Hello! I wondered if there’s any chance that RTL8822BU Linux driver could be upgraded to the latest kernels. It worked fine up to 5.14 kernel, but now it’s unsupported, so for the last months I’m unable to use my usb 5G wifi and my navigation speed is stuck at 100M thanks to my internal wifi card, so I miss those 500M my usb wifi gives me. I would really appreciate if I could use it back in my Manjaro Linux…
Kernel: 5.16.14-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64
root=UUID=b0af860c-520b-4918-a714-8e475fddc4b4 rw quiet apparmor=1
Desktop: KDE Plasma v: 5.24.4 tk: Qt v: 5.15.3 info: kdocker wm: kwin_x11
vt: 7 dm: LightDM v: 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: Gigabyte product: H110M-S2H v: N/A
serial: <superuser required>
Mobo: Gigabyte model: H110M-S2H-CF v: x.x serial: <superuser required>
UEFI: American Megatrends v: F22 date: 06/12/2017
RAM: total: 7.65 GiB used: 4.33 GiB (56.6%)
RAM Report:
Info: model: Intel Core i5-7400 bits: 64 type: MCP arch: Kaby Lake family: 6
model-id: 0x9E (158) stepping: 9 microcode: 0xEC
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 800 min/max: 800/3500 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 24008
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht
hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf
STIBP: disabled, RSB filling
Device-1: Intel HD Graphics 630 vendor: Gigabyte driver: i915 v: kernel
ports: active: HDMI-A-1 empty: DP-1,HDMI-A-2,HDMI-A-3 bus-ID: 00:02.0
chip-ID: 8086:5912 class-ID: 0300
Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 1360x768 s-dpi: 96 s-size: 359x203mm (14.13x7.99")
s-diag: 412mm (16.24")
Monitor-1: HDMI-A-1 mapped: HDMI-1 model: DGM CVTE TV built: 2010
res: 1360x768 hz: 60 dpi: 60 size: 575x323mm (22.64x12.72")
diag: 1171mm (46.1") ratio: 15:9, 16:10 modes: max: 1360x768 min: 720x400
OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2) v: 4.6 Mesa 21.3.8
direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
class-ID: 0403
Sound Server-1: ALSA v: k5.16.14-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.20 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.49 running: yes
lanes: 1 port: e000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: down mac: <filter>
Device-2: Qualcomm Atheros AR9287 Wireless Network Adapter driver: ath9k
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0
chip-ID: 168c:002e class-ID: 0280
Local Storage: total: 1.93 TiB used: 961.79 GiB (48.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SUV400S37120G
size: 111.79 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 96R9 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM006-2DM164
type: HDD rpm: 7200 serial: <filter> rev: CC26 scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GH24NSD1 rev: LG00
dev-links: cdrom
Features: speed: 12 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 52.11 GiB size: 51.04 GiB (97.95%) used: 37.75 GiB (74.0%)
fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: b0af860c-520b-4918-a714-8e475fddc4b4
ID-2: /boot/efi raw-size: 312.8 MiB size: 312.1 MiB (99.80%)
used: 4.4 MiB (1.4%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: EABA-FE4C
ID-3: /home raw-size: 244.14 GiB size: 239.3 GiB (98.02%)
used: 88.12 GiB (36.8%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: 5af1c6ab-2712-463f-9c82-1370235b0375
ID-4: /mnt/datuak raw-size: 1.58 TiB size: 1.56 TiB (98.37%)
used: 804.35 GiB (50.5%) fs: ext4 dev: /dev/sdb5 maj-min: 8:21 label: N/A
uuid: 9843afea-efb9-408e-b50e-6cf56756cf68
ID-5: /mnt/windows raw-size: 59.37 GiB size: 57.94 GiB (97.59%)
used: 31.57 GiB (54.5%) fs: ext4 dev: /dev/sda6 maj-min: 8:6 label: N/A
uuid: 78376759-30ad-4506-b44d-00f687846e78
ID-1: /dev/sda2 maj-min: 8:2 size: 1 KiB fs: <superuser required> label: N/A
uuid: N/A
ID-2: /dev/sdb2 maj-min: 8:18 size: 1 KiB fs: <superuser required>
label: N/A uuid: N/A
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-3:2 info: Sunplus Innovation Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 98mA chip-ID: 1bcf:0005 class-ID: 0301
Hub-2: 1-4:3 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-4.4:5 info: Realtek RTL88x2bu [AC1200 Techkey]
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.1 speed: 480 Mb/s
power: 500mA chip-ID: 0bda:b812 class-ID: 0000 serial: <filter>
Device-2: 1-8:4 info: N/A type: Keyboard,HID driver: hid-generic,usbhid
interfaces: 2 rev: 1.1 speed: 1.5 Mb/s power: 100mA chip-ID: 026d:0005
class-ID: 0300
Hub-3: 1-10:6 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-4: 2-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
Hub-5: 2-4:2 info: Genesys Logic hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 05e3:0616 class-ID: 0900
System Temperatures: cpu: 29.8 C mobo: 27.8 C
Processes: 251 Uptime: 2h 30m wakeups: 0 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1816
pacman: 1796 lib: 465 flatpak: 20 Shell: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.15
Thanx for any help and excuse my poor English!!
