To keep short. I have fixed my sound output and system microphone input by adding this to alsa-base.conf
options snd-hda-intel dmic_detect=1
How on earth do I disable or remove these HDMI sound output from the menu? It’s just a little clunky to have when I will never use them and get in the way of easy access of the master sound and microphone volume. Thank you.
Pulseaudio detects them as input devices? “Smart Sound Technology Audio Controller”
I’ve marked the below answer as the solution to your question as it is by far the best answer you’ll get.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (I just want to avoid even more subjective opinions being posted and confusing you even more)
P.S. In the future, please mark a solution like this:
