Hello,
my system has recently stopped booting, and hangs on messages on the black screen while booting. This happened possibly after I installed cuda, so I suspect it has something to do with nvidia GPUs.
I was using kernel 5.18.7-1 due to issues discussed in this topic, where my system information can also be found. Both 5.18 and 5.19rc4-1 fail to boot, while kernel 5.15.50-1 boots succesfully, but causes the issues described in the previous topic, so I would like to restore boot to 5.18. I would also like to keep the nvidia drivers to be able to use CUDA.
I caught an error loading kernel modules while startup, but I don’t know how to access the logs to investigate further or report errors here. Can someone guide me in the right direction and help me troubleshoot?
System info with the working kernel:
Kernel: 5.15.50-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=c0382431-3b04-4e3b-82d0-8eec3d9f6e2c rw quiet apparmor=1
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.5 info: latte-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Dell product: XPS 17 9720 v: N/A
Mobo: Dell model: 0W7GHH v: A00 serial: <superuser required> UEFI: Dell
v: 1.4.0 date: 03/08/2022
ID-1: BAT0 charge: 87.9 Wh (100.0%) condition: 87.9/95.1 Wh (92.4%)
volts: 13.2 min: 11.4 model: SMP DELL 01RR3YM type: Li-poly serial: <filter>
status: full
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 3
status: discharging
RAM: total: 31.04 GiB used: 6.25 GiB (20.1%)
RAM Report:
Info: model: 12th Gen Intel Core i9-12900HK bits: 64 type: MST AMCP
arch: Alder Lake gen: core 12 built: 2021 process: Intel 7 (10nm ESF)
family: 6 model-id: 0x9A (154) stepping: 3 microcode: 0x41C
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 617 high: 928 min/max: 400/6300:6400:3800 scaling:
driver: intel_pstate governor: powersave cores: 1: 530 2: 556 3: 481 4: 928
5: 442 6: 722 7: 463 8: 567 9: 563 10: 720 11: 444 12: 440 13: 525 14: 687
15: 501 16: 729 17: 861 18: 842 19: 817 20: 531 bogomips: 116780
arch_capabilities arch_lbr arch_perfmon art avx avx2 avx_vnni bmi1 bmi2 bts
cat_l2 cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault
cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts
rdpid rdrand rdseed rdt_a rdtscp rep_good sdbg sep serialize sha_ni smap
smep smx split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq
umip vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel Alder Lake-P Integrated Graphics vendor: Dell driver: i915
v: kernel arch: Gen12.2 process: Intel 10nm built: 2021-22+ ports:
active: DP-5,eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1
bus-ID: 0000:00:02.0 chip-ID: 8086:46a6 class-ID: 0300
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Dell
driver: nvidia v: 515.57 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Ampere process: TSMC n7 (7nm)
built: 2020-22 bus-ID: 0000:01:00.0 chip-ID: 10de:2520 class-ID: 0300
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-6:3 chip-ID: 0c45:6a15 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,nv,vesa
gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 7680x2400 s-dpi: 96 s-size: 2032x635mm (80.00x25.00")
s-diag: 2129mm (83.82")
Monitor-1: DP-5 pos: primary,bottom-r model: Samsung U28E570
serial: <filter> built: 2020 res: 3840x2160 hz: 60 dpi: 160 gamma: 1.2
size: 608x345mm (23.94x13.58") diag: 699mm (27.5") ratio: 16:9 modes:
max: 3840x2160 min: 720x400
Monitor-2: eDP-1 pos: primary,top-left model: Sharp 0x1517 built: 2021
res: 3840x2400 hz: 60 dpi: 266 gamma: 1.2 size: 366x229mm (14.41x9.02")
diag: 432mm (17") ratio: 16:10 modes: 3840x2400
OpenGL: renderer: Mesa Intel Graphics (ADL GT2) v: 4.6 Mesa 22.1.2
direct render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Dell
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 1-2.1:5
chip-ID: 17a0:0310 bus-ID: 0000:00:1f.3 class-ID: 0300 chip-ID: 8086:51c8
class-ID: 0401
Device-2: NVIDIA vendor: Dell driver: snd_hda_intel v: kernel
bus-ID: 0000:01:00.1 chip-ID: 10de:228e class-ID: 0403
Device-3: Samson Meteor condenser microphone type: USB
driver: hid-generic,snd-usb-audio,usbhid
Sound Server-1: ALSA v: k5.15.50-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 16.1 running: no
Sound Server-4: PipeWire v: 0.3.52 running: yes
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 0000:00:14.3 chip-ID: 8086:51f0 class-ID: 0280
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 1-10:6
chip-ID: 8087:0033 class-ID: e001
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 1.86 TiB used: 49.13 GiB (2.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: PC801 NVMe 2TB
size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 51002141 temp: 47.9 C scheme: GPT
ID-1: / raw-size: 976.56 GiB size: 960.16 GiB (98.32%)
used: 49.03 GiB (5.1%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
label: N/A uuid: c0382431-3b04-4e3b-82d0-8eec3d9f6e2c
ID-2: /boot/efi raw-size: 200 MiB size: 196 MiB (98.00%)
used: 99.5 MiB (50.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: ESP uuid: 2ADE-507B
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 910.43 GiB fs: bitlocker
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 1.01 GiB fs: ntfs
label: WINRETOOLS uuid: 0C5A195C5A1943BC
ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 17.97 GiB fs: ntfs label: Image
uuid: 761C19C11C197CF5
ID-5: /dev/nvme0n1p6 maj-min: 259:6 size: 1.43 GiB fs: ntfs
label: DELLSUPPORT uuid: A026A74726A71D72
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Hub-2: 1-2:2 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2211 class-ID: 0900
Device-1: 1-2.1:5 info: Samson Meteor condenser microphone type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 17a0:0310 class-ID: 0300
Device-2: 1-2.2:7 info: Dell DA20 Adapter type: Billboard driver: N/A
interfaces: 1 rev: 2.1 speed: 12 Mb/s power: 2mA chip-ID: 413c:b080
class-ID: 1100 serial: <filter>
Device-3: 1-6:3 info: Microdia Integrated_Webcam_HD type: Video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-4: 1-9:4 info: Shenzhen Goodix USB2.0 MISC type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 27c6:63ac class-ID: ef00 serial: <filter>
Device-5: 1-10:6 info: Intel type: Bluetooth driver: btusb interfaces: 2
rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0033 class-ID: e001
Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-5: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-6: 4-1:2 info: VIA Labs USB3.0 Hub ports: 1 rev: 3.1 speed: 5 Gb/s
chip-ID: 2109:0211 class-ID: 0900
Hub-7: 5-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-8: 6-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 51.0 C mobo: N/A
Processes: 525 Uptime: 14m wakeups: 653 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.0 alt: 11
clang: 13.0.1 Packages: 1355 pacman: 1344 lib: 347 flatpak: 0 snap: 11
Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.19
Let me know if additional information or action is needed. Thanks!
