For some time now, I have an issue with manjaro booting to a distorted screen.
´https://paste.pics/3178b66028431d1a8bf6be5ed4bfbcf9´
At first, I experienced some major issues with the dreaded manjaro update, not being able to boot, then massive tearing - to fix the first i had to revert, the latter was somehow patched i guess.
At that same time, manjaro started booting with the screen distortion shown in the image, but not reliably, only about 50% of the time. It also doesnt affect external monitors or any other OS booted.
Does anyone have sugestions as to how i could fix this issue?
Thanks in advance
The inxi output is here:
Kernel: 5.10.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=a4e25fc4-5151-459e-953e-95dcebab32dd rw quiet apparmor=1
security=apparmor resume=UUID=c00a92d3-8976-41c4-8647-cde86d116942
udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 20N3S19L00 v: ThinkPad T490
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 20N3S19L00 serial: <filter> UEFI: LENOVO
v: N2IET75W (1.53 ) date: 08/21/2019
ID-1: BAT0 charge: 45.6 Wh condition: 45.6/50.5 Wh (90%) volts: 12.9/11.5
model: SMP 02DL008 type: Li-poly serial: <filter> status: Full cycles: 119
RAM: total: 15.42 GiB used: 3.16 GiB (20.5%)
Info: Quad Core model: Intel Core i7-8565U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: C (12)
microcode: DE L2 cache: 8 MiB bogomips: 32012
Speed: 600 MHz min/max: 400/4600 MHz Core speeds (MHz): 1: 600 2: 600 3: 600
4: 600 5: 600 6: 600 7: 600 8: 600
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb erms est f16c
flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify
ibpb ibrs ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca
mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand
rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tsc tsc_adjust tsc_deadline_timer vme x2apic
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Type: srbds mitigation: TSX disabled
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:3ea0 class ID: 0300
Device-2: NVIDIA GP108M [GeForce MX250] vendor: Lenovo driver: nvidia
v: 460.39 alternate: nouveau,nvidia_drm bus ID: 3c:00.0 chip ID: 10de:1d13
class ID: 0302
Device-3: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus ID: 1-8:4 chip ID: 13d3:56bc class ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.10 driver: loaded: modesetting,nvidia
unloaded: intel,nouveau alternate: fbdev,nv,vesa display ID: :0.0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.0x11.3")
s-diag: 1055mm (41.6")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 158 size: 309x174mm (12.2x6.9")
diag: 355mm (14")
Monitor-2: HDMI-2 res: 1920x1080 hz: 60 dpi: 93 size: 527x296mm (20.7x11.7")
diag: 604mm (23.8")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 20.3.4
direct render: Yes
Device-1: Intel Cannon Point-LP High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus ID: 00:1f.3 chip ID: 8086:9dc8 class ID: 0403
Sound Server: ALSA v: k5.10.15-1-MANJARO
Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel
port: 3000 bus ID: 00:14.3 chip ID: 8086:9df0 class ID: 0280
Device-2: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel
port: efa0 bus ID: 00:1f.6 chip ID: 8086:15be class ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Message: No Bluetooth data was found.
Local Storage: total: 476.94 GiB used: 130.26 GiB (27.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKKF512G8L
size: 476.94 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 rotation: SSD serial: <filter> rev: L14P temp: 29.9 C scheme: GPT
ID-1: / raw size: 467.84 GiB size: 459.5 GiB (98.22%)
used: 130.26 GiB (28.3%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: a4e25fc4-5151-459e-953e-95dcebab32dd
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 316 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 8886-766D
dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: c00a92d3-8976-41c4-8647-cde86d116942
Message: No Unmounted partitions found.
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
Device-1: 1-1:2 info: Alcor Micro AU9540 Smartcard Reader type: Smart Card
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s chip ID: 058f:9540
class ID: 0b00
Device-2: 1-3:3
info: SHARKOON 2.4GHz Wireless rechargeable vertical mouse [More&Better]
type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
chip ID: 1ea7:0064 class ID: 0301
Device-3: 1-8:4 info: IMC Networks Integrated Camera type: Video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s chip ID: 13d3:56bc
Device-4: 1-9:5 info: Synaptics Prometheus MIS Touch Fingerprint Reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s
chip ID: 06cb:00bd class ID: ff00 serial: <filter>
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003 class ID: 0900
System Temperatures: cpu: 45.0 C mobo: 36.0 C
Fan Speeds (RPM): cpu: 0
Processes: 271 Uptime: 3m wakeups: 4 Init: systemd v: 247 Compilers:
gcc: 10.2.0 Packages: pacman: 1571 lib: 393 flatpak: 0 Shell: Zsh v: 5.8
running in: xfce4-terminal inxi: 3.3.01
