my nvidia driver and . intel driver. How can i switch my card to nVidia? GitHub - dglt1/optimus-switch-sddm: easy installer for optimus-switch for SDDM, sets up nvidia PRIME and also allows for easy switching between intel/nvidia (prime mode) and intel only mode where nvidia gpu is powered down and no longer visible. modes are switched with "sudo set-intel.sh" or "sudo set-nvidia.sh" . breaks my system(I read the entire instruction). Also i tryed this solution: Need help with PRIME render offload - Linux - NVIDIA Developer Forums P.s. nvidia-390xx doesnt support nvidia prime render offload. $ inxi -G Graphics: Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics driver: i915 v: kernel Device-2: NVIDIA GF119M [GeForce GT 520MX] driver: nvidia v: 390.132 Device-3: Alcor Micro Asus Integrated Webcam type: USB driver: uvcvideo Display: x11 server: X.Org 1.20.9 driver: intel resolution: 1366x768~60Hz OpenGL: renderer: Mesa DRI Intel HD Graphics 3000 (SNB GT2) v: 3.3 Mesa 20.1.8
I also activated bumblebee:
sudo pacman -S bumblebee virtualgl bbswitch acpid mesa
sudo systemctl enable bumblebeed.service
sudo systemctl enable acpid.service
sudo usermod -a -G bumblebee $USER``
pobrn
18 October 2020 17:49
2
If you want to use the integrated display on your device, then the intel gpu needs to be active. (Except if you have an option in the BIOS to switch the integrated display to the nvidia gpu.)
lol, I said that I want to activate NVIDIA, but not intel
So, i dont have that option in BIOS, please help, how to activate nVidia?
pobrn
18 October 2020 18:34
6
Please read this thread and see if the solution there works for you.
no, it doesnt work too( i tried this
pobrn
18 October 2020 19:26
8
So you followed these steps Bumblebee driver not working and it it still gives the same error?
yep, i followed, but it still gives same error
pobrn
18 October 2020 19:43
11
Has it ever worked in the past or is this the first time you try it?
also i activated MODULES=(nvidia nvidia_modeset nvidia_uvm nvidia_drm) in /etc/mkinitcpio.conf ;
and GRUB_CMDLINE_LINUX_DEFAULT="nvidia-drm.modeset=1" in /etc/default/grub
i try it for the first time
pobrn
18 October 2020 19:45
14
This shouldn’t be necessary, furthermore, there is no such module as nvidia_modeset, so please remove it.
pobrn
18 October 2020 19:48
15
Please run optirun glxinfo, then if it fails, find the latest Xorg log in ~/.local/share/xorg/ or /var/log/ and post it.
Also post the output of ls -lR /etc/X11 /etc/bumblebee.
[ 81.340]
X.Org X Server 1.20.9
[ 81.340] Build Operating System: Linux Manjaro Linux
[ 81.340] Current Operating System: Linux comp 5.8.11-1-MANJARO #1 SMP PREEMPT Wed Sep 23 14:35:40 UTC 2020 x86_64
[ 81.340] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=f846ca6e-0d43-4bc2-abbc-02c1e3859d9e rw nvidia-drm.modeset=1
[ 81.340] Build Date: 02 September 2020 07:39:17AM
[ 81.340]
[ 81.340] Current version of pixman: 0.40.0
[ 81.340] Before reporting problems, check http://wiki.x.org
[ 81.340] Markers: (--) probed, (**) from config file, (==) default setting,
[ 81.340] (==) Log file: "/var/log/Xorg.8.log", Time: Sun Oct 18 22:52:24 2020
[ 81.341] (++) Using config file: "/etc/bumblebee/xorg.conf.nvidia"
[ 81.341] (++) Using config directory: "/etc/bumblebee/xorg.conf.d"
[ 81.341] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 81.342] (==) ServerLayout "Layout0"
[ 81.342] (==) No screen section available. Using defaults.
[ 81.342] (**) |-->Screen "Default Screen Section" (0)
[ 81.342] (**) | |-->Monitor "<default monitor>"
[ 81.342] (==) No device specified for screen "Default Screen Section".
Using the first device section listed.
[ 81.342] (**) | |-->Device "Device1"
[ 81.342] (==) No monitor specified for screen "Default Screen Section".
[ 81.342] (**) Option "AutoAddDevices" "false"
[ 81.342] (**) Not automatically adding devices
[ 81.342] (==) Automatically enabling devices
[ 81.342] (==) Automatically adding GPU devices
[ 81.342] (==) Automatically binding GPU devices
[ 81.342] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 81.342] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/misc".
[ 81.342] Entry deleted from font path.
[ 81.342] (Run 'mkfontdir' on "/usr/share/fonts/misc").
[ 81.342] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/TTF".
[ 81.342] (Run 'mkfontdir' on "/usr/share/fonts/TTF").
[ 81.342] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 81.342] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 81.342] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 81.342] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 81.342] (==) FontPath set to:
[ 81.342] (++) ModulePath set to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules"
[ 81.342] (==) |-->Input Device "<default pointer>"
[ 81.342] (==) |-->Input Device "<default keyboard>"
[ 81.342] (==) The core pointer device wasn't specified explicitly in the layout.
Using the default mouse configuration.
[ 81.342] (==) The core keyboard device wasn't specified explicitly in the layout.
Using the default keyboard configuration.
[ 81.342] (II) Module ABI versions:
[ 81.342] X.Org ANSI C Emulation: 0.4
[ 81.342] X.Org Video Driver: 24.1
[ 81.342] X.Org XInput driver : 24.1
[ 81.342] X.Org Server Extension : 10.0
[ 81.344] (--) using VT number 1
[ 81.344] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 81.345] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 81.345] (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/drm/card0
[ 81.347] (--) PCI: (1@0:0:0) 10de:1051:0000:0000 rev 161, Mem @ 0xdb000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000d000/128, BIOS @ 0x????????/524288
[ 81.348] (II) Open ACPI successful (/var/run/acpid.socket)
[ 81.348] (II) LoadModule: "glx"
[ 81.348] (II) Loading /usr/lib/nvidia/xorg/libglx.so
[ 81.445] (II) Module glx: vendor="NVIDIA Corporation"
[ 81.445] compiled for 4.0.2, module version = 1.0.0
[ 81.445] Module class: X.Org Server Extension
[ 81.446] (II) NVIDIA GLX Module 390.132 Fri Nov 1 04:00:46 PDT 2019
[ 81.447] (II) LoadModule: "nvidia"
[ 81.447] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 81.456] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 81.456] compiled for 4.0.2, module version = 1.0.0
[ 81.456] Module class: X.Org Video Driver
[ 81.457] (II) LoadModule: "mouse"
[ 81.457] (WW) Warning, couldn't open module mouse
[ 81.457] (EE) Failed to load module "mouse" (module does not exist, 0)
[ 81.457] (II) LoadModule: "kbd"
[ 81.457] (WW) Warning, couldn't open module kbd
[ 81.457] (EE) Failed to load module "kbd" (module does not exist, 0)
[ 81.458] (II) NVIDIA dlloader X Driver 390.132 Fri Nov 1 03:36:28 PDT 2019
[ 81.458] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 81.460] (II) Loading sub module "fb"
[ 81.460] (II) LoadModule: "fb"
[ 81.460] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 81.462] (II) Module fb: vendor="X.Org Foundation"
[ 81.462] compiled for 1.20.9, module version = 1.0.0
[ 81.462] ABI class: X.Org ANSI C Emulation, version 0.4
[ 81.462] (II) Loading sub module "wfb"
[ 81.462] (II) LoadModule: "wfb"
[ 81.462] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 81.464] (II) Module wfb: vendor="X.Org Foundation"
[ 81.464] compiled for 1.20.9, module version = 1.0.0
[ 81.464] ABI class: X.Org ANSI C Emulation, version 0.4
[ 81.464] (II) Loading sub module "ramdac"
[ 81.464] (II) LoadModule: "ramdac"
[ 81.464] (II) Module "ramdac" already built-in
[ 81.468] (II) NVIDIA(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 81.468] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 81.468] (==) NVIDIA(0): RGB weight 888
[ 81.468] (==) NVIDIA(0): Default visual is TrueColor
[ 81.468] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 81.468] (**) NVIDIA(0): Option "UseEDID" "false"
[ 81.468] (**) NVIDIA(0): Option "ConnectedMonitor" "DFP"
[ 81.468] (**) NVIDIA(0): Enabling 2D acceleration
[ 81.468] (**) NVIDIA(0): ConnectedMonitor string: "DFP"
[ 81.468] (**) NVIDIA(0): Ignoring EDIDs
[ 81.535] (EE) NVIDIA(GPU-0): Failed to initialize the NVIDIA GPU at PCI:1:0:0. Please
[ 81.535] (EE) NVIDIA(GPU-0): check your system's kernel log for additional error
[ 81.535] (EE) NVIDIA(GPU-0): messages and refer to Chapter 8: Common Problems in the
[ 81.535] (EE) NVIDIA(GPU-0): README for additional information.
[ 81.535] (EE) NVIDIA(GPU-0): Failed to initialize the NVIDIA graphics device!
[ 81.535] (EE) NVIDIA(0): Failing initialization of X screen 0
[ 81.535] (II) UnloadModule: "nvidia"
[ 81.535] (II) UnloadSubModule: "wfb"
[ 81.535] (II) UnloadSubModule: "fb"
[ 81.535] (EE) Screen(s) found, but none have a usable configuration.
[ 81.535] (EE)
Fatal server error:
[ 81.535] (EE) no screens found(EE)
[ 81.535] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 81.535] (EE) Please also check the log file at "/var/log/Xorg.8.log" for additional information.
[ 81.535] (EE)
[ 81.535] (EE) Server terminated with error (1). Closing log file.
k, bb i will be here tommorow(10:00 MSK)
pobrn
18 October 2020 20:02
18
Please run sudo dmesg | grep -i nvidia.
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=f846ca6e-0d43-4bc2-abbc-02c1e3859d9e rw nvidia-drm.modeset=1
[ 0.051687] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=f846ca6e-0d43-4bc2-abbc-02c1e3859d9e rw nvidia-drm.modeset=1
[ 43.488530] nvidia: module license 'NVIDIA' taints kernel.
[ 43.516049] nvidia-nvlink: Nvlink Core is being initialized, major device number 235
[ 44.017140] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[ 44.017539] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 390.132 Fri Nov 1 00:40:14 PDT 2019 (using threaded interrupts)
[ 44.029675] audit: type=1130 audit(1603050707.482:72): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=load-nvidia comm="systemd" exe="/usr/lib/systemd/systemd
" hostname=? addr=? terminal=? res=success'
[ 44.029686] audit: type=1131 audit(1603050707.482:73): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=load-nvidia comm="systemd" exe="/usr/lib/systemd/systemd
[ 81.514834] caller _nv027774rm+0x58/0x90 [nvidia] mapping multiple BARs
pobrn
18 October 2020 20:06
20
Please start sudo dmesg -w, then in a different terminal run optirun glxgears, post anything that appears in the first terminal after you ran optirun. Also check if nvidia-smi works.
