Sd cards and flash drives not showing in Thunar
So I was wanting to transfer some game files from my computer to an sd card. Just like I successfully did last week. But now my computer suddenly isn’t recognizing the card reader. At least not in a way I can use.
(it’s also not recognizing flash drives)
The card shows up in the terminal with
lsblk
fdisk
lsusb
((sorry if that didn’t type as code… This is my first time on here and i’m trying the 3 ` thing. my phone isn’t letting me highlight for some reason so i can’t try that))
Anyway : I can find the card reader in terminal and it works immediately on my mom’s lubuntu laptop but I can’t get it to show up in Thunar.
It did pop up once after several minutes but wouldn’t mount where I could explore the files… until it decided I could look… after buffering alot. When I tried to transfer files I got an “error splicing” message and it went back to being unable to do anything then vanished.
I tested the card on a miyoo a30 and it does work.
The usb slots on my computer ((a mini pc nucbox gmktec g3 with intel… all I could afford)) also work for everything else (I even transferred different files just today via a usb cord).
…though I do remember having issues with flash drives and sd cards on card readers being stubborn back when I was using windows but it stopped after I switched to Manjaro… until now.
I did have other issues with thunar yesterday and today that went away after I updated. Thunar would open but stop responding immediately after opening or as soon as I tried moving a file around. Don’t know if it’s related.
Also last night it failed at transferring a file over usb cord but it worked fine after updating.
So… that’s basically it… I don’t know what’s going on or how to fix it. The card shows up in terminal but won’t show up in Thunar (minus that one glitchy exception) or mount even though it did last week.
I’ve tried mounting it from the terminal as well though maybe I did it wrong or it just didn’t work.
I don’t know if it’s the drivers, thunar, my mini pc, the card reader, or what…
Any help (with detailed instructions preferably) is appreciated.
Have you checked the ‘settings’? Settings / Removable Drives & Media / Storage
And Settings / Desktop / File Launcher Icons
You haven’t included any system info so I’m guessing, but are you running an rc version of the 7 kernel?
udev-usb-sync and kernel 7.0-rc
If you experience slow transfers to USB attached disks, remove the package udev-usb-sync. It is not known why the 7.0-rc kernel causes this. There may be a regression of some sort. Awaiting the final release of the 7.0 kernel before jumping to conclusions.
See [Unstable Update] April 2026 thread for more info
Just quickly, you have rebooted the computer since upgrading, right? :wink:
Please take note of the comment from @bananamangodog:
At this stage Kernel 7 iterations are only release candidates – it is very likely that kernel support for your device is either flaky, or doesn’t exist.
I suggest reverting to kernel 6.18 (LTS) to see if you have better luck. Once kernel 7 is officially released (no longer an “rc”) it may be worth trying it again. Keep in mind that the latest LTS kernel is generally recommended for most cases.
inxi -zv8 (short-form)
Your privacy is respected
@soundofthunder has missed the fun over the past few days. The version 7 kernels in stable, and testing are not release candidates (rc versions) and so you can ignore that part.
Trying the 6.18 LTS kernel is however a great idea; as is supplying us with the output of inxi -zv8 so we have some idea of what we’re trying to diagnose.
@AstralPhnx28
Mentioned in the Unstable Updates announcement thread:
It might be worthwhile applying the suggested temporary workaround and/or watching that topic (and possibly the Testing announcement thread as well) for any updates on the issue, in case it’s related.
Otherwise, I wonder if you have performed an update recently?
As @bananamangodog mentions, kernel 7.0 is now in all branches – perhaps you only need to apply the latest Stable update, which was made available a few days ago.
I just come to tell the result of my test. My favourite usb mounts and the speed is OK just as before. Without removing udev-usb.
XFCE, stable, kernel 7.1.0-rc1-1-MANJARO
I don’t know if any of you who responded will see this but I just wanted to say I’m sorry I didn’t respond at all for so long.
I had an impacted wisdom tooth removed a little over a day after making this post and didn’t get to see or respond to the comments until now.
A small update : I got a new card reader which was recognized immediately by pc. I also tested a new flashdrive and it was recognized.
I don’t know why the old ones were revognized on the lubuntu laptop and not my computer but that’s what happened.
I did have a moment where, after formatting the sd card, thunar stopped recognizing it but gparted did recognize it and I created the smallest partition on the card which made it visible to thunar again.
As for system info : I’m not sure exactly how much is needed.
I’m on 6.18.26-1-Manjaro.
I don’t know what other info to give?
Admittedly I’m one of those “switched to linux because windows annoyed me” people who is still learning.
Generally what is advised here:
If in doubt the output of inxi -zv8.
A formatted SD card would have no partitions for thunar to display
xfce:thunar:using-removable-media [Xfce Docs]
Thunar is able to automatically manage removable drives and media if the thunar-volman package is installed on your system*. To enable this feature, open the file manager Preferences, go to the Advanced tab and check the Enable Volume Management box in the Volume Management section. Finally, click on the Configure link right below that. The Removable Drives and Media configuration dialog shown below will be displayed. The tabs in this dialog are organized by device categories to make it easy to locate the options for your specific device.
* thunar-volman is included on Manjaro Xfce ISOs
The following is my system info. Sorry I was slow to getting it on here. Another update is I’ve started having seemingly random moments where an sd card in my card reader will be visible but I can’t copy anything to it despite it having write permissions. I can copy to the same sd card on other devices however.
  Kernel: 6.18.26-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.18-x86_64
    root=UUID=b4080277-1c7e-434f-a7f6-eccd5776bf36 rw rootflags=subvol=@
    quiet splash apparmor=1 security=apparmor udev.log_priority=3
  Desktop: Xfce v: 4.20.2 tk: Gtk v: 3.24.52 wm: xfwm4 v: 4.20.0
    with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
  Type: N/A System: GMKtec product: NucBox G3 v: N/A
    serial: <superuser required>
  Mobo: GMKtec model: GMKtec serial: <superuser required> part-nu: G3-001
    uuid: <superuser required> Firmware: UEFI vendor: American Megatrends LLC.
    v: GMK_G3 date: 10/10/2024
  Device-1: hidpp_battery_0 model: Logitech ERGO M575 Trackball
    serial: <filter> charge: 90% rechargeable: yes status: discharging
  System RAM: total: 16 GiB available: 15.36 GiB used: 1.39 GiB (9.0%)
  Array-1: capacity: 64 GiB slots: 2 modules: 1 EC: None
  Device-1: Controller0-ChannelA-DIMM0 type: DDR4 detail: synchronous
    size: 16 GiB speed: 3200 MT/s volts: note: check curr: 1 min: 1 max: 1
    width (bits): data: 64 total: 64 manufacturer: 0x0F9B
    part-no: USV4S32C228SP-16C serial: <filter>
  Device-2: Controller1-ChannelA-DIMM0 type: no module installed
  Info: model: Intel N100 bits: 64 type: MCP arch: Alder Lake level: v3
    note: check built: 2021+ process: Intel 7 (10nm ESF) family: 6
    model-id: 0xBE (190) stepping: 0 microcode: 0x21
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 smt: <unsupported> cache:
    L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 1x2 MiB L3: 6 MiB
    desc: 1x6 MiB
  Speed (MHz): avg: 700 min/max: 700/3400 scaling: driver: intel_pstate
    governor: powersave cores: 1: 700 2: 700 3: 700 4: 700 bogomips: 6451
    bts cat_l2 cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid
    f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
    hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt
    ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx monitor movbe
    movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
    pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid
    rdrand rdseed rdt_a rdtscp rep_good sdbg sep serialize sha_ni smap smep
    split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
    tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip
    user_shstk vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave
    xsavec xsaveopt xsaves xtopology xtpr
    conditional; PBRSB-eIBRS: Not affected; BHI: BHI_DIS_S
  Device-1: Intel Alder Lake-N [UHD Graphics] driver: i915 v: kernel
    alternate: xe arch: Xe process: Intel 10nm built: 2020-21 ports:
    active: HDMI-A-2 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:46d1
    class-ID: 0300
  Display: x11 server: X.org v: 1.21.1.22 with: Xwayland v: 24.1.11
    compositor: xfwm4 v: 4.20.0 driver: X: loaded: modesetting
    alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
  Monitor-1: HDMI-A-2 mapped: HDMI-2 model: Kado F16 built: 2024 res:
    mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 141 gamma: 1.2 chroma: red:
    x: 0.651 y: 0.337 green: x: 0.322 y: 0.616 blue: x: 0.157 y: 0.043 white:
    x: 0.314 y: 0.329 size: 345x194mm (13.58x7.64") diag: 396mm (15.6")
    ratio: 16:9 modes: 1920x1080, 1680x1050, 1600x900, 1280x1024, 1440x900,
    1366x768, 1280x720, 1024x768, 800x600, 720x480, 640x480
    device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
    inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 26.0.6-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL-N)
    device-ID: 8086:46d1 memory: 15 GiB unified: yes
    x11: xprop,xrandr
  Device-1: Intel Alder Lake-N PCH High Definition Audio driver: snd_hda_intel
    v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
    chip-ID: 8086:54c8 class-ID: 0403
  Device-2: Zoran Personal Media Division (Nogatech) USB Audio and HID
    driver: snd-usb-audio type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1
    bus-ID: 3-6:5 chip-ID: 0573:1573 class-ID: 0300 serial: <filter>
  API: ALSA v: k6.18.26-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.4 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8852BE PCIe 802.11ax Wireless Network
    driver: rtw89_8852be v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:b852 class-ID: 0280
  Device-2: Intel Ethernet I226-V driver: igc v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 port: N/A bus-ID: 03:00.0 chip-ID: 8086:125c
    class-ID: 0200
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-8:8 chip-ID: 0bda:b85b
  Local Storage: total: 953.87 GiB used: 855.99 GiB (89.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Lexar model: SSD NM6A1 1TB
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 12544 temp: 41.9 C scheme: GPT
  ID-1: / raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
    used: 855.99 GiB (89.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: b4080277-1c7e-434f-a7f6-eccd5776bf36
    used: 664 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 0166-91AF
  ID-3: /home raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
  ID-4: /var/cache raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
  ID-5: /var/log raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-1:2 info: Logitech Unifying Receiver type: keyboard,mouse,HID
    driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
    chip-ID: 046d:c52b class-ID: 0300
  Device-2: 3-2:3 info: Evision RGB Keyboard type: keyboard,mouse
    lanes: 1 mode: 1.1 power: 400mA chip-ID: 320f:505b class-ID: 0301
  Hub-4: 3-3:4 info: Genesys Logic Hub ports: 4 rev: 2.1
  Device-1: 3-6:5 info: Zoran Personal Media Division (Nogatech) USB Audio
    and HID type: audio,HID driver: snd-usb-audio interfaces: 4 rev: 2.0
  Device-2: 3-8:8 info: Realtek Bluetooth Radio type: bluetooth
    driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 0bda:b85b class-ID: e001 serial: <filter>
  Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-6: 4-3:2 info: Genesys Logic Hub ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0626
  System Temperatures: cpu: 46.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: 1484 pm: pacman pkgs: 1412 libs: 396
    tools: gnome-software,pamac,yay pm: flatpak pkgs: 72
    1: https://manjaro.mirrors.uk2.net/stable/$repo/$arch
    2: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
    3: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    4: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    5: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    6: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    7: https://manjaro.grena.ge/stable/$repo/$arch
    8: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 248
  1: cpu: 100% command: ps pid: 10018 mem: 4.02 MiB (0.0%)
  2: cpu: 12.9% command: localsearch-extractor-3 pid: 10000
    mem: 42.0 MiB (0.2%)
  3: cpu: 3.7% command: Xorg pid: 847 mem: 100.3 MiB (0.6%)
  4: cpu: 2.7% command: Thunar pid: 1203 mem: 67.0 MiB (0.4%)
  5: cpu: 2.4% command: xfce4-terminal pid: 9711 mem: 58.1 MiB (0.3%)
  Memory top: 5 of 248
  1: mem: 100.3 MiB (0.6%) command: Xorg pid: 847 cpu: 3.7%
  2: mem: 81.3 MiB (0.5%) command: xfdesktop pid: 1211 cpu: 0.6%
  3: mem: 71.6 MiB (0.4%) command: pamac-daemon pid: 2831 cpu: 0.2%
  4: mem: 67.0 MiB (0.4%) command: Thunar pid: 1203 cpu: 2.7%
  5: mem: 63.2 MiB (0.4%) command: xfwm4 pid: 1138 cpu: 0.4%
  Processes: 248 Power: uptime: 28m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.08 GiB services: upowerd,xfce4-power-manager
    Init: systemd v: 260 default: graphical tool: systemctl
  Compilers: gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: xfce4-terminal
    inxi: 3.3.40
Mod edit: Corrected formatting.
Hi @AstralPhnx28, please see this quick guide on how to post Terminal output:
[Mini How-To] format code or command output
Select and copy all the text in the Terminal window (minus the prompt, if you are using zsh).
Then paste the output in between two lines containing three backticks
or three tildes
Or:
Copy & paste, then highlight the pasted text and click the </> button at the top of the reply window (easier for smaller outputs).
Cheers! :wink:
Did you have the device connected when you ran inxi?
Can you please connect the device(s) and give us the output of lsusb and lsblk?
I’ll have to add multiple terminal outputs because I had a new card reader that seemed to be working but quickly started to have issues with letting me read the sd card.
This first one is with my new card reader which was very slow to read after first few times and even when it did I had trouble trouble transferring files after several times where it worked :
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 002: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 003 Device 003: ID 320f:505b Evision RGB Keyboard
Bus 003 Device 004: ID 05e3:0610 Genesys Logic, Inc. Hub
Bus 003 Device 005: ID 0573:1573 Zoran Co. Personal Media Division (Nogatech) USB Audio and HID
Bus 003 Device 008: ID 0bda:b85b Realtek Semiconductor Corp. Bluetooth Radio
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 004 Device 002: ID 05e3:0626 Genesys Logic, Inc. Hub
Bus 004 Device 004: ID 05e3:0764 Genesys Logic, Inc. USB Storage
❯ lsblk
NAME        MAJ:MIN RM   SIZE RO TYPE MOUNTPOINTS
sda           8:0    1 238.3G  0 disk
├─sda1        8:1    1   512B  0 part
└─sda2        8:2    1 238.3G  0 part /run/media/brownie/B97A-908F
sdb           8:16   1     0B  0 disk
nvme0n1     259:0    0 953.9G  0 disk
├─nvme0n1p1 259:1    0   300M  0 part /boot/efi
└─nvme0n1p2 259:2    0 953.6G  0 part /var/cache
                                      /var/log
                                      /home
This next one will be with the old card reader which sorta showed up in Thunar but failed to mount :
Bus 003 Device 011: ID aaaa:8816 MXT microSD CardReader
❯ lsblk
                                      /var/log
                                      /home
And here’s the complete system info with the more stubborn card reader hooked up :
  System RAM: total: 16 GiB available: 15.36 GiB used: 2.42 GiB (15.8%)
    desc: 1x6 MiB
    class-ID: 0300
    inactive: wayland
    x11: xprop,xrandr
    class-ID: 0200
After my most recent response I tried to shutdown my computer because thunar crashed but I got an error (which I didn’t get a chance to screenshot or take a pic of) which said the computer couldn’t shutdown while something else was going on? (sorry… I didn’t catch all the exact words before the screen went to a loading/shutdown screen where it stayed.
I had to hold down the power button to get it to go off.
Not sure if this is important to the situation but thought I’d add it.
Mod edit: Consecutive posts merged. Please edit the last post to add more information. :wink:
The inxi output is truncated; it’s always better to provide the full output. :wink:
Sorry. I thought it was the full output because it completely stopped. I tested after reading your response and this time it actually completed. Here’s the completed version. (sorry again)
  System RAM: total: 16 GiB available: 15.36 GiB used: 5.3 GiB (34.5%)
    desc: 1x6 MiB
    class-ID: 0300
    inactive: wayland
    x11: xprop,xrandr
    class-ID: 0200
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-8:7 chip-ID: 0bda:b85b
  Local Storage: total: 1.16 TiB used: 804.62 GiB (67.5%)
    lanes: 4 tech: SSD serial: <filter> fw-rev: 12544 temp: 43.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 model: MXT-USB Storage Device size: 238.3 GiB
    block-size: physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s
    lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 1501 scheme: MBR
    used: 804.62 GiB (84.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    uuid: 0166-91AF
  ID-1: /dev/sda1 maj-min: 8:1 size: 0 KiB fs: <superuser required> label: N/A
    uuid: N/A
  ID-2: /dev/sda2 maj-min: 8:2 size: 238.29 GiB fs: <superuser required>
    label: N/A uuid: N/A
  Device-1: 3-3.2:26 info: MXT microSD CardReader type: mass storage
    driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 100mA chip-ID: aaaa:8816 class-ID: 0806
    serial: <filter>
  Device-2: 3-3.4:25 info: Microdia USB KEYBOARD type: keyboard,mouse,HID
    driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 0c45:8009 class-ID: 0300
  Device-3: 3-6:5 info: Zoran Personal Media Division (Nogatech) USB Audio
  Device-4: 3-8:7 info: Realtek Bluetooth Radio type: bluetooth
  System Temperatures: cpu: 49.0 C mobo: N/A
Processes:
  CPU top: 5 of 299
  1: cpu: 40.1% command: firefox pid: 4759 mem: 964.9 MiB (6.1%)
  2: cpu: 19.2% command: firefox pid: 4873 mem: 111.2 MiB (0.7%)
  3: cpu: 12.6% command: pavucontrol pid: 15757 mem: 219.7 MiB (1.3%)
  4: cpu: 10.6% command: Xorg pid: 782 mem: 103.5 MiB (0.6%)
  5: cpu: 4.0% command: zsh pid: 49669 mem: 10.3 MiB (0.0%)
  Memory top: 5 of 299
  1: mem: 964.9 MiB (6.1%) command: firefox pid: 4759 cpu: 40.1%
  2: mem: 633.1 MiB (4.0%) command: firefox pid: 27440 cpu: 1.6%
  3: mem: 599.2 MiB (3.8%) command: firefox pid: 5507 cpu: 0.5%
  4: mem: 560.9 MiB (3.5%) command: firefox pid: 30362 cpu: 0.8%
  5: mem: 547.2 MiB (3.4%) command: firefox pid: 28460 cpu: 1.4%
  Processes: 299 Power: uptime: 3h 41m states: freeze,mem,disk suspend: deep
    inxi: 3.3.40
(oh btw sorry I did 2 separate posts that you had to merge. I was using my phone and it wouldn’t let me edit the first one for some reason…)
No worries. I’m unfortunately needing to do that when I’m out and about, so I know exactly what you’re saying. Post edits on that thing are a nightmare! :wink:
Actually, are you using the Web version of the site? I think some controls may be inaccessible using the Mobile version.
Also, I’ve known inxi to “hang up” for a brief period whilst certain parameters were being fetched. Maybe it was just down to that. :wink:
I’m trying to use the web version when I can. The edit from earlier was due to my computer hanging when I tried to reboot because Thunar crashed so I only had my phone.
