Screen Artifacts after resuming from sleep
Hi everyone,
So recently, after updating to video-hybrid-intel-nvidia-440x-prime, I’ve been getting strange screen artifacts every time the computer resumes from suspend. This was never an issue while using any of the bumblebee drivers. Nvidia drivers losing background images during context switches is apparently a known issue, but one that should have been solved with Qt5.13 and Plasma 5.16.
The issue is not only with chrome, but also with icons in latte dock, and also in the settings application. Usually hovering over the icons in the dock, and restarting chrome will get rid of the issue, but there has to be a better solution than that.
I’ve searched around for solutions to the problem, but the only advice I’ve found was to downgrade from the 450 drivers to the 440 drivers (which I’ve already tried) and to upgrade to Qt5.13 and Plasma 5.16 (but I’m already on Qt5.15 and Plasma 5.19). I’ve also tried to look at the logs, but I don’t see anything that’s relevant.
Any help with the issue would be much appreciated.
`inxi --admin --verbosity=7 --filter --no-host`
System:    Kernel: 5.8.6-1-MANJARO x86_64 bits: 64 compiler: N/A
           parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=af13e3d4-aed2-4f67-8b23-f4c706c9b786 rw quiet
           resume=UUID=e5bb7d1c-ba23-4d28-b944-a0958a1194ec
           Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.0 info: latte-dock wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine:   Type: Laptop System: LENOVO product: 81FV v: Lenovo Legion Y530-15ICH serial: <filter> Chassis: type: 10
           Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN serial: <filter> UEFI: LENOVO v: 8JCN52WW date: 06/14/2019
Battery:   ID-1: BAT0 charge: 20.7 Wh condition: 44.0/52.5 Wh (84%) volts: 12.0/11.2 model: SMP L17M3PG1 type: Li-poly
           serial: <filter> status: Charging
Memory:    RAM: total: 7.65 GiB used: 3.86 GiB (50.4%)
CPU:       Topology: Quad Core model: Intel Core i5-8300H bits: 64 type: MT MCP arch: Kaby Lake family: 6 model-id: 9E (158)
           stepping: A (10) microcode: D6 L2 cache: 8192 KiB bogomips: 36812
           Speed: 800 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
           Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art avx avx2 bmi1 bmi2 bts clflush
           clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb erms est f16c flush_l1d fma
           fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
           mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
           pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
           sse4_2 ssse3 stibp syscall tm tm2 tsc tsc_adjust tsc_deadline_timer vme x2apic xgetbv1 xsave xsavec xsaveopt xsaves
           xtopology xtpr
           Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
           Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics:  Device-1: Intel UHD Graphics 630 vendor: Lenovo driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:3e9b
           Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Lenovo driver: nvidia v: 440.100
           alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1c8d
           Device-3: Lite-On Integrated Camera type: USB driver: uvcvideo bus ID: 1-6:3 chip ID: 04ca:7070
           Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: modesetting,nvidia display ID: :0 screens: 1
           Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
           Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 82 size: 598x336mm (23.5x13.2") diag: 686mm (27")
           OpenGL: renderer: GeForce GTX 1050/PCIe/SSE2 v: 4.6.0 NVIDIA 440.100 direct render: Yes
Audio:     Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel v: kernel
           alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:a348
           Sound Server: ALSA v: k5.8.6-1-MANJARO
Network:   Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi v: kernel port: 5000 bus ID: 00:14.3
           chip ID: 8086:a370
           IF: wlp0s20f3 state: down mac: <filter>
           Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8169 v: kernel port: 3000
           bus ID: 07:00.0 chip ID: 10ec:8168
           IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
           IF-ID-1: br-97cba58c03c0 state: down mac: <filter>
           IF-ID-2: br-d8ceec48f030 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
           IP v6: <filter> scope: link
           IF-ID-3: docker0 state: down mac: <filter>
           IF-ID-4: veth35da179 state: up speed: 10000 Mbps duplex: full mac: <filter>
           IF-ID-5: veth9e10df4 state: up speed: 10000 Mbps duplex: full mac: <filter>
           IF-ID-6: veth9fc319c state: up speed: 10000 Mbps duplex: full mac: <filter>
           IF-ID-7: vethc4ef9fa state: up speed: 10000 Mbps duplex: full mac: <filter>
Drives:    Local Storage: total: 1.36 TiB used: 685.64 GiB (49.1%)
           ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO 500GB size: 465.76 GiB block size: physical: 512 B
           logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 2B2QEXE7 scheme: GPT
           ID-2: /dev/sda vendor: Seagate model: ST1000LM049-2GH172 size: 931.51 GiB block size: physical: 4096 B
           logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: LXM3 scheme: GPT
RAID:      Message: No RAID data was found.
Partition: ID-1: / raw size: 175.00 GiB size: 171.25 GiB (97.86%) used: 94.76 GiB (55.3%) fs: ext4 dev: /dev/nvme0n1p6
           label: Manjaro Root uuid: af13e3d4-aed2-4f67-8b23-f4c706c9b786
           ID-2: /boot/efi raw size: 260.0 MiB size: 256.0 MiB (98.46%) used: 34.0 MiB (13.3%) fs: vfat dev: /dev/nvme0n1p2
           label: N/A uuid: 5BA3-DC22
           ID-3: /mnt/Data raw size: 600.00 GiB size: 600.00 GiB (100.00%) used: 590.84 GiB (98.5%) fs: ntfs dev: /dev/sda3
           label: Data uuid: 88EA748CEA7477F0
Swap:      Kernel: swappiness: 60 (default) cache pressure: 100 (default)
           ID-1: swap-1 type: partition size: 8.00 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p7 label: swap
           uuid: e5bb7d1c-ba23-4d28-b944-a0958a1194ec
Unmounted: ID-1: /dev/nvme0n1p1 size: 1000.0 MiB fs: ntfs label: WINRE_DRV uuid: 9C56BEBD56BE978A
           ID-2: /dev/nvme0n1p3 size: 16.0 MiB fs: <superuser/root required> label: N/A uuid: N/A
           ID-3: /dev/nvme0n1p4 size: 275.00 GiB fs: ntfs label: Windows uuid: BE2ABD3B2ABCF18F
           ID-4: /dev/nvme0n1p5 size: 526.0 MiB fs: ntfs label: N/A uuid: 94C421C2C421A806
           ID-5: /dev/sda1 size: 100.00 GiB fs: ext4 label: Backup uuid: d29a7f34-e2c3-45c3-a364-6a74a7ec1cfb
           ID-6: /dev/sda7 size: 10.00 GiB fs: <superuser/root required> label: N/A uuid: N/A
USB:       Hub: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
           Hub: 1-1:2 info: Realtek 4-Port USB 2.0 Hub ports: 4 rev: 2.1 speed: 480 Mb/s chip ID: 0bda:5409
           Device-1: 1-1.2:4 info: N/A type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
           chip ID: 3938:1032
           Device-2: 1-1.3:6 info: HP Elite Keyboard type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 1.1
           speed: 1.5 Mb/s chip ID: 03f0:034a
           Device-3: 1-6:3 info: Lite-On Integrated Camera type: Video driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s
           chip ID: 04ca:7070
           Device-4: 1-14:5 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: Bluetooth driver: btusb interfaces: 2
           rev: 2.0 speed: 12 Mb/s chip ID: 8087:0aaa
           Hub: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
           Hub: 2-1:2 info: Realtek 4-Port USB 3.0 Hub ports: 2 rev: 3.1 speed: 5 Gb/s chip ID: 0bda:0409
Sensors:   System Temperatures: cpu: 60.0 C mobo: N/A gpu: nvidia temp: 48 C
Info:      Processes: 327 Uptime: 31m Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: 1677 pacman: 1669 lib: 438
           flatpak: 8 Shell: Zsh v: 5.8 default: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
Having the same problem after sleep and additionally I frequently loose sound after which I have to fiddle with pulse ro get it back. Unfortunately the 1 October update didn’t fix anything.
I’m also on the nvidia 450 drivers and the 5.8.11-1 kernel, Qt5.15 and Plasma 5.19
I have followed up on various suggestions that I came across but zero results so far.
I found this thread with a similar problem. I also get the Black bar on settings when resuming from suspend, but unlike that thread, going back to the 440 drivers didn’t solve the issue.
I’m on the 440 series pure nVidia, no Intel and don’t have any of these issues…
Also, what are your nVidia OpenGL settings?
2020-10-04_16-58
They are identical to yours, except the G-Sync part
Edit: Also, If it makes any difference, I switched from using bumblebee to optimus manager when I updated to the 440 drivers.
The problem is solved! (At least on Chrome).
I came across this other question here on the forum and the person pointed to the AMD GPU Arch Wiki page for Chromium artifacts.
While I have an Nvidia GPU I thought I’d give it a shot anyway.
Turns out all I needed to do was set the #enable-vulkan chrome flag and I no longer get strange screen artifacts when waking from sleep. :smile: :tada:
