I first went to TTY2 then removed the drivers and then installed em again . came back to home … got blamed with the flickering issue again … I then removed the driver via gui and then installed it again . It worked .
Thanks for the feed-back!
That’s totally and utterly weird, because it should do the same thing, but on TTY2 you can remove all drivers and still be able to reboot (back into the TTY only though) and then fix any issues that cannot be fixed thorugh a GUI…
I’m stumped!
yes , that’s the same thing stranged me but yeah whatever does good with minimal solution is appreciated XD
@Fabby Update : Seems the issue is resolved after upgrading to 455 as I they pushed the update as LTS
I’ve marked the below answer as the solution to your question:
In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this:
so that the next person that has the same problem as you will now find a “solved” question.
Hey thanks for letting me know this option . I will definitely do that
