I couldn’t find log file in /home/valery/.config/unity3d/Ludeon Studios/RimWorld by Ludeon Studios.
There is my system information:
Kernel: 6.7.0-3-rt6-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.7-rt-x86_64
root=UUID=411b2cb6-606d-4c98-b1a3-6a7f0905c9ae rw rootflags=subvol=@
quiet splash apparmor=1 security=apparmor udev.log_priority=3
zram.num_devices=2
Desktop: GNOME v: 46.1 tk: GTK v: 3.24.42 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 46.0 Distro: Manjaro
base: Arch Linux
Type: Laptop System: ASUSTeK product: Vivobook_ASUSLaptop M3401QA_M3401QA
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: M3401QA v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: M3401QA.308
date: 11/07/2022
ID-1: BAT0 charge: 51.5 Wh (100.0%) condition: 51.5/63.0 Wh (81.7%)
volts: 12.0 min: 12.0 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: not charging cycles: 258
System RAM: total: 8 GiB available: 7.17 GiB used: 4.72 GiB (65.9%)
(unregistered) size: 4 GiB speed: 3200 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64
manufacturer: Micron Technology part-no: 4ATF51264HZ-3G2J1 serial: N/A
Info: model: AMD Ryzen 5 5600H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
microcode: 0xA50000D
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3092 high: 4242 min/max: 400/4280 scaling:
driver: amd-pstate-epp governor: performance cores: 1: 4238 2: 3302 3: 3285
4: 400 5: 3531 6: 3288 7: 3610 8: 4242 9: 400 10: 3621 11: 3564 12: 3625
bogomips: 79052
vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 03:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 47.0 C
Device-2: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:3 chip-ID: 13d3:5458
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.0
compositor: gnome-shell driver: gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: Samsung 0x4154 built: 2020 res: 2880x1800 dpi: 242
gamma: 1.2 chroma: red: x: 0.682 y: 0.322 green: x: 0.235 y: 0.725 blue:
x: 0.137 y: 0.047 white: x: 0.314 y: 0.329 size: 302x189mm (11.89x7.44")
diag: 356mm (14") ratio: 16:10 modes: 2880x1800, 1920x1200, 1920x1080,
1600x1200, 1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720, 1024x768,
800x600, 640x480
device: 1 drv: swrast surfaceless: drv: radeonsi wayland: drv: radeonsi x11:
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.8-manjaro1.1
renoir LLVM 17.0.6 DRM 3.56 6.7.0-3-rt6-MANJARO) device-ID: 1002:1638
memory: 500 MiB unified: no display-ID: :0.0
Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 03:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x,
snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
snd_sof_amd_acp63 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 03:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: ASUSTeK
link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.6 chip-ID: 1022:15e3
class-ID: 0403
API: ALSA v: k6.7.0-3-rt6-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
vendor: AzureWave driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 1 bus-ID: 01:00.0 chip-ID: 14c3:7961 class-ID: 0280
Device-1: IMC Networks Wireless_Device driver: btusb v: 0.8 type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:2 chip-ID: 13d3:3563
Report: rfkill ID: hci0 rfk-id: 4 state: up address: see --recommends
Local Storage: total: 476.94 GiB used: 151.69 GiB (31.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNU512GZ
lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 33.9 C scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
used: 151.69 GiB (31.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 411b2cb6-606d-4c98-b1a3-6a7f0905c9ae
used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: D4C8-9D32
ID-3: /home raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
ID-4: /var/cache raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
ID-5: /var/log raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.17 GiB used: 3.99 GiB (55.6%)
priority: 100 comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 12
dev: /dev/zram0
Device-1: 3-2:2 info: IMC Networks Wireless_Device type: bluetooth
mode: 2.0 power: 100mA chip-ID: 13d3:3563 class-ID: e001 serial: <filter>
Device-2: 3-3:3 info: IMC Networks USB2.0 HD UVC WebCam type: video
driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 13d3:5458 class-ID: fe01
serial: <filter>
System Temperatures: cpu: 59.4 C mobo: 44.0 C gpu: amdgpu temp: 49.0 C
Fan Speeds (rpm): cpu: 3100
Packages: 1491 pm: pacman pkgs: 1477 libs: 493
tools: gnome-software,pamac,yay pm: flatpak pkgs: 14
1: https://mirrors.manjaro.org/repo/stable/$repo/$arch
2: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
3: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
4: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
5: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
6: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
7: https://muug.ca/mirror/manjaro/stable/$repo/$arch
8: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 670
1: cpu: 23.0% command: tracker-extract-3 pid: 1055961 mem: 27.0 MiB (0.3%)
2: cpu: 15.5% command: chrome pid: 1054728 mem: 229.9 MiB (3.1%)
3: cpu: 8.5% command: steam pid: 1050245 mem: 39.7 MiB (0.5%)
4: cpu: 8.1% command: steamwebhelper pid: 1051079 mem: 312.2 MiB (4.2%)
5: cpu: 6.3% command: chrome pid: 1009377 mem: 192.7 MiB (2.6%)
Memory top: 5 of 670
1: mem: 312.2 MiB (4.2%) command: steamwebhelper pid: 1051079 cpu: 8.1%
2: mem: 229.9 MiB (3.1%) command: chrome pid: 1054728 cpu: 15.5%
3: mem: 192.7 MiB (2.6%) command: chrome pid: 1009377 cpu: 6.3%
4: mem: 186.5 MiB (2.5%) command: chrome pid: 492490 cpu: 3.9%
5: mem: 184.0 MiB (2.5%) command: chrome pid: 1038324 cpu: 3.1%
Processes: 670 Power: uptime: 2d 21h 16m states: freeze,mem,disk
suspend: s2idle wakeups: 5 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 2.85 GiB services: gsd-power,
tool: systemctl
Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.34
Drivers:
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-linux 2024.05.06 true PCI
> 0000:03:00.0 (0300:1002:1638) Display controller ATI Technologies Inc:
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
Kernel:
Currently running: 6.7.0-3-rt6-MANJARO (linux67)
Manjaro Version:
ManjaroLinux 24.0.1 Wynsdey
RimWorld version is 1.5.4104
