Hi there! So my problem is, that whenever I put my computer (iMac8,1 1.0) into sleep mode and i awake it, the screen glitches for no reason. It gets weirdly in negative or idk what thingy… Like the photo attached. Any ideas what is it due to and how to resolve it?
For some reason, i can’t upload the image here… (Sorry, you can’t embed media items in a post.)
Welcome to Manjaro!
Please read this:
How to provide good information
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies… -
An
inxi --admin --verbosity=7 --filter --no-host --widthwould be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text. -
Also read this:
[HowTo] post screenshots and links
Kernel: 5.11.6-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64
root=UUID=6d87b7e2-5430-403e-873a-20386d2f0c0a ro quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4 vt: 7
Type: Desktop System: Apple product: iMac8,1 v: 1.0 serial: <filter>
Chassis: type: 13 v: Mac-F226BEC8 serial: <filter>
Mobo: Apple model: Mac-F226BEC8 v: PVT serial: <filter> UEFI: Apple
v: IM81.88Z.00C1.B00.0802091538 date: 02/09/08
RAM: total: 3.84 GiB used: 1.49 GiB (38.9%)
Info: Dual Core model: Intel Core2 Duo E8335 bits: 64 type: MCP arch: Penryn
family: 6 model-id: 17 (23) stepping: 6 microcode: 60F cache: L2: 6 MiB
bogomips: 10636
Speed: 1382 MHz min/max: 800/2667 MHz Core speeds (MHz): 1: 1382 2: 1449
Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc cpuid
cx16 cx8 de ds_cpl dtes64 dtherm dts est flexpriority fpu fxsr ht lahf_lm lm
mca mce mmx monitor msr mtrr nopl nx pae pat pbe pdcm pebs pge pni pse pse36
pti rep_good sep sse sse2 sse4_1 ssse3 syscall tm tm2 tpr_shadow tsc vme vmx
vnmi vpid xtpr
Type: l1tf mitigation: PTE Inversion; VMX: EPT disabled
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
Type: spectre_v2
mitigation: Full generic retpoline, STIBP: disabled, RSB filling
Device-1: AMD RV630/M76 [Mobility Radeon HD 2600 XT/2700]
vendor: Apple iMac 7 1 driver: radeon v: kernel bus-ID: 01:00.0
chip-ID: 1002:9583 class-ID: 0300
Device-2: Apple Built-in iSight type: USB driver: uvcvideo bus-ID: 2-4:3
chip-ID: 05ac:8502 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.10 driver: loaded: ati,radeon
unloaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1680x1050 s-dpi: 96 s-size: 444x277mm (17.5x10.9")
s-diag: 523mm (20.6")
Monitor-1: LVDS res: 1680x1050 hz: 60 dpi: 99 size: 433x270mm (17.0x10.6")
diag: 510mm (20.1")
OpenGL: renderer: AMD RV630 (DRM 2.50.0 / 5.11.6-1-MANJARO LLVM 11.1.0)
v: 3.3 Mesa 20.3.4 compat-v: 3.0 direct render: Yes
Device-1: Intel 82801H HD Audio vendor: Apple driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:284b class-ID: 0403
Sound Server-1: ALSA v: k5.11.6-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.23 running: no
Device-1: Broadcom BCM4321 802.11a/b/g/n vendor: Apple AirPort Extreme
driver: wl v: kernel modules: ssb port: 6000 bus-ID: 04:00.0
chip-ID: 14e4:4328 class-ID: 0280
IF: wls4 state: up mac: <filter>
Device-2: Marvell 88E8058 PCI-E Gigabit Ethernet driver: sky2 v: 1.30
port: 5000 bus-ID: 05:00.0 chip-ID: 11ab:436a class-ID: 0200
IF: ens5 state: down mac: <filter>
Device-1: Apple Bluetooth HCI type: USB driver: btusb v: 0.8 bus-ID: 3-1.1:3
chip-ID: 05ac:820f class-ID: fe01 serial: <filter>
Message: No LVM data was found.
Local Storage: total: 298.09 GiB used: 17.4 GiB (5.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD3200AAJS-40VWA1
size: 298.09 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
serial: <filter> rev: 1D02 scheme: GPT
Optical-1: /dev/sr0 vendor: MATSHITA model: DVD-R UJ-875 rev: DB09
dev-links: cdrom
rw: cd-r,cd-rw,dvd-r state: running
ID-1: / raw-size: 297.79 GiB size: 292.12 GiB (98.09%) used: 17.4 GiB (6.0%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 6d87b7e2-5430-403e-873a-20386d2f0c0a
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 620C-C205
Message: No Unmounted partitions found.
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Hub-3: 2-1:2 info: Apple Hub in Aluminum Keyboard ports: 3 rev: 2.0
speed: 480 Mb/s power: 300mA chip-ID: 05ac:1006 class-ID: 0900
Device-1: 2-1.2:4 info: Apple Aluminum Keyboard (ISO) type: Keyboard,HID
driver: apple,usbhid interfaces: 2 rev: 2.0 speed: 1.5 Mb/s power: 20mA
chip-ID: 05ac:0221 class-ID: 0300
Device-2: 2-4:3 info: Apple Built-in iSight type: Video driver: uvcvideo
interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 05ac:8502
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
chip-ID: 1d6b:0001 class-ID: 0900
Hub-5: 3-1:2
info: Broadcom BCM2046B1 USB 2.0 Hub (part of BCM2046 Bluetooth) ports: 3
rev: 2.0 speed: 12 Mb/s chip-ID: 0a5c:4500 class-ID: 0900
Device-1: 3-1.1:3 info: Apple Bluetooth HCI type: Bluetooth driver: btusb
interfaces: 4 rev: 2.0 speed: 12 Mb/s chip-ID: 05ac:820f class-ID: fe01
serial: <filter>
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
Device-1: 4-2:2 info: Logitech Unifying Receiver type: Keyboard,Mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c534 class-ID: 0301
Hub-7: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-8: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-9: 7-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
Device-1: 7-1:2 info: Apple Built-in IR Receiver type: HID
driver: appleir,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s power: 100mA
chip-ID: 05ac:8242 class-ID: 0300
System Temperatures: cpu: 49.0 C mobo: N/A gpu: radeon temp: 58.0 C
Fan Speeds (RPM): cpu: 1196
Processes: 172 Uptime: 6m wakeups: 0 Init: systemd v: 247 tool: systemctl
Compilers: gcc: 10.2.0 Packages: 1276 pacman: 1270 lib: 406 flatpak: 0
snap: 6 Shell: Bash v: 5.1.0 running-in: xfce4-terminal inxi: 3.3.03
and for the pic: https://paste.pics/b0fa5a1bf741e429fb5e72d808b1d643
