Screen flickers
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 [Radeon RX
5600 OEM/5600 XT / 5700/5700 XT] vendor: ASUSTeK
driver: amdgpu v: kernel bus ID: 0b:00.0
chip ID: 1002:731f Display: x11 server: X. Org 1.20.8
The problem was in X. Org I have solved it by separating org from.
I apologize if I have bothered someone, when I have complained because I did not see a solution by not seeing responses from anyone at some point.
We are all volunteers here. Not receiving a reply was due the lack of you providing the information we requested. Now is all over the places …
The only one bothered here seems to be you. have patience that now someone will take a look at what you provided so far, put it back together so they can understand what is going on, then give an informed advice.
@mlpbcn Keep in mind that all the people here are doing this in their spare time, so do not expect immediate help and give everyone some time to read things.
In addition the way you post is a little irritating. Currently you have 19 posts in this thread. @anon89812132 has asked you to provide the output of your terminal and explained how to do it. I will give it another try:
Please mark the whole text output of that terminal command with your mouse, right click, copy, then paste it here and format it using the </> button you have available when adding a post.
I apologize again.
System:    Kernel: 5.8.3-2-MANJARO x86_64 bits: 64 compiler: N/A
            parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=9144410b-9b1b-48b5-909b-0195a8dd1f94 rw apparmor=1
            Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0 wm: kwin_x11 dm:
SDDM Distro: Manjaro Linux
Machine:   Type: Desktop Mobo: ASUSTeK model: ROG CROSSHAIR VIII HERO v:
Rev X.0x serial: <filter> UEFI: American Megatrends
            v: 2206 date: 08/13/2020
Battery:   Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard
serial: <filter> charge: 55% (should be ignored)
            rechargeable: yes status: Discharging
            Device-2: hidpp_battery_1 model: Logitech Wireless Mouse
CPU:       Topology: 12-Core model: AMD Ryzen 9 3900X bits: 64 type: MT
MCP arch: Zen 2 family: 17 (23) model-id: 71 (113)
            stepping: N/A microcode: 8701021 L2 cache: 6144 KiB
            flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a
ssse3 svm bogomips: 182123
            Speed: 3605 MHz min/max: 2200/3800 MHz boost: enabled Core
speeds (MHz): 1: 3611 2: 3593 3: 3594 4: 3519 5: 3640
            6: 3589 7: 4324 8: 3591 9: 3590 10: 3593 11: 3595 12: 3626
13: 3871 14: 4138 15: 4285 16: 3913 17: 3426 18: 3515
            19: 3529 20: 4125 21: 3612 22: 3713 23: 3878 24: 4001
            Type: spec_store_bypass mitigation: Speculative Store Bypass
disabled via prctl and seccomp
            Type: spectre_v1 mitigation: usercopy/swapgs barriers and
__user pointer sanitization
            Type: spectre_v2 mitigation: Full AMD retpoline, IBPB:
conditional, STIBP: conditional, RSB filling
            driver: amdgpu v: kernel bus ID: 0b:00.0 chip ID: 1002:731f
            Display: x11 server: X. Org 1.20.8 compositor: kwin_x11
driver: amdgpu FAILED: ati unloaded: modesetting,radeon
            alternate: fbdev,vesa display ID: :0 screens: 1
            Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm
(20.0x11.2") s-diag: 582mm (22.9")
            Monitor-1: DisplayPort-2 res: 1920x1080 hz: 60 dpi: 102
size: 477x268mm (18.8x10.6") diag: 547mm (21.5")
            OpenGL: renderer: AMD Radeon RX 5700 (NAVI10 DRM 3.38.0
5.8.3-2-MANJARO LLVM 10.0.1) v: 4.6 Mesa 20.1.6
            direct render: Yes
Audio:     Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 HDMI Audio
driver: snd_hda_intel v: kernel bus ID: 0b:00.1
            chip ID: 1002:ab38
            Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD
Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
            bus ID: 0d:00.4 chip ID: 1022:1487
            Sound Server: ALSA v: k5.8.3-2-MANJARO
Network:   Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver:
r8169 v: kernel port: e000 bus ID: 04:00.0
            chip ID: 10ec:8125
            IF: enp4s0 state: down mac: <filter>
            Device-2: Intel I211 Gigabit Network vendor: ASUSTeK driver:
igb v: 5.6.0-k port: d000 bus ID: 05:00.0
            chip ID: 8086:1539
            IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac:
<filter>
Drives:    Local Storage: total: 13.66 TiB used: 8.30 TiB (60.7%)
            SMART Message: Unable to run smartctl. Root privileges
required.
            ID-1: /dev/nvme0n1 vendor: Gigabyte model: GP-ASM2NE6100TTTD
size: 931.51 GiB block size: physical: 512 B
            logical: 512 B speed: 63.2 Gb/s lanes: 4 serial: <filter>
rev: EGFM11.3 scheme: GPT
            ID-2: /dev/sda vendor: Seagate model: ST3000DM001-1ER166
size: 2.73 TiB block size: physical: 4096 B logical: 512 B
            speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev:
CC25 scheme: GPT
            ID-3: /dev/sdb vendor: Western Digital model:
WD20EARX-00PASB0 size: 1.82 TiB block size: physical: 4096 B
            logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: AB51
scheme: GPT
            ID-4: /dev/sdc vendor: Seagate model: ST8000DM004-2CX188
size: 7.28 TiB block size: physical: 4096 B logical: 512 B
            speed: 6.0 Gb/s rotation: 5425 rpm serial: <filter> rev:
0001 scheme: GPT
            ID-5: /dev/sdd vendor: Samsung model: SSD 850 PRO 256GB
size: 238.47 GiB block size: physical: 512 B logical: 512 B
            speed: 6.0 Gb/s serial: <filter> rev: 4B6Q scheme: GPT
            ID-6: /dev/sde vendor: Toshiba model: MQ01ABD075 size:
698.64 GiB block size: physical: 512 B logical: 512 B
            speed: 3.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 4M
scheme: GPT
            ID-7: /dev/sdf type: USB vendor: SanDisk model: Ultra Fit
size: 14.32 GiB block size: physical: 512 B
            logical: 512 B serial: <filter> rev: 1.00 scheme: MBR
            SMART Message: Unknown USB bridge. Flash drive/Unsupported
enclosure?
Partition: ID-1: / raw size: 55.00 GiB size: 54.97 GiB (99.95%) used:
22.77 GiB (41.4%) fs: xfs dev: /dev/nvme0n1p6
            ID-2: /home raw size: 410.46 GiB size: 410.26 GiB (99.95%)
used: 226.10 GiB (55.1%) fs: xfs dev: /dev/nvme0n1p7
Swap:      Alert: No Swap data was found.
Sensors:   System Temperatures: cpu: 49.5 C mobo: N/A gpu: amdgpu temp:
38 C
            Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Info:      Processes: 502 Uptime: 9h 28m Memory: 31.34 GiB used: 3.55
GiB (11.3%) Init: systemd v: 246 Compilers: gcc: 10.2.0
            Packages: 1624 pacman: 1590 lib: 402 flatpak: 22 snap: 12
Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
Note: Ahora esta bien formateado el texto!
Create this file if doesn’t exist:
/etc/X11/xorg.conf.d/20-amdgpu.conf
Please check first in Dolphin if that file exists, and add this lines to it:
Section "Device"
        Identifier "AMD"
        Driver "amdgpu"
        Option "TearFree" "true"
EndSection
If it doesn’t exist, create it like this from terminal:
sudo touch /etc/X11/xorg.conf.d/20-amdgpu.conf
Then
kate /etc/X11/xorg.conf.d/20-amdgpu.conf
Once you modify it, save it and reboot the system.
That’s it, now it works fine. Many thanks.
The file did not exist, I have created it following your instructions and that’s it, now it works fine. Many thanks.
