Hello,
I’ve recently installed Manjaro KDE on a brand new pc, but when I try to set the desktop resolution to the max value (3840:2400 16:10) I get some awful screen tearing whenever I move the mouse (staying still doesn’t trigger this). Interestingly, it doesn’t seem to get picked up by the built in screencap, so I can’t get a screenshot to show the effect. I can try with an external tool if that’s needed for more info. How can I fix this?
System information:
Kernel: 5.15.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=c0382431-3b04-4e3b-82d0-8eec3d9f6e2c rw quiet apparmor=1
Desktop: KDE Plasma v: 5.24.4 tk: Qt v: 5.15.3 info: latte-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Dell product: XPS 17 9720 v: N/A
Mobo: Dell model: 0W7GHH v: A00 serial: <superuser required> UEFI: Dell
v: 1.4.0 date: 03/08/2022
ID-1: BAT0 charge: 93.2 Wh (100.0%) condition: 93.2/95.1 Wh (98.0%)
volts: 13.2 min: 11.4 model: SMP DELL 01RR3YM type: Li-poly serial: <filter>
status: full
RAM: total: 31.04 GiB used: 3.47 GiB (11.2%)
RAM Report:
Info: model: 12th Gen Intel Core i9-12900HK bits: 64 type: MST AMCP
arch: Alder Lake family: 6 model-id: 0x9A (154) stepping: 3 microcode: 0x419
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 1295 high: 2787 min/max: 400/6300:6400:3800 scaling:
driver: intel_pstate governor: powersave cores: 1: 612 2: 603 3: 400 4: 768
5: 485 6: 519 7: 456 8: 626 9: 560 10: 594 11: 985 12: 1437 13: 2567
14: 2756 15: 1351 16: 2698 17: 1489 18: 2364 19: 1846 20: 2787
bogomips: 116780
arch_capabilities arch_lbr arch_perfmon art avx avx2 avx_vnni bmi1 bmi2 bts
cat_l2 cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault
cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts
rdpid rdrand rdseed rdt_a rdtscp rep_good sdbg sep serialize sha_ni smap
smep smx split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq
umip vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel Alder Lake-P Integrated Graphics vendor: Dell driver: i915
v: kernel ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, DP-5, HDMI-A-1
bus-ID: 0000:00:02.0 chip-ID: 8086:46a6 class-ID: 0300
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Dell
driver: nvidia v: 510.60.02 alternate: nouveau,nvidia_drm
bus-ID: 0000:01:00.0 chip-ID: 10de:2520 class-ID: 0300
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-6:3 chip-ID: 0c45:6a15 class-ID: 0e02
Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa gpu: i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1600 s-dpi: 96 s-size: 677x423mm (26.65x16.65")
s-diag: 798mm (31.43")
Monitor-1: eDP-1 model: Sharp 0x1517 built: 2021 res: 2560x1600 hz: 60
dpi: 178 gamma: 1.2 size: 366x229mm (14.41x9.02") diag: 432mm (17")
ratio: 16:10 modes: 3840x2400
OpenGL: renderer: Mesa Intel Graphics (ADL GT2) v: 4.6 Mesa 21.3.8
direct render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Dell
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:51c8 class-ID: 0401
Device-2: NVIDIA vendor: Dell driver: snd_hda_intel v: kernel
bus-ID: 0000:01:00.1 chip-ID: 10de:228e class-ID: 0403
Sound Server-1: ALSA v: k5.15.32-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.49 running: yes
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 0000:00:14.3 chip-ID: 8086:51f0 class-ID: 0280
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 1-10:6
chip-ID: 8087:0033 class-ID: e001
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 1.86 TiB used: 19.24 GiB (1.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: PC801 NVMe 2TB
size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 51002141 temp: 41.9 C scheme: GPT
ID-1: / raw-size: 976.56 GiB size: 960.16 GiB (98.32%)
used: 19.14 GiB (2.0%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
label: N/A uuid: c0382431-3b04-4e3b-82d0-8eec3d9f6e2c
ID-2: /boot/efi raw-size: 200 MiB size: 196 MiB (98.00%)
used: 99.5 MiB (50.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: ESP uuid: 2ADE-507B
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 910.43 GiB fs: bitlocker
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 1.01 GiB fs: ntfs
label: WINRETOOLS uuid: 0C5A195C5A1943BC
ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 17.97 GiB fs: ntfs label: Image
uuid: 761C19C11C197CF5
ID-5: /dev/nvme0n1p6 maj-min: 259:6 size: 1.43 GiB fs: ntfs
label: DELLSUPPORT uuid: A026A74726A71D72
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Hub-2: 1-3:2 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2211 class-ID: 0900
Device-1: 1-3.2:5 info: Dell DA20 Adapter type: Billboard driver: N/A
interfaces: 1 rev: 2.1 speed: 12 Mb/s power: 2mA chip-ID: 413c:b080
class-ID: 1100 serial: <filter>
Device-2: 1-6:3 info: Microdia Integrated_Webcam_HD type: Video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-3: 1-9:4 info: Shenzhen Goodix USB2.0 MISC type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 27c6:63ac class-ID: ef00 serial: <filter>
Device-4: 1-10:6 info: Intel type: Bluetooth driver: btusb interfaces: 2
rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0033 class-ID: e001
Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-5: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-6: 5-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-7: 6-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-8: 6-2:2 info: VIA Labs USB3.0 Hub ports: 1 rev: 3.1 speed: 5 Gb/s
chip-ID: 2109:0211 class-ID: 0900
System Temperatures: cpu: 49.0 C mobo: N/A
Processes: 504 Uptime: 4m wakeups: 283 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1268 pacman: 1257 lib: 333
flatpak: 0 snap: 11 Shell: Zsh v: 5.8.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.15
