Randomly Losing Connection
I have a fresh install of Manjaro Linux w/ xfce on stable and the wifi is randomly disconnecting.
Please provide some system information. Please read:
  Kernel: 6.5.5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: hpet available: acpi_pm
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
    root=UUID=82268f03-e25d-49f2-8269-e8885066570d rw quiet splash
    udev.log_priority=3
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
    v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: LENOVO product: 82MF v: IdeaPad 3 15ALC6
    serial: <superuser required> Chassis: type: 10 v: IdeaPad 3 15ALC6
  Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
    UEFI: LENOVO v: GLCN46WW date: 03/23/2022
  ID-1: BAT0 charge: 34.9 Wh (100.0%) condition: 34.9/38.0 Wh (91.8%)
    volts: 8.6 min: 7.7 model: SMP L20M2PF0 type: Li-poly serial: <filter>
    status: full cycles: 54
  Info: model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
    process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x68 (104) stepping: 1
    microcode: 0x8608103
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
    desc: 2x4 MiB
  Speed (MHz): avg: 1069 high: 1978 min/max: 400/4056 scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 1528 2: 400 3: 1978
    4: 400 5: 400 6: 400 7: 1394 8: 1438 9: 1397 10: 400 11: 1715 12: 1381
    bogomips: 50323
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
  Type: spec_rstack_overflow mitigation: safe RET
  Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
    always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: AMD Lucienne vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
    code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
    empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:164c class-ID: 0300
    temp: 44.0 C
  Device-2: Syntek Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 174f:2459
  Display: x11 server: X.org v: 1.21.1.8 compositor: xfwm v: 4.18.0 driver:
    X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
    gpu: amdgpu display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
  Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x08d5 built: 2019
    res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
    diag: 395mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
    device: 1 drv: swrast surfaceless: drv: radeonsi x11: drv: radeonsi
    inactive: gbm,wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.1.9-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (renoir LLVM
    16.0.6 DRM 3.54 6.5.5-1-MANJARO) device-ID: 1002:164c memory: 1.95 GiB
    unified: no
  Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo
    link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.1 chip-ID: 1002:1637
    class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo driver: N/A
    alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
    snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir,
    snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s bus-ID: 03:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.5.5-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.81 status: off tools: pw-cli
    type: plugin tools: pacat,pactl,pavucontrol
  Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
    vendor: Lenovo driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 01:00.0 chip-ID: 10ec:c822
    class-ID: 0280
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:3 chip-ID: 0bda:c123
  Local Storage: total: 238.47 GiB used: 24.21 GiB (10.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SSSTC model: CL1-4D256
    size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: BS262 temp: 34.9 C scheme: GPT
  ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%)
    used: 24.21 GiB (10.4%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  System Temperatures: cpu: 50.8 C mobo: N/A gpu: amdgpu temp: 43.0 C
  Fan Speeds (rpm): N/A
  Processes: 298 Uptime: 2h 17m wakeups: 1 Memory: total: 6 GiB
  available: 5.65 GiB used: 3.33 GiB (58.9%) Init: systemd v: 254
  Packages: pm: pacman pkgs: 1039 libs: 321 tools: pamac Shell: Bash v: 5.1.16
  running-in: xfce4-terminal inxi: 3.3.30
The system does not appear to be fully updated:
stable 6.5.12-1 is current as of today. 6.5.13 already has been marked EOL.
Have you tried a LTS kernel, either 6.1 or 6.6?
Have you looked into wifi powersave options e.g. in tlp.conf?
# Wi-Fi power saving mode: on=enable, off=disable.
# Default: off (AC), on (BAT)
WIFI_PWR_ON_AC=off
#WIFI_PWR_ON_BAT=on
Or disable network manager powersave:
Disable Wifi power saving:
You can disable Network Manager's power saving features by creating /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf with the following command::
sudo touch /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf
Add the following contents to the newly created conf file with your preferred text editor:
[connection]
wifi.powersave = 0
Reboot or restart Network Manager
I believe now that this issue is mainly related to poor connection, because I’ve been using other wifi networks and I am not facing the same problem.
By the way, I believe my system is updated although I am not very sure since I’m a newbie.
I ran pacman -Syyu and it returned:
 core is up to date
 extra is up to date
 multilib is up to date
 there is nothing to do
Looks up to date to me.
To be triple sure you can sort mirrors;
sudo pacman-mirrors -f && sudo pacman -Syu
Then it does sound like an issue at least related to that one network, rather than your manjaro system or wireless card/module.
