Good evening in the Manjaro community.
I have the distribution installed on my machine, worse, after a power surge I started having problems booting the operating system.
I used the pendrive bootloader to later restore the system by timeshift and realized that the problem was in GRUB.
After restoring the system and GRUB, I would like to know if it is possible to have more than one GRUB on the hard drive and if so, how do I identify when GRUB has it and how do I remove them and leave only one, which is working normally.
Hugs…
Kernel: 5.10.89-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=4c99a061-31b7-445a-ad39-2ef99ad4a052 rw quiet
udev.log_priority=3
Desktop: LXDE 0.10.1 info: lxpanel wm: Openbox 3.6.1 vt: 7
Type: Desktop Mobo: INTEL model: H81 serial: <superuser required>
UEFI: American Megatrends v: 4.6.5 date: 10/21/2020
RAM: total: 7.71 GiB used: 871.9 MiB (11.0%)
RAM Report:
Info: model: Intel Pentium G3250 bits: 64 type: MCP arch: Haswell family: 6
model-id: 0x3C (60) stepping: 3 microcode: 0x28
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB desc: 2x256 KiB L3: 3 MiB
desc: 1x3 MiB
Speed (MHz): avg: 1036 high: 1274 min/max: 800/3200 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 798 2: 1274
bogomips: 12777
Flags: abm acpi aperfmperf apic arat arch_perfmon bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept
ept_ad erms est flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr
pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sdbg sep ss ssbd
sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer vme vmx vnmi vpid xsave xsaveopt xtopology
xtpr
Type: l1tf
Device-1: AMD Baffin [Radeon RX 460/560D / Pro 450/455/460/555/555X/560/560X] vendor: XFX Pine driver: amdgpu v: kernel bus-ID: 01:00.0 chip-ID: 1002:67ef
class-ID: 0300
Display: x11 server: X.Org 1.21.1.2 driver: loaded: amdgpu,ati
unloaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: HDMI-A-0 res: 1920x1080 hz: 75 dpi: 82
size: 598x336mm (23.5x13.2") diag: 686mm (27")
Device-1: Intel 8 Series/C220 Series High Definition Audio
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
class-ID: 0403
Device-2: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / RX 560/560X]
vendor: XFX Pine driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 1002:aae0 class-ID: 0403
Sound Server-1: ALSA v: k5.10.89-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
driver: r8169 v: kernel port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168
class-ID: 0200
Local Storage: total: 223.57 GiB used: 78.71 GiB (35.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 61K1 scheme: GPT
ID-1: / raw-size: 223.27 GiB size: 218.77 GiB (97.98%)
used: 78.71 GiB (36.0%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 4c99a061-31b7-445a-ad39-2ef99ad4a052
used: 300 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 84A3-A666
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:8008 class-ID: 0900
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 3-9:2 info: Dell KB216 Wired Keyboard type: Keyboard,HID
power: 100mA chip-ID: 413c:2113 class-ID: 0300
Device-2: 3-10:3 info: [Maxxter] Optical Gaming Mouse [Xtrem]
type: Mouse,Keyboard driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s power: 100mA chip-ID: 18f8:0f97 class-ID: 0301
Hub-6: 4-0:1 info: Super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: amdgpu temp: 31.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1340
Processes: 159 Uptime: 1m wakeups: 0 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 742 lib: 211 Shell: Zsh v: 5.8
running-in: lxterminal inxi: 3.3.11
