07293915]
[    23.053] (EE) 4: /usr/lib/Xorg (?+0x0) [0x55aa072abb38]
[    23.054] (EE) unw_get_proc_name failed: no unwind info found [-10]
[    23.054] (EE) 5: /usr/lib/Xorg (?+0x0) [0x55aa072ad5bb]
[    23.054] (EE) 6: /usr/lib/Xorg (?+0x0) [0x55aa072ac88a]
[    23.054] (EE) 7: /usr/lib/Xorg (?+0x0) [0x55aa071f837e]
[    23.054] (EE) 8: /usr/lib/libc.so.6 (?+0x0) [0x7f5485627781]
[    23.054] (EE) 9: /usr/lib/libc.so.6 (__libc_start_main+0x89) [0x7f54856278b9]
[    23.055] (EE) 10: /usr/lib/Xorg (_start+0x25) [0x55aa071f8995]
[    23.055] (EE)
[    23.055] (EE) Segmentation fault at address 0x0
[    23.055] (EE)
[    23.055] (EE) Caught signal 11 (Segmentation fault). Server aborting
[    23.055] (EE)
[    23.055] (EE)
[    23.055] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[    23.055] (EE)
[    23.271] (EE) Server terminated with error (1). Closing log file.
and here is the inxi output
❯ inxi -zv8
  Kernel: 7.2.9-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.2.1
    clocksource: hpet avail: acpi_pm
    parameters: BOOT_IMAGE=/boot/vmlinuz-7.2-x86_64
    root=UUID=595d69c8-93d7-4873-9bc6-700f587bd198 rw apparmor=1
    security=apparmor amdgpu.ppfeaturemask=0xffffffff systemd.restore_state=0
  Desktop: Cinnamon v: 6.6.9 tk: GTK v: 3.24.52 wm: Muffin v: 6.6.3 tools:
    avail: cinnamon-screensaver dm: 1: LightDM v: 1.33.1 2: SDDM note: stopped
  Type: Laptop System: TIMI product: RedmiBook 16 v: N/A
  Mobo: TIMI model: TM1953 v: V54D2 serial: <superuser required>
    part-nu: TM1953-28893 uuid: <superuser required> Firmware: UEFI vendor: TIMI
    v: RMARN6B0P0404 date: 04/26/2020
  ID-1: BATT charge: 50.2 Wh (100.6%) note: check
    condition: 49.9/47 Wh (106.3%) volts: 15.2 min: 15.2 model: SUNWODA R14B01W
    type: Li-ion serial: <filter> charging: status: full cycles: -1
  System RAM: total: 16 GiB available: 14.99 GiB used: 5.59 GiB (37.3%)
    (unregistered) size: 8 GiB speed: 2667 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Samsung
    part-no: M471A1G44AB0-CTD serial: N/A
  Info: model: AMD Ryzen 7 4700U with Radeon Graphics bits: 64 type: MCP
    arch: Zen 2 gen: 2 level: v3 note: check built: 2020-22
    process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
    microcode: 0x860010D
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 8 smt: <unsupported> cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
    desc: 2x4 MiB
  Speed (MHz): avg: 1400 min/max: 1400/2000 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 1400 2: 1400 3: 1400
    4: 1400 5: 1400 6: 1400 7: 1400 8: 1400 bogomips: 31938
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs
    ibs irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
    movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx osvw
    overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
    perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36 rapl rdpid
    rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca
    smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock
    syscall tce topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif
    vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr
    xsaveopt xtopology
  Type: spec_rstack_overflow mitigation: SMT disabled
  Device-1: Advanced Micro Devices [AMD/ATI] Renoir [Radeon Vega Series /
    Radeon Mobile Series] vendor: Xiaomi driver: amdgpu v: kernel arch: GCN-5
    code: Vega process: GF 14nm built: 2017-20 pcie: gen: 4 speed: 16 GT/s
    lanes: 16 ports: active: DP-1,HDMI-A-1,eDP-1 empty: none bus-ID: 02:00.0
    chip-ID: 1002:1636 class-ID: 0300 temp: 44.0 C
  Display: wayland server: X.org v: 1.21.1.25 with: Xwayland v: 24.1.14
    driver: X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa
    dri: radeonsi gpu: amdgpu display-ID: 0
  Monitor-1: DP-1 model: Samsung U32J59x serial: <filter> built: 2021 res:
    mode: 3840x2160 hz: 30 scale: 100% (1) dpi: 140 gamma: 1.2 chroma: red:
    x: 0.686 y: 0.310 green: x: 0.259 y: 0.686 blue: x: 0.149 y: 0.059 white:
    x: 0.314 y: 0.329 size: 700x390mm (27.44x15.43") diag: 800mm (31.5")
    ratio: 16:9 modes: 3840x2160, 2560x1440, 1920x1080, 1680x1050, 1600x900,
    1280x1024, 1440x900, 1280x800, 1152x864, 1280x720, 1024x768, 832x624,
    800x600, 720x576, 720x480, 640x480, 720x400
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 95 2: parse_edid:
    unhandled CEA mode 94 3: parse_edid: unhandled CEA mode 93
  Monitor-2: HDMI-1 model: HKC L27000WHS res: mode: 1920x1080 hz: 60
    scale: 100% (1) dpi: 81 size: 600x340mm (23.62x13.39") diag: 690mm (27.15")
    modes: N/A
  Monitor-3: HDMI-A-1 model: L27000WHS serial: <filter> built: 2016
    res: 1920x1080 dpi: 82 gamma: 1.2 chroma: red: x: 0.631 y: 0.345 green:
    x: 0.310 y: 0.584 blue: x: 0.149 y: 0.086 white: x: 0.314 y: 0.329
    size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720,
    1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
  Monitor-4: eDP-1 model: ChiMei InnoLux 0x1608 built: 2019 res:
    mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 137 gamma: 1.2 chroma: red:
    x: 0.639 y: 0.329 green: x: 0.298 y: 0.600 blue: x: 0.149 y: 0.059 white:
    x: 0.306 y: 0.318 size: 360x200mm (13.98x7.83") diag: 407mm (16")
    ratio: 16:9 modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x800,
    1280x720, 1024x768, 800x600, 640x480
    device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi wayland:
    drv: swrast x11: drv: swrast
  API: OpenGL v: 4.6 vendor: mesa v: 26.2.4-arch1.1 glx-v: 1.4
    direct-render: yes renderer: llvmpipe (LLVM 23.1.1 256 bits)
    device-ID: ffffffff:ffffffff memory: 14.64 GiB unified: yes
    display-ID: :0.0
  API: Vulkan v: 1.4.363 layers: 2 device: 0 type: integrated-gpu name: AMD
    Radeon Graphics (RADV RENOIR) driver: mesa radv v: 26.2.4-arch1.1
    device-ID: 1002:1636 surfaces: N/A
    de: kscreen-console,kscreen-doctor gpu: amdgpu_top wl: wayland-info
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Renoir/Cezanne HDMI/DP Audio
    vendor: Xiaomi driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 02:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Audio Coprocessor vendor: Xiaomi
    driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x,
    snd_pci_acp6x, snd_acp_pci, snd_pci_ps, snd_sof_amd_renoir,
    snd_sof_amd_rembrandt, snd_sof_amd_vangogh, snd_sof_amd_acp63,
    snd_sof_amd_acp70 pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 02:00.5
    chip-ID: 1022:15e2 class-ID: 0480
  Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio vendor: Xiaomi
    bus-ID: 02:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k7.2.9-1-MANJARO status: kernel-api
  Server-3: PipeWire v: 1.6.9 status: off with: pipewire-media-session
    status: active tools: pw-cat,pw-cli
  Server-4: PulseAudio v: 17.0-98-gb096 status: active with:
    1: pulseaudio-alsa type: plugin 2: pulseaudio-jack type: module tools: pacat,
    pactl, pamixer, pavucontrol, pulsemixer
  Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
    driver: rtw88_8822ce v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 2000 bus-ID: 01:00.0 chip-ID: 10ec:c822 class-ID: 0280
  IF-ID-1: br-6c0c565bebd7 state: down mac: <filter>
  IF-ID-2: br-a1ae5c1e905e state: down mac: <filter>
  IF-ID-3: docker0 state: down mac: <filter>
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:2 chip-ID: 0cb5:c547
  Local Storage: total: 476.94 GiB used: 285.85 GiB (59.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: MZNLH512HALU-00000
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 200Q scheme: GPT
  ID-1: / raw-size: 329.08 GiB size: 322.84 GiB (98.11%)
    used: 285.82 GiB (88.5%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
    uuid: 595d69c8-93d7-4873-9bc6-700f587bd198
  ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
    used: 25.9 MiB (10.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: SYSTEM
    uuid: BA56-3239
  ID-3: /home/<filter>/Cloud/onedrive raw-size: N/A size: 1024 GiB
    used: 260.8 MiB (0.0%) fs: fuse.rclone remote: onedrive:
  ID-4: /home/<filter>/Cloud/uma raw-size: N/A size: 344.63 TiB
    used: 101.14 TiB (29.3%) fs: fuse.rclone remote: uma:
  ID-1: /dev/sda2 maj-min: 8:2 size: 128 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/sda3 maj-min: 8:3 size: 146.48 GiB fs: ext4 label: N/A
    uuid: 234446fd-e4ec-4a67-aea4-53bb8d40071f
  ID-3: /dev/sda5 maj-min: 8:5 size: 1024 MiB fs: ntfs label: Windows_RE
    uuid: 84A857D5A857C3F8
  Device-1: 1-4:2 info: Realtek Bluetooth Radio type: bluetooth
    driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 0cb5:c547 class-ID: e001 serial: <filter>
  Device-1: 3-1:2 info: Pixart Imaging Optical Mouse type: mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1
    chip-ID: 093a:2510 class-ID: 0301
  System Temperatures: cpu: 54.5 C mobo: 0.0 C gpu: amdgpu temp: 43.0 C
  Fan Speeds (rpm): cpu: 0 mobo: 0
  Packages: pm: pacman pkgs: 2319 libs: 383 tools: gnome-software,pamac,yay
    1: https://mirror.init7.net/manjaro/unstable/$repo/$arch
    2: https://manjaro.ipacct.com/manjaro/unstable/$repo/$arch
    3: https://mirror.truenetwork.ru/manjaro/unstable/$repo/$arch
Processes:
  CPU top: 5 of 313
  1: cpu: 32.8% command: brave pid: 7007 mem: 680.5 MiB (4.4%)
  2: cpu: 25.8% command: ghostty pid: 4531 mem: 391.8 MiB (2.5%)
  3: cpu: 20.3% command: brave pid: 7304 mem: 486.3 MiB (3.1%)
  4: cpu: 19.2% command: brave pid: 7110 mem: 494.0 MiB (3.2%)
  5: cpu: 13.5% command: brave pid: 7811 mem: 293.9 MiB (1.9%)
  Memory top: 5 of 313
  1: mem: 680.5 MiB (4.4%) command: brave pid: 7007 cpu: 32.8%
  2: mem: 494.0 MiB (3.2%) command: brave pid: 7110 cpu: 19.2%
  3: mem: 486.3 MiB (3.1%) command: brave pid: 7304 cpu: 20.3%
  4: mem: 410.3 MiB (2.6%) command: brave pid: 7402 cpu: 12.0%
  5: mem: 391.8 MiB (2.5%) command: ghostty pid: 4531 cpu: 25.8%
  Processes: 313 Power: uptime: 6m states: freeze,mem,disk suspend: s2idle
    image: 5.91 GiB services: csd-power,upowerd Init: systemd v: 261
  Compilers: clang: 23.1.1 gcc: 16.2.1 Shell: Zsh v: 5.9.2
    running-in: ghostty inxi: 3.3.41
I found a possibly related upstream issue:
Meanwhile I think the segfault only happens to me with external monitor connected to HDMI cable. Everything fine if connected via cheap hub to usc c port.
Check the issues I just linked above. It sounds like it is indeed related.
How can I know? I do not explicitly have VariableRefresh or TearFree set as far as I can see
❯ grep -iE "(variable|tear)" $(locate org.conf)
grep: /etc/X11/xorg.conf.d: Is a directory
grep: /usr/share/X11/xorg.conf.d: Is a directory
❯ locate org.conf
/etc/X11/xorg.conf.d/00-keyboard.conf
/usr/share/X11/xorg.conf.d/10-amdgpu.conf
/usr/share/X11/xorg.conf.d/10-evdev.conf
/usr/share/X11/xorg.conf.d/10-quirks.conf
/usr/share/X11/xorg.conf.d/10-radeon.conf
/usr/share/X11/xorg.conf.d/40-libinput.conf
/usr/share/X11/xorg.conf.d/50-digimend.conf
/usr/share/X11/xorg.conf.d/70-wacom.conf
/usr/share/man/man5/xorg.conf.5.gz
/usr/share/man/man5/xorg.conf.d.5.gz
/usr/src/digimend-10/xorg.conf
/var/lib/dkms/digimend/10/build/xorg.conf
can someone rebuild xf86-video-amdgpu so we can see?
TL;DR: seems like a silent ABI break happened. Rebuilding xf86-video-amdgpu/xf86-video-ati should mitigate the issue for now.
it is an ABI break between 21.1.25 and the pre-built amdgpu/ati DDX drivers.
Distros rebuild xf86-video-amdgpu and xf86-video-ati against the 21.1.25 headers.
Arch currently ships xf86-video-amdgpu 25.0.0-1 built in 2025-08.
Fabian A
Moderator edit: Merged consecutive replies
I believe Arch is waiting for the related merge request before making any packaging changes.
ok i can wait :slight_smile:
just what unstable means, not a conspiracy to move people to wayland :smiley:
xorg-server 21.1.25-2 seems to fix it, looks like someone was too hasty https:// gitlab.freedesktop. org/xorg/xserver/-/merge_requests/2355
