I made the same question here:
First of all sorry for my bad english, I’m italian and a NEW user
I installed Manjaro KDE on my notebook Huawei Matebook D 14 and everything is ok but I have a strnge issue with sound. Soud quality is good but when I play a soud (music on my system or a web content with sound) there is a “bang or little carck sound” coming from my speaker even if I’m using a different sound source as my headphone. After this “bang/crack” sound works perfectly but if I start another sound source or there is a ne…
I mark it as solved but is not solved (still cracking/buzzing sound from speakers sometimes low level crack, sometimes high level crack from speakers) so install sof-firmware package: sudo pacman -S sof-firmware does not solve the issue. Change kernel to older LTS does not solve the issue too.
My setting is:
Kernel: 5.17.9-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.17-x86_64
root=UUID=ee6cbac7-ba22-4004-a228-4a0a18e05d5a rw quiet apparmor=1
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.4 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HUAWEI product: KPL-W0X v: M1D
serial: <superuser required>
Mobo: HUAWEI model: KPL-W0X-PCB v: M1D serial: <superuser required>
UEFI: HUAWEI v: 1.23 date: 09/28/2021
ID-1: BAT1 charge: 54.9 Wh (100.0%) condition: 54.9/56.3 Wh (97.5%)
volts: 8.0 min: 7.6 model: DYNAPACK HB4593R1ECW type: Li-ion
serial: <filter> status: full cycles: 103
Info: model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx bits: 64
type: MT MCP arch: Zen family: 0x17 (23) model-id: 0x11 (17) stepping: 0
microcode: 0x8101007
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1538 high: 2289 min/max: 1600/2000 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1391 2: 1371
3: 1747 4: 2289 5: 1376 6: 1398 7: 1366 8: 1371 bogomips: 31948
Type: spectre_v2
mitigation: Retpolines, IBPB: conditional, STIBP: disabled, RSB filling
Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Mobile Series]
vendor: Huawei driver: amdgpu v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 02:00.0
chip-ID: 1002:15dd class-ID: 0300
Device-2: Quanta hm1091_techfront type: USB driver: uvcvideo bus-ID: 3-1:2
chip-ID: 0408:1020 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu
display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x14d4 built: 2016
res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81")
diag: 354mm (13.9") ratio: 16:9 modes: max: 1920x1080 min: 640x480
OpenGL: renderer: AMD Radeon Vega 8 Graphics (raven LLVM 13.0.1 DRM 3.44
5.17.9-1-MANJARO)
v: 4.6 Mesa 22.0.4 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Huawei
bus-ID: 02:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Huawei
driver: snd_pci_acp3x v: kernel
alternate: snd_rn_pci_acp3x,snd_pci_acp5x,snd_sof_amd_renoir pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 02:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Huawei driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 02:00.6
chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.17.9-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:24fd class-ID: 0280
bus-ID: 1-2:2 chip-ID: 8087:0a2b class-ID: e001
Local Storage: total: 238.47 GiB used: 49.6 GiB (20.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: LITE-ON model: CV8-8E256
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 402 scheme: GPT
ID-1: / raw-size: 15.5 GiB size: 15.15 GiB (97.77%) used: 11.31 GiB (74.6%)
fs: ext4 dev: /dev/sda5 maj-min: 8:5
used: 38.2 MiB (39.8%) fs: vfat dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 54.0 C
Processes: 249 Uptime: 37m wakeups: 1 Memory: 6.74 GiB
used: 1.81 GiB (26.9%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1198 lib: 327 flatpak: 0
desc: 1x4 MiB
Type: spectre_v2
5.17.9-1-MANJARO)
Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.16Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.16
try with the 5.18rc kernel, install it from system settings/kernel, reboot and test with it
nothig changed, same issue even with new kernel 5.18
so try using either pulse or pipewire … install this package:
sudo pacman -S manjaro-pulse
it should remove pipewire, then reboot and test
if it doesnt work install pipewire:
sudo pacman -S manjaro-pipewire
it will give you dependency issues, so uninstall them first, then install it again, and select wireplumber, then reboot and test
if it still doesnt work, uninstall wireplumber and install pipewire media session, reboot and test
Not solved even if now the issue seems less prominent (crack sound is low now but still presented)
But al least now sound quality seems better with pipewire (installed wireplumber too). Tried with media-session before install wireplumber but same issue.
Pipewire is active i think
pactl info ✔
Server String: /run/user/1000/pulse/native
Library Protocol Version: 35
Server Protocol Version: 35
Is Local: yes
Client Index: 136
Tile Size: 65472
User Name: cris
Host Name: Huawei
Server Name: PulseAudio (on PipeWire 0.3.51)
Server Version: 15.0.0
Default Sample Specification: float32le 2ch 48000Hz
Default Channel Map: front-left,front-right
Default Sink: alsa_output.pci-0000_02_00.6.analog-stereo
Default Source: alsa_input.pci-0000_02_00.6.analog-stereo
Cookie: e19c:a1db
please try the following and report if crackling disappeares. if so, i’ll post how to do this setting permanent.
echo 0 | sudo tee /sys/module/snd_hda_intel/parameters/power_save
echo N | sudo tee /sys/module/snd_hda_intel/parameters/power_save_controller
Untill I reboot seems that those 2 paramateres are working (even if I doesn’t have intel hardware on my system), if you can tell me how made permanent I will test better. Thanks
echo “options snd-hda-intel power_save=0 power_save_controller=N” | sudo tee /etc/modprobe.d/hda.conf
and reboot.
hope that solved your issue
P.S.: it doesn’t matter, your hardware is intel-compatible and the used driver is the intel_snd-driver.
Not solved sadly, I hope I made it permanent ( I copy your string on terminal and reboot) but after some testing nothing changed.
cczzz
29 May 2022 04:52
10
Hi there, it seems that I have the same issue, where I previously also had the buzzing sound issue solved here , but it suddenly appeared again. I used the dual boot, and I found this after booting to windows (but not sure if it is relevant). Also, I could not find /sys/module/snd_hda_intel, the only options related to snd_hda would be
snd_hda_codec/ snd_hda_codec_hdmi/ snd_hda_core/
snd_hda_codec_generic/ snd_hda_codec_realtek/ snd_hda_ext_core/
This is also not solved for me, and there is only one line in /etc/modprobe.d/hda.conf after this command.
I used xfce though.
root=UUID=17a57bc5-4569-4d1b-8454-2c7d491f058c rw quiet apparmor=1
security=apparmor udev.log_priority=3 snd_hda_intel.power_save=0
button.lid_init_state=open
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29
info: xfce4-panel, plank, vala-panel wm: xfwm v: 4.16.1 vt: 7 dm: LightDM
v: 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Razer product: Blade 15 (2022) - RZ09-0421 v: 8.04
Mobo: Razer model: CH580 v: 4 serial: <superuser required> UEFI: Razer
v: 1.09 date: 02/22/2022
ID-1: BAT0 charge: 81.9 Wh (100.0%) condition: 81.9/80.2 Wh (102.2%)
volts: 17.4 min: 15.4 model: Razer Blade type: Unknown serial: <filter>
status: full
ID-2: hidpp_battery_0 charge: 20% condition: N/A volts: 3.7 min: N/A
model: Logitech G903 LIGHTSPEED Wireless Gaming Mouse w/ HERO type: N/A
serial: <filter> status: discharging
Info: model: 12th Gen Intel Core i7-12800H bits: 64 type: MST AMCP
arch: Alder Lake family: 6 model-id: 0x9A (154) stepping: 3 microcode: 0x41C
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 811 high: 2198 min/max: 400/2400:1800 scaling:
driver: intel_pstate governor: powersave cores: 1: 522 2: 2198 3: 529 4: 708
5: 958 6: 713 7: 631 8: 1188 9: 612 10: 709 11: 413 12: 874 13: 661
14: 794 15: 873 16: 803 17: 1041 18: 517 19: 768 20: 726 bogomips: 112160
Device-1: Intel Alder Lake-P Integrated Graphics vendor: Razer USA
driver: i915 v: kernel ports: active: eDP-1 empty: none bus-ID: 00:02.0
chip-ID: 8086:46a6 class-ID: 0300
Device-2: NVIDIA GA103M [GeForce RTX 3080 Ti Laptop GPU] vendor: Razer USA
driver: nvidia v: 510.73.05 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-05) arch: Ampere pcie: gen: 1 speed: 2.5 GT/s
lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:2460 class-ID: 0300
Device-3: IMC Networks Integrated RGB Camera type: USB driver: uvcvideo
bus-ID: 1-2:2 chip-ID: 13d3:5279 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 with: Xwayland v: 22.1.1
compositor: xfwm v: 4.16.1 driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa gpu: i915 display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 4608x1985 s-dpi: 96 s-size: 1219x525mm (47.99x20.67")
s-diag: 1327mm (52.25")
Monitor-1: HDMI-1-0 pos: primary,top-right res: 2560x1440 hz: 60 dpi: 108
size: 600x340mm (23.62x13.39") diag: 690mm (27.15") modes: N/A
Monitor-2: eDP-1 pos: bottom-l res: 2048x1152 hz: 60 dpi: 151
size: 344x194mm (13.54x7.64") diag: 395mm (15.55") modes: N/A
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Razer USA
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:51c8 class-ID: 0401
Device-2: NVIDIA vendor: Razer USA driver: N/A alternate: snd_hda_intel
pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:2288 class-ID: 0403
Sound Server-3: PulseAudio v: 15.0 running: no
Device-1: Intel Alder Lake-P PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 1-10:6
chip-ID: 8087:0033 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 953.87 GiB used: 164.5 GiB (17.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: NVMe CA6-8D1024 size: 953.87 GiB
block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4
type: SSD serial: <filter> rev: ERA0902 temp: 37.9 C scheme: GPT
ID-1: / raw-size: 672.78 GiB size: 661.15 GiB (98.27%)
used: 164.45 GiB (24.9%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
used: 50.7 MiB (52.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 27.8 C mobo: N/A
Processes: 427 Uptime: 5m wakeups: 4 Memory: 31.04 GiB
used: 4.56 GiB (14.7%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: 1457 pacman: 1438 lib: 333 flatpak: 10
snap: 9 Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.16
not sure if I need to create a new post but just sharing here for now.
cczzz
29 May 2022 05:38
11
just a follow-up. I booted to the windows system again, and instead of “restart”, I shut it down first and then booted to Manjaro. The first boot leads me to lose WiFi connection, but when I did a reboot, everything works fine now. no buzzing sound anymore. Does it seem because of the dual boot? really wired.
Me too dual boot but I think is not dual boot the problem.
On Arch Wiki i found that
https://wiki.archlinux.org/title/Advanced_Linux_Sound_Architecture/Troubleshooting#Pops_when_starting_and_stopping_playback
But I have not a file called modprobe.conf , I have only HDA.conf so I don’t know if create this modbrobe.conf is a good idea
thats the same thing you alredy have from @olli recommendation, but you have hda.conf instead modprobe.conf, but the parameters are the same…
whats the output from:
systemctl --user status pipewire
dsystemctl --user status pipewire ✔
● pipewire.service - PipeWire Multimedia Service
Loaded: loaded (/usr/lib/systemd/user/pipewire.service; disabled; vendor preset: enabled)
Active: active (running) since Sun 2022-05-29 08:39:47 CEST; 1h 50min ago
TriggeredBy: ● pipewire.socket
Main PID: 1028 (pipewire)
Tasks: 2 (limit: 8188)
Memory: 7.3M
CPU: 5.310s
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire.service
└─ 1028 /usr/bin/pipewire
mag 29 08:39:47 Huawei systemd[699]: Started PipeWire Multimedia Service.igita o incolla il codice qui
nothing there… you could try running this command, after you created the file in etc/modprobe:
sudo mkinitcpio -P
sorry I don’t understand: I have to create a file (and what file) before the command? Or get the command and than reboot and the file is created by the command?
no you already created the file with @olli command above - the file hda.conf … but i think you have to recreate initframs (not 100% sure) after you create something in the etc/modprobe folder… and you do this with this commnad:
sudo mkinitcpio -P
buzz sound from speaker is here when booting and when desktop is loading, and I think is normal because manjaro does not have time to load the sound setting at boot. But after that I have not buzzing sound on firefox or VLC playing somethig. So seems buzz sound now is only at startup. I test more to see if does not appear anymore during activity. Thanks
After testing the issue is not solved, but at least the buzz sound is low not disturbing and less preminent than before.
I’m guessing you mean from the laptop speakers and not external Speakers, Have you tested with ear phones and does it do the same thing, you could try editing file (with super user):
/etc/pipewire/pipewire.conf
and un-hash these lines:
default.clock.allowed-rates = [ ****** ]
default.clock.min-quantum = **
default.clock.max-quantum = ****
And as I’m not to sure about the specs of your onboard sound card try these settings first:
default.clock.allowed-rates = [ 48000 44100 ]
default.clock.min-quantum = 32
default.clock.max-quantum = 8192
If you card does upto 96k then you can try:
default.clock.allowed-rates = [ 96000 88200 48000 44100 ]
Save and reboot, not saying this will work but worth a try.
Also make sure these (user) services are running:
pipewire
pipewire-media-session or wireplumber (depends on which one your using here)
pipewire-pulse
pipewire.socket
pipewire-pulse.socket
