Hello.
Post-installation of the RT kernel, i’m unable to mount. load or find efivarfs. And because of this I’m unable to use efibootmgr.
Everything works as expected when running the normal/generic kernel, 5.15.12-1, on the same system.
For both kernels, generic and RT, the following produces exactly the same output -
zcat /proc/config.gz | grep -i efi
Any advice would be much appreciated.
Thanks.
Have you testet to boot in UEFI-mode ?
When booting in legacy mode (BIOS) the evi variables are not accessible.
Increase your chances of solving your issue:
Difficulty: ★☆☆☆☆
Strong of its many members, the Manjaro support forum can provide you help whenever you have an issue with your Manjaro installation. But in order to work efficiently, we shall also ask you to commit to a few things.
Keep calm and read
First some basics: whenever you need to troubleshoot, chances are the solution is already under your nose.
Find error messages
Very often when an applications crashes, and sometimes when it misbehaves, it prints an error message somewhere.
Provide Information:
Welcome to Manjaro!
To allow all of us helpful people on this forum TO HELP YOU, we need some basic information about your system. This probably means you described the symptoms of your problem, but now we need some more information to know where the origin of your issue is exactly.
Someone else probably linked you to this tutorial, so if you’re reading this in response to a question, please click the link above this text to bring you to the full and unabridged text of the tutorial…
Hi.
Thanks for the reply.
Yes, I checked that I was booting into UEFI, multiple times, before posting.
I disabled legacy boot in BIOS to ensure I’m only booting in UEFI mode. I also don’t have a boot partition, only a EFI partition. Also, when I boot into the normal kernel via the same GRUB menu, I have access to efivarfs.
Also, the top lines in my dmesg log -
[ 0.000000] efi: EFI v2.31 by INSYDE Corp.
[ 0.000000] efi: ACPI=0xaaffe000 ACPI 2.0=0xaaffe014 SMBIOS=0xaaebef98
[ 0.013090] ACPI: UEFI 0x00000000AAFFC000 000236 (v01 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.013154] ACPI: Reserving UEFI table memory at [mem 0xaaffc000-0xaaffc235]
Sam
