Program links are not working
I can’t open any program from taskbar. A small icon just hopping near cursor. I can just open pamac and I can run programs from there. What can I do?
When did this start happening?
looks like this could be it:
I used airmon-ng after that I just restrat my computer than I can’t open that.
no it is not working :frowning:
Hi and welcome to the Forum :+1:
In what way, how did you use airmon-ng, and how did you install it etc etc etc…
If you keep being this cryptic no one will be able to assist.
If that program caused your problem, the first reaction anyone would do is to uninstall that program..
Please read and follow the link posted in reply 1 just under your Original post…
