Random crack from speakers when playng some audio content
First of all sorry for my bad english, I’m italian and a NEW user
I installed Manjaro KDE on my notebook Huawei Matebook D 14 and everything is ok but I have a strnge issue with sound. Soud quality is good but when I play a soud (music on my system or a web content with sound) there is a “bang or little carck sound” coming from my speaker even if I’m using a different sound source as my headphone. After this “bang/crack” sound works perfectly but if I start another sound source or there is a new sound from the system well this “Bang” comes agains from speakers even if the output source is another…
How can I solve this issue?
I try some different kernel from LTS to the last one but the issue is still present.
Thanks
provide formated output from, by clicking this icon in the editor:</>
inxi -Fazy
Have you did this and the crack sound still persists after that ?
https://wiki.archlinux.org/title/Huawei_MateBook_14_AMD_(2020)#Audio
Not sure if related, but maybe worth reading Soundcard not detected on Huawei Matebook d14 (intel) / Newbie Corner / Arch Linux Forums
My headset (and without MIC in my case) works perfectly fine
My Matebook is another model I have Matebook D 14 that is a AMD Ryzen hardware
See my second link and this one then
https://bbs.archlinux.org/viewtopic.php?id=274559
In the future, consult this on [HowTo] Provide System Information and share that info, so nobody will do a guess work …
As said I have a different hardware comapred to the link you provide. I have a AMD chipset and not a Intel chipset
Then let me repeat
When i copy system info with 3 ‘’’ above and 3 ‘’’ at the end here the page said I can’t insert LINK (there are no link so I don’t know what it is telling and so I can’t provide those info
is 3 ``` and not 3 ‘’’
Kernel: 5.17.6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.17-x86_64
root=UUID=ee6cbac7-ba22-4004-a228-4a0a18e05d5a rw quiet apparmor=1
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 1 dm: SDDM
click this icon in the editor : </> and inside it put output from this command:
inxi -Fazy
  Type: Laptop System: HUAWEI product: KPL-W0X v: M1D
    serial: <superuser required>
  Mobo: HUAWEI model: KPL-W0X-PCB v: M1D serial: <superuser required>
    UEFI: HUAWEI v: 1.23 date: 09/28/2021
  ID-1: BAT1 charge: 54.8 Wh (100.0%) condition: 54.8/56.3 Wh (97.2%)
    volts: 8.0 min: 7.6 model: DYNAPACK HB4593R1ECW type: Li-ion
    serial: <filter> status: full cycles: 103
  Info: model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx bits: 64
    type: MT MCP arch: Zen family: 0x17 (23) model-id: 0x11 (17) stepping: 0
    microcode: 0x8101007
    L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
    desc: 1x4 MiB
  Speed (MHz): avg: 1432 high: 1637 min/max: 1600/2000 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1478 2: 1376
    3: 1383 4: 1386 5: 1637 6: 1465 7: 1367 8: 1371 bogomips: 31948
  Type: spectre_v2
    mitigation: Retpolines, IBPB: conditional, STIBP: disabled, RSB filling
  Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Mobile Series]
    vendor: Huawei driver: amdgpu v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
    ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 02:00.0
    chip-ID: 1002:15dd class-ID: 0300
  Device-2: Quanta hm1091_techfront type: USB driver: uvcvideo bus-ID: 3-1:2
    chip-ID: 0408:1020 class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
    loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu
    display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x14d4 built: 2016
    res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81")
    diag: 354mm (13.9") ratio: 16:9 modes: max: 1920x1080 min: 640x480
  OpenGL: renderer: AMD Radeon Vega 8 Graphics (raven LLVM 13.0.1 DRM 3.44
  5.17.6-1-MANJARO)
    v: 4.6 Mesa 22.0.3 direct render: Yes
  Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Huawei
    bus-ID: 02:00.1 chip-ID: 1002:15de class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Huawei
    driver: snd_pci_acp3x v: kernel
    alternate: snd_rn_pci_acp3x,snd_pci_acp5x,snd_sof_amd_renoir pcie: gen: 3
    speed: 8 GT/s lanes: 16 bus-ID: 02:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: Huawei driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 02:00.6
    chip-ID: 1022:15e3 class-ID: 0403
  Sound Server-1: ALSA v: k5.17.6-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.51 running: yes
  Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:24fd class-ID: 0280
    bus-ID: 1-2:2 chip-ID: 8087:0a2b class-ID: e001
  Local Storage: total: 238.47 GiB used: 48.17 GiB (20.2%)
  ID-1: /dev/sda maj-min: 8:0 vendor: LITE-ON model: CV8-8E256
    size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    type: SSD serial: <filter> rev: 402 scheme: GPT
  ID-1: / raw-size: 15.5 GiB size: 15.15 GiB (97.77%) used: 9.88 GiB (65.2%)
    fs: ext4 dev: /dev/sda5 maj-min: 8:5
    used: 38.2 MiB (39.8%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 45.0 C
  Processes: 251 Uptime: 2h 51m wakeups: 1 Memory: 6.74 GiB
  used: 2 GiB (29.6%) Init: systemd v: 250 tool: systemctl Compilers:
  gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1195 lib: 327 flatpak: 0
  Shell: Zsh v: 5.8.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.16digita o incolla il codice qui
install sof-firmware package:
sudo pacman -S sof-firmware
reboot and check
I made some reboot just to check and now seems everithing is OK, no more crack from speakers
Many thanks :heart_eyes:
