ocor61
January 13, 2022, 6:05pm
#1
Hi,
It was no problem to set up my external monitor, which is a pretty old but functional Sony XDM-X93 (1280x1024). However, every time after I switch the external monitor off and back on again, the resolution settings for the monitor are lost and get reset to 1024x768.
Is this a bug or am I supposed to edit a config file additionally?
Thanks!
Grtz.,
ocor61
ocor61
January 13, 2022, 8:36pm
#3
Thanks! This is the output of $ inxi --admin --verbosity=7 --filter --width
Kernel: 5.15.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=3238c63d-120f-4ca6-951a-8f9e3dbe1596 rw quiet apparmor=1
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: N750JV v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: N750JV v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: N750JV.210 date: 04/11/2014
ID-1: BAT0 charge: 39.5 Wh (100.0%) condition: 39.5/69.3 Wh (57.0%)
volts: 11.1 min: 11.1 model: ASUSTeK N750-62 type: Li-ion serial: N/A
status: Full
RAM: total: 7.65 GiB used: 6.87 GiB (89.8%)
RAM Report:
Info: model: Intel Core i7-4700HQ bits: 64 type: MT MCP arch: Haswell
family: 6 model-id: 0x3C (60) stepping: 3 microcode: 0x28
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 2058 high: 3233 min/max: 800/3400 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 861 2: 880 3: 3188
4: 3208 5: 3168 6: 1034 7: 898 8: 3233 bogomips: 38335
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
fsgsbase fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdtscp rep_good sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xsave xsaveopt xtopology xtpr
Type: l1tf
Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: ASUSTeK
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0416 class-ID: 0300
Device-2: NVIDIA GK107M [GeForce GT 750M] vendor: ASUSTeK driver: nouveau
v: kernel bus-ID: 01:00.0 chip-ID: 10de:0fe4 class-ID: 0302
Display: x11 server: X.Org 1.21.1.2 compositor: kwin_x11 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 3200x1080 s-dpi: 96 s-size: 844x285mm (33.2x11.2")
s-diag: 891mm (35.1")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 128
size: 381x214mm (15.0x8.4") diag: 437mm (17.2")
Monitor-2: HDMI-2 res: 1280x1024 hz: 60 dpi: 91
size: 359x287mm (14.1x11.3") diag: 460mm (18.1")
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0c0c
class-ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
class-ID: 0403
Sound Server-1: ALSA v: k5.15.12-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.42 running: yes
Device-1: Qualcomm Atheros AR9485 Wireless Network Adapter vendor: AzureWave
driver: ath9k v: kernel bus-ID: 03:00.0 chip-ID: 168c:0032 class-ID: 0280
vendor: ASUSTeK driver: r8169 v: kernel port: d000 bus-ID: 04:00.0
IF: enp4s0 state: down mac: <filter>
Device-1: IMC Networks Bluetooth USB Host Controller type: USB driver: btusb
v: 0.8 bus-ID: 3-5:9 chip-ID: 13d3:3402 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 704.24 GiB used: 348.63 GiB (49.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: LITE-ON IT model: LCS-256M6S
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 605 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Samsung model: HD501LJ
size: 465.76 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GU71N rev: AS00
dev-links: cdrom
ID-1: / raw-size: 60.84 GiB size: 59.58 GiB (97.94%) used: 38.4 GiB (64.4%)
fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: 3238c63d-120f-4ca6-951a-8f9e3dbe1596
ID-2: /boot/efi raw-size: 487 MiB size: 486 MiB (99.80%)
used: 52.2 MiB (10.7%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 0966-C552
ID-3: /run/media/ocor61/a0c1f7fb-0514-48d7-b6ff-3a6bcb63ebb5
raw-size: 93.13 GiB size: 91.17 GiB (97.89%) used: 12.45 GiB (13.7%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: a0c1f7fb-0514-48d7-b6ff-3a6bcb63ebb5
ID-4: /run/media/ocor61/ab145823-9a71-43e5-b96a-f6d441ba472a
raw-size: 68.4 GiB size: 66.83 GiB (97.70%) used: 34.85 GiB (52.1%) fs: ext4
dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: ab145823-9a71-43e5-b96a-f6d441ba472a
ID-5: /run/timeshift/backup raw-size: 465.76 GiB size: 457.45 GiB (98.22%)
used: 259.85 GiB (56.8%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17
label: Ambrosia Backup uuid: 957358b1-4846-4cd4-b33b-0b11598f1223
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 15.63 GiB used: 3.03 GiB (19.4%)
priority: -2 dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: b9e8fcb7-8ab3-4cfc-a95b-13dee53715e5
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:8008 class-ID: 0900
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 14 rev: 2.0
Device-1: 3-2:3 info: Chicony KU-0420 keyboard type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 04f2:0403 class-ID: 0300
Device-2: 3-3:4
info: JMicron / JMicron USA JM20337 Hi-Speed USB to SATA & PATA Combo Bridge
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
speed: 480 Mb/s power: 2mA chip-ID: 152d:2338 class-ID: 0806
serial: <filter>
Device-3: 3-4:5 info: Trust Wireless Mouse type: Mouse,Keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 50mA
chip-ID: 145f:01c8 class-ID: 0301
Device-4: 3-5:9 info: IMC Networks Bluetooth USB Host Controller
type: Bluetooth driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 13d3:3402 class-ID: e001 serial: <filter>
Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 56.0 C mobo: N/A gpu: nouveau temp: 30.0 C
Fan Speeds (RPM): cpu: 3800
Processes: 392 Uptime: 2d 1h 53m wakeups: 1 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.1.0 Packages: 1490 pacman: 1485 lib: 419
flatpak: 5 Shell: fish v: 3.3.1 running-in: konsole inxi: 3.3.11
