I a having this issue for a few weeks now, when I logged in the my secondary monitor connected to hdmi is black/no desktop I cant even do right click, but I can move apps there.
Its something like this.
But it will show the desktop if I will re-plugged the hdmi cable. Also sometimes after login its just fine but most the time now I have that problem.
Here is my hardware info.
Kernel: 5.12.19-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64
root=UUID=29e8c1bf-181d-44f6-ba23-d1fd69c09d6d ro quiet apparmor=1
security=apparmor resume=UUID=cfe38a00-9663-4d70-bcf5-993b0345d8a5
udev.log_priority=3 mitigations=off
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: X542UN v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X542UN v: 1.0 serial: <filter>
UEFI: American Megatrends v: X542UN.303 date: 01/05/2018
ID-1: BAT0 charge: 36.6 Wh (98.1%) condition: 37.3/37.3 Wh (100.0%)
volts: 7.6 min: 7.6 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: Not charging cycles: 33
RAM: total: 15.52 GiB used: 3.96 GiB (25.5%)
Info: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
microcode: EA cache: L2: 6 MiB bogomips: 28808
Speed: 722 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 722 2: 1077
3: 765 4: 677 5: 797 6: 726 7: 702 8: 742
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand
rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme
vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf mitigation: PTE Inversion; VMX: vulnerable
Type: mds status: Vulnerable; SMT vulnerable
Type: meltdown status: Vulnerable
Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
usercopy barriers only; no swapgs barriers
Type: spectre_v2 status: Vulnerable, IBPB: disabled, STIBP: disabled
Type: srbds status: Vulnerable
Device-1: Intel UHD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX150] vendor: ASUSTeK driver: nvidia
v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1d10 class-ID: 0302
Device-3: IMC Networks USB2.0 VGA UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-6:4 chip-ID: 13d3:5a01 class-ID: 0e02 serial: <filter>
loaded: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1200 s-dpi: 96 s-size: 1016x317mm (40.0x12.5")
s-diag: 1064mm (41.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
Monitor-2: HDMI-2 res: 1920x1200 hz: 60 dpi: 94 size: 518x324mm (20.4x12.8")
diag: 611mm (24.1")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.1.6
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.12.19-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: no
vendor: ASUSTeK driver: r8169 v: kernel port: d000 bus-ID: 02:00.0
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: AzureWave driver: ath10k_pci v: kernel port: d000 bus-ID: 03:00.0
chip-ID: 168c:0042 class-ID: 0280
IF: wlp3s0 state: down mac: <filter>
Device-1: IMC Networks type: USB driver: btusb v: 0.8 bus-ID: 1-8:5
chip-ID: 13d3:3496 class-ID: e001
Local Storage: total: 1.36 TiB used: 566.87 GiB (40.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS541010B7E610
type: HDD rpm: 5400 serial: <filter> rev: 1A03 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WDS500G2B0B-00YS70 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 00WD
scheme: GPT
Optical-1: /dev/sr0 vendor: Slimtype model: DVD A DA8AESH rev: XAAM
dev-links: cdrom
rw: cd-r,cd-rw,dvd-r state: running
ID-1: / raw-size: 448.39 GiB size: 440.35 GiB (98.21%)
used: 95.81 GiB (21.8%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: 29e8c1bf-181d-44f6-ba23-d1fd69c09d6d
used: 300 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: AB4D-E2CB
ID-3: /hgst raw-size: 931.51 GiB size: 915.89 GiB (98.32%)
used: 471.06 GiB (51.4%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 9112270e-bbd2-4a4e-b067-dd0045d879fe
ID-1: swap-1 type: partition size: 17.07 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdb3 maj-min: 8:19 label: N/A
uuid: cfe38a00-9663-4d70-bcf5-993b0345d8a5
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-1:2 info: Elecom M-HT1DRBK HUGE Wireless Optical TrackBall
type: Mouse driver: elecom,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 98mA chip-ID: 056e:010d class-ID: 0301
Device-2: 1-3:3 info: SINO WEALTH Gaming KB type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 500mA chip-ID: 258a:002a class-ID: 0300
Device-3: 1-6:4 info: IMC Networks USB2.0 VGA UVC WebCam type: Video
Device-4: 1-8:5 info: IMC Networks type: Bluetooth driver: btusb
interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 13d3:3496
class-ID: e001
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 46.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2600
Processes: 244 Uptime: 1h 40m wakeups: 1 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1403
lib: 369 flatpak: 0 Shell: Bash v: 5.1.8 running-in: kitty inxi: 3.3.06
Thanks updated my question
Hi!
I do have the same problem. Does anyone have any ideas? I couldnβt find any hints on the internet.
My Specs:
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=3ce2d119-c2f6-4379-8fe0-63d195f3f711 rw quiet apparmor=1
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Gigabyte product: X570 AORUS ELITE v: -CF
serial: <filter>
Mobo: Gigabyte model: X570 AORUS ELITE v: x.x serial: <filter>
UEFI: American Megatrends v: F10 date: 11/15/2019
Device-1: hidpp_battery_0 model: Logitech MX Keys Wireless Keyboard
status: Discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse MX Master 3
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: Discharging
RAM: total: 31.3 GiB used: 7.6 GiB (24.3%)
Info: 8-Core model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: 0 microcode: 8701013 cache:
L2: 4 MiB bogomips: 115024
Speed: 3765 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
1: 3765 2: 2098 3: 3549 4: 2053 5: 2226 6: 2066 7: 2065 8: 2135 9: 3593
10: 2056 11: 2559 12: 2117 13: 2083 14: 2181 15: 3578 16: 2053
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sev_es sha_ni
skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves
conditional, RSB filling
Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
vendor: Tul driver: amdgpu v: kernel bus-ID: 0b:00.0 chip-ID: 1002:731f
class-ID: 0300
loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
Screen-1: 0 s-res: 5120x1440 s-dpi: 96 s-size: 1354x381mm (53.3x15.0")
s-diag: 1407mm (55.4")
Monitor-1: DisplayPort-0 res: 2560x1440 hz: 60 dpi: 109
size: 597x336mm (23.5x13.2") diag: 685mm (27")
Monitor-2: DisplayPort-1 res: 2560x1440 hz: 60 dpi: 109
OpenGL: renderer: AMD Radeon RX 5700 (NAVI10 DRM 3.41.0 5.13.19-2-MANJARO
LLVM 12.0.1)
v: 4.6 Mesa 21.2.2 direct render: Yes
Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel
bus-ID: 0b:00.1 chip-ID: 1002:ab38 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 0d:00.4 chip-ID: 1022:1487
class-ID: 0403
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.37 running: yes
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
port: f000 bus-ID: 04:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp4s0 state: down mac: <filter>
Device-2: Intel Wireless-AC 9260 driver: iwlwifi v: kernel port: f000
bus-ID: 05:00.0 chip-ID: 8086:2526 class-ID: 0280
IF: wlp5s0 state: up mac: <filter>
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
v: 0.8 bus-ID: 3-6.2:5 chip-ID: 8087:0025 class-ID: e001
Local Storage: total: 1.82 TiB used: 125.97 GiB (6.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Corsair model: Force MP600
lanes: 4 type: SSD serial: <filter> rev: EGFM11.1 temp: 40.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 1TB
type: SSD serial: <filter> rev: 1B6Q scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE BP55EB40 rev: 1.03
dev-links: cdrom
ID-1: / raw-size: 48.83 GiB size: 47.76 GiB (97.81%) used: 10.88 GiB (22.8%)
fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 3ce2d119-c2f6-4379-8fe0-63d195f3f711
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: FA9C-72C8
ID-3: /home raw-size: 845.07 GiB size: 830.73 GiB (98.30%)
used: 115.08 GiB (13.9%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: Home
uuid: bd406c12-3832-4df5-b922-334484ac39d3
ID-1: swap-1 type: partition size: 37.11 GiB used: 4 MiB (0.0%) priority: -2
dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: c2420d30-464d-43d2-b6b0-39b34be01612
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 529 MiB fs: ntfs
label: Wiederherstellung uuid: 58B4901FB48FFE26
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 99 MiB fs: vfat label: N/A
uuid: B090-54C8
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 930.88 GiB fs: ntfs label: N/A
uuid: 7E7C91377C90EAE3
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Hub-2: 1-3:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-4:3 info: Integrated Express IT8297 RGB LED Controller
type: Keyboard driver: hid-generic,usbhid interfaces: 1 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 048d:8297 class-ID: 0301
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Device-1: 3-2:7 info: LG (HLDS) GP08NU6W DVD-RW type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 30mA
chip-ID: 152e:2571 class-ID: 0806 serial: <filter>
Hub-5: 3-6:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 3-6.2:5 info: Intel Wireless-AC 9260 Bluetooth Adapter
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0025 class-ID: e001
Device-2: 3-6.4:6 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-7: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-8: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 46.2 C mobo: 32.0 C gpu: amdgpu temp: 56.0 C
mem: 56.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1472
Processes: 368 Uptime: 9h 14m wakeups: 90 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1227 lib: 332
flatpak: 0 Shell: Bash v: 5.1.8 running-in: yakuake inxi: 3.3.06
JoGerr
23 November 2021 20:43
5
Hi all,
i do have kind of a simillar Problem
My Specs:
ββββββββββββββββββ ββββββββ jffp@jon-fa506QR
ββββββββββββββββββ ββββββββ -----------------
ββββββββββββββββββ ββββββββ OS: Manjaro Linux x86_64
ββββββββββββββββββ ββββββββ Host: ASUS TUF Gaming A15 FA506QR_FA506QR 1.0
ββββββββ ββββββββ Kernel: 5.15.2-2-MANJARO
ββββββββ ββββββββ ββββββββ Uptime: 1 min
ββββββββ ββββββββ ββββββββ Packages: 1412 (pacman)
ββββββββ ββββββββ ββββββββ Shell: bash 5.1.8
ββββββββ ββββββββ ββββββββ Resolution: 1920x1080, 2560x1440
ββββββββ ββββββββ ββββββββ DE: Plasma 5.23.3
ββββββββ ββββββββ ββββββββ WM: KWin
ββββββββ ββββββββ ββββββββ Theme: Breath2 2021 Dark [Plasma], Breeze [GTK2/3]
ββββββββ ββββββββ ββββββββ Icons: We10X [Plasma], We10X [GTK2/3]
ββββββββ ββββββββ ββββββββ Terminal: konsole
CPU: AMD Ryzen 7 5800H with Radeon Graphics (16) @ 3.200GHz
GPU: NVIDIA GeForce RTX 3070 Mobile / Max-Q
GPU: AMD ATI 06:00.0 Cezanne
Memory: 2032MiB / 15463MiB
edit1 Updated to Supported Kernel, did not change stuff BUT my Bluetooth now works
edit2 A complete restart of KDE with:
kquitapp5 plasmashell && kstart5 plasmashell
makes it proper again, but donβt want to do that after every restartβ¦
Wollie
23 November 2021 20:54
6
First, install a kernel being still supported like 5.10 LTS or 5.15. The kernel 5.13 is EOL (no longer supported). Afterwards, reboot and remove 5.13.
gilcon
1 December 2021 02:45
7
Anyone have a solution for this? I am on Kernel 5.14.18 with the same issue.
This wont happen if I disable compositor on start up or using xrandr. but xrandr gives me screen tearing.
It seems using OpenGl for the rendering backend cause this issue.
I had this issue after switching Prime Profile to Intel graphic on nvidia x server settings app. reverting Prime Profile to On-Demand solved the issue.
mskr
3 January 2022 09:13
9
After last updates, the same happen to me. In my case, there was also a problem with Prime.
Running sudo systemctl status optimus-manager
showed me that:
ModuleNotFoundError: No module named 'optimus_manager'
So I reinstalled optimus-manager and run:
sudo systemctl enable optimus-manager
After switching again to Nvidia profile and rebooting, both screens are detected correctly.
