Either way I try to run pacman -Syu grub as per the guide it seems to fail:
[manjaro /]# pacman -Syu grub
core is up to date
extra is up to date
community is up to date
multilib is up to date
:: Replace jack with extra/jack2? [Y/n] Y
:: Replace lib32-jack with multilib/lib32-jack2? [Y/n] Y
:: Replace lib32-libcanberra-pulse with multilib/lib32-libcanberra? [Y/n] Y
:: Replace libcanberra-pulse with extra/libcanberra? [Y/n] Y
:: Replace pamac-common with extra/libpamac? [Y/n] Y
:: Replace pamac-flatpak-plugin with extra/libpamac-flatpak-plugin? [Y/n] Y
:: Replace pamac-snap-plugin with extra/libpamac-snap-plugin? [Y/n] Y
resolving dependencies...
:: installing lib32-libcanberra (0.30+2+gc0620e4-5) breaks dependency 'lib32-libcanberra=0.30+2+gc0620e4-3' required by lib32-libcanberra-gstreamer
:: installing libcanberra (0.30+2+gc0620e4-5) breaks dependency 'libcanberra=0.30+2+gc0620e4-3' required by libcanberra-gstreamer
core is up to date
extra is up to date
:: Replace jack with extra/jack2? [Y/n] n
:: Replace lib32-jack with multilib/lib32-jack2? [Y/n] n
:: Replace lib32-libcanberra-pulse with multilib/lib32-libcanberra? [Y/n] n
:: Replace libcanberra-pulse with extra/libcanberra? [Y/n] n
:: Replace pamac-common with extra/libpamac? [Y/n] n
:: Replace pamac-flatpak-plugin with extra/libpamac-flatpak-plugin? [Y/n] n
:: Replace pamac-snap-plugin with extra/libpamac-snap-plugin? [Y/n] n
:: libpamac and pamac-common are in conflict. Remove pamac-common? [y/N] N
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
This is what gives me the most pause, however.
[manjaro /]# lsblk -o PATH,PTTYPE,PARTTYPE,FSTYPE,PARTTYPENAME
PATH PTTYPE PARTTYPE FSTYPE PARTTYPENAME
/dev/loop0
/dev/loop1
/dev/loop2
/dev/loop3
/dev/sda
/dev/sda1
/dev/sda2
/dev/nvme0n1
/dev/nvme0n1p1
/dev/nvme0n1p2
/dev/nvme0n1p3
/dev/nvme0n1p4
/dev/nvme0n1p5
/dev/nvme0n1p6
/dev/nvme0n1p7
/dev/nvme0n1p8
Shouldn’t I be getting those PTTYPE, PARTTYPE, etc fields populated with something?
You have a really sick puppy there, so I’m going to call in our resident UEFI expert @stephane
Summary:
gives the above errors…
first you boot on USB iso manjaro live
open a terminal and return
inxi -Mxa
test -d /sys/firmware/efi && echo efi || echo bios
sudo efibootmgr -v
sudo parted -l
sudo lsblk -fs
Here’s the output of the commands asked for, I appreciate the help. I’m curious what went wrong because I want to learn from this so I put some questions/my understanding at the end – feel free to ignore
[manjaro@manjaro Desktop]$ inxi -Mxa
Type: Desktop Mobo: Micro-Star model: B450 GAMING PRO CARBON AC (MS-7B85)
v: 1.0 serial: <superuser required> UEFI: American Megatrends LLC. v: 1.F4
date: 04/22/2021
[manjaro@manjaro Desktop]$ test -d /sys/firmware/efi && echo efi || echo bios
efi
[manjaro@manjaro Desktop]$ sudo efibootmgr -v
BootCurrent: 0007
Timeout: 1 seconds
BootOrder: 0000,0004,0002,0007,0006,0001,0005
Boot0000* Windows Boot Manager HD(2,GPT,4b35f749-00e9-4788-87a8-5e6c03abd4c1,0x109000,0x32000)/File(\EFI\MICROSOFT\BOOT\BOOTMGFW.EFI)WINDOWS.........x...B.C.D.O.B.J.E.C.T.=.{.9.d.e.a.8.6.2.c.-.5.c.d.d.-.4.e.7.0.-.a.c.c.1.-.f.3.2.b.3.4.4.d.4.7.9.5.}...9................
Boot0001 Hard Drive BBS(HD,,0x0)/VenHw(5ce8128b-2cec-40f0-8372-80640e3dc858,0200)..GO..NO..........S.a.m.s.u.n.g. .S.S.D. .9.7.0. .E.V.O. .5.0.0.G.B...................\.,.@.r.d.=.X..........A...........................%8T.B~}.....4..Gd-.;.A..MQ..L.S.5.H.7.N.J.0.N.4.1.4.1.6.7.L........BO
Boot0002* manjaro HD(2,GPT,4b35f749-00e9-4788-87a8-5e6c03abd4c1,0x109000,0x32000)/File(\EFI\MANJARO\GRUBX64.EFI)
Boot0004* UEFI OS HD(5,GPT,a54c3b62-5111-f040-b0c4-ff899245d586,0x19df2000,0x100000)/File(\EFI\BOOT\BOOTX64.EFI)..BO
Boot0005 USB HDD BBS(HD,,0x0)/VenHw(5ce8128b-2cec-40f0-8372-80640e3dc858,0900)..GO..NO..........K.i.n.g.s.t.o.n.D.a.t.a.T.r.a.v.e.l.e.r. .3...0.P.M.A.P...................\.,.@.r.d.=.X..........A.............................F..Gd-.;.A..MQ..L.6.0.A.4.4.C.4.1.3.D.F.8.E.4.9.1.1.9.2.E.0.4.A.3........BO
Boot0006* UEFI: KingstonDataTraveler 3.0PMAP PciRoot(0x0)/Pci(0x1,0x3)/Pci(0x0,0x0)/USB(2,0)/CDROM(1,0x4d88ac,0x8000)..BO
Boot0007* UEFI: KingstonDataTraveler 3.0PMAP, Partition 2 PciRoot(0x0)/Pci(0x1,0x3)/Pci(0x0,0x0)/USB(2,0)/HD(2,MBR,0x0,0x4d88ac,0x2000)..BO
[manjaro@manjaro Desktop]$ sudo parted -l
Model: Kingston DataTraveler 3.0 (scsi)
Disk /dev/sda: 62.1GB
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
2 2602MB 2606MB 4194kB primary esp
Model: Samsung SSD 970 EVO 500GB (nvme)
Disk /dev/nvme0n1: 500GB
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 556MB 555MB ntfs Basic data partition hidden, diag
2 556MB 661MB 105MB fat32 EFI system partition boot, esp
3 661MB 677MB 16.8MB Microsoft reserved partition msftres
4 677MB 222GB 222GB ntfs Basic data partition msftdata
5 222GB 223GB 537MB fat32 msftdata
6 223GB 225GB 2147MB linux-swap(v1) swap
7 225GB 246GB 21.5GB ext4
8 246GB 500GB 254GB ext4
[manjaro@manjaro Desktop]$ sudo lsblk -fs
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINT
loop0 squashfs 4.0 0 100% /run/miso/sfs/livefs
loop1 squashfs 4.0 0 100% /run/miso/sfs/mhwdfs
loop2 squashfs 4.0 0 100% /run/miso/sfs/desktopfs
loop3 squashfs 4.0 0 100% /run/miso/sfs/rootfs
sda1 iso9660 Joliet Extension MANJARO_XFCE_2106 2021-06-07-19-55-50-00
└─sda iso9660 Joliet Extension MANJARO_XFCE_2106 2021-06-07-19-55-50-00 0 100% /run/miso/bootmnt
sda2 vfat FAT12 MISO_EFI 4A03-D73C
nvme0n1p1 ntfs Recovery 34DECF54DECF0CD4
└─nvme0n1
nvme0n1p2 vfat FAT32 2ACF-93D6
└─nvme0n1
nvme0n1p3
└─nvme0n1
nvme0n1p4 ntfs 9C0CD0A00CD076AC
└─nvme0n1
nvme0n1p5 vfat FAT32 1EB7-C94B
└─nvme0n1
nvme0n1p6 swap 1 afd121e3-cca8-40fd-8535-3e241d39435c
└─nvme0n1
nvme0n1p7 ext4 1.0 88ec38db-9f99-4ff1-8f7a-41b7f1ec6589
└─nvme0n1
nvme0n1p8 ext4 1.0 d1447f1e-654f-435c-9153-0b6e4472eb4e
└─nvme0n1
This all started when I update mobo drivers on Windows (I did the guide by aarhus found here which has Windows first, so all my drivers were windows side).
It looks like this somehow overwrote my GRUB and windows MBR is the default, correct? I suspect my /etc/fstab might be slightly off as well because it doesn’t have entries for all the partitions I remember, but it seems weird that a Windows update would be able to edit that?
This is your default, based on your output:
You can temporarily override this during the boot sequence by pressing and holding down (or repeatedly pressing!) ESC, F9, F10, or whichever key is assigned to Boot Override for your particular computer.
You can use efibootmgr to re-arrange the order of boot priority, and place manjaro as the first entry:
efibootmgr -o 0002,0000,0004,0007,0006,0001,0005
0002 is manjaro
0000 is Windows Boot Manager
The rest are “whatever”.
However, this is all possible to do within your BIOS setup screen when you first boot up. Once again, you need to know the correct key to press to access it (DEL, ESC, F10, etc)
@stephane interject if I’m mistaken about anything. I replied once I saw their output (from the supplied commands) in case they have a time constraint and need to try something as soon as possible.
I truly appreciate that. I would like to get back to a point that GRUB is frist so that I can set the grub window time and have 3-5 seconds to choose which OS to boot to since I restart frequently.
I’m in MDT (UTC -7:00) and I have the rest of the day tomorrow to trouble shoot, but hopefully it won’t take that
there are 2 partitions /boot/efi ,only the one with option flag boot& esp works
p2 contains windows boot
p5 contains manjaro boot
you CANT have 2 /boot/efi on same disk , only one with flag boot&esp will works
What Stéphane is trying to tell you is:
- You have a very sick puppy
- Better euthanise it
- Get a new puppy:
- back up all of your data, (Cold System Backup will be enough, use an external USB stick with CloneZilla Live
- wipe all your Manjaro partitions (Keep all the Windows ones!)
- install again using one single ESP (EFI System Partition)
- Restore your data
It’s not impossible to merge 2 ESPs, but looking at all the other problems you have, a reinstall will definitely be easier. Therefore, please read this first:
(All of it: I’ll be adding an UEFI / BIOS section later)
Then go back to point 3 above.
Stéphane: I’ll ping you over there to verify anything I’ve written as you’re the EIF Guru here… ![]()
Have read through both, thank you. I have a brand new external HDD I was going to use for backups, so now is the opportune time for that I guess. Will it need formatting first?
Just to check: I’ll be booting to my Manjaro OS to make the backup using CLoneZilla live, correct? Or should it be done from the Manjaro live media on my USB?
Yes.
You didn’t read the CloneZilla link yet, did you??? ![]()
Something else:
- You should “burn” the CloneZilla Live
.isoto a USB stick - You should burn another USB stick with the Manjaro
.iso - Boot and make the backup with the CloneZilla USB using Disk-to-Image.
- Reinstall using the Manjaro USB stick
- If you mess up, you boot the bootable CloneZilla USB stick and restore. (Don’t overwrite it with but keep it handy! 2 USB sticks needed!)
"You didn’t read the CloneZilla link yet, did you??? "
I did, but it begins by saying to download the CloneZilla Live but considering my situation I wasn’t sure if this should be done via the Manjaro ISO or booting into my Manjaro OS, sorry
No apologies needed: I was unclear…
Anyway, as you’re re-formatting your system with your new-found wisdom, Stéphane’s answer was the best you got as he found the root cause of your issue, therefore, I’ve marked his answer as the solution to your question.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or
or
if you agree)
P.S. In the future, please don’t forget to come back to your question after your issue has been solved and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
Appreciate all the help. I’m not trying to be truant in marking what worked well for me I just haven’t gotten around to doing the full repair on my system yet. In the middle of a cross-country move and still feeling quite scattered.
Hoping to have it all solved and restored to normal this weekend
Open a new post for each individual issue you (would) run into, please.
Success with the move!
