I don’t know if the problem is with the graphics card, the GPU driver or what it may be, but the screen flickers in the upper left, at the moment it only happens to me in the google-chrome browser and it doesn’t work at all the webs, in windows 10 it does not happen to me. I have reinstalled google-chrome, but it keeps happening. I appreciate all the comments, but please don’t tell me to use another browser, I already use firefox and chromium.
(upload://pri1KOl9di7f9K3xKcvH8ruxdcf.png)
Neither we can know, so please share from terminal:
inxi -Fxza --no-host
Use ``` above and bellow that test for proper formatting when you paste it here.
I can’t answer, because I get this message:
Sorry, you cannot include links in your posts.
just copy the results and paste them in between ``` above and below the pasted text or use the </> button.
That is what I have done, but I get this message:
I have taken a screenshot of my screen, to be able to publish what you ask, but I get this message:
Sorry, you can’t embed media items in a post.
Help please, what can I do?
Paste the output terminal text in here for
anon89812132:
I paste it where? and how, because I already said that he won’t let me.
Exactly as you type a text, just for proper formatting you add ``` above and bellow it. There should be no issue with that.
mlpbcn
30 August 2020 08:41
11
It continues without leaving me, as if I did not have permissions, in the forum that there was before, I could do it without problem, but in this I do not know what happens that I can not.
mlpbcn
31 August 2020 05:29
12
Can you check my account, to check that I can paste the content of my screen and add screenshots? Thank you.
mlpbcn
1 September 2020 06:04
13
No one from the Manjaro team is going to help me?
Have you already checked why I can’t publish images or the result of the mmi terminal commands?
Sorry that my presence here was unhelpful so far. Now it seems we have X -Y problem …
We did not asked for screenshots.
You copy the text from terminal and you paste it here. Is exactly like a text. You can write text, right?
We do not want terminal output as images! We need them as text.
mlpbcn
1 September 2020 06:21
15
I can write text, but I can’t copy text.
mlpbcn
1 September 2020 06:22
16
System: Kernel: 5.8.3-2-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=9144410b-9b1b-48b5-909b-0195a8dd1f94 rw apparmor=1
Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0 wm: kwin_x11 dm:
SDDM Distro: Manjaro Linux
Machine: Type: Desktop Mobo: ASUSTeK model: ROG CROSSHAIR VIII HERO v:
Rev X.0x serial: UEFI: American Megatrends
v: 2206 date: 08/13/2020
Battery: Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard
serial: charge: 55% (should be ignored)
rechargeable: yes status: Discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse
CPU: Topology: 12-Core model: AMD Ryzen 9 3900X bits: 64 type: MT
MCP arch: Zen 2 family: 17 (23) model-id: 71 (113)
stepping: N/A microcode: 8701021 L2 cache: 6144 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a
ssse3 svm bogomips: 182123
mlpbcn
1 September 2020 06:23
17
Speed: 3605 MHz min/max: 2200/3800 MHz boost: enabled Core
speeds (MHz): 1: 3611 2: 3593 3: 3594 4: 3519 5: 3640
6: 3589 7: 4324 8: 3591 9: 3590 10: 3593 11: 3595 12: 3626
13: 3871 14: 4138 15: 4285 16: 3913 17: 3426 18: 3515
19: 3529 20: 4125 21: 3612 22: 3713 23: 3878 24: 4001
Type: spec_store_bypass mitigation: Speculative Store Bypass
disabled via prctl and seccomp
Type: spectre_v1 mitigation: usercopy/swapgs barriers and
__user pointer sanitization
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB:
conditional, STIBP: conditional, RSB filling
mlpbcn:
You should be able to copy any text from any program you have installed, including from Terminal.
Please do not cut down the inxi -Fxza --no-host
Provide it entirely as is …
Please send a PM to @discobot and type @discobot display help that in the message, and make the steps of the tutorial how to use the forum. Like this is impossible to have a dialog. Don’t take it derogatory. Have a good day!
mlpbcn
1 September 2020 06:29
19
kwin_x11 driver:
amdgpu FAILED: ati unloaded: modesetting,radeon
alternate: fbdev,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm
(20.0x11.2") s-diag: 582mm (22.9")
Monitor-1: DisplayPort-2 res: 1920x1080 hz: 60 dpi: 102
size: 477x268mm (18.8x10.6") diag: 547mm (21.5")
OpenGL: renderer: AMD Radeon RX 5700 (NAVI10 DRM 3.38.0
5.8.3-2-MANJARO LLVM 10.0.1) v: 4.6 Mesa 20.1.6
direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 HDMI Audio
driver: snd_hda_intel v: kernel bus ID: 0b:00.1
chip ID: 1002:ab38
Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD
Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 0d:00.4 chip ID: 1022:1487
Sound Server: ALSA v: k5.8.3-2-MANJARO
Network: Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver:
r8169 v: kernel port: e000 bus ID: 04:00.0
chip ID: 10ec:8125
IF: enp4s0 state: down mac:
Device-2: Intel I211 Gigabit Network vendor: ASUSTeK driver:
igb v: 5.6.0-k port: d000 bus ID: 05:00.0
chip ID: 8086:1539
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac:
Drives: Local Storage: total: 13.66 TiB used: 8.30 TiB (60.7%)
SMART Message: Unable to run smartctl. Root privileges
required.
ID-1: /dev/nvme0n1 vendor: Gigabyte model: GP-ASM2NE6100TTTD
size: 931.51 GiB block size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 serial:
rev: EGFM11.3 scheme: GPT
ID-2: /dev/sda vendor: Seagate model: ST3000DM001-1ER166
size: 2.73 TiB block size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s rotation: 7200 rpm serial: rev:
CC25 scheme: GPT
ID-3: /dev/sdb vendor: Western Digital model:
WD20EARX-00PASB0 size: 1.82 TiB block size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s serial: rev: AB51
scheme: GPT
ID-4: /dev/sdc vendor: Seagate model: ST8000DM004-2CX188
size: 7.28 TiB block size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s rotation: 5425 rpm serial: rev:
0001 scheme: GPT
ID-5: /dev/sdd vendor: Samsung model: SSD 850 PRO 256GB
size: 238.47 GiB block size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s serial: rev: 4B6Q scheme: GPT
ID-6: /dev/sde vendor: Toshiba model: MQ01ABD075 size:
698.64 GiB block size: physical: 512 B logical: 512 B
speed: 3.0 Gb/s rotation: 5400 rpm serial: rev: 4M
scheme: GPT
ID-7: /dev/sdf type: USB vendor: SanDisk model: Ultra Fit
size: 14.32 GiB block size: physical: 512 B
logical: 512 B serial: rev: 1.00 scheme: MBR
SMART Message: Unknown USB bridge. Flash drive/Unsupported
enclosure?
Partition: ID-1: / raw size: 55.00 GiB size: 54.97 GiB (99.95%) used:
22.77 GiB (41.4%) fs: xfs dev: /dev/nvme0n1p6
ID-2: /home raw size: 410.46 GiB size: 410.26 GiB (99.95%)
used: 226.10 GiB (55.1%) fs: xfs dev: /dev/nvme0n1p7
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 49.5 C mobo: N/A gpu: amdgpu temp:
38 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Info: Processes: 502 Uptime: 9h 28m Memory: 31.34 GiB used: 3.55
GiB (11.3%) Init: systemd v: 246 Compilers: gcc: 10.2.0
Packages: 1624 pacman: 1590 lib: 402 flatpak: 22 snap: 12
Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
mlpbcn
1 September 2020 06:33
20
Some lines are missing referring to the model of the graphics card, which is an Asus ROG Strix Radeon RX 5700 OC 8GB GDDR6, which are the ones that give me the error message.
