Problems with keyring (andrew@archlinux.org)
For a few weeks now I have been having update problems on various Manjaro computers. They were all solvable, but why are they now appearing so frequently?
The problems always affect the Arch Linux keyring and “Daniel M. Capella” several times.
This post
says:
but i find that:
systemctl status archlinux-keyring-wkd-sync        [4]
● archlinux-keyring-wkd-sync.service - Refresh existing keys of archlinux-keyring
     Loaded: loaded (/usr/lib/systemd/system/archlinux-keyring-wkd-sync.service; static)
     Active: activating (auto-restart) (Result: exit-code) since Sun 2024-12-08 14:56:29 CET; 1min 36s ago
 Invocation: 78a52da3d7bf465588b90eb2ce06e07d
TriggeredBy: ● archlinux-keyring-wkd-sync.timer
    Process: 13817 ExecStart=/usr/bin/archlinux-keyring-wkd-sync (code=exited, status=1/FAILURE)
   Main PID: 13817 (code=exited, status=1/FAILURE)
   Mem peak: 8.3M
        CPU: 5.655s
the mentioned process died ?!?
What exactly is the problem? Show logs.
If this is outdated key, you can remove it manually from database or leave as it is – this won’t break anything except failing archlinux-keyring-wkd-sync service at the end.
The problems where already solved by reinstalling the keyrings (manjaro and arch) :footprints:
What log do you suggest ?
I have /var/log/pacman.log on all 5 machines
But these are big.
manjaro18
cat pacman.log|grep -E '(ALPM|PACMAN).{10,100}(manjaro|archlinux)-keyring'        [1]
[2018-09-15 12:47] [ALPM] installed archlinux-keyring (20180808-1)
[2018-09-15 12:47] [ALPM] installed manjaro-keyring (20180607-1)
[2018-10-11 16:50] [ALPM] upgraded archlinux-keyring (20180808-1 -> 20181003-1)
[2018-10-11 18:04] [PACMAN] Running 'pacman -Sy gnupg archlinux-keyring manjaro-keyring'
[2018-10-31 11:02] [ALPM] upgraded archlinux-keyring (20181003-1 -> 20181018-1)
[2018-11-10 15:41] [ALPM] upgraded archlinux-keyring (20181018-1 -> 20181031-1)
[2018-12-04 20:12] [ALPM] upgraded archlinux-keyring (20181031-1 -> 20181128-1)
[2019-01-01 07:49] [ALPM] upgraded archlinux-keyring (20181128-1 -> 20181218-1)
[2019-02-10 20:39] [ALPM] upgraded archlinux-keyring (20181218-1 -> 20190123-1)
[2019-02-23 13:19] [ALPM] upgraded archlinux-keyring (20190123-1 -> 20190123-2)
[2019-05-17 18:00] [ALPM] upgraded manjaro-keyring (20180607-1 -> 20190512-1)
[2019-07-13 16:49] [ALPM] upgraded manjaro-keyring (20190512-1 -> 20190608-1)
[2019-07-13 17:11] [PACMAN] Running 'pacman -S manjaro-keyring'
[2019-07-13 17:12] [PACMAN] Running 'pacman -S manjaro-keyring archlinux-keyring'
[2019-07-13 17:51] [ALPM-SCRIPTLET] # Found snapshot: 2019-07-13 16:49:16 | @snapshots/3654/snapshot | post   | manjaro-keyring
[2019-07-13 17:53] [ALPM-SCRIPTLET] # Found snapshot: 2019-07-13 16:49:16 | @snapshots/3654/snapshot | post   | manjaro-keyring
[2019-08-15 15:08] [ALPM] upgraded archlinux-keyring (20190123-2 -> 20190805-1)
[2019-08-15 15:10] [ALPM-SCRIPTLET] # Found snapshot: 2019-08-15 15:08:06 | @snapshots/4309/snapshot | post   | archlinux-keyring
[2019-09-05 10:37] [ALPM] upgraded archlinux-keyring (20190805-1 -> 20190827-1)
[2019-09-05 10:37] [ALPM-SCRIPTLET] '/var/cache/pacman/pkg/archlinux-keyring-20190123-2-any.pkg.tar.xz' wurde entfernt
[2019-09-08 21:01] [ALPM-SCRIPTLET] # Found snapshot: 2019-09-05 10:37:08 | @snapshots/4724/snapshot | post   | archlinux-keyring
[2019-10-13 11:32] [ALPM] upgraded archlinux-keyring (20190827-1 -> 20191007-1)
[2019-10-13 11:39] [ALPM-SCRIPTLET] # Found snapshot: 2019-10-13 11:33:02 | @snapshots/5609/snapshot | post   | archlinux-keyring
[2019-11-02 07:36] [ALPM] upgraded archlinux-keyring (20191007-1 -> 20191018-1)
[2019-11-02 07:36] [ALPM-SCRIPTLET] '/var/cache/pacman/pkg/archlinux-keyring-20190827-1-any.pkg.tar.xz' wurde entfernt
[2019-11-02 07:55] [ALPM-SCRIPTLET] # Found snapshot: 2019-11-02 07:36:55 | @snapshots/6034/snapshot | post   | archlinux-keyring
[2019-12-12T08:58:44+0100] [ALPM] upgraded archlinux-keyring (20191018-1 -> 20191018-2)
[2019-12-12T09:08:30+0100] [ALPM-SCRIPTLET] # Found snapshot: 2019-12-12 08:58:46 | @snapshots/6607/snapshot | post   | archlinux-keyring manjaro-system
[2019-12-30T20:40:02+0100] [ALPM] upgraded archlinux-keyring (20191018-2 -> 20191219-1)
[2019-12-30T20:40:07+0100] [ALPM-SCRIPTLET] '/var/cache/pacman/pkg/archlinux-keyring-20191018-1-any.pkg.tar.xz' wurde entfernt
[2019-12-31T08:39:11+0100] [ALPM-SCRIPTLET] # Found snapshot: 2019-12-30 20:40:07 | @snapshots/7102/snapshot | post   | archlinux-keyring
[2020-01-17T09:45:47+0100] [ALPM] upgraded archlinux-keyring (20191219-1 -> 20200108-1)
[2020-01-17T09:48:36+0100] [ALPM-SCRIPTLET] # Found snapshot: 2020-01-17 09:45:52 | @snapshots/7404/snapshot | post   | archlinux-keyring
[2020-04-24T19:35:00+0200] [ALPM] upgraded manjaro-keyring (20190608-1 -> 20200421-1)
[2020-04-24T19:37:20+0200] [ALPM-SCRIPTLET] # Found snapshot: 2020-04-24 19:35:05 | @snapshots/8902/snapshot | post   | manjaro-keyring
[2020-04-27T08:01:51+0200] [ALPM] upgraded archlinux-keyring (20200108-1 -> 20200422-1)
[2020-04-27T08:04:21+0200] [ALPM-SCRIPTLET] # Found snapshot: 2020-04-27 08:01:59 | @snapshots/8939/snapshot | post   | archlinux-keyring manjaro-system
[2020-04-27T08:04:21+0200] [ALPM-SCRIPTLET] # Found snapshot: 2020-04-24 19:35:05 | @snapshots/8902/snapshot | post   | manjaro-keyring
[2020-06-06T17:14:19+0200] [ALPM] upgraded manjaro-keyring (20200421-1 -> 20200603-1)
[2020-06-16T19:27:24+0200] [ALPM] upgraded archlinux-keyring (20200422-1 -> 20200603-1)
[2020-06-16T19:43:57+0200] [ALPM-SCRIPTLET] # Found snapshot: 2020-06-16 19:27:30 | @snapshots/9905/snapshot | post   | archlinux-keyring
[2020-07-24T18:37:18+0200] [ALPM] upgraded archlinux-keyring (20200603-1 -> 20200622-1)
[2020-07-24T18:48:06+0200] [ALPM-SCRIPTLET] # Found snapshot: 2020-07-24 18:37:24 | @snapshots/10571/snapshot | post   | archlinux-keyring
[2020-07-24T18:50:19+0200] [ALPM-SCRIPTLET] # Found snapshot: 2020-07-24 18:37:24 | @snapshots/10571/snapshot | post   | archlinux-keyring
[2020-09-10T20:07:27+0200] [ALPM] upgraded archlinux-keyring (20200622-1 -> 20200820-1)
[2020-09-10T20:15:50+0200] [ALPM-SCRIPTLET] # Found snapshot: 2020-09-10 20:07:34 | @snapshots/11367/snapshot | post   | archlinux-keyring manjaro-system
[2020-09-13T19:18:04+0200] [ALPM-SCRIPTLET] # Found snapshot: 2020-09-10 20:07:34 | @snapshots/11367/snapshot | post   | archlinux-keyring manjaro-system
[2020-10-21T21:08:44+0200] [ALPM] upgraded manjaro-keyring (20200603-1 -> 20200929-1)
[2020-10-21T21:11:08+0200] [ALPM-SCRIPTLET] Found snapshot: 2020-10-21 21:08:52 | @snapshots/12102/snapshot | post   | manjaro-keyring
[2020-11-18T18:28:35+0100] [ALPM] upgraded archlinux-keyring (20200820-1 -> 20201028-1)
[2020-11-18T18:28:44+0100] [ALPM] upgraded manjaro-keyring (20200929-1 -> 20201030-1)
[2020-11-18T18:37:24+0100] [ALPM-SCRIPTLET] Found snapshot: 2020-11-18 18:28:53 | @snapshots/12649/snapshot | post   | archlinux-keyring manjaro-keyring manjaro-system
[2020-11-18T18:39:34+0100] [ALPM-SCRIPTLET] Found snapshot: 2020-11-18 18:28:53 | @snapshots/12649/snapshot | post   | archlinux-keyring manjaro-keyring manjaro-system
[2020-12-16T20:49:55+0100] [ALPM] upgraded manjaro-keyring (20201030-1 -> 20201216-1)
[2020-12-31T07:57:57+0100] [ALPM] upgraded archlinux-keyring (20201028-1 -> 20201210-1)
[2021-01-01T14:12:05+0100] [ALPM-SCRIPTLET] Found snapshot: 2020-12-31 07:58:05 | @snapshots/13440/snapshot | post   | archlinux-keyring manjaro-system
[2021-01-19T19:51:37+0100] [ALPM] upgraded archlinux-keyring (20201210-1 -> 20210110-1)
[2021-01-19T20:07:44+0100] [ALPM-SCRIPTLET] Found snapshot: 2021-01-19 19:51:49 | @snapshots/13855/snapshot | post   | archlinux-keyring
[2021-07-13T16:47:47+0200] [ALPM] upgraded archlinux-keyring (20210110-1 -> 20210616-1)
[2021-07-13T16:47:52+0200] [ALPM] upgraded manjaro-keyring (20201216-1 -> 20210622-1)
[2021-07-13T17:02:34+0200] [ALPM-SCRIPTLET] Found snapshot: 2021-07-13 16:47:58 | @snapshots/17467/snapshot | post   | archlinux-keyring manjaro-keyring
[2021-08-12T17:57:29+0200] [ALPM] upgraded archlinux-keyring (20210616-1 -> 20210802-1)
[2021-08-12T18:05:45+0200] [ALPM-SCRIPTLET] Found snapshot: 2021-08-12 17:57:37 | @snapshots/18012/snapshot | post   | archlinux-keyring
[2021-08-17T19:54:52+0200] [ALPM] upgraded manjaro-keyring (20210622-1 -> 20210807-2)
[2021-08-17T20:03:31+0200] [ALPM-SCRIPTLET] Found snapshot: 2021-08-17 19:54:59 | @snapshots/18143/snapshot | post   | manjaro-keyring
[2021-09-16T21:07:30+0200] [ALPM] upgraded archlinux-keyring (20210802-1 -> 20210902-1)
[2021-09-16T21:07:35+0200] [ALPM] upgraded manjaro-keyring (20210807-2 -> 20210910-2)
[2021-11-20T08:36:54+0100] [ALPM] upgraded archlinux-keyring (20210902-1 -> 20211028-1)
[2021-11-20T08:58:16+0100] [ALPM-SCRIPTLET] Found snapshot: 2021-11-20 08:37:06 | @snapshots/19800/snapshot | post   | archlinux-keyring
[2021-11-20T09:41:12+0100] [ALPM-SCRIPTLET] Found snapshot: 2021-11-20 08:37:06 | @snapshots/19800/snapshot | post   | archlinux-keyring
[2022-01-23T18:55:24+0100] [ALPM] upgraded archlinux-keyring (20211028-1 -> 20220118-1)
[2022-02-09T07:50:32+0100] [ALPM] upgraded archlinux-keyring (20220118-1 -> 20220125-1)
[2022-02-09T08:08:18+0100] [ALPM-SCRIPTLET] Found snapshot: 2022-02-09 07:50:41 | @snapshots/21474/snapshot | post   | archlinux-keyring manjaro-system                                         |
[2022-03-01T16:39:53+0100] [ALPM] upgraded archlinux-keyring (20220125-1 -> 20220224-1)
[2022-03-01T16:39:59+0100] [ALPM-SCRIPTLET] '/var/cache/pacman/pkg/archlinux-keyring-20220118-1-any.pkg.tar.zst' wurde entfernt
[2022-03-01T16:39:59+0100] [ALPM-SCRIPTLET] '/var/cache/pacman/pkg/archlinux-keyring-20220118-1-any.pkg.tar.zst.sig' wurde entfernt
[2022-03-01T16:55:32+0100] [ALPM-SCRIPTLET] Found snapshot: 2022-03-01 16:40:02 | @snapshots/21850/snapshot | post   | archlinux-keyring                                                        |
[2022-04-21T12:46:52+0200] [ALPM] upgraded manjaro-keyring (20210910-2 -> 20220421-1)
[2022-04-29T16:57:17+0200] [ALPM] upgraded archlinux-keyring (20220224-1 -> 20220424-1)
[2022-05-03T17:32:22+0200] [ALPM] upgraded manjaro-keyring (20220421-1 -> 20220503-1)
[2022-05-03T17:32:25+0200] [ALPM-SCRIPTLET] '/var/cache/pacman/pkg/manjaro-keyring-20210910-2-any.pkg.tar.zst' wurde entfernt
[2022-05-03T17:32:25+0200] [ALPM-SCRIPTLET] '/var/cache/pacman/pkg/manjaro-keyring-20210910-2-any.pkg.tar.zst.sig' wurde entfernt
[2022-05-04T17:40:29+0200] [ALPM] upgraded manjaro-keyring (20220503-1 -> 20220504-2)
[2022-05-04T17:40:30+0200] [ALPM-SCRIPTLET] '/var/cache/pacman/pkg/manjaro-keyring-20220421-1-any.pkg.tar.zst' wurde entfernt
[2022-05-04T17:40:30+0200] [ALPM-SCRIPTLET] '/var/cache/pacman/pkg/manjaro-keyring-20220421-1-any.pkg.tar.zst.sig' wurde entfernt
[2022-05-09T17:44:13+0200] [ALPM] upgraded manjaro-keyring (20220504-2 -> 20220509-1)
[2022-05-14T15:14:11+0200] [ALPM] upgraded manjaro-keyring (20220509-1 -> 20220514-1)
[2022-05-14T15:14:15+0200] [ALPM-SCRIPTLET] '/var/cache/pacman/pkg/manjaro-keyring-20220504-2-any.pkg.tar.xz' wurde entfernt
[2022-05-14T15:14:15+0200] [ALPM-SCRIPTLET] '/var/cache/pacman/pkg/manjaro-keyring-20220504-2-any.pkg.tar.xz.sig' wurde entfernt
[2022-05-14T15:34:41+0200] [ALPM-SCRIPTLET] Found snapshot: 2022-05-14 15:14:17 | @snapshots/23310/snapshot | post   | manjaro-keyring                                                          |
[2022-07-19T17:06:06+0200] [ALPM] upgraded archlinux-keyring (20220424-1 -> 20220713-1)
[2022-07-19T17:14:04+0200] [ALPM-SCRIPTLET] Found snapshot: 2022-07-19 17:06:14 | @snapshots/24500/snapshot | post   | archlinux-keyring                                                        |
[2022-07-30T19:06:42+0200] [ALPM] upgraded manjaro-keyring (20220514-1 -> 20220514-2)
[2022-07-30T19:06:44+0200] [ALPM] upgraded archlinux-keyring (20220713-1 -> 20220713-2)
[2022-07-30T19:06:47+0200] [ALPM-SCRIPTLET] '/var/cache/pacman/pkg/archlinux-keyring-20220424-1-any.pkg.tar.zst' wurde entfernt
[2022-07-30T19:06:47+0200] [ALPM-SCRIPTLET] '/var/cache/pacman/pkg/archlinux-keyring-20220424-1-any.pkg.tar.zst.sig' wurde entfernt
[2022-07-30T19:22:23+0200] [ALPM-SCRIPTLET] Found snapshot: 2022-07-30 19:06:48 | @snapshots/24696/snapshot | post   | archlinux-keyring base manjaro-keyring manjaro-system                    |
[2022-08-07T20:25:01+0200] [ALPM] upgraded archlinux-keyring (20220713-2 -> 20220727-1)
[2022-08-07T20:32:48+0200] [ALPM-SCRIPTLET] Found snapshot: 2022-08-07 20:25:06 | @snapshots/24835/snapshot | post   | archlinux-keyring                                                        |
[2022-09-13T20:22:03+0200] [ALPM] upgraded archlinux-keyring (20220727-1 -> 20220831-1)
[2022-09-13T20:37:02+0200] [ALPM-SCRIPTLET] Found snapshot: 2022-09-13 20:22:09 | @snapshots/25465/snapshot | post   | archlinux-keyring                                                        |
[2022-10-06T08:00:17+0200] [ALPM] upgraded archlinux-keyring (20220831-1 -> 20220927-1)
[2022-10-06T08:01:57+0200] [ALPM-SCRIPTLET] Found snapshot: 2022-10-06 08:00:22 | @snapshots/25807/snapshot | post   | archlinux-keyring                                                        |
[2022-10-06T17:12:45+0200] [ALPM-SCRIPTLET] Found snapshot: 2022-10-06 08:00:22 | @snapshots/25807/snapshot | post   | archlinux-keyring                                                        |
[2022-11-04T20:22:45+0100] [ALPM] upgraded manjaro-keyring (20220514-2 -> 20221028-4)
[2022-11-04T20:37:59+0100] [ALPM-SCRIPTLET] Found snapshot: 2022-11-04 20:22:50 | @snapshots/26326/snapshot | post   | manjaro-keyring                                                          |
[2022-11-04T21:06:05+0100] [ALPM-SCRIPTLET] Found snapshot: 2022-11-04 20:22:50 | @snapshots/26326/snapshot | post   | manjaro-keyring                                                          |
[2022-11-04T21:06:35+0100] [ALPM-SCRIPTLET] Found snapshot: 2022-11-04 20:22:50 | @snapshots/26326/snapshot | post   | manjaro-keyring                                                          |
[2022-11-16T07:33:17+0100] [ALPM] upgraded archlinux-keyring (20220927-1 -> 20221110-1)
[2022-11-16T07:47:03+0100] [ALPM-SCRIPTLET] Found snapshot: 2022-11-16 07:33:23 | @snapshots/26516/snapshot | post   | archlinux-keyring                                                        |
[2022-12-06T18:40:26+0100] [ALPM] upgraded archlinux-keyring (20221110-1 -> 20221123-1)
[2022-12-06T18:53:13+0100] [ALPM-SCRIPTLET] Found snapshot: 2022-12-06 18:40:31 | @snapshots/26870/snapshot | post   | archlinux-keyring                                                        |
[2022-12-20T15:48:22+0100] [ALPM] upgraded archlinux-keyring (20221123-1 -> 20221213-1)
[2022-12-20T15:48:30+0100] [ALPM-SCRIPTLET] '/var/cache/pacman/pkg/archlinux-keyring-20221110-1-any.pkg.tar.zst' wurde entfernt
[2022-12-20T15:48:30+0100] [ALPM-SCRIPTLET] '/var/cache/pacman/pkg/archlinux-keyring-20221110-1-any.pkg.tar.zst.sig' wurde entfernt
[2022-12-20T16:06:34+0100] [ALPM-SCRIPTLET] Found snapshot: 2022-12-20 15:48:32 | @snapshots/27085/snapshot | post   | archlinux-keyring                                                        |
[2022-12-25T08:19:57+0100] [ALPM] upgraded archlinux-keyring (20221213-1 -> 20221220-1)
[2022-12-25T08:20:04+0100] [ALPM-SCRIPTLET] '/var/cache/pacman/pkg/archlinux-keyring-20221123-1-any.pkg.tar.zst' wurde entfernt
[2022-12-25T08:20:04+0100] [ALPM-SCRIPTLET] '/var/cache/pacman/pkg/archlinux-keyring-20221123-1-any.pkg.tar.zst.sig' wurde entfernt
[2022-12-25T08:24:28+0100] [ALPM-SCRIPTLET] Found snapshot: 2022-12-25 08:20:06 | @snapshots/27185/snapshot | post   | archlinux-keyring                                                        |
[2023-02-04T08:07:28+0100] [ALPM] upgraded archlinux-keyring (20221220-1 -> 20230130-1)
[2023-02-04T08:17:28+0100] [ALPM-SCRIPTLET] Found snapshot: 2023-02-04 08:07:34 | @snapshots/27871/snapshot | post   | archlinux-keyring                                                        |
[2023-02-04T10:36:49+0100] [ALPM-SCRIPTLET] Found snapshot: 2023-02-04 08:07:34 | @snapshots/27871/snapshot | post   | archlinux-keyring                                                        |
[2023-02-04T10:37:31+0100] [ALPM-SCRIPTLET] Found snapshot: 2023-02-04 08:07:34 | @snapshots/27871/snapshot | post   | archlinux-keyring                                                        |
[2023-03-31T16:12:16+0200] [ALPM] upgraded archlinux-keyring (20230130-1 -> 20230320-1)
[2023-03-31T16:12:19+0200] [ALPM] upgraded manjaro-keyring (20221028-4 -> 20230318-1)
[2023-03-31T16:28:11+0200] [ALPM-SCRIPTLET] Found snapshot: 2023-03-31 16:12:23 | @snapshots/28855/snapshot | post   | archlinux-keyring manjaro-keyring                                        |
[2023-06-08T18:46:39+0200] [ALPM] upgraded archlinux-keyring (20230320-1 -> 20230504-1)
[2023-06-08T18:59:33+0200] [ALPM-SCRIPTLET] Found snapshot: 2023-06-08 18:46:47 | @snapshots/29740/snapshot | post   | archlinux-keyring                                                        |
[2023-06-20T20:14:38+0200] [ALPM] upgraded manjaro-keyring (20230318-1 -> 20230616-3)
[2023-07-10T20:17:42+0200] [ALPM] upgraded archlinux-keyring (20230504-1 -> 20230704-1)
[2023-07-10T20:57:36+0200] [ALPM-SCRIPTLET] Found snapshot: 2023-07-10 20:17:48 | @snapshots/30262/snapshot | post   | archlinux-keyring                                                        |
[2023-07-25T18:39:06+0200] [ALPM] upgraded manjaro-keyring (20230616-3 -> 20230719-2)
[2023-08-30T15:45:26+0200] [ALPM] upgraded archlinux-keyring (20230704-1 -> 20230821-1)
[2023-08-30T15:55:23+0200] [ALPM-SCRIPTLET] Found snapshot: 2023-08-30 15:45:32 | @snapshots/31060/snapshot | post   | archlinux-keyring                                                        |
[2023-09-10T20:17:22+0200] [ALPM] upgraded archlinux-keyring (20230821-1 -> 20230821-2)
[2023-09-10T20:31:39+0200] [ALPM-SCRIPTLET] Found snapshot: 2023-09-10 20:17:27 | @snapshots/31201/snapshot | post   | archlinux-keyring                                                        |
[2023-10-04T14:35:42+0200] [ALPM] upgraded archlinux-keyring (20230821-2 -> 20230918-1)
[2023-10-04T14:35:47+0200] [ALPM-SCRIPTLET] '/var/cache/pacman/pkg/archlinux-keyring-20230821-1-any.pkg.tar.zst' wurde entfernt
[2023-10-04T14:35:47+0200] [ALPM-SCRIPTLET] '/var/cache/pacman/pkg/archlinux-keyring-20230821-1-any.pkg.tar.zst.sig' wurde entfernt
[2023-10-04T14:50:50+0200] [ALPM-SCRIPTLET] Found snapshot: 2023-10-04 14:35:49 | @snapshots/31528/snapshot | post   | archlinux-keyring                                                        |
[2023-11-02T14:53:39+0100] [ALPM] upgraded archlinux-keyring (20230918-1 -> 20231026-1)
[2023-11-13T19:26:57+0100] [ALPM] upgraded archlinux-keyring (20231026-1 -> 20231107-1)
[2023-11-13T19:38:24+0100] [ALPM-SCRIPTLET] Found snapshot: 2023-11-13 19:27:03 | @snapshots/32053/snapshot | post   | archlinux-keyring                                                        |
[2023-11-21T10:05:11+0100] [ALPM] upgraded archlinux-keyring (20231107-1 -> 20231113-1)
[2023-11-21T10:05:15+0100] [ALPM-SCRIPTLET] '/var/cache/pacman/pkg/archlinux-keyring-20231026-1-any.pkg.tar.zst' wurde entfernt
[2023-11-21T10:05:15+0100] [ALPM-SCRIPTLET] '/var/cache/pacman/pkg/archlinux-keyring-20231026-1-any.pkg.tar.zst.sig' wurde entfernt
[2023-12-10T15:07:58+0100] [ALPM] upgraded archlinux-keyring (20231113-1 -> 20231207-1)
[2023-12-10T15:30:47+0100] [ALPM-SCRIPTLET] Found snapshot: 2023-12-10 15:08:05 | @snapshots/32459/snapshot | post   | archlinux-keyring                                                        |
[2023-12-11T17:46:30+0100] [ALPM-SCRIPTLET] Found snapshot: 2023-12-10 15:08:05 | @snapshots/32459/snapshot | post   | archlinux-keyring                                                        |
[2024-01-02T11:13:26+0100] [ALPM] upgraded archlinux-keyring (20231207-1 -> 20231222-1)
[2024-01-02T11:13:30+0100] [ALPM-SCRIPTLET] '/var/cache/pacman/pkg/archlinux-keyring-20231113-1-any.pkg.tar.zst' wurde entfernt
[2024-01-02T11:13:30+0100] [ALPM-SCRIPTLET] '/var/cache/pacman/pkg/archlinux-keyring-20231113-1-any.pkg.tar.zst.sig' wurde entfernt
[2024-01-02T11:17:36+0100] [ALPM-SCRIPTLET] Found snapshot: 2024-01-02 11:13:32 | @snapshots/32787/snapshot | post   | archlinux-keyring                                                        |
[2024-02-22T17:59:29+0100] [ALPM] upgraded archlinux-keyring (20231222-1 -> 20240208-1)
[2024-02-22T18:13:46+0100] [ALPM-SCRIPTLET] Found snapshot: 2024-02-22 17:59:34 | @snapshots/33422/snapshot | post   | archlinux-keyring                                                        |
[2024-05-13T16:24:55+0200] [ALPM] upgraded archlinux-keyring (20240208-1 -> 20240429-1)
[2024-05-13T17:05:51+0200] [ALPM-SCRIPTLET] Found snapshot: 2024-05-13 16:25:02 | @snapshots/34600/snapshot | post   | archlinux-keyring                                                        |
[2024-05-13T17:05:54+0200] [ALPM-SCRIPTLET] Found snapshot: 2024-05-13 16:25:02 | @snapshots/34600/snapshot | post   | archlinux-keyring                                                        |
[2024-05-13T17:59:42+0200] [ALPM-SCRIPTLET] Found snapshot: 2024-05-13 16:25:02 | @snapshots/34600/snapshot | post   | archlinux-keyring                                                        |
[2024-05-30T11:22:05+0200] [ALPM] upgraded archlinux-keyring (20240429-1 -> 20240520-1)
[2024-05-30T17:48:48+0200] [PACMAN] Running 'pacman -U manjaro-keyring-YYYYMMDD-R-any.pkg.tar.xz archlinux-keyring-YYYYMMDD-R-any.pkg.tar.zst'
[2024-05-30T18:04:30+0200] [PACMAN] Running 'pacman -U manjaro-keyring-20230719-2-any.pkg.tar.xz manjaro-keyring-20240530-R-any.pkg.tar.xz archlinux-keyring-20240520-1-any.pkg.tar.zst archlinux-keyring-20240530-R-any.pkg.tar.zst'
[2024-05-30T18:05:03+0200] [PACMAN] Running 'pacman -U manjaro-keyring-20230719-2-any.pkg.tar.xz manjaro-keyring-20240530-R-any.pkg.tar.xz archlinux-keyring-20240520-1-any.pkg.tar.zst archlinux-keyring-20240530-R-any.pkg.tar.zst'
[2024-05-30T18:07:05+0200] [PACMAN] Running 'pacman -U manjaro-keyring-20230719-2-any.pkg.tar.xz archlinux-keyring-20240520-1-any.pkg.tar.zst'
[2024-05-30T18:07:15+0200] [ALPM] reinstalled manjaro-keyring (20230719-2)
[2024-05-30T18:07:16+0200] [ALPM] reinstalled archlinux-keyring (20240520-1)
[2024-06-20T19:36:07+0200] [ALPM] upgraded archlinux-keyring (20240520-1 -> 20240609-1)
[2024-07-01T14:16:16+0200] [ALPM] upgraded manjaro-keyring (20230719-2 -> 20230719-3)
[2024-07-16T14:34:16+0200] [ALPM] upgraded archlinux-keyring (20240609-1 -> 20240709-1)
[2024-10-11T18:04:19+0200] [ALPM] upgraded archlinux-keyring (20240709-1 -> 20240709-2)
[2024-11-11T18:15:36+0100] [ALPM] upgraded archlinux-keyring (20240709-2 -> 20241015-1)
[2024-12-05T18:52:18+0100] [ALPM] upgraded archlinux-keyring (20241015-1 -> 20241203-1)
[2024-12-05T18:52:37+0100] [ALPM-SCRIPTLET] '/var/cache/pacman/pkg/archlinux-keyring-20240709-2-any.pkg.tar.zst' wurde entfernt
[2024-12-05T18:52:37+0100] [ALPM-SCRIPTLET] '/var/cache/pacman/pkg/archlinux-keyring-20240709-2-any.pkg.tar.zst.sig' wurde entfernt
gast19
[2019-05-04 10:20] [ALPM] installed archlinux-keyring (20190123-2)
[2019-05-04 10:20] [ALPM] installed manjaro-keyring (20180607-1)
[2020-08-18 08:44] [PACMAN] Running 'pacman -Sy gnupg archlinux-keyring manjaro-keyring'
[2020-08-18 08:47] [PACMAN] Running 'pacman -Sy gnupg archlinux-keyring manjaro-keyring'
[2020-08-18 08:51] [PACMAN] Running 'pacman -Sy gnupg archlinux-keyring manjaro-keyring'
[2020-08-18 08:54] [PACMAN] Running 'pacman -Sy gnupg archlinux-keyring manjaro-keyring'
[2020-08-18 08:58] [PACMAN] Running 'pacman -Sy gnupg archlinux-keyring manjaro-keyring'
[2020-08-18 08:58] [ALPM] upgraded archlinux-keyring (20190123-2 -> 20200622-1)
[2020-08-18 08:58] [ALPM] upgraded manjaro-keyring (20180607-1 -> 20200603-1)
[2020-08-18 08:59] [PACMAN] Running 'pacman -Sy gnupg archlinux-keyring'
[2020-08-18 08:59] [PACMAN] Running 'pacman -Sy gnupg manjaro-keyring'
[2020-08-18 09:02] [PACMAN] Running 'pacman -Sy gnupg archlinux-keyring manjaro-keyring'
[2020-08-18 09:04] [PACMAN] Running 'pacman -Sy archlinux-keyring manjaro-keyring'
[2020-08-18 09:29] [PACMAN] Running 'pacman -Sy gnupg archlinux-keyring manjaro-keyring'
[2020-08-18 09:29] [ALPM] reinstalled archlinux-keyring (20200622-1)
[2020-08-18 09:29] [ALPM] reinstalled manjaro-keyring (20200603-1)
[2022-04-14T19:07:20+0200] [ALPM] upgraded archlinux-keyring (20200622-1 -> 20220224-1)
[2022-04-14T19:07:32+0200] [ALPM] upgraded manjaro-keyring (20200603-1 -> 20210910-2)
[2022-05-12T08:34:10+0200] [ALPM] upgraded archlinux-keyring (20220224-1 -> 20220424-1)
[2022-05-12T08:34:15+0200] [ALPM] upgraded manjaro-keyring (20210910-2 -> 20220509-1)
[2022-05-14T19:11:45+0200] [ALPM] upgraded manjaro-keyring (20220509-1 -> 20220514-1)
[2022-07-21T14:17:24+0200] [ALPM] upgraded archlinux-keyring (20220424-1 -> 20220713-1)
[2022-08-07T18:25:19+0200] [ALPM] upgraded manjaro-keyring (20220514-1 -> 20220514-2)
[2022-08-07T18:25:23+0200] [ALPM] upgraded archlinux-keyring (20220713-1 -> 20220727-1)
[2022-10-06T17:17:34+0200] [ALPM] upgraded archlinux-keyring (20220727-1 -> 20220927-1)
[2022-11-06T08:15:25+0100] [ALPM] upgraded manjaro-keyring (20220514-2 -> 20221028-4)
[2023-05-04T20:27:28+0200] [ALPM] upgraded archlinux-keyring (20220927-1 -> 20230320-1)
[2023-05-04T20:27:37+0200] [ALPM] upgraded manjaro-keyring (20221028-4 -> 20230318-1)
[2023-06-09T06:50:32+0200] [ALPM] upgraded archlinux-keyring (20230320-1 -> 20230504-1)
[2023-08-06T07:13:41+0200] [ALPM] upgraded archlinux-keyring (20230504-1 -> 20230704-1)
[2023-08-06T07:13:50+0200] [ALPM] upgraded manjaro-keyring (20230318-1 -> 20230719-2)
[2023-08-30T18:02:30+0200] [ALPM] upgraded archlinux-keyring (20230704-1 -> 20230821-1)
[2023-09-16T19:57:21+0200] [ALPM] upgraded archlinux-keyring (20230821-1 -> 20230821-2)
[2023-10-18T11:13:59+0200] [ALPM] upgraded archlinux-keyring (20230821-2 -> 20230918-1)
[2023-11-06T19:24:37+0100] [ALPM] upgraded archlinux-keyring (20230918-1 -> 20231026-1)
[2023-11-15T18:01:33+0100] [ALPM] upgraded archlinux-keyring (20231026-1 -> 20231107-1)
[2023-11-26T16:10:59+0100] [ALPM] upgraded archlinux-keyring (20231107-1 -> 20231113-1)
[2023-12-26T09:38:41+0100] [ALPM] upgraded archlinux-keyring (20231113-1 -> 20231207-1)
[2024-01-17T10:57:52+0100] [ALPM] upgraded archlinux-keyring (20231207-1 -> 20231222-1)
[2024-02-23T15:54:15+0100] [ALPM] upgraded archlinux-keyring (20231222-1 -> 20240208-1)
[2024-05-21T15:27:05+0200] [ALPM] upgraded archlinux-keyring (20240208-1 -> 20240429-1)
[2024-06-09T14:17:46+0200] [ALPM] upgraded archlinux-keyring (20240429-1 -> 20240520-1)
[2024-07-01T17:56:08+0200] [ALPM] upgraded archlinux-keyring (20240520-1 -> 20240609-1)
[2024-07-01T17:56:15+0200] [ALPM] upgraded manjaro-keyring (20230719-2 -> 20230719-3)
[2024-10-03T10:10:47+0200] [PACMAN] Running 'pacman -S manjaro-keyring archlinux-keyring'
[2024-10-03T10:10:52+0200] [ALPM] reinstalled manjaro-keyring (20230719-3)
[2024-10-03T10:10:53+0200] [ALPM] upgraded archlinux-keyring (20240609-1 -> 20240709-1)
[2024-11-02T19:13:03+0100] [ALPM] upgraded archlinux-keyring (20240709-1 -> 20240709-2)
[2024-12-08T15:19:44+0100] [PACMAN] Running 'pacman -S manjaro-keyring'
[2024-12-08T15:19:46+0100] [ALPM] reinstalled manjaro-keyring (20230719-3)
[2024-12-08T15:20:01+0100] [PACMAN] Running 'pacman -S archlinux-keyring'
[2024-12-08T15:20:03+0100] [ALPM] upgraded archlinux-keyring (20240709-2 -> 20241203-1)
There must be a reason why the keyring keeps breaking. If you look in this forum, this is a recurring problem.
And in my case, I can guarantee that updates are installed on each of the systems at least once a month. Nevertheless, keyring problems keep cropping up at irregular intervals.
:footprints:
You wrote that problem was with this service:
so logs for that, output of this command: journalctl -u rchlinux-keyring-wkd-sync.service
The file is
-rw-r–r-- 1 andreas andreas 1349415 8. Dez 19:22 /tmp/keyring.txt
it ends with:
Dez 08 15:01:46 natalie archlinux-keyring-wkd-sync[15704]: sub   rsa4096 2023-04-30 [E] [verfällt: 2028-04-28]
Dez 08 15:01:46 natalie archlinux-keyring-wkd-sync[15469]: Refreshing key 8AA2213C8464C82D879C8127D4B58E897A929F2E with UID torxed@archlinux.org...
Dez 08 15:01:46 natalie archlinux-keyring-wkd-sync[15706]: pub   ed25519 2023-04-13 [SC]
Dez 08 15:01:46 natalie archlinux-keyring-wkd-sync[15706]:       8AA2213C8464C82D879C8127D4B58E897A929F2E
Dez 08 15:01:46 natalie archlinux-keyring-wkd-sync[15706]: uid        [vollständig] Anton Hvornum <torxed@archlinux.org>
Dez 08 15:01:46 natalie archlinux-keyring-wkd-sync[15706]: sub   rsa4096 2023-05-01 [A] [verfällt: 2025-04-30]
Dez 08 15:01:46 natalie archlinux-keyring-wkd-sync[15706]: sub   rsa4096 2023-05-01 [E] [verfällt: 2025-04-30]
Dez 08 15:01:46 natalie archlinux-keyring-wkd-sync[15469]: Skipping key A44C644D792767CED7941AFEABB2075D5F310CF8 with UID info@jonas-strassel.de...
Dez 08 15:01:46 natalie archlinux-keyring-wkd-sync[15469]: Skipping key A44C644D792767CED7941AFEABB2075D5F310CF8 with UID jonas.strassel@manjaro.org...
Dez 08 15:01:46 natalie archlinux-keyring-wkd-sync[15469]: Skipping key A44C644D792767CED7941AFEABB2075D5F310CF8 with UID jonas.strassel@ioki.com...
Dez 08 15:01:46 natalie archlinux-keyring-wkd-sync[15469]: Skipping key A44C644D792767CED7941AFEABB2075D5F310CF8 with UID jo.strassel@gmail.com...
Dez 08 15:01:46 natalie archlinux-keyring-wkd-sync[15469]: Refreshing key 5E6D49448958B384301F1F22498EF247F340C1E0 with UID fabiscafe@archlinux.org...
Dez 08 15:01:46 natalie archlinux-keyring-wkd-sync[15708]: pub   ed25519 2023-09-03 [SC] [verfällt: 2028-09-01]
Dez 08 15:01:46 natalie archlinux-keyring-wkd-sync[15708]:       5E6D49448958B384301F1F22498EF247F340C1E0
Dez 08 15:01:46 natalie archlinux-keyring-wkd-sync[15708]: uid        [vollständig] Fabian Bornschein <fabiscafe@archlinux.org>
Dez 08 15:01:46 natalie archlinux-keyring-wkd-sync[15708]: sub   cv25519 2023-09-03 [E] [verfällt: 2028-09-01]
Dez 08 15:01:46 natalie archlinux-keyring-wkd-sync[15469]: Skipping key 3572FA2A1B067F22C58AF155F8B821B42A6FDCD7 with UID artafinde@master-key.archlinux.org...
Dez 08 15:01:46 natalie archlinux-keyring-wkd-sync[15469]: Refreshing key 1F7156C2AD7D3B15873C5E2940825C6BDD1A4146 with UID rgacogne@archlinux.org...
Dez 08 15:01:46 natalie archlinux-keyring-wkd-sync[15717]: pub   rsa4096 2014-10-22 [SC] [widerrufen: 2021-01-31]
Dez 08 15:01:46 natalie archlinux-keyring-wkd-sync[15717]:       A4CBEA7974898599195E4FEC46EC46F39F3E2EF1
Dez 08 15:01:46 natalie archlinux-keyring-wkd-sync[15717]: uid        [ widerrufen] Remi Gacogne <rgacogne@archlinux.org>
Dez 08 15:01:46 natalie archlinux-keyring-wkd-sync[15469]: Refreshing key E87E5B39F04A5D889D8C0147F6D84143496F6680 with UID serebit@archlinux.org...
Dez 08 15:01:46 natalie archlinux-keyring-wkd-sync[15720]: pub   ed25519 2023-10-03 [SC] [verfällt: 2031-10-01]
Dez 08 15:01:46 natalie archlinux-keyring-wkd-sync[15720]:       E87E5B39F04A5D889D8C0147F6D84143496F6680
Dez 08 15:01:46 natalie archlinux-keyring-wkd-sync[15720]: uid        [vollständig] Campbell Jones <serebit@archlinux.org>
Dez 08 15:01:46 natalie archlinux-keyring-wkd-sync[15720]: sub   cv25519 2023-10-03 [E] [verfällt: 2031-10-01]
Dez 08 15:01:46 natalie archlinux-keyring-wkd-sync[15469]: Skipping key 2191B89431BAC0A8B96DE93D244740D17C7FD0EC with UID artafinde@gmail.com...
Dez 08 15:01:46 natalie archlinux-keyring-wkd-sync[15469]: Refreshing key 2191B89431BAC0A8B96DE93D244740D17C7FD0EC with UID artafinde@archlinux.org...
Dez 08 15:01:47 natalie archlinux-keyring-wkd-sync[15722]: pub   rsa4096 2017-06-18 [SC] [verfällt: 2025-07-18]
Dez 08 15:01:47 natalie archlinux-keyring-wkd-sync[15722]:       B4B759625D4633430B74877059E43E106B247368
Dez 08 15:01:47 natalie archlinux-keyring-wkd-sync[15722]: uid        [vollständig] Leonidas Spyropoulos <artafinde@archlinux.org>
Dez 08 15:01:47 natalie archlinux-keyring-wkd-sync[15722]: uid        [ unbekannt ] Leonidas Spyropoulos <artafinde@gmail.com>
Dez 08 15:01:47 natalie archlinux-keyring-wkd-sync[15722]: sub   rsa4096 2022-01-11 [A]
Dez 08 15:01:47 natalie archlinux-keyring-wkd-sync[15722]: sub   rsa4096 2017-06-18 [E]
Dez 08 15:01:47 natalie archlinux-keyring-wkd-sync[15469]: Refreshing key 8FE6A7D4CC42C83C9BCCA8E32DA2ACC3ECE4DCE6 with UID tcanabrava@archlinux.org...
Dez 08 15:01:47 natalie archlinux-keyring-wkd-sync[15724]: pub   ed25519 2023-11-22 [SC] [verfällt: 2027-11-21]
Dez 08 15:01:47 natalie archlinux-keyring-wkd-sync[15724]:       8FE6A7D4CC42C83C9BCCA8E32DA2ACC3ECE4DCE6
Dez 08 15:01:47 natalie archlinux-keyring-wkd-sync[15724]: uid        [vollständig] Tomaz Canabrava <tcanabrava@archlinux.org>
Dez 08 15:01:47 natalie archlinux-keyring-wkd-sync[15724]: sub   ed25519 2023-11-22 [A]
Dez 08 15:01:47 natalie archlinux-keyring-wkd-sync[15724]: sub   cv25519 2023-11-22 [E] [verfällt: 2027-11-21]
Dez 08 15:01:47 natalie archlinux-keyring-wkd-sync[15469]: Refreshing key 109415E692007609CA7EBFE4001CF4810BE8D911 with UID lahwaacz@archlinux.org...
Dez 08 15:01:47 natalie archlinux-keyring-wkd-sync[15726]: pub   ed25519 2023-12-05 [SC] [verfällt: 2025-12-30]
Dez 08 15:01:47 natalie archlinux-keyring-wkd-sync[15726]:       109415E692007609CA7EBFE4001CF4810BE8D911
Dez 08 15:01:47 natalie archlinux-keyring-wkd-sync[15726]: uid        [vollständig] Jakub Klinkovský <lahwaacz@archlinux.org>
Dez 08 15:01:47 natalie archlinux-keyring-wkd-sync[15726]: sub   cv25519 2023-12-05 [E] [verfällt: 2025-12-30]
Dez 08 15:01:47 natalie archlinux-keyring-wkd-sync[15469]: Skipping key 83BC8889351B5DEBBB68416EB8AC08600F108CDF with UID jan.steffens@gmail.com...
Dez 08 15:01:47 natalie archlinux-keyring-wkd-sync[15469]: Refreshing key 83BC8889351B5DEBBB68416EB8AC08600F108CDF with UID heftig@archlinux.org...
Dez 08 15:01:47 natalie archlinux-keyring-wkd-sync[15728]: pub   ed25519 2020-05-11 [SC]
Dez 08 15:01:47 natalie archlinux-keyring-wkd-sync[15728]:       A2FF3A36AAA56654109064AB19802F8B0D70FC30
Dez 08 15:01:47 natalie archlinux-keyring-wkd-sync[15728]: uid        [ unbekannt ] Jan Alexander Steffens (heftig) <jan.steffens@gmail.com>
Dez 08 15:01:47 natalie archlinux-keyring-wkd-sync[15728]: uid        [vollständig] Jan Alexander Steffens (heftig) <heftig@archlinux.org>
Dez 08 15:01:47 natalie archlinux-keyring-wkd-sync[15728]: uid        [ unbekannt ] Jan Alexander Steffens (heftig) <jan.steffens@ltnglobal.com>
Dez 08 15:01:47 natalie archlinux-keyring-wkd-sync[15728]: sub   ed25519 2020-05-11 [A]
Dez 08 15:01:47 natalie archlinux-keyring-wkd-sync[15728]: sub   ed25519 2020-05-11 [S]
Dez 08 15:01:47 natalie archlinux-keyring-wkd-sync[15728]: sub   cv25519 2020-05-11 [E]
Dez 08 15:01:47 natalie archlinux-keyring-wkd-sync[15469]: Refreshing key 69F8E5E5E85F771020A0777C3D309011083BA25E with UID carsme@archlinux.org...
Dez 08 15:01:47 natalie archlinux-keyring-wkd-sync[15730]: pub   ed25519 2024-04-01 [C] [verfällt: 2027-04-02]
Dez 08 15:01:47 natalie archlinux-keyring-wkd-sync[15730]:       69F8E5E5E85F771020A0777C3D309011083BA25E
Dez 08 15:01:47 natalie archlinux-keyring-wkd-sync[15730]: uid        [vollständig] Carl Smedstad <carsme@archlinux.org>
Dez 08 15:01:47 natalie archlinux-keyring-wkd-sync[15730]: sub   ed25519 2024-04-01 [S]
Dez 08 15:01:47 natalie archlinux-keyring-wkd-sync[15730]: sub   ed25519 2024-04-01 [A]
Dez 08 15:01:47 natalie archlinux-keyring-wkd-sync[15730]: sub   cv25519 2024-04-01 [E]
Dez 08 15:01:47 natalie archlinux-keyring-wkd-sync[15469]: Refreshing key 44A62127789A949F2F082ED429C71CE612B57264 with UID polyzen@archlinux.org...
Dez 08 15:01:48 natalie archlinux-keyring-wkd-sync[15732]: pub   ed25519 2024-02-02 [C] [verfällt: 2027-02-02]
Dez 08 15:01:48 natalie archlinux-keyring-wkd-sync[15732]:       44A62127789A949F2F082ED429C71CE612B57264
Dez 08 15:01:48 natalie archlinux-keyring-wkd-sync[15732]: uid        [vollständig] Daniel M. Capella <polyzen@archlinux.org>
Dez 08 15:01:48 natalie archlinux-keyring-wkd-sync[15732]: sub   ed25519 2024-02-02 [S] [verfällt: 2027-02-02]
Dez 08 15:01:48 natalie archlinux-keyring-wkd-sync[15732]: sub   ed25519 2024-02-02 [A] [verfällt: 2027-02-02]
Dez 08 15:01:48 natalie archlinux-keyring-wkd-sync[15732]: sub   cv25519 2024-02-02 [E] [verfällt: 2027-02-02]
Dez 08 15:01:48 natalie archlinux-keyring-wkd-sync[15469]: Refreshing key 09AC932ED7B1EC1E2DA7C6797A08E72CD906F59E with UID anonfunc@archlinux.org...
Dez 08 15:01:50 natalie archlinux-keyring-wkd-sync[15734]: pub   ed25519 2024-06-23 [C] [verfällt: 2027-06-24]
Dez 08 15:01:50 natalie archlinux-keyring-wkd-sync[15734]:       09AC932ED7B1EC1E2DA7C6797A08E72CD906F59E
Dez 08 15:01:50 natalie archlinux-keyring-wkd-sync[15734]: uid        [vollständig] Giovanni Harting <anonfunc@archlinux.org>
Dez 08 15:01:50 natalie archlinux-keyring-wkd-sync[15734]: sub   ed25519 2024-06-23 [A]
Dez 08 15:01:50 natalie archlinux-keyring-wkd-sync[15734]: sub   ed25519 2024-06-23 [S]
Dez 08 15:01:50 natalie archlinux-keyring-wkd-sync[15734]: sub   cv25519 2024-06-23 [E]
Dez 08 15:01:50 natalie archlinux-keyring-wkd-sync[15469]: Refreshing key 38100C24376CD5F6ED4FF4B46918400C2703040C with UID bertptrs@archlinux.org...
Dez 08 15:01:50 natalie archlinux-keyring-wkd-sync[15745]: pub   ed25519 2024-06-16 [SC] [verfällt: 2025-06-16]
Dez 08 15:01:50 natalie archlinux-keyring-wkd-sync[15745]:       38100C24376CD5F6ED4FF4B46918400C2703040C
Dez 08 15:01:50 natalie archlinux-keyring-wkd-sync[15745]: uid        [vollständig] Bert Peters (packager key) <bertptrs@archlinux.org>
Dez 08 15:01:50 natalie archlinux-keyring-wkd-sync[15745]: sub   cv25519 2024-06-16 [E] [verfällt: 2025-06-16]
Dez 08 15:01:50 natalie archlinux-keyring-wkd-sync[15469]: Refreshing key D2E95FEC015CF1F911AAAB0C3D4C5008BB5C8D29 with UID ptr1337@archlinux.org...
Dez 08 15:01:50 natalie archlinux-keyring-wkd-sync[15747]: pub   ed25519 2024-09-24 [SC]
Dez 08 15:01:50 natalie archlinux-keyring-wkd-sync[15747]:       D2E95FEC015CF1F911AAAB0C3D4C5008BB5C8D29
Dez 08 15:01:50 natalie archlinux-keyring-wkd-sync[15747]: uid        [vollständig] Peter Jung <ptr1337@archlinux.org>
Dez 08 15:01:50 natalie archlinux-keyring-wkd-sync[15747]: sub   cv25519 2024-09-24 [E]
Dez 08 15:01:50 natalie archlinux-keyring-wkd-sync[15469]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Dez 08 15:01:50 natalie systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Dez 08 15:01:50 natalie systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Dez 08 15:01:50 natalie systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 5.467s CPU time, 8.3M memory peak.
Dez 08 15:06:50 natalie systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 3.
Dez 08 15:06:50 natalie systemd[1]: archlinux-keyring-wkd-sync.service: Start request repeated too quickly.
Dez 08 15:06:50 natalie systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Dez 08 15:06:50 natalie systemd[1]: Failed to start Refresh existing keys of archlinux-keyring.
with another grep ‘systemd’
journalctl -u archlinux-keyring-wkd-sync.service |grep -E 'systemd|Error'        [1]
Jun 09 15:08:55 natalie systemd[1]: Started Refresh existing keys of archlinux-keyring.
Jun 09 15:09:23 natalie archlinux-keyring-wkd-sync[42853]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Jun 09 15:09:23 natalie systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Jun 09 15:09:23 natalie systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Jun 09 15:09:23 natalie systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 3.895s CPU time.
Jun 09 15:14:23 natalie systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 1.
Jun 09 15:14:23 natalie systemd[1]: Started Refresh existing keys of archlinux-keyring.
Jun 09 15:14:44 natalie archlinux-keyring-wkd-sync[44211]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Jun 09 15:14:44 natalie systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Jun 09 15:14:44 natalie systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Jun 09 15:14:44 natalie systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 4.262s CPU time.
Jun 09 15:19:44 natalie systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 2.
Jun 09 15:19:44 natalie systemd[1]: Started Refresh existing keys of archlinux-keyring.
Jun 09 15:20:04 natalie archlinux-keyring-wkd-sync[45585]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Jun 09 15:20:04 natalie systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Jun 09 15:20:04 natalie systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Jun 09 15:20:04 natalie systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 4.183s CPU time.
Jun 09 15:25:04 natalie systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 3.
Jun 09 15:25:04 natalie systemd[1]: archlinux-keyring-wkd-sync.service: Start request repeated too quickly.
Jun 09 15:25:04 natalie systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Jun 09 15:25:04 natalie systemd[1]: Failed to start Refresh existing keys of archlinux-keyring.
Jun 09 15:25:04 natalie systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 4.183s CPU time.
Dez 08 14:50:39 natalie systemd[1]: Started Refresh existing keys of archlinux-keyring.
Dez 08 14:51:08 natalie archlinux-keyring-wkd-sync[12435]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Dez 08 14:51:08 natalie systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Dez 08 14:51:08 natalie systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Dez 08 14:51:08 natalie systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 12.717s CPU time, 8.5M memory peak.
Dez 08 14:56:08 natalie systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 1.
Dez 08 14:56:08 natalie systemd[1]: Started Refresh existing keys of archlinux-keyring.
Dez 08 14:56:29 natalie archlinux-keyring-wkd-sync[13817]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Dez 08 14:56:29 natalie systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Dez 08 14:56:29 natalie systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Dez 08 14:56:29 natalie systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 5.655s CPU time, 8.3M memory peak.
Dez 08 15:01:29 natalie systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 2.
Dez 08 15:01:29 natalie systemd[1]: Started Refresh existing keys of archlinux-keyring.
:footprints:
notebook
ssh notebook journalctl -u archlinux-keyring-wkd-sync.service |grep -E ‘systemd|Error’  :heavy_check_mark:
Aug 02 10:03:48 manjaronotebook systemd[1]: Started Refresh existing keys of archlinux-keyring.
Aug 02 10:04:12 manjaronotebook archlinux-keyring-wkd-sync[3099]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Aug 02 10:04:12 manjaronotebook systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Aug 02 10:04:12 manjaronotebook systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result ‘exit-code’.
Aug 02 10:09:12 manjaronotebook systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 1.
Aug 02 10:09:12 manjaronotebook systemd[1]: Started Refresh existing keys of archlinux-keyring.
Aug 02 10:09:33 manjaronotebook archlinux-keyring-wkd-sync[5560]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Aug 02 10:09:33 manjaronotebook systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Aug 02 10:09:33 manjaronotebook systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result ‘exit-code’.
Aug 02 10:14:33 manjaronotebook systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 2.
Aug 02 10:14:33 manjaronotebook systemd[1]: Started Refresh existing keys of archlinux-keyring.
Aug 02 10:15:01 manjaronotebook archlinux-keyring-wkd-sync[7974]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Aug 02 10:15:01 manjaronotebook systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Aug 02 10:15:01 manjaronotebook systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result ‘exit-code’.
Aug 02 10:20:01 manjaronotebook systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 3.
Aug 02 10:20:01 manjaronotebook systemd[1]: archlinux-keyring-wkd-sync.service: Start request repeated too quickly.
Aug 02 10:20:01 manjaronotebook systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result ‘exit-code’.
Aug 02 10:20:01 manjaronotebook systemd[1]: Failed to start Refresh existing keys of archlinux-keyring.
Sep 03 14:12:19 manjaronotebook systemd[1]: Started Refresh existing keys of archlinux-keyring.
Sep 03 14:12:40 manjaronotebook archlinux-keyring-wkd-sync[13463]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Sep 03 14:12:40 manjaronotebook systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Sep 03 14:12:40 manjaronotebook systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result ‘exit-code’.
Sep 03 14:12:40 manjaronotebook systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 3.695s CPU time, 17.1M memory peak.
Sep 03 14:17:40 manjaronotebook systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 1.
Sep 03 14:17:40 manjaronotebook systemd[1]: Started Refresh existing keys of archlinux-keyring.
Sep 03 14:18:01 manjaronotebook archlinux-keyring-wkd-sync[15947]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Sep 03 14:18:01 manjaronotebook systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Sep 03 14:18:01 manjaronotebook systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result ‘exit-code’.
Sep 03 14:18:01 manjaronotebook systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 3.562s CPU time, 8.3M memory peak.
Sep 03 14:23:01 manjaronotebook systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 2.
Sep 03 14:23:01 manjaronotebook systemd[1]: Started Refresh existing keys of archlinux-keyring.
Sep 03 14:23:23 manjaronotebook archlinux-keyring-wkd-sync[18421]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Sep 03 14:23:23 manjaronotebook systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Sep 03 14:23:23 manjaronotebook systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result ‘exit-code’.
Sep 03 14:23:23 manjaronotebook systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 3.572s CPU time, 8.3M memory peak.
Sep 03 14:28:23 manjaronotebook systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 3.
Sep 03 14:28:23 manjaronotebook systemd[1]: archlinux-keyring-wkd-sync.service: Start request repeated too quickly.
Sep 03 14:28:23 manjaronotebook systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result ‘exit-code’.
Sep 03 14:28:23 manjaronotebook systemd[1]: Failed to start Refresh existing keys of archlinux-keyring.
gast
ssh gast journalctl -u archlinux-keyring-wkd-sync.service |grep -E 'systemd|Error'         ✔
Dec 08 14:50:39 natalie systemd[1]: Started Refresh existing keys of archlinux-keyring.
Dec 08 14:51:08 natalie archlinux-keyring-wkd-sync[12435]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Dec 08 14:51:08 natalie systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Dec 08 14:51:08 natalie systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Dec 08 14:51:08 natalie systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 12.717s CPU time, 8.5M memory peak.
Dec 08 14:56:08 natalie systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 1.
Dec 08 14:56:08 natalie systemd[1]: Started Refresh existing keys of archlinux-keyring.
Dec 08 14:56:29 natalie archlinux-keyring-wkd-sync[13817]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Dec 08 14:56:29 natalie systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Dec 08 14:56:29 natalie systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Dec 08 14:56:29 natalie systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 5.655s CPU time, 8.3M memory peak.
Dec 08 15:01:29 natalie systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 2.
Dec 08 15:01:29 natalie systemd[1]: Started Refresh existing keys of archlinux-keyring.
Dec 08 15:01:50 natalie archlinux-keyring-wkd-sync[15469]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Dec 08 15:01:50 natalie systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Dec 08 15:01:50 natalie systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Dec 08 15:01:50 natalie systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 5.467s CPU time, 8.3M memory peak.
Dec 08 15:06:50 natalie systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 3.
Dec 08 15:06:50 natalie systemd[1]: archlinux-keyring-wkd-sync.service: Start request repeated too quickly.
Dec 08 15:06:50 natalie systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Dec 08 15:06:50 natalie systemd[1]: Failed to start Refresh existing keys of archlinux-keyring.
jitsim1
 ssh jitsim1 journalctl -u archlinux-keyring-wkd-sync.service |grep -E 'systemd|Error'         ✔
Jun 09 14:13:47 jitsim1 systemd[1]: Started Refresh existing keys of archlinux-keyring.
Jun 09 14:14:13 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Jun 09 14:14:13 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Jun 09 14:14:13 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 2.588s CPU time.
Jun 09 14:14:14 jitsim1 archlinux-keyring-wkd-sync[4983]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Jun 09 14:19:13 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 1.
Jun 09 14:19:13 jitsim1 systemd[1]: Started Refresh existing keys of archlinux-keyring.
Jun 09 14:19:32 jitsim1 archlinux-keyring-wkd-sync[27092]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Jun 09 14:19:32 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Jun 09 14:19:32 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Jun 09 14:19:32 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 3.080s CPU time.
Jun 09 14:24:33 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 2.
Jun 09 14:24:33 jitsim1 systemd[1]: Started Refresh existing keys of archlinux-keyring.
Jun 09 14:24:54 jitsim1 archlinux-keyring-wkd-sync[27440]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Jun 09 14:24:54 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Jun 09 14:24:54 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Jun 09 14:24:54 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 3.245s CPU time.
Jun 09 14:29:55 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 3.
Jun 09 14:29:55 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Start request repeated too quickly.
Jun 09 14:29:55 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Jun 09 14:29:55 jitsim1 systemd[1]: Failed to start Refresh existing keys of archlinux-keyring.
Jun 09 14:29:55 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 3.245s CPU time.
Jul 06 10:49:08 jitsim1 systemd[1]: Started Refresh existing keys of archlinux-keyring.
Jul 06 10:49:30 jitsim1 archlinux-keyring-wkd-sync[4203]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Jul 06 10:49:30 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Jul 06 10:49:30 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Jul 06 10:54:30 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 1.
Jul 06 10:54:30 jitsim1 systemd[1]: Started Refresh existing keys of archlinux-keyring.
Jul 06 10:54:50 jitsim1 archlinux-keyring-wkd-sync[4414]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Jul 06 10:54:50 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Jul 06 10:54:50 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Jul 06 10:59:50 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 2.
Jul 06 10:59:50 jitsim1 systemd[1]: Started Refresh existing keys of archlinux-keyring.
Jul 06 11:00:09 jitsim1 archlinux-keyring-wkd-sync[4625]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Jul 06 11:00:09 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Jul 06 11:00:09 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Jul 06 11:05:09 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 3.
Jul 06 11:05:09 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Start request repeated too quickly.
Jul 06 11:05:09 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Jul 06 11:05:09 jitsim1 systemd[1]: Failed to start Refresh existing keys of archlinux-keyring.
Jul 08 22:03:40 jitsim1 systemd[1]: Started Refresh existing keys of archlinux-keyring.
Jul 08 22:04:02 jitsim1 archlinux-keyring-wkd-sync[5858]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Jul 08 22:04:02 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Jul 08 22:04:02 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Jul 08 22:09:02 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 1.
Jul 08 22:09:02 jitsim1 systemd[1]: Started Refresh existing keys of archlinux-keyring.
Jul 08 22:09:24 jitsim1 archlinux-keyring-wkd-sync[6066]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Jul 08 22:09:24 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Jul 08 22:09:24 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Jul 08 22:14:24 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 2.
Jul 08 22:14:24 jitsim1 systemd[1]: Started Refresh existing keys of archlinux-keyring.
Jul 08 22:14:44 jitsim1 archlinux-keyring-wkd-sync[6276]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Jul 08 22:14:44 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Jul 08 22:14:44 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Jul 08 22:19:44 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 3.
Jul 08 22:19:44 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Start request repeated too quickly.
Jul 08 22:19:44 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Jul 08 22:19:44 jitsim1 systemd[1]: Failed to start Refresh existing keys of archlinux-keyring.
Jul 15 13:55:15 jitsim1 systemd[1]: Started Refresh existing keys of archlinux-keyring.
Jul 15 13:55:53 jitsim1 archlinux-keyring-wkd-sync[6060]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Jul 15 13:55:53 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Jul 15 13:55:53 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Jul 15 14:00:53 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 1.
Jul 15 14:00:53 jitsim1 systemd[1]: Started Refresh existing keys of archlinux-keyring.
Jul 15 14:01:13 jitsim1 archlinux-keyring-wkd-sync[6303]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Jul 15 14:01:13 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Jul 15 14:01:13 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Jul 15 14:06:13 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 2.
Jul 15 14:06:13 jitsim1 systemd[1]: Started Refresh existing keys of archlinux-keyring.
Jul 15 14:06:34 jitsim1 archlinux-keyring-wkd-sync[6594]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Jul 15 14:06:34 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Jul 15 14:06:34 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Jul 15 14:11:34 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 3.
Jul 15 14:11:34 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Start request repeated too quickly.
Jul 15 14:11:34 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Jul 15 14:11:34 jitsim1 systemd[1]: Failed to start Refresh existing keys of archlinux-keyring.
Aug 04 21:56:09 jitsim1 systemd[1]: Started Refresh existing keys of archlinux-keyring.
Aug 04 21:56:33 jitsim1 archlinux-keyring-wkd-sync[5439]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Aug 04 21:56:33 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Aug 04 21:56:33 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Aug 04 22:01:34 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 1.
Aug 04 22:01:34 jitsim1 systemd[1]: Started Refresh existing keys of archlinux-keyring.
Aug 04 22:01:57 jitsim1 archlinux-keyring-wkd-sync[5712]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Aug 04 22:01:57 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Aug 04 22:01:57 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Aug 04 22:06:57 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 2.
Aug 04 22:06:57 jitsim1 systemd[1]: Started Refresh existing keys of archlinux-keyring.
Aug 04 22:07:20 jitsim1 archlinux-keyring-wkd-sync[5940]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Aug 04 22:07:20 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Aug 04 22:07:20 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Aug 04 22:12:21 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 3.
Aug 04 22:12:21 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Start request repeated too quickly.
Aug 04 22:12:21 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Aug 04 22:12:21 jitsim1 systemd[1]: Failed to start Refresh existing keys of archlinux-keyring.
Aug 18 07:12:12 jitsim1 systemd[1]: Started Refresh existing keys of archlinux-keyring.
Aug 18 07:12:36 jitsim1 archlinux-keyring-wkd-sync[3397]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Aug 18 07:12:36 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Aug 18 07:12:36 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Aug 18 07:12:36 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 5.221s CPU time, 11.8M memory peak.
Aug 18 07:17:36 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 1.
Aug 18 07:17:37 jitsim1 systemd[1]: Started Refresh existing keys of archlinux-keyring.
Aug 18 07:17:58 jitsim1 archlinux-keyring-wkd-sync[3622]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Aug 18 07:17:58 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Aug 18 07:17:58 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Aug 18 07:17:58 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 5.115s CPU time, 8.2M memory peak.
Aug 18 07:22:58 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 2.
Aug 18 07:22:58 jitsim1 systemd[1]: Started Refresh existing keys of archlinux-keyring.
Aug 18 07:23:20 jitsim1 archlinux-keyring-wkd-sync[3847]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Aug 18 07:23:20 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Aug 18 07:23:20 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Aug 18 07:23:20 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 4.866s CPU time, 8.2M memory peak.
Aug 18 07:28:20 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 3.
Aug 18 07:28:20 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Start request repeated too quickly.
Aug 18 07:28:20 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Aug 18 07:28:20 jitsim1 systemd[1]: Failed to start Refresh existing keys of archlinux-keyring.
Aug 19 14:02:30 jitsim1 systemd[1]: Started Refresh existing keys of archlinux-keyring.
Aug 19 14:02:54 jitsim1 archlinux-keyring-wkd-sync[4383]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Aug 19 14:02:54 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Aug 19 14:02:54 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Aug 19 14:02:54 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 5.155s CPU time, 9.6M memory peak.
Aug 19 14:07:54 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 1.
Aug 19 14:07:54 jitsim1 systemd[1]: Started Refresh existing keys of archlinux-keyring.
Aug 19 14:08:16 jitsim1 archlinux-keyring-wkd-sync[4607]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Aug 19 14:08:16 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Aug 19 14:08:16 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Aug 19 14:08:16 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 4.959s CPU time, 8.2M memory peak.
Aug 19 14:13:16 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 2.
Aug 19 14:13:16 jitsim1 systemd[1]: Started Refresh existing keys of archlinux-keyring.
Aug 19 14:13:38 jitsim1 archlinux-keyring-wkd-sync[4834]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Aug 19 14:13:38 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Aug 19 14:13:38 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Aug 19 14:13:38 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 4.975s CPU time, 8.3M memory peak.
Aug 19 14:18:38 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 3.
Aug 19 14:18:38 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Start request repeated too quickly.
Aug 19 14:18:38 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Aug 19 14:18:38 jitsim1 systemd[1]: Failed to start Refresh existing keys of archlinux-keyring.
Aug 30 22:32:52 jitsim1 systemd[1]: Started Refresh existing keys of archlinux-keyring.
Aug 30 22:33:16 jitsim1 archlinux-keyring-wkd-sync[5714]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Aug 30 22:33:16 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Aug 30 22:33:16 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Aug 30 22:33:16 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 5.257s CPU time, 11.7M memory peak.
Aug 30 22:38:16 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 1.
Aug 30 22:38:16 jitsim1 systemd[1]: Started Refresh existing keys of archlinux-keyring.
Aug 30 22:38:40 jitsim1 archlinux-keyring-wkd-sync[5939]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Aug 30 22:38:40 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Aug 30 22:38:40 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Aug 30 22:38:40 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 5.240s CPU time, 8.2M memory peak.
Aug 30 22:43:40 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 2.
Aug 30 22:43:40 jitsim1 systemd[1]: Started Refresh existing keys of archlinux-keyring.
Aug 30 22:44:02 jitsim1 archlinux-keyring-wkd-sync[6166]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Aug 30 22:44:02 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Aug 30 22:44:02 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Aug 30 22:44:02 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 5.076s CPU time, 8.2M memory peak.
Aug 30 22:49:03 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 3.
Aug 30 22:49:03 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Start request repeated too quickly.
Aug 30 22:49:03 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Aug 30 22:49:03 jitsim1 systemd[1]: Failed to start Refresh existing keys of archlinux-keyring.
Sep 17 16:17:58 jitsim1 systemd[1]: Started Refresh existing keys of archlinux-keyring.
Sep 17 16:18:22 jitsim1 archlinux-keyring-wkd-sync[4960]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Sep 17 16:18:22 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Sep 17 16:18:22 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Sep 17 16:18:22 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 5.150s CPU time, 11.8M memory peak.
Sep 17 16:23:23 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 1.
Sep 17 16:23:23 jitsim1 systemd[1]: Started Refresh existing keys of archlinux-keyring.
Sep 17 16:23:48 jitsim1 archlinux-keyring-wkd-sync[5197]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Sep 17 16:23:48 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Sep 17 16:23:48 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Sep 17 16:23:48 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 5.233s CPU time, 8.2M memory peak.
Sep 17 16:28:48 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 2.
Sep 17 16:28:48 jitsim1 systemd[1]: Started Refresh existing keys of archlinux-keyring.
Sep 17 16:29:11 jitsim1 archlinux-keyring-wkd-sync[5425]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Sep 17 16:29:11 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Sep 17 16:29:11 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Sep 17 16:29:11 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 5.139s CPU time, 8.2M memory peak.
Sep 17 16:34:11 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 3.
Sep 17 16:34:11 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Start request repeated too quickly.
Sep 17 16:34:11 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Sep 17 16:34:11 jitsim1 systemd[1]: Failed to start Refresh existing keys of archlinux-keyring.
Sep 25 20:57:47 jitsim1 systemd[1]: Started Refresh existing keys of archlinux-keyring.
Sep 25 20:58:13 jitsim1 archlinux-keyring-wkd-sync[4692]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Sep 25 20:58:13 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Sep 25 20:58:13 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Sep 25 20:58:13 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 5.383s CPU time, 12M memory peak.
Sep 25 21:03:13 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 1.
Sep 25 21:03:13 jitsim1 systemd[1]: Started Refresh existing keys of archlinux-keyring.
Sep 25 21:03:37 jitsim1 archlinux-keyring-wkd-sync[4966]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Sep 25 21:03:37 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Sep 25 21:03:37 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Sep 25 21:03:37 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 5.190s CPU time, 8.4M memory peak.
Sep 25 21:08:37 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 2.
Sep 25 21:08:37 jitsim1 systemd[1]: Started Refresh existing keys of archlinux-keyring.
Sep 25 21:09:01 jitsim1 archlinux-keyring-wkd-sync[5193]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Sep 25 21:09:01 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Sep 25 21:09:01 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Sep 25 21:09:01 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 5.209s CPU time, 8.3M memory peak.
Sep 25 21:14:01 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 3.
Sep 25 21:14:01 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Start request repeated too quickly.
Sep 25 21:14:01 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Sep 25 21:14:01 jitsim1 systemd[1]: Failed to start Refresh existing keys of archlinux-keyring.
Nov 01 15:54:58 jitsim1 systemd[1]: Started Refresh existing keys of archlinux-keyring.
Nov 01 15:55:26 jitsim1 archlinux-keyring-wkd-sync[5153]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Nov 01 15:55:26 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Nov 01 15:55:26 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Nov 01 15:55:26 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 10.693s CPU time, 11.3M memory peak.
Nov 01 16:00:26 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 1.
Nov 01 16:00:26 jitsim1 systemd[1]: Started Refresh existing keys of archlinux-keyring.
Nov 01 16:00:47 jitsim1 archlinux-keyring-wkd-sync[5386]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Nov 01 16:00:47 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Nov 01 16:00:47 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Nov 01 16:00:47 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 5.019s CPU time, 8.4M memory peak.
Nov 01 16:05:47 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 2.
Nov 01 16:05:47 jitsim1 systemd[1]: Started Refresh existing keys of archlinux-keyring.
Nov 01 16:06:08 jitsim1 archlinux-keyring-wkd-sync[5692]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Nov 01 16:06:08 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Nov 01 16:06:08 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Nov 01 16:06:08 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 5.088s CPU time, 8.4M memory peak.
Nov 01 16:11:08 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 3.
Nov 01 16:11:08 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Start request repeated too quickly.
Nov 01 16:11:08 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Nov 01 16:11:08 jitsim1 systemd[1]: Failed to start Refresh existing keys of archlinux-keyring.
Nov 09 18:10:12 jitsim1 systemd[1]: Started Refresh existing keys of archlinux-keyring.
Nov 09 18:10:35 jitsim1 archlinux-keyring-wkd-sync[5476]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Nov 09 18:10:35 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Nov 09 18:10:35 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Nov 09 18:10:35 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 5.124s CPU time, 11.9M memory peak.
Nov 09 18:15:35 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 1.
Nov 09 18:15:35 jitsim1 systemd[1]: Started Refresh existing keys of archlinux-keyring.
Nov 09 18:15:56 jitsim1 archlinux-keyring-wkd-sync[5714]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Nov 09 18:15:56 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Nov 09 18:15:56 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Nov 09 18:15:56 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 4.958s CPU time, 8.4M memory peak.
Nov 09 18:20:56 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 2.
Nov 09 18:20:56 jitsim1 systemd[1]: Started Refresh existing keys of archlinux-keyring.
Nov 09 18:21:17 jitsim1 archlinux-keyring-wkd-sync[5941]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Nov 09 18:21:17 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Nov 09 18:21:17 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Nov 09 18:21:17 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 5.017s CPU time, 8.4M memory peak.
Nov 09 18:26:17 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 3.
Nov 09 18:26:17 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Start request repeated too quickly.
Nov 09 18:26:17 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Nov 09 18:26:17 jitsim1 systemd[1]: Failed to start Refresh existing keys of archlinux-keyring.
Nov 18 10:14:19 jitsim1 systemd[1]: Started Refresh existing keys of archlinux-keyring.
Nov 18 10:14:41 jitsim1 archlinux-keyring-wkd-sync[4757]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Nov 18 10:14:41 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Nov 18 10:14:41 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Nov 18 10:14:41 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 5.062s CPU time, 9.8M memory peak.
Nov 18 10:19:41 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 1.
Nov 18 10:19:41 jitsim1 systemd[1]: Started Refresh existing keys of archlinux-keyring.
Nov 18 10:20:03 jitsim1 archlinux-keyring-wkd-sync[5013]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Nov 18 10:20:03 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Nov 18 10:20:03 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Nov 18 10:20:03 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 4.910s CPU time, 8.5M memory peak.
Nov 18 10:25:03 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 2.
Nov 18 10:25:03 jitsim1 systemd[1]: Started Refresh existing keys of archlinux-keyring.
Nov 18 10:25:24 jitsim1 archlinux-keyring-wkd-sync[5237]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Nov 18 10:25:24 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Nov 18 10:25:24 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Nov 18 10:25:24 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 5.092s CPU time, 8.5M memory peak.
Nov 18 10:30:24 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 3.
Nov 18 10:30:24 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Start request repeated too quickly.
Nov 18 10:30:24 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Nov 18 10:30:24 jitsim1 systemd[1]: Failed to start Refresh existing keys of archlinux-keyring.
Nov 30 13:55:33 jitsim1 systemd[1]: Started Refresh existing keys of archlinux-keyring.
Nov 30 13:55:59 jitsim1 archlinux-keyring-wkd-sync[3988]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Nov 30 13:55:59 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Nov 30 13:55:59 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Nov 30 13:55:59 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 6.647s CPU time, 12.1M memory peak.
Nov 30 14:00:59 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 1.
Nov 30 14:00:59 jitsim1 systemd[1]: Started Refresh existing keys of archlinux-keyring.
Nov 30 14:01:20 jitsim1 archlinux-keyring-wkd-sync[4220]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Nov 30 14:01:20 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Nov 30 14:01:20 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Nov 30 14:01:20 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 5.048s CPU time, 8.4M memory peak.
Nov 30 14:06:20 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 2.
Nov 30 14:06:20 jitsim1 systemd[1]: Started Refresh existing keys of archlinux-keyring.
Nov 30 14:06:42 jitsim1 archlinux-keyring-wkd-sync[4485]: Error refreshing key B8151B117037781095514CA7BBDFFC92306B1121 with UID andrew@archlinux.org.
Nov 30 14:06:42 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Main process exited, code=exited, status=1/FAILURE
Nov 30 14:06:42 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Nov 30 14:06:42 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Consumed 5.120s CPU time, 8.4M memory peak.
Nov 30 14:11:42 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Scheduled restart job, restart counter is at 3.
Nov 30 14:11:42 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Start request repeated too quickly.
Nov 30 14:11:42 jitsim1 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Nov 30 14:11:42 jitsim1 systemd[1]: Failed to start Refresh existing keys of archlinux-keyring.
Yep, that’s most likely expired key, check with
pacman-key -l andrew@archlinux.org
and if indeed expired, you can safely remove it with
sudo pacman-key --delete andrew@archlinux.org
pub   rsa2048 2017-06-04 [SC] [expired: 2019-06-04]
uid           [ expired] Andrew Gregory (pacman) <andrew@archlinux.org>
==> Updating trust database...
gpg: next trustdb check due at 2025-01-01
This solves the problem on one machine.
I can do this on my other machines too. But I doubt that I’m the only one affected.
Do I understand this correctly?
  • Does this one “unremoved key” cause the built-in mechanism for keeping the key database clean to crash repeatedly?
  • Will this result in problems with the update sooner or later?
  • Can this be avoided?
    :footprints:
No. Expired keys won’t cause problems with updates, installing packages etc. Pacman will ignore this key and won’t allow install packages signed with expired key
Don’t know, probably not unless you fix archlinux-keyring-wkd-sync to be able remove expired keys. Expired keys will appear sooner or later anyway – this is simply unavoidable.
Yes – this cause archlinux-keyring-wkd-sync service to crash repeatedly – but it anyway refresh other keys – so no problem for pacman/pamac and other things.
In this case, I think that’s one piece of the puzzle. When the puzzle is put together, we’ll be able to permanently fix the problems with the manjaro-arch-keyrings.
But until we know the other pieces of the puzzle, we’ll have to live with the sporadic failures in the keyrings.
:footprints:
