Screen Capture Flickering and Not Recording Opened Windows
I hope somebody can help me. Im on Manjaro Gnome and unable to do screen capture properly, recorded video is flickering and only the desktop, mouse and screen capture app is recorded. Newly opened windows does not appear. Tried OBS Studio, vocoscreenNG and simplescreenrecorder with same result.
Sorry cant post link here, if there a work around please let me know.
Thanks in advance.
Hello,
You should be able to provide this kind of information, so we know what we deal with
oh im so sorry. will do this. thanks
so here is my setup, its an old acer laptop my kid is using for online schooling now. yes im training my kid to use linux :slight_smile:
~ >>> inxi -Fazy
  Kernel: 5.8.6-1-MANJARO x86_64 bits: 64 compiler: N/A
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
  root=UUID=cc40fd53-7686-4a3c-a908-8beb3fcaa690 rw quiet udev.log_priority=3
  Desktop: GNOME 3.36.6 tk: GTK 3.24.23 info: plank wm: gnome-shell
  dm: GDM 3.36.3 Distro: Manjaro Linux
  Type: Laptop System: Acer product: Aspire R3-131T v: V1.17 serial: <filter>
  Mobo: Acer model: Aspire R3-131T v: V1.17 serial: <filter> UEFI: Insyde
  v: 1.17 date: 11/30/2016
  ID-1: BAT0 charge: 11.2 Wh condition: 11.2/51.1 Wh (22%) volts: 17.3/15.4
  model: SANYO AC14B3K type: Li-ion serial: <filter> status: Full
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse B330/M330/M331
  serial: <filter> charge: 5% (should be ignored) rechargeable: yes
  status: Discharging
  Topology: Quad Core model: Intel Pentium N3700 bits: 64 type: MCP
  arch: Airmont family: 6 model-id: 4C (76) stepping: 3 microcode: 368
  L2 cache: 1024 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 12805
  Speed: 480 MHz min/max: 480/2400 MHz Core speeds (MHz): 1: 1859 2: 1570
  3: 480 4: 480
  Type: spec_store_bypass status: Not affected
  Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx
  Integrated Graphics
  vendor: Acer Incorporated ALI driver: i915 v: kernel bus ID: 00:02.0
  chip ID: 8086:22b1
  Device-2: Sunplus Innovation HD WebCam type: USB driver: uvcvideo
  bus ID: 1-3:3 chip ID: 1bcf:2c81
  Display: x11 server: X.org 1.20.8 compositor: gnome-shell driver: intel
  unloaded: modesetting alternate: fbdev,vesa resolution: <xdpyinfo missing>
  OpenGL: renderer: Mesa DRI Intel HD Graphics 405 (BSW) v: 4.6 Mesa 20.1.7
  compat-v: 3.0 direct render: Yes
  Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series
  High Definition Audio
  vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
  bus ID: 00:1b.0 chip ID: 8086:2284
  Sound Server: ALSA v: k5.8.6-1-MANJARO
  vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 1000
  bus ID: 01:00.0 chip ID: 10ec:8168
  IF: enp1s0 state: down mac: <filter>
  Device-2: Intel Wireless 3165 driver: iwlwifi v: kernel port: 1000
  bus ID: 02:00.0 chip ID: 8086:3165
  Local Storage: total: 465.76 GiB used: 15.37 GiB (3.3%)
  ID-1: /dev/sda vendor: Seagate model: ST500LT012-1DG142 size: 465.76 GiB
  block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
  rotation: 5400 rpm serial: <filter> rev: SDM1 scheme: GPT
  ID-1: / raw size: 92.63 GiB size: 90.68 GiB (97.89%) used: 15.16 GiB (16.7%)
  fs: ext4 dev: /dev/sda6
  ID-1: swap-1 type: file size: 3.00 GiB used: 0 KiB (0.0%) priority: -2
  file: /swapfile
  System Temperatures: cpu: 54.0 C mobo: N/A
  Processes: 240 Uptime: 5m Memory: 3.68 GiB used: 1.01 GiB (27.3%)
  Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1131 lib: 367
  Shell: Zsh v: 5.8 running in: gnome-terminal inxi: 3.1.05
and here is a drive link to an actual screen capture using obs studio:
https://drive.google.com/file/d/1ReNoQ0x8g4rpqIclq3R49BbzZBXVce2D/view?usp=sharing
Im new on manjaro my english not very good , sorry for that
I think i know what you mean , i have same problem and follow this steps to solve
Disable Xorg graphic configurations in /etc/X11/xorg.conf.d/
by rename with .bak in last
like “90-mhwd.conf” to “90-mhwd.conf.bak”
let every think else without rename like “keybord.conf” “touchpad.cong”
don’t worry if you didn’t see any graphic config just don’t do any thing
disable Xorg graphic configurations in /etc/X11/
like above if you see anything graphic just rename it with .bak “mhwd.conf” “intel.conf nvidia.conf” etc
at last go to sitting->display and monitor->compositor
and change the Rendering backend to xRender
just sure the “enable compositor on startup”
reboot
that worked for me in kde but i think work anothrs , i hope work for you
