Hi,
Created a new thread as this one was already closed and can’t be replied to.
I had the same problem with OP, and applied the same configuration as suggested. But following a reboot, I lost display on my second monitor. Any help is greatly appreciated.
System: Kernel: 5.8.6-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/vmlinuz-5.8-x86_64 root=/dev/mapper/VolGroup00-lvolroot rw quiet
udev.log_priority=3
Desktop: i3 4.18.2 info: i3bar dm: LightDM 1.30.0 Distro: Manjaro Linux
Machine: Type: Desktop Mobo: Micro-Star model: B450 TOMAHAWK MAX (MS-7C02) v: 1.0 serial: <filter>
UEFI [Legacy]: American Megatrends v: 3.70 date: 06/09/2020
CPU: Topology: 6-Core model: AMD Ryzen 5 3600X bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: N/A microcode: 8701021 L2 cache: 3072 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 91245
Speed: 3597 MHz min/max: 2200/3800 MHz boost: enabled Core speeds (MHz): 1: 3602 2: 2055
3: 2194 4: 2194 5: 2057 6: 2200 7: 2199 8: 2199 9: 3544 10: 2062 11: 2123 12: 2200
Type: spectre_v2
mitigation: Full AMD retpoline, IBPB: conditional, STIBP: conditional, RSB filling
Graphics: Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] vendor: ASUSTeK
driver: amdgpu v: kernel bus ID: 28:00.0 chip ID: 1002:731f
Display: x11 server: X.Org 1.20.8 driver: amdgpu display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: DisplayPort-1 res: 1920x1080 hz: 75 dpi: 102 size: 480x270mm (18.9x10.6")
diag: 551mm (21.7")
OpenGL: renderer: AMD Radeon RX 5700 XT (NAVI10 DRM 3.38.0 5.8.6-1-MANJARO LLVM 10.0.1)
v: 4.6 Mesa 20.1.7 direct render: Yes
Audio: Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel bus ID: 28:00.1
chip ID: 1002:ab38
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus ID: 2a:00.4 chip ID: 1022:1487
Device-3: Logitech G930 type: USB driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-8:3
chip ID: 046d:0a1f
Sound Server: ALSA v: k5.8.6-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI
driver: r8169 v: kernel port: f000 bus ID: 22:00.0 chip ID: 10ec:8168
IF: enp34s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives: Local Storage: total: 4.79 TiB used: 112.12 GiB (2.3%)
ID-1: /dev/nvme0n1 vendor: Intel model: SSDPEKNW010T8 size: 953.87 GiB block size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 002C
scheme: MBR
ID-2: /dev/sda vendor: Western Digital model: WD40EZRZ-19GXCB0 size: 3.64 TiB block size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter>
rev: 0A80 scheme: GPT
ID-3: /dev/sdb vendor: SanDisk model: SDSSDA240G size: 223.57 GiB block size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 80RL scheme: MBR
Partition: ID-1: / raw size: 32.00 GiB size: 31.25 GiB (97.65%) used: 9.60 GiB (30.7%) fs: ext4
dev: /dev/dm-0
ID-2: /boot raw size: 256.0 MiB size: 252.0 MiB (98.46%) used: 195.1 MiB (77.4%) fs: vfat
dev: /dev/sdb1
ID-3: /home raw size: 191.32 GiB size: 187.81 GiB (98.17%) used: 102.34 GiB (54.5%)
fs: ext4 dev: /dev/dm-1
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 44.8 C mobo: N/A gpu: amdgpu temp: 42 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Info: Processes: 283 Uptime: 11m Memory: 15.65 GiB used: 1.67 GiB (10.7%) Init: systemd v: 246
Compilers: gcc: 10.2.0 Packages: pacman: 1109 lib: 306 Shell: Bash v: 5.0.18
running in: kitty inxi: 3.1.05
I’m not sure why but the issue is fixed after another reboot. Here’s the relevant for inxi/graphics portion of my working config.
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] vendor: ASUSTeK
Display: x11 server: X.Org 1.20.9 driver: amdgpu display ID: :0 screens: 1
Screen-1: 0 s-res: 4480x1440 s-dpi: 96 s-size: 1185x381mm (46.7x15.0") s-diag: 1245mm (49")
Monitor-1: DisplayPort-1 res: 1920x1080 hz: 75 dpi: 102 size: 480x270mm (18.9x10.6") diag: 551mm (21.7")
Monitor-2: DisplayPort-2 res: 2560x1440 hz: 144 dpi: 109 size: 597x336mm (23.5x13.2") diag: 685mm (27")
OpenGL: renderer: AMD Radeon RX 5700 XT (NAVI10 DRM 3.38.0 5.8.11-1-MANJARO LLVM 10.0.1) v: 4.6 Mesa 20.1.8
direct render: Yes
Fabby
3 October 2020 07:45
4
So the issue fixed itself after 2 reboots instead of a single one?
