After manjaro installation I can’t see the list of available wifi’s in network connections. I’m using USB wifi adapter to be able to connect to wifi from my PC, the adapter is tp-link AC1300 if this helps.
nmcli -Nazy
eno1: unavailable
"Realtek RTL8111/8168/8411"
ethernet (r8169), D8:5E:D3:58:48:51, hw, mtu 1500
lo: unmanaged
"lo"
loopback (unknown), 00:00:00:00:00:00, sw, mtu 65536
Use "nmcli device show" to get complete information about known devices and
"nmcli connection show" to get an overview on active connection profiles.
Consult nmcli(1) and nmcli-examples(7) manual pages for complete usage details.
Shows this, so I thought that this might be a driver issue: right now r8169 is in use. I’ve tried to compile this drivers manually on my PC because I don’t have internet connection and can’t download drivers via hardware configuration. If there any solution how can I make wifi work on my PC?
here’s my inxi output
You can use the Manjaro Hardware Configuration tool to select the driver, and it will automatically install the needed packages, invoke DKMS, and blacklist the alternative driver.
EDIT: You also need to reboot your system to use the latest installed kernel.
I believe your thread title includes a typo. You meant to write 8168 instead of 8618?
If any more information is needed I’m glad to provide you
nmcli
eno1: unavailable
lo: unmanaged
"lo"
sudo modprobe eno1
modprobe: FATAL: Module eno1 not found in directory /lib/modules/5.15.60-1-MANJARO
You already have the r8169 kernel driver installed.
This is an XY Problem: You’re asking about your attempted solution rather than your actual problem . This leads to enormous amounts of wasted time and energy, both on the part of people asking for help, and on the part of those providing help.
But in hardware configuration I can see RTL81111/8168/8411 ethernet controller.without an installed driver. I tried to install it with hardware configuration, but it couldn’t get a driver because I am not connected to the ethernet. I can’t see my wifi (or any wifi) in the list of connections.
Thanks. I’ve edited the original post to formulate the problem more clearer and explicit. Also, yes, I’m entirely sure that this is the full result of inxi -Nazy output. I can give full inxi -Fazy if this is needed.
The problem is that I can’t connect via cable, only with wifi. I use wifi adapter to connect my PC, and it works fine in windows, but I can’t make it work in manjaro. Already tried reboot and manjaro reinstall.
I did not blacklist anything and rfkill gives no output.
I wanted to make my wifi work.
I’ve resolved the problem. What helped:
Installing this driver, then compiling it with make and add to dkms with sudo ./deploy.sh
Thread can be closed, thanks everyone for help
