Screen flickering issue with NVIDIA graphics card
My screen flickers.
It happens when the screen is turned on after being off for a while and also after boot/startup. I have a nvidia GTX 1650 and my kernal is linux58(i just updated).
EDIT: I have night color on.
Hello,
Is this a Laptop or Desktop PC? Please provide:
inxi -Fxza --no-host
mhwd -li
and if is a desktop pc also provide:
cat /etc/X11/mhwd.d/nvidia.conf
Hey , I have the same issue and same gpu .
Mine is a laptop ( asus tuf fx505dt) .
Here is the output :
   Kernel: 5.8.11-1-MANJARO x86_64 bits: 64 compiler: N/A
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
  root=UUID=662bbf43-65eb-4a90-b1d3-e4c377c258d0 rw quiet apparmor=1
  security=apparmor resume=UUID=71f15591-4215-4ccf-9cb3-8c8169941782
  udev.log_priority=3
  Desktop: GNOME 3.36.6 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.36.3
  Distro: Manjaro Linux
  Type: Laptop System: ASUSTeK product: TUF Gaming FX505DT_FX505DT v: 1.0
  serial: <filter>
  Mobo: ASUSTeK model: FX505DT v: 1.0 serial: <filter>
  UEFI: American Megatrends v: FX505DT.310 date: 12/24/2019
  ID-1: BAT0 charge: 7.3 Wh condition: 37.3/48.2 Wh (77%) volts: 10.9/11.9
  model: FX50442 type: Li-ion serial: N/A status: Discharging
  Topology: Quad Core model: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx
  bits: 64 type: MT MCP arch: Zen+ family: 17 (23) model-id: 18 (24)
  stepping: 1 microcode: 8108102 L2 cache: 2048 KiB
  bogomips: 33551
  Speed: 1301 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz):
  1: 1350 2: 1323 3: 1292 4: 1228 5: 1261 6: 1209 7: 1225 8: 1282
  disabled, RSB filling
  Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK
  driver: nvidia v: 450.66 alternate: nouveau,nvidia_drm bus ID: 01:00.0
  chip ID: 10de:1f91
  Device-2: AMD Picasso vendor: ASUSTeK driver: amdgpu v: kernel
  bus ID: 05:00.0 chip ID: 1002:15d8
  Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
  bus ID: 3-1:2 chip ID: 13d3:56a2 serial: <filter>
  Display: x11 server: X.org 1.20.9 compositor: gnome-shell
  driver: amdgpu,ati,nvidia unloaded: modesetting,nouveau,radeon
  alternate: fbdev,nv,vesa resolution: <xdpyinfo missing>
  OpenGL: renderer: AMD RAVEN (DRM 3.38.0 5.8.11-1-MANJARO LLVM 10.0.1)
  v: 4.6 Mesa 20.1.8 direct render: Yes
  Device-1: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
  v: kernel bus ID: 05:00.6 chip ID: 1022:15e3
  Sound Server: ALSA v: k5.8.11-1-MANJARO
  vendor: ASUSTeK driver: r8169 v: kernel port: e000 bus ID: 02:00.0
  chip ID: 10ec:8168
  Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
  vendor: AzureWave driver: rtw_8822ce v: N/A modules: rtw88_8822ce
  port: c000 bus ID: 04:00.0 chip ID: 10ec:c822
  IF: wlp4s0 state: up mac: <filter>
  Local Storage: total: 1.14 TiB used: 18.53 GiB (1.6%)
  ID-1: /dev/nvme0n1 vendor: Kingston model: RBUSNS8154P3256GJ3
  size: 238.47 GiB block size: physical: 512 B logical: 512 B
  speed: 15.8 Gb/s lanes: 2 serial: <filter> rev: E8FK11.T scheme: GPT
  ID-2: /dev/sda vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB
  block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
  rotation: 5400 rpm serial: <filter> rev: SDM4 scheme: GPT
  ID-1: / raw size: 229.37 GiB size: 224.77 GiB (97.99%)
  used: 15.62 GiB (6.9%) fs: ext4 dev: /dev/nvme0n1p2
  ID-1: swap-1 type: partition size: 8.80 GiB used: 2.91 GiB (33.0%)
  priority: -2 dev: /dev/nvme0n1p3
  System Temperatures: cpu: 45.6 C mobo: N/A gpu: amdgpu temp: 45 C
  Fan Speeds (RPM): cpu: 2400
  Processes: 379 Uptime: 4h 18m Memory: 5.80 GiB used: 4.18 GiB (72.0%)
  Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1277
  lib: 340 flatpak: 0 Shell: Zsh v: 5.8 running in: gnome-terminal
  inxi: 3.1.05
Hi!
I have the same laptop and had the same problem in kde and i3. I was able to fix it follow this thread
Tearing nvidia
  1. In the future, when providing code/output, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text so that the output looks like this:
    Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua.
    Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat.
    Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur.
    Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.
    instead of like this:
    Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.
    (as that makes our life much easier so you get helped more quickly and efficiently)
  2. No need to do anything right now as I’m an editor here on this site and have fixed it for you already. However, in the future I might not see your post so review my edits by pushing the orange pencil above the post I just fixed. :wink:
Thanks . I will surely remember that :smiley:
No worries! We live and we learn… :+1:
Did @visone 's advice work out for you?
Hi @Fabby, I have same laptop (Asus fx505dt) with same configuration.
I also got the same issue. After trying bunch of different methods. I just removed non-free drivers video-hybrid-amd-nvidia-450xx-prime and started using free drivers video-linux .
Everything works fine now.
Also, method mentioned by @visone did not work for me, It gives error ‘cannot start SDDM’ at start.
Thank you for the feed-back, but @TheEpicProgrammer is the person that should confirm your answer works for him/her too…
:man_shrugging:
@Fabby that’s alright. I just wanted to confirm if solution works with everyone.
Also, The solution I gave above does not work in all conditions. I apologize for that.
I just found the solution here on forums that works and I have thoroughly tested it.
Please check point 4.0 Suspend Issues.
If someone is having same problem, please let me know.
Hey first of all apologies for late replies ,
No it is not workinng I am getting the same issues again & again .
@ashu
:point_up_2: :pray: :bowing_man:
also for an update : the issue gets resolved if I switch to nvidia 440.x.x.x. but the system automatically upgrades itself to 450+.x.x. and that causes the issue again and again
I’m on the 440 series (have a look at my profile why) and that’s rock stable and does not upgrade itself to the 450 series automatically.
What’s the output of:
mhwd --listinstalled
:thinking:
video-hybrid-amd-nvidia-440xx-prime            2020.10.04               false            PCI
           video-linux            2018.05.04                true            PCI
Hrmpf. That’s good!
How did you install those?
mhwd --install pci video-hybrid-amd-nvidia-440xx-prime
:question: :thinking:
Note: I’m on
> Installed PCI configs:
    video-nvidia-440xx            2020.10.04               false            PCI
And that one doesn’t upgrade to 450… :upside_down_face:
I install those from harware configuration settings
also I am on manjaro gnome .
I think it upgrades whenever I upgrade my machine via pamac manager or install a new package …
in that case what can I do ?
  • Stop using the GUI to install nVidia drivers (it does things “automatically”)
  • Print this page so you have it as a reference while in TTY2
  • Log off
  • Switch to TTY2 by pressing Ctrl+Alt+F2
  • Log in there
  • remove everything (and why you’re in a TTY) with:
    sudo mhwd --remove pci video-hybrid-amd-nvidia-440xx-prime
    sudo mhwd --remove pci video-linux
  • Install everything again:
    sudo mhwd --install pci video-hybrid-amd-nvidia-440xx-prime
    sudo mhwd --install pci video-linux
    sudo reboot
Now it shouldn’t auto-update any more
:man_shrugging:
Hey , sad to say but After trying the method u suggested , broke the screen and starten flickering again… I then deleted uninstalled the driver then again installed … now its working
Huh? that’s exactly what I told you above… What did you do differently?
:open_mouth:
