blp92
22 May 2021 16:41
1
I have been having persistent issues for a couple months now that used to happen 1/3 of boots but now seems to occur about 4/5 boots. Whenever I log into my Manjaro distro I get no audio inputs, pulseaudio shows busy, and when I try to systemctl --user restart pulseaudio I get an error:
Failed to restart pulseaudio.service: Process org.freedesktop.systemd1 exited with status 1
See user logs and 'systemctl --user status pulseaudio.service' for details.
[foo@bar Desktop]$ systemctl --user status pulseaudio.service
Failed to get properties: Process org.freedesktop.systemd1 exited with status 1
[foo@bar Desktop]$
It’s getting to the point where I just play bootup roulette and restart 6 times until I finally have audio
Fabby
23 May 2021 08:12
2
Welcome to Manjaro!
Please read this:
How to provide good information
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text .
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU, GPU or Kernel you have without typing it every time
blp92
25 May 2021 13:15
3
Here is the result:
Kernel: 5.10.36-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=88ec38db-9f99-4ff1-8f7a-41b7f1ec6589 ro quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel, plank wm: xfwm4
vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: Micro-Star product: MS-7B85 v: 1.0 serial: <filter>
Mobo: Micro-Star model: B450 GAMING PRO CARBON AC (MS-7B85) v: 1.0
serial: <filter> UEFI: American Megatrends v: 1.B0 date: 11/08/2019
RAM: total: 15.64 GiB used: 2.6 GiB (16.6%)
Info: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: 0 microcode: 8701013 cache:
L2: 3 MiB bogomips: 86434
Speed: 2800 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
1: 2800 2: 1866 3: 2201 4: 2192 5: 1865 6: 2201 7: 2200 8: 2196 9: 2796
10: 1857 11: 1865 12: 2197
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sev_es sha_ni
skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload
vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr
xsaveopt xsaves
conditional, RSB filling
Device-1: NVIDIA TU106 [GeForce RTX 2060 SUPER] vendor: Micro-Star MSI
driver: nouveau v: kernel bus-ID: 26:00.0 chip-ID: 10de:1f06 class-ID: 0300
Display: x11 server: X.Org 1.20.11 driver: loaded: modesetting,nouveau
alternate: fbdev,nv,vesa display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 4480x1440 s-dpi: 96 s-size: 1185x381mm (46.7x15.0")
s-diag: 1245mm (49")
Monitor-1: HDMI-1 res: 1920x1080 hz: 60 dpi: 93 size: 527x296mm (20.7x11.7")
diag: 604mm (23.8")
Monitor-2: DP-3 res: 2560x1440 dpi: 109 size: 597x336mm (23.5x13.2")
diag: 685mm (27")
OpenGL: renderer: NV166 v: 4.3 Mesa 21.0.3 direct render: Yes
Device-1: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 26:00.1 chip-ID: 10de:10f9
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 28:00.4 chip-ID: 1022:1487
class-ID: 0403
Device-3: Blue Microphones Yeti Stereo Microphone type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-2:2 chip-ID: b58e:9e84
class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.10.36-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.28 running: no
Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel bus-ID: 21:00.0
chip-ID: 8086:2526 class-ID: 0280
Device-2: Intel I211 Gigabit Network vendor: Micro-Star MSI driver: igb
v: kernel port: f000 bus-ID: 22:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp34s0 state: down mac: <filter>
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
v: 0.8 bus-ID: 5-4:4 chip-ID: 8087:0025 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 465.76 GiB used: 109.06 GiB (23.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 rotation: SSD serial: <filter> rev: 2B2QEXE7 temp: 29.9 C
scheme: GPT
ID-1: / raw-size: 20 GiB size: 19.56 GiB (97.81%) used: 18.33 GiB (93.7%)
fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
uuid: 88ec38db-9f99-4ff1-8f7a-41b7f1ec6589
used: 25.2 MiB (26.2%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 2ACF-93D6
ID-3: /home raw-size: 236.29 GiB size: 231.58 GiB (98.01%)
used: 90.71 GiB (39.2%) fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8
label: N/A uuid: d1447f1e-654f-435c-9153-0b6e4472eb4e
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 2 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
uuid: afd121e3-cca8-40fd-8535-3e241d39435c
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 529 MiB fs: ntfs label: Recovery
uuid: 34DECF54DECF0CD4
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 206.34 GiB fs: ntfs label: N/A
uuid: 9C0CD0A00CD076AC
ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 512 MiB fs: vfat label: N/A
uuid: 1EB7-C94B
Device-1: 1-2:2 info: Blue Microphones Yeti Stereo Microphone
type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: b58e:9e84 class-ID: 0300
serial: <filter>
Device-2: 1-4:3 info: Holtek Keyboard type: Keyboard,Mouse
power: 100mA chip-ID: 04d9:2323 class-ID: 0301
Device-3: 1-8:4 info: Logitech G9x Laser Mouse type: Mouse,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 98mA
chip-ID: 046d:c066 class-ID: 0300 serial: <filter>
Device-4: 1-9:5 info: LazyDesigners THE50 type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 500mA chip-ID: feed:0050 class-ID: 0300
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 5-2:2 info: Wacom PTH-660 [Intuos Pro (M)] type: HID
driver: usbhid,wacom interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 500mA
chip-ID: 056a:0357 class-ID: 0300 serial: <filter>
Device-2: 5-3:3 info: Micro Star PRO CARBON type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 500mA chip-ID: 1462:7b85 class-ID: 0300 serial: <filter>
Device-3: 5-4:4 info: Intel Wireless-AC 9260 Bluetooth Adapter
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0025 class-ID: e001
Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 46.9 C mobo: 0 C gpu: nouveau temp: 25.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 887
Processes: 302 Uptime: 2d 20h 18m wakeups: 4 Init: systemd v: 247
tool: systemctl Compilers: gcc: 10.2.0 Packages: pacman: 1264 lib: 413
flatpak: 0 Shell: Bash v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.04
Fabby
26 May 2021 07:45
4
You’ve got 2 audio sources and nVidia seems to be #1 .
Can you:
pamac install alsa-tools
hdajackretask
and tell us what pins are connected to what in both nVidia and AMD?
blp92
27 May 2021 15:39
5
Did that above and here’s a screenshot of the resulting hdaretask window:
Fabby
29 May 2021 08:13
6
That’s the realtek only. Can you change the Select a coded drop-down in the upper left corner to nVidia and give me that one too, please?
You should consider updating motherboard BIOS as it mentions a fix is included for audio
that might help resolve the intermittent problem on your system
B450-GAMING-PRO-CARBON-AC | MSI Global
Version - 7B85v1C
Release Date - 2020-06-15
Updated AMD AGESA ComboAm4PI 1.0.0.6
Fix HDMI audio lost issue when use AMD RX570 vga card.
If system is dual-boot with a Windows OS, audio devices might be affected by Fast Startup
Intermittent problem - sometimes no sound after boot
Most of the time I boot up and sound works fine, but less often when I boot into the system there is no sound and I have to reboot
Are you dual-booting with Windows?
Is the audio device missing after selecting ‘Restart’ from other OS, then booting to Manjaro?
If ‘Shutdown’ is used to close other OS instead of ‘Restart’, is the audio device detected OK ?
If the answer to all 3 of those questions is yes, the problem is in Windows not Linux
the solution is to Turn Off Fast Startup in Windows 10
blp92
29 May 2021 17:14
8
Here’s the Nvidia screenshot.
I do have dual boot but I do not have fast start enabled, iirc that was supposed to be disabled to get the system clocks to synchronize correctly so it’s never been enabled for me.
updating the mobo drivers is something I should do in the Windows side too right?
Fabby
29 May 2021 20:08
9
You have an UEFI system, so should just upgrade the firmware once: your choice Windows or Manjaro.
Try that first and then report back if that automagically solves your issue.
If it doesn’t check of the two screenshots you’ve posted are still the same and provide the textual output of the dropdown box of hdajackretask and please confirm you don’t get any input or output or both. (Original only mentions input)
blp92
3 June 2021 17:08
10
I’ve updated the BIOS on my motherboard and now GRUB is bypassed and my system only boots into windows without the option to select Manjaro…that feels bad
I suppose I need to check my boot priorities but I can’t remember what the boot option is for GRUB
blp92
3 June 2021 17:19
11
I tried to run CMD as admin and then input
bcdedit /set {bootmgr} path \EFI\manjaro\grubx64.efi
it said operation completed successfully yet when I reboot it still goes straight to Windows. When I open the boot options in BIOS it only lists Windows boot manager as an option and I don’t see an option for GRUB
Fabby
3 June 2021 20:57
12
Urgh! Boot a Manjaro live USB and execute:
grub-install /dev/XdY
Where X and Y denominate your boot drive under Manjaro.
P.S. Never try a Windows solution on a Linux system (though the reverse may be true)
blp92
9 June 2021 21:11
13
I guess it’s been too long since I’ve done something like this, I’m running into issues
I run lsblk and get
lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
loop0 7:0 0 84.7M 1 loop /run/miso/sfs/livefs
loop1 7:1 0 395.7M 1 loop /run/miso/sfs/mhwdfs
loop2 7:2 0 1.2G 1 loop /run/miso/sfs/desktopfs
loop3 7:3 0 692.2M 1 loop /run/miso/sfs/rootfs
sda 8:0 1 57.8G 0 disk /run/miso/bootmnt
├─sda1 8:1 1 2.4G 0 part
└─sda2 8:2 1 4M 0 part
nvme0n1 259:0 0 465.8G 0 disk
├─nvme0n1p1 259:1 0 529M 0 part
├─nvme0n1p2 259:2 0 100M 0 part
├─nvme0n1p3 259:3 0 16M 0 part
├─nvme0n1p4 259:4 0 206.3G 0 part
├─nvme0n1p5 259:5 0 512M 0 part
├─nvme0n1p6 259:6 0 2G 0 part
├─nvme0n1p7 259:7 0 20G 0 part
└─nvme0n1p8 259:8 0 236.3G 0 part
512 is the right size for my boot partition, so I tried grub-install /dev/nvme0n1p5 but that gives an error:
Installing for x86_64-efi platform.
grub-install: error: cannot find EFI directory.
Fabby
10 June 2021 07:45
14
The correct way is: grub-install device not grub-install partition so execute:
blp92
10 June 2021 18:12
15
I get the same error with that:
[manjaro@manjaro Desktop]$ grub-install /dev/nvme0n1
Fabby
12 June 2021 07:42
16
blp92
6 September 2021 03:15
17
when I get to the step of
manjaro-chroot -a
I get
bash: manjaro-chroot: command not found
another curious thing I just realized is that when I entered super user there was no username/password check
[manjaro@manjaro Desktop]$ su
[manjaro Desktop]#
winnie
6 September 2021 05:28
18
Once you get back into a working system, try this:
Stop pulseaudio service with,
systemctl --user stop pulseaudio.service
Remove everything under ~/.config/pulse/
Edit /etc/pulse/client.conf and change it to,
autospawn = yes
Start pulseaudio service with,
systemctl --user start pulseaudio.service
(Optionally) Reboot your computer
winnie
6 September 2021 05:32
19
That’s normal behavior for a live USB session. It’s not really anyone’s personal system, thus no need for passphrase protection.
blp92
6 September 2021 19:14
20
Will do when I get there, trying to follow the GRUB/restore the GRUB guide. This time
manjaro-chroot -a
gave the output
grub-probe: error: cannot find a GRUB drive for /dev/sda1. Check your device.map.
==> Mounting (ManjaroLinux) [/dev/nvme0n1p7]
--> mount: [/mnt]
mount: /mnt: /dev/nvme0n1p7 already mounted on /mnt.
--> mount: [/mnt/boot/efi]
mount: /mnt/boot/efi: /dev/nvme0n1p2 already mounted on /mnt/boot/efi.
and so I went to check my /etc/fstab and it looks like that file somehow was overwritten in the Windows update? At least it doesn’t list all the partitions it should. Here is what I see:
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=2ACF-93D6 /boot/efi vfat umask=0077 0 2
UUID=88ec38db-9f99-4ff1-8f7a-41b7f1ec6589 / ext4 defaults,noatime 0 1
UUID=d1447f1e-654f-435c-9153-0b6e4472eb4e /home ext4 defaults,noatime 0 2
UUID=afd121e3-cca8-40fd-8535-3e241d39435c none swap defaults 0 0
should I continue with the grub re-install?
Also, dumb question, but once this is done what is the command to unmount all before rebooting? Or can I just reboot and see if I get to GRUB?
