@brahma
tried with the 5.15 LTS kernel and the behavior is the same. here are the logs from the previous boot using journalctl -b -1, as I wasn’t able to regain a usable system after wake.
Nov 03 12:33:02 rainb0w kernel: Linux version 5.15.76-1-MANJARO (builduser@fv-az214-469) (gcc (GCC) 12.2.0, GNU ld (GNU Binutils) 2.39.0) #1 SMP PREEMPT Sat Oct 29 14:22:16 UTC 2022
Nov 03 12:33:02 rainb0w kernel: Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64 root=UUID=aace86d6-e678-4f95-9744-2f5921506fc0 rw rootflags=subvol=@ quiet apparmor=1 security=apparmor udev.log_priority=3
Nov 03 12:33:02 rainb0w kernel: Unknown kernel command line parameters "BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64", will be passed to user space.
Nov 03 12:33:02 rainb0w kernel: x86/cpu: SGX disabled by BIOS.
Nov 03 12:33:02 rainb0w kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Nov 03 12:33:02 rainb0w kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
Nov 03 12:33:02 rainb0w kernel: #7 #8 #9 #10 #11
Nov 03 12:33:02 rainb0w kernel: audit: type=2000 audit(1667475178.053:1): state=initialized audit_enabled=0 res=1
Nov 03 12:33:02 rainb0w kernel: SCSI subsystem initialized
Nov 03 12:33:02 rainb0w kernel: VFS: Disk quotas dquot_6.6.0
Nov 03 12:33:02 rainb0w kernel: Initialise system trusted keyrings
Nov 03 12:33:02 rainb0w kernel: Key type blacklist registered
Nov 03 12:33:02 rainb0w kernel: Key type asymmetric registered
Nov 03 12:33:02 rainb0w kernel: Asymmetric key parser 'x509' registered
Nov 03 12:33:02 rainb0w kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PR00._CPC], AE_NOT_FOUND (20210730/psargs-330)
Nov 03 12:33:02 rainb0w kernel: ACPI Error: Aborting method \_SB.PR01._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Nov 03 12:33:02 rainb0w kernel: ACPI Error: Aborting method \_SB.PR02._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Nov 03 12:33:02 rainb0w kernel: ACPI Error: Aborting method \_SB.PR03._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Nov 03 12:33:02 rainb0w kernel: ACPI Error: Aborting method \_SB.PR04._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Nov 03 12:33:02 rainb0w kernel: ACPI Error: Aborting method \_SB.PR05._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Nov 03 12:33:02 rainb0w kernel: ACPI Error: Aborting method \_SB.PR06._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Nov 03 12:33:02 rainb0w kernel: ACPI Error: Aborting method \_SB.PR07._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Nov 03 12:33:02 rainb0w kernel: ACPI Error: Aborting method \_SB.PR08._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Nov 03 12:33:02 rainb0w kernel: ACPI Error: Aborting method \_SB.PR09._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Nov 03 12:33:02 rainb0w kernel: ACPI Error: Aborting method \_SB.PR10._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Nov 03 12:33:02 rainb0w kernel: ACPI Error: Aborting method \_SB.PR11._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Nov 03 12:33:02 rainb0w kernel: Loading compiled-in X.509 certificates
Nov 03 12:33:02 rainb0w kernel: Loaded X.509 cert 'Build time autogenerated kernel key: 68a427c4edde4c83cfe81268a7da6ca1fa25f99b'
Nov 03 12:33:02 rainb0w kernel: Key type ._fscrypt registered
Nov 03 12:33:02 rainb0w kernel: Key type .fscrypt registered
Nov 03 12:33:02 rainb0w kernel: Key type fscrypt-provisioning registered
Nov 03 12:33:02 rainb0w kernel: scsi 5:0:0:0: Direct-Access ATA WDC WDS480G2G0A- 0400 PQ: 0 ANSI: 5
Nov 03 12:33:02 rainb0w kernel: sd 5:0:0:0: [sda] 937703088 512-byte logical blocks: (480 GB/447 GiB)
Nov 03 12:33:02 rainb0w kernel: sd 5:0:0:0: [sda] Write Protect is off
Nov 03 12:33:02 rainb0w kernel: sd 5:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Nov 03 12:33:02 rainb0w kernel: sd 5:0:0:0: [sda] Attached SCSI disk
Nov 03 12:33:02 rainb0w kernel: sd 5:0:0:0: Attached scsi generic sg0 type 0
Nov 03 12:33:02 rainb0w kernel: random: lvm: uninitialized urandom read (4 bytes read)
Nov 03 12:33:02 rainb0w systemd-random-seed[321]: Kernel entropy pool is not initialized yet, waiting until it is.
Nov 03 12:33:02 rainb0w kernel: audit: type=1130 audit(1667475182.880:2): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 03 12:33:02 rainb0w kernel: audit: type=1130 audit(1667475182.893:3): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 03 12:33:02 rainb0w kernel: audit: type=1130 audit(1667475182.930:4): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 03 12:33:02 rainb0w kernel: audit: type=1130 audit(1667475182.986:5): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 03 12:33:02 rainb0w kernel: audit: type=1130 audit(1667475182.993:6): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=modprobe@fuse comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 03 12:33:02 rainb0w kernel: audit: type=1131 audit(1667475182.993:7): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=modprobe@fuse comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 03 12:33:03 rainb0w kernel: acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
Nov 03 12:33:03 rainb0w kernel: acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
Nov 03 12:33:03 rainb0w kernel: Creating 1 MTD partitions on "0000:00:1f.5":
Nov 03 12:33:03 rainb0w kernel: 0x000000000000-0x000001000000 : "BIOS"
Nov 03 12:33:03 rainb0w kernel: audit: type=1130 audit(1667475183.360:8): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-fsck@dev-disk-by\x2duuid-20BB\x2d3157 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 03 12:33:03 rainb0w kernel: audit: type=1130 audit(1667475183.753:9): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=modprobe@fuse comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 03 12:33:03 rainb0w kernel: audit: type=1131 audit(1667475183.753:10): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=modprobe@fuse comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 03 12:33:04 rainb0w kernel: nvidia: loading out-of-tree module taints kernel.
Nov 03 12:33:04 rainb0w kernel: nvidia: module license 'NVIDIA' taints kernel.
Nov 03 12:33:04 rainb0w kernel: Disabling lock debugging due to kernel taint
Nov 03 12:33:04 rainb0w kernel: audit: type=1400 audit(1667475183.966:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="klogd" pid=464 comm="apparmor_parser"
Nov 03 12:33:04 rainb0w kernel: audit: type=1300 audit(1667475183.966:11): arch=c000003e syscall=1 success=yes exit=18209 a0=6 a1=560dd8055f00 a2=4721 a3=0 items=0 ppid=448 pid=464 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="apparmor_parser" exe="/usr/bin/apparmor_parser" subj=unconfined key=(null)
Nov 03 12:33:04 rainb0w kernel: audit: type=1327 audit(1667475183.966:11): proctitle=2F7362696E2F61707061726D6F725F706172736572002D2D7265706C616365002D2D002F6574632F61707061726D6F722E64
Nov 03 12:33:04 rainb0w kernel: audit: type=1400 audit(1667475183.980:12): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=456 comm="apparmor_parser"
Nov 03 12:33:04 rainb0w kernel: audit: type=1300 audit(1667475183.980:12): arch=c000003e syscall=1 success=yes exit=30921 a0=6 a1=560dd820def0 a2=78c9 a3=0 items=0 ppid=448 pid=456 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="apparmor_parser" exe="/usr/bin/apparmor_parser" subj=unconfined key=(null)
Nov 03 12:33:04 rainb0w kernel: audit: type=1327 audit(1667475183.980:12): proctitle=2F7362696E2F61707061726D6F725F706172736572002D2D7265706C616365002D2D002F6574632F61707061726D6F722E64
Nov 03 12:33:04 rainb0w kernel: nvidia: module verification failed: signature and/or required key missing - tainting kernel
Nov 03 12:33:04 rainb0w kernel: audit: type=1400 audit(1667475184.006:13): apparmor="STATUS" operation="profile_load" profile="unconfined" name="samba-dcerpcd" pid=460 comm="apparmor_parser"
Nov 03 12:33:04 rainb0w kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 520.56.06 Thu Oct 6 21:38:55 UTC 2022
Nov 03 12:33:04 rainb0w kernel: random: crng init done
Nov 03 12:33:04 rainb0w kernel: nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
Nov 03 12:33:05 rainb0w polkitd[590]: Loading rules from directory /etc/polkit-1/rules.d
Nov 03 12:33:05 rainb0w polkitd[590]: Loading rules from directory /usr/share/polkit-1/rules.d
Nov 03 12:33:05 rainb0w polkitd[590]: Finished loading, compiling and executing 8 rules
Nov 03 12:33:05 rainb0w polkitd[590]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
Nov 03 12:33:07 rainb0w systemd[729]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[sddm] ruser=[<unknown>] rhost=[<unknown>]
Nov 03 12:33:07 rainb0w systemd[729]: xdg-user-dirs-update.service: Main process exited, code=exited, status=1/FAILURE
Nov 03 12:33:07 rainb0w systemd[729]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
Nov 03 12:33:07 rainb0w systemd[729]: Failed to start Update XDG user dir configuration.
Nov 03 12:33:08 rainb0w kernel: kauditd_printk_skb: 237 callbacks suppressed
Nov 03 12:33:08 rainb0w kernel: audit: type=1334 audit(1667475188.700:123): prog-id=19 op=LOAD
Nov 03 12:33:08 rainb0w kernel: audit: type=1300 audit(1667475188.700:123): arch=c000003e syscall=321 success=yes exit=26 a0=5 a1=7ffc3ffede30 a2=90 a3=5e items=0 ppid=1 pid=655 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="NetworkManager" exe="/usr/bin/NetworkManager" subj=unconfined key=(null)
Nov 03 12:33:08 rainb0w kernel: audit: type=1327 audit(1667475188.700:123): proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
Nov 03 12:33:08 rainb0w kernel: audit: type=1130 audit(1667475188.726:124): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 03 12:33:09 rainb0w kernel: audit: type=1400 audit(1667475189.410:125): apparmor="STATUS" operation="profile_load" profile="unconfined" name="docker-default" pid=777 comm="apparmor_parser"
Nov 03 12:33:09 rainb0w kernel: audit: type=1300 audit(1667475189.410:125): arch=c000003e syscall=1 success=yes exit=7945 a0=4 a1=565007d86670 a2=1f09 a3=0 items=0 ppid=776 pid=777 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="apparmor_parser" exe="/usr/bin/apparmor_parser" subj=unconfined key=(null)
Nov 03 12:33:09 rainb0w kernel: audit: type=1327 audit(1667475189.410:125): proctitle=61707061726D6F725F706172736572002D4B72002F7661722F6C69622F646F636B65722F746D702F646F636B65722D64656661756C7431313736393237353432
Nov 03 12:33:09 rainb0w kernel: Bridge firewalling registered
Nov 03 12:33:09 rainb0w kernel: audit: type=1325 audit(1667475189.560:126): table=nat family=2 entries=0 op=xt_register pid=779 subj=unconfined comm="iptables"
Nov 03 12:33:09 rainb0w kernel: audit: type=1300 audit(1667475189.560:126): arch=c000003e syscall=55 success=yes exit=0 a0=4 a1=0 a2=40 a3=7ffe53e94120 items=0 ppid=744 pid=779 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-legacy-multi" subj=unconfined key=(null)
Nov 03 12:33:09 rainb0w kernel: audit: type=1327 audit(1667475189.560:126): proctitle=2F7573722F62696E2F69707461626C6573002D2D77616974002D74006E6174002D4C002D6E
Nov 03 12:33:09 rainb0w udisksd[841]: udisks daemon version 2.9.4 starting
Nov 03 12:33:09 rainb0w udisksd[841]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Nov 03 12:33:14 rainb0w kernel: kauditd_printk_skb: 127 callbacks suppressed
Nov 03 12:33:14 rainb0w kernel: audit: type=1100 audit(1667475194.366:174): pid=946 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="ben" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Nov 03 12:33:14 rainb0w kernel: audit: type=1101 audit(1667475194.366:175): pid=946 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="ben" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Nov 03 12:33:14 rainb0w kernel: audit: type=1103 audit(1667475194.366:176): pid=946 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="ben" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Nov 03 12:33:14 rainb0w kernel: audit: type=1006 audit(1667475194.366:177): pid=946 uid=0 subj=unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
Nov 03 12:33:14 rainb0w kernel: audit: type=1300 audit(1667475194.366:177): arch=c000003e syscall=1 success=yes exit=4 a0=8 a1=7ffdf32baa30 a2=4 a3=7ffdf32ba744 items=0 ppid=685 pid=946 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="sddm-helper" exe="/usr/lib/sddm/sddm-helper" subj=unconfined key=(null)
Nov 03 12:33:14 rainb0w kernel: audit: type=1327 audit(1667475194.366:177): proctitle=2F7573722F6C69622F7364646D2F7364646D2D68656C706572002D2D736F636B6574002F746D702F7364646D2D6175746837623138346632352D656663352D343232382D623361392D623633346530613233623637002D2D69640031002D2D7374617274002F7573722F62696E2F7374617274706C61736D612D783131002D2D
Nov 03 12:33:14 rainb0w kernel: audit: type=1130 audit(1667475194.453:178): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 03 12:33:14 rainb0w systemd[948]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[ben] ruser=[<unknown>] rhost=[<unknown>]
Nov 03 12:33:14 rainb0w kernel: audit: type=1101 audit(1667475194.456:179): pid=948 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="ben" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 03 12:33:14 rainb0w kernel: audit: type=1103 audit(1667475194.456:180): pid=948 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:setcred grantors=? acct="ben" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Nov 03 12:33:14 rainb0w kernel: audit: type=1006 audit(1667475194.456:181): pid=948 uid=0 subj=unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=3 res=1
Nov 03 12:33:16 rainb0w backlighthelper[1125]: org.kde.powerdevil: no kernel backlight interface found
Nov 03 12:33:17 rainb0w pipewire[1141]: mod.rt: Can't find xdg-portal: (null)
Nov 03 12:33:17 rainb0w pipewire[1141]: mod.rt: found session bus but no portal
Nov 03 12:33:17 rainb0w pipewire-media-session[1142]: mod.rt: Can't find xdg-portal: (null)
Nov 03 12:33:17 rainb0w pipewire-media-session[1142]: mod.rt: found session bus but no portal
Nov 03 12:33:17 rainb0w polkitd[590]: Registered Authentication Agent for unix-session:2 (system bus name :1.60 [/usr/lib/polkit-kde-authentication-agent-1], object path /org/kde/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8)
Nov 03 12:33:19 rainb0w pamac-tray-plas[1207]: updates_checker.vala:71: check updates
Nov 03 12:33:19 rainb0w kernel: kauditd_printk_skb: 17 callbacks suppressed
Nov 03 12:33:19 rainb0w kernel: audit: type=1334 audit(1667475199.570:193): prog-id=0 op=UNLOAD
Nov 03 12:33:20 rainb0w pamac-tray-plas[1207]: updates_checker.vala:101: 0 updates found
Nov 03 12:33:22 rainb0w pulseaudio[1310]: stat('/etc/pulse/default.pa.d'): No such file or directory
Nov 03 12:33:24 rainb0w systemd[730]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[sddm] ruser=[<unknown>] rhost=[<unknown>]
Nov 03 12:33:24 rainb0w kernel: audit: type=1131 audit(1667475204.783:194): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=user@962 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 03 12:33:24 rainb0w kernel: audit: type=1131 audit(1667475204.836:195): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=user-runtime-dir@962 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 03 12:33:35 rainb0w kernel: audit: type=1131 audit(1667475215.403:196): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 03 12:33:35 rainb0w kernel: audit: type=1334 audit(1667475215.476:197): prog-id=0 op=UNLOAD
Nov 03 12:33:35 rainb0w kernel: audit: type=1334 audit(1667475215.476:198): prog-id=0 op=UNLOAD
Nov 03 12:33:35 rainb0w kernel: audit: type=1334 audit(1667475215.476:199): prog-id=0 op=UNLOAD
Nov 03 12:33:42 rainb0w dbus-daemon[589]: [system] Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
Nov 03 12:33:42 rainb0w pulseaudio[1310]: GetManagedObjects() failed: org.freedesktop.DBus.Error.TimedOut: Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
Nov 03 12:33:47 rainb0w kernel: audit: type=1131 audit(1667475227.927:200): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 03 12:33:48 rainb0w kernel: audit: type=1334 audit(1667475228.025:201): prog-id=0 op=UNLOAD
Nov 03 12:33:48 rainb0w kernel: audit: type=1334 audit(1667475228.025:202): prog-id=0 op=UNLOAD
Nov 03 12:33:48 rainb0w kernel: audit: type=1334 audit(1667475228.025:203): prog-id=0 op=UNLOAD
Nov 03 12:38:22 rainb0w kernel: sd 5:0:0:0: [sda] Synchronizing SCSI cache
Nov 03 12:38:22 rainb0w kernel: sd 5:0:0:0: [sda] Stopping disk
Nov 03 12:38:22 rainb0w kernel: sd 5:0:0:0: [sda] Starting disk
Nov 03 12:38:22 rainb0w kernel: done.
Nov 03 12:38:22 rainb0w kernel: audit: type=1130 audit(1667475502.129:204): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 03 12:38:22 rainb0w kernel: audit: type=1131 audit(1667475502.129:205): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 03 12:38:22 rainb0w kernel: audit: type=1130 audit(1667475502.419:206): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 03 12:38:24 rainb0w kernel: audit: type=1701 audit(1667475504.449:207): auid=1000 uid=1000 gid=1000 ses=3 subj=unconfined pid=1066 comm="QSGRenderThread" exe="/usr/bin/plasmashell" sig=11 res=1
Nov 03 12:38:24 rainb0w kernel: audit: type=1334 audit(1667475504.496:208): prog-id=24 op=LOAD
Nov 03 12:38:24 rainb0w kernel: audit: type=1334 audit(1667475504.496:209): prog-id=25 op=LOAD
Nov 03 12:38:24 rainb0w kernel: audit: type=1334 audit(1667475504.496:210): prog-id=26 op=LOAD
Nov 03 12:38:24 rainb0w kernel: audit: type=1130 audit(1667475504.496:211): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-coredump@0-2171-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 03 12:38:25 rainb0w kernel: audit: type=1334 audit(1667475505.613:212): prog-id=27 op=LOAD
Nov 03 12:38:26 rainb0w systemd-coredump[2172]: [🡕] Process 1066 (plasmashell) of user 1000 dumped core.
Module linux-vdso.so.1 with build-id 507836a1ad0d4946b9a245e6fd3cc243bc6a8b35
Module libprisonquickplugin.so with build-id 6e194f0e297e9134c9652d4bd63410c982bb6f4f
Module libKF5NotifyConfig.so.5 with build-id ad7b00201ad76611d1557ff216100d87e0ec9f16
Module plasma_engine_notifications.so with build-id a12a7dbfe60063c2fb61ec46127e27440384bc11
Module kio_file.so with build-id ba41f5c9d8183ba5e708fd50c76083a308bfbd16
Module KF5IdleTimeXcbPlugin0.so with build-id 26802838ee2ff7ee89bfa0a46243291b53f2c85e
Module libplc4.so with build-id ae18d68f01288868c93380064a1517522f3a844f
Module libplds4.so with build-id 26c6c93ab7e9b7022734be96a91d0959b4c84fe5
Module libnssutil3.so with build-id 88012b532a109e5b0dbc437ea8a7ca92ae905e6e
Module libnspr4.so with build-id 7810f60fbe92aa8395979eb46f16f4dac61e6a93
Module libnss3.so with build-id 5ce14f6297f3d9e24242317a4393191a0f9d569d
Module libsmime3.so with build-id 05058ebd3a55330d58ede6ebf181650605f14f39
Module libKF5Wallet.so.5 with build-id a10857fb418edf47b3287097ef1d58ad6ba07a46
Module libnm.so.0 with build-id e0434b18f12f38a12a785f5cd3148b2a34c4f4f7
Module libKF5NetworkManagerQt.so.6 with build-id d86c1b235913662a22bf1b4c58de78af64961549
Module libKF5ModemManagerQt.so.6 with build-id 7bc09fc5a23679258500859739246c31d9c5168d
Module libplasmanm_editor.so with build-id 66e2351a48bb10d851c8fec0bf6ebe2a04ab91db
Module libplasmanm_internal.so with build-id 068ed297ddbeb1e98329fd7289d29ed6e208aebf
Module libplasmanm_qmlplugins.so with build-id ae40f364911c2a111b6e9f1ca3e4f245d8e524e6
Module libavahi-client.so.3 with build-id 1858551543958190c653b565cf0eb64609ad908a
Module libavahi-common.so.3 with build-id 80fda945459a3476ccd1050783dfd5f5c17c479a
Module libcups.so.2 with build-id 62620e2ba8de0b241ddcde466d8355ac8a37b41b
Module libkcupslib.so with build-id f9140a83d2e57f8c033959f7ccedc47a5cc31956
Module libprintmanager.so with build-id dacd213593e3ecd85234d90cbbeaa4426d37646e
Module libnotificationmanagerplugin.so with build-id 2b4d0e6d18426226a6c9c88365e9151ed1c71cdd
Module libnightcolorcontrolplugin.so with build-id d23ba7976af00fc996012750e485e0acbfd53c53
Module libkeyboardlayoutplugin.so with build-id 12a078366aa6f68bc68c62690daf63d8d06a8f9e
Module libqtlabsplatformplugin.so with build-id 0c18b639deab28a2258b791f61dbd5065550d206
Module plasma_engine_keystate.so with build-id 6619a508954ecb865e37d094bf228603dc0a097c
Module plasma_engine_devicenotifications.so with build-id ca05436fb5717e0497a10947166e7e92681451d7
Module plasma_engine_soliddevice.so with build-id ca04e2da36c46b9acd843594d10cfa4350ec8671
Module plasma_engine_hotplug.so with build-id 3a5c23e3a8c336f8e630549e349677db63c488fa
Module libKF5SonnetCore.so.5 with build-id 382e11aa280575f2450b2221c84dc511451de110
Module libKF5SonnetUi.so.5 with build-id a7d5907bbfa5ece5415b1596b920f6bb35ccfb7c
Module libZXing.so.1 with build-id 052f11e769620cb9fb8a08182cc34037f5f35462
Module libdmtx.so.0 with build-id e4dd258baefc1f3cac0bc970fa416d4ab58e69ad
Module libqrencode.so.4 with build-id abf3bf609471dbc409c77b0406677af374595acd
Module libKF5TextWidgets.so.5 with build-id 6efb4709cf3b45e4c2dec7704acf4f4aa08cc75e
Module libKF5Prison.so.5 with build-id fb6120f943dfbbf816e35fccc63012d8f673712c
Module plasma_engine_clipboard.so with build-id 6c9691ff9cc8936afe7229abf9555b89fc084ff3
Module libqmlsettingsplugin.so with build-id 50639c5b62ae96c5f64dedf6ae77843719b20980
Module libqmlfolderlistmodelplugin.so with build-id 6675d966e1a1d17664b41197508a919ccbef7124
Module libdialogsprivateplugin.so with build-id 480a8aed6d477af0943cbbc1a099c1751b9e13ef
Module libdialogplugin.so with build-id 8f6c002093522aea8dfd41554f52056b0b1d1a8b
Module libqca-qt5.so.2 with build-id 307e201f50b6ef24003c05007d3468f8441ebcec
Module libkdeconnectcore.so.22 with build-id e9cd8e95ae2779cd0faeef61fdce5c0bd20a7910
Module libkdeconnectinterfaces.so.22 with build-id d77c78e4066b8ab6d75bc2f0f0f0d2094402ccdc
Module libkdeconnectdeclarativeplugin.so with build-id 242ff465c088aa9041abf8745ab8ba04b80b1e9d
Module libFormatterPlugin.so with build-id e33690ca1077598b2572bc92608a93a446086c7e
Module libQuickChartsControls.so with build-id c8fdbd10267f724b8035d966b3208ae639284c3f
Module plasma_engine_time.so with build-id 50296a16bac99081d3d7670d516b02eed2611376
Module libKF5CalendarEvents.so.5 with build-id 9b62bd4a14690fc138f3cc4ceea477a1842eb8ac
Module libcalendarplugin.so with build-id 46d46791a6c9521561c5ae8206596ad2d46a9ba8
Module libdigitalclockplugin.so with build-id 764943e2b2441d68fde356c1bb90060544108341
Module libpagerplugin.so with build-id a926161f10585f7a6174477dc1efb27ed2975b88
Module libshowdesktopplugin.so with build-id a9f29c8673ff66b73be34340a3b826023f0d10e9
Module libopus.so.0 with build-id 35fafc4024675e9cfe57c7d50c3965eac6bac358
Module libFLAC.so.12 with build-id d09804bc783c1cad0b423b136a5260c0e8c62d40
Module libvorbisenc.so.2 with build-id 2b1ce7fcdcc925bc663ebe2c1c008c0dd96e5bd0
Module libasyncns.so.0 with build-id 3ed7e52f247b08f1dff19aef6a253ee4c5c785c0
Module libsndfile.so.1 with build-id 923361ca7a51d29651ef1e282559cbff70e31cde
Module libpulsecommon-16.1.so with build-id 17e5c781f557e60fbc789cb631816a4a29230f4a
Module libpulse.so.0 with build-id 0c1618cb1e11cc14128914e45965433374cbd10e
Module libpulse-mainloop-glib.so.0 with build-id 557c18bd5f54743e924a5b8e77bbc1b55a31e219
Module libplasma-volume-declarative.so with build-id e88358a342ca0866dd50fdf35ec840199a9b026d
Module plasma_engine_mpris2.so with build-id 928dcfc3735edaf6cce7052caeff2fb9f3e348cc
Module libKF5Screen.so.7 with build-id 90ca44ff82582aad8c00dc742ef372f62e69400d
Module libnotificationmanager.so.1 with build-id 66e11d134f859c9cb30d361229a25c8e7ff2ba9b
Module libprocesscore.so.9 with build-id 9cee225804583006f380d9019d748231f029e7d8
Module libtaskmanagerplugin.so with build-id 1cfc2770bf4511cdf62c49c6221e6a2a9bd0c726
Module libKF5IdleTime.so.5 with build-id 75f318618fdcb64bff63b523f4ba68625a014666
Module plasma_engine_powermanagement.so with build-id d9fe6afcb08f4e544a495fe409fb130d3a9d34f5
Module libsqlite3.so.0 with build-id 782ea1abbeebfd86f7d34c1c4fd1c23d14a8cefd
Module libqsqlite.so with build-id c33f9b1af8bb408f035b3697bd89d24cf6a14023
Module libmodelsplugin.so with build-id dec3b95ffe86af6c5cc585e512e2a453d4d95a66
Module libkcoreaddonsplugin.so with build-id 159b382c208b5a079adb7387120fc601f2650604
Module libgmodule-2.0.so.0 with build-id 4145f63148e903c5cc49730868d4b108e4a2afba
Module libstemmer.so.0 with build-id 013b48e71279a5ec55e3021fc0bd8fb10a08bae5
Module libyaml-0.so.2 with build-id 94fd2b16e4c311e4c8b041061dfdb9ca8f508e29
Module libxml2.so.2 with build-id 171e32069b76d4cfedbfdf97f2087807948a9b3d
Module libxmlb.so.2 with build-id 272439d071eeb589576992d93c91897ad955d064
Module libgio-2.0.so.0 with build-id e40d688960cf27f1e3b08533563affb8baed62af
Module libgobject-2.0.so.0 with build-id 4912a41f41a806314fb1a528139e368746d80dda
Module libappstream.so.4 with build-id 486291eaf797405047a693efbcc2ea76e888c7c6
Module libKF5ThreadWeaver.so.5 with build-id 2e492115c6353d1c33c44f695f2da7a8d1977228
Module libKF5PeopleBackend.so.5 with build-id 1bc196fd75230207b6167125665dc60dd4f2e21c
Module libKF5People.so.5 with build-id fcd540a7c48120a6f57218d3014a84715ffecb57
Module libAppStreamQt.so.2 with build-id 88cde09de8689e3aab04f558b0391c713852038a
Module libKF5Runner.so.5 with build-id 7af4b4520652a5178fbb2a0ec42923aeb664be6b
Module libKF5PeopleWidgets.so.5 with build-id acedb5b349327ffd9d54d27bc9913ada0aae5305
Module libKF5ActivitiesStats.so.1 with build-id 1173f3bfbe4276add005150ea2c7dc1b47da2132
Module libkickerplugin.so with build-id d57de6aa88cd9bc5309e69b338b90d97bc4fe5e6
Module libqqc2desktopstyleplugin.so with build-id 5246d2cfbce39c9d07bb65693829cc234bb88f0f
Module libQuickCharts.so with build-id 688f798b9dc212e6554a544738d08fe685191f0d
Module libFacesPlugin.so with build-id ecbf109ff988680ad028584b30e720631498d24c
Module libSensorsPlugin.so with build-id e5097ef90a3b05161216e2086ea2cebeadbf058e
Module libspa-journal.so with build-id 27ee1f412a07da986ef31ae07ad8a66c0c7e6518
Module libspa-support.so with build-id 643dc98ac8926194625b6308b887331cdccf6003
Module libpipewire-0.3.so.0 with build-id 2493a5061ccfaf0c5b6e34ab3c1b3402c5be680d
Module libKPipeWire.so.5 with build-id fcaf0d56b7a6bdf2645ebd58e91fc0fd430dd128
Module libtaskmanagerplugin.so with build-id 75267142a0d6512c7652b067075a5232f933d9bd
Module org.kde.desktop.so with build-id 215954b5f01eb0783c07898af43878269a8e0c7e
Module libplasmaextracomponentsplugin.so with build-id b3b09a7c0ad3bf95fb664a5a34bf580bf7d2b762
Module libkconfigplugin.so with build-id 5e3f67cc1431338e6cf9e4570c7009a854359774
Module libplasmacomponentsplugin.so with build-id 976367875b2ac914b62a08f0e08ed90786d00881
Module libqmlplugin.so with build-id 4371bda1120bcd66729c3679993a799165b62b01
Module libqtgraphicaleffectsprivate.so with build-id b9b4e3f07305ece9648cfb6278a42d0cc0b721b3
Module libqtgraphicaleffectsplugin.so with build-id bc1cd386d3d00d57f51f7d6d62490907693fe240
Module libcontainmentlayoutmanagerplugin.so with build-id 606736e52eeea50698a3c847023135f8c3410b7f
Module libfolderplugin.so with build-id 936c69838782eb7042101998abd08955eb22b77d
Module libdesktopplugin.so with build-id df9644f48f5db80209033d1a407510b028ad887e
Module libepoxy.so.0 with build-id edc178a150c4255d124e1e1ecbdbecebd1a388cd
Module libkquickcontrolsaddonsplugin.so with build-id c465c423b0508b5cfed2f61f05ecf3ad80f9572f
Module libdraganddropplugin.so with build-id 164b10ac1378066698ed13c9a91d1c4066925f9f
Module libqquicklayoutsplugin.so with build-id 7a4113b6a11813d6e9be13985841de8c6824d775
Module libqtquicktemplates2plugin.so with build-id f4b00f294df9f8e45a2abca8a6b4423d74bed3c0
Module libpsl.so.5 with build-id 0229a201aaf5652186c9fdc192ebe52baf19d7f1
Module libssh2.so.1 with build-id a4adfe44cc7ebd295b3b783361acc3dcfcea1d50
Module libnghttp2.so.14 with build-id 2b3da1b8c8fef25bf3aa4dbfea446a7ac94e41f9
Module libcurl.so.4 with build-id a237f509366ff8301677b1d1a52c4d4f3d875a6d
Module libexiv2.so.27 with build-id f205ba91d7693de2eeb491c402950faa6195f47b
Module libKF5KExiv2.so.15.0.0 with build-id 01f7ecd62116b19fe49939694213da92a58925eb
Module libplasma_wallpaper_imageplugin.so with build-id aebfa48eaf8a0bcd86887e894df0f7ad44ff9eda
Module libwindowplugin.so with build-id 607f45b39ea2369baf25afdd70fba816c6fc25e1
Module libqtquickcontrols2plugin.so with build-id d977ec4fc318ca05a84a9fc7db1faad6ca4732d1
Module plasma_wallpaper.so with build-id 6338a7a6940448929f9b8317aef5864973219226
Module libwebp.so.7 with build-id 96dd01a02a3b0b4dae0d744fc3200fd36f1c2148
Module libwebpdemux.so.2 with build-id 181ecf1a79aa805a45cce672f3f229570eca9f26
Module libwebpmux.so.3 with build-id c987ad73c6cbbfcdb4d632ead20256769852066e
Module libqwebp.so with build-id 725d6aeee464966be97e71ea125da887497e73f8
Module libqwbmp.so with build-id ebaf2ce77c046c0c2de405a8efd3a7367ba6fb5f
Module libtiff.so.5 with build-id 62a8aefb339c3cbe35d1089c66c527a7b090804c
Module libqtiff.so with build-id a8c7a67d7bfc70aec589e49d2640214d3f3ea0e2
Module libqsvg.so with build-id e00dd7ced56a175eef4e4c63fab3faec7191d143
Module libQt5Pdf.so.5 with build-id a4e4fc8897f265f7a24b1d883d68147c0dcf1036
Module libqpdf.so with build-id 3dae34811999e0e7cfaff259afab2809dc58145c
Module libmng.so.2 with build-id 2de13b8bba73f358ab2e323aa2209c2e2fc886e7
Module libqmng.so with build-id 8647deb2c743c3649f8b86158cb9ea4412460cd3
Module libqjpeg.so with build-id 084e64bc3e811ec381bcc51a86105cdb624997e9
Module libqjp2.so with build-id fa28f346f69d77d5377a79e206842165a6ea4880
Module libqico.so with build-id a43ca21df2fe1bc4fa39b49493a9bd7ec71db2c8
Module libqicns.so with build-id 9abf6684280e69a83a486248849775d27dddcaba
Module libqgif.so with build-id a6e54e41d1e766e702d2e4d4b8ce54e94291daf3
Module kimg_xcf.so with build-id 7b57383cd721eda7ca43fa3fdb7990aa65b9b3b3
Module kimg_tga.so with build-id b361772cc688501d34c335072dbb293e89b0b65b
Module kimg_rgb.so with build-id 12c23fdea1c85d8e6e75da61767f9128fe8549e2
Module libgomp.so.1 with build-id 117ab7458eb756ac0e9e4791c510ae72fe710bd5
Module liblcms2.so.2 with build-id c01e5649a38dbf37768d02dc751b52de0dcbd141
Module libjasper.so.6 with build-id 920c93104c2081399a4d6334e239cc0fa14bc4b2
Module libraw.so.20 with build-id 6140fabd31b4e8f1e8a6a2e6cff9d53a3358e8e6
Module kimg_raw.so with build-id fe53f3e53b389179e389e8bb63bf62d580bccf4c
Module kimg_ras.so with build-id 7c95926a500d8a07d55883935181052fc9d6d2ca
Module kimg_psd.so with build-id 9d4040aaeb0b14a42b2d7b03c357a51cec20b264
Module kimg_pic.so with build-id 3dd1e03363ae92f999d27d43d152d95d16b59932
Module kimg_pcx.so with build-id b86beec84c0e73a79484c1e34671acefbad582e1
Module kimg_ora.so with build-id a4b2c495210b528bf44ee70d323bf20c3fef9073
Module kimg_kra.so with build-id 61e045af9dde8c0398f5dc42e25a8936a9121181
Module libmvec.so.1 with build-id 87830691ff1275668548231fddf8ff8eaa937fd6
Module libx265.so.199 with build-id 4fd2d7155725df753c6b32274c442349fc05e632
Module libde265.so.0 with build-id 243caf27268d3ccf706d0588f1535922b89b8674
Module libheif.so.1 with build-id 038e0a8d11ceb6bd37b4f2b8930f268b9cf7adfe
Module kimg_heif.so with build-id 278597bb60053fa70ee33c1b1eae680f14d03796
Module kimg_hdr.so with build-id 0e8b5ccd64576bf97b502268914528397ae7178e
Module libIlmThread-3_1.so.30 with build-id fb61aaa8abdf748eb68984c0ef25b0ae85a6565f
Module libIex-3_1.so.30 with build-id 5e8a8f33fa7d4b83185155f19d4604501a86cf62
Module libImath-3_1.so.29 with build-id e896fb1a525652197371e499d81b83e6c5a3d0a5
Module libOpenEXR-3_1.so.30 with build-id 875e7df47bd5ce2de8806bb9fa046061fa43a8ef
Module kimg_exr.so with build-id 6a3b1a89068a765fba1144b13190b663eb9028aa
Module kimg_eps.so with build-id 841662819d310ad7616692dcaa19f161aa8eed37
Module libjpeg.so.8 with build-id 46dfd8b2cbe8a10d13cd3182a7b490d0959534f9
Module libyuv.so with build-id 60a987609f24d8125baf7f8f2a3b288eb465d87e
Module libaom.so.3 with build-id eacc2c29204604b1ebf7a40325dcaab738ce0bd1
Module libSvtAv1Enc.so.1 with build-id 5404c3c56ac81ef10fb890164bcbdb48fdd17774
Module librav1e.so.0 with build-id 71e3a64e4f1fd0bda7ec80b255af3de4ea403ac1
Module libdav1d.so.6 with build-id a93560a23a7f1def734a3cf54f09eadd7c3c46e9
Module libavif.so.14 with build-id 7c7c60390f804291a41ed3e75cd75121eda0ed35
Module kimg_avif.so with build-id a86168e2103ba56dc6a902adb999744d87fef6e0
Module kimg_ani.so with build-id 38919e689c61edae6e6e70039e9aa349c84e9c42
Module libKirigamiPlugin.so with build-id 925ed09d941711ebed6c37b825f628d36a5fc8bd
Module libactivityswitcherextensionplugin.so with build-id 41f24cbc6817b80d1ab2dfb0c48af38f2f023358
Module libkwindowsystem.so with build-id 273aab4c9c0233366501a625321c06f4f0ab8aef
Module libOpenGL.so.0 with build-id 3df533822644f44fa89abdb75b9f89220dfdee56
Module libEGL.so.1 with build-id 14389538015bb4a3a44e794e2466e31bf0834209
Module libxcb-composite.so.0 with build-id e8b69e2806d928f66445390cc50ab33a0b98bef0
Module libxcb-damage.so.0 with build-id d18fa3897f9041bfe25380abd9834332896cda81
Module libcorebindingsplugin.so with build-id 53a1870ad4eb36211448334f1a8027eb1ddfaa62
Module libqtquickcontrolsplugin.so with build-id 338504ba25557f012bfe7a10c04856c83a7446fa
Module libQt5QmlWorkerScript.so.5 with build-id 38e5b4ffdd879132bcd64d5859e8649e72b1e9dc
Module libqtquick2plugin.so with build-id 550d613539501220da472cd367f7c65c834abe2d
Module org.kde.plasma.notifications.so with build-id f7ff6a8b1a9a43adf668b458ff106d125bcf0e16
Module org.kde.plasma.private.systemtray.so with build-id 05d843682fc9f0d4fa83aacbe3daa3123878d187
Module org.kde.plasma.systemtray.so with build-id be06edf033e60c9a68fd01126dc69829e2aba908
Module sensorface_packagestructure.so with build-id 25dc5bc24dc5a0a136b1a7f6a25be97fc84f5a66
Module libsensors.so.5 with build-id dc8b2c1c0d8525411aca188ea3cc3fb86d381d30
Module libKSysGuardFormatter.so.1 with build-id 0aebc86b1586aaf8134a9d8b3670ba4808e72d97
Module libKSysGuardSystemStats.so.1 with build-id a7b4b1f21c0dce4ecffb74972c2ff3ac6de6cba3
Module libKF5ConfigQml.so.5 with build-id 796dcb7128e387a42fd25c2e5c71c6f1c4cdb9e0
Module libKSysGuardSensors.so.1 with build-id 33f4c3ffc59eee97cdb27fd34b02baa625147d16
Module libKSysGuardSensorFaces.so.1 with build-id 70023286e44930d345fc6b86734b298b3ca6e385
Module org.kde.plasma.systemmonitor.so with build-id f81334cab96554004a99d64538a1efaca67bcfde
Module libKF5ItemModels.so.5 with build-id f428cd57aa3cb8cca0050121a631aca1d87d17fb
Module libtaskmanager.so.6 with build-id 960c38d7c78f0d46dec272168dcb612e073b915c
Module plasma_containmentactions_switchdesktop.so with build-id 6de2e43d88a81ee20a65f0815b7d6458eb32ae08
Module plasma_containmentactions_contextmenu.so with build-id 587036751457f027ee0f5d36333920ada0db4b27
Module plasma_containmentactions_paste.so with build-id 528778881d7b4d1d9485eac05e70560f7d46ed10
Module plasma_appletscript_declarative.so with build-id d52c98d24143d7e85c18e9a29f29455f7850f823
Module plasma_layouttemplate.so with build-id 9483a30c9522f8740d32a0b1501d12e4e5964d03
Module plasma_applet.so with build-id a624a767a563372d43ca9fbadfec5bfbfb5578fd
Module libxcb-res.so.0 with build-id cd3dbd6dd9e412a002d1be5ae0ec0d85650542ba
Module KF5WindowSystemX11Plugin.so with build-id 9750008551c84c8cd749a50df79be39e44ab8020
Module plasma_shell.so with build-id 0fd60789e11774d306a32335b8624d8d8ffeac29
Module plasma_lookandfeel.so with build-id 59442fafb987a585a4d2983a7fa846a83788c3f8
Module libKF5Style.so.5 with build-id 4c2db1b84e3a5d5538f2ff091bb5f0897b131910
Module libbreezecommon5.so.5 with build-id 3bcf609c0beb9f09973fc3b47b44fec09d156afc
Module libKF5Kirigami2.so.5 with build-id 9da45886e79d1d394d5471eee27e0181bdc368ea
Module breeze.so with build-id b3c73a1450dacaf707283786887eac215d0ed362
Module libdrm.so.2 with build-id 5b59e55b50556f6d541e4d73fd6a2dcfb1983894
Module librt.so.1 with build-id ce8e0934f83057f038b5a06eb70082bef142d2f0
Module libnvidia-glcore.so.520.56.06 with build-id b5e8446f41653b373f33acb52a71eba82b133d52
Module libnvidia-tls.so.520.56.06 with build-id 923c587d22039c45235d942668af2db11204a200
Module libnvidia-glsi.so.520.56.06 with build-id 3a9139abd662306e3c750492e0c0fa98d3348b8c
Module libGLX_nvidia.so.0 with build-id 2a8c63baf3f20fe2cc3b56a199a54cac93594c4b
Module libxcb-glx.so.0 with build-id 71d5b6691f53a235696da49ffa2178d643ecc228
Module libqxcb-glx-integration.so with build-id a9ee30eef2f19532b08a6e6572737e0a6ecec96d
Module libcomposeplatforminputcontextplugin.so with build-id b7d75f89aa42cbf4504bce73360cd2bb3fe2535c
Module libQt5QuickTemplates2.so.5 with build-id ef1e40831d52b364bb22c93e3155f3fb579f1fb4
Module libKF5Bookmarks.so.5 with build-id eac2902348e7f3cf50624eee40054c375870ff60
Module libQt5QuickControls2.so.5 with build-id cb27d61b09aa45ce43aeef8e025765452a153dc0
Module libKF5KIOFileWidgets.so.5 with build-id 9ef12b55f79d5a4fcab9247aa680900112b26ac2
Module KDEPlasmaPlatformTheme.so with build-id 5e08eb70da25c0eddc8f49722617584ddaa07081
Module libXfixes.so.3 with build-id 0a05c7e8714522bfbdd7c0027c3e2a94965664b0
Module libXrender.so.1 with build-id 9d6512ea1c9698e8c81f27e89fda57d36eb4b18e
Module libXcursor.so.1 with build-id f0525ae3715ac95f96a8cdb44795b03f831334b0
Module libuuid.so.1 with build-id 9057a530e6b3b0e71f24602a0039c490c9a0b5a1
Module libxcb-util.so.1 with build-id b1e4c01b388a3bd7a0a9ad384865b61f5f1d4a24
Module libxkbcommon-x11.so.0 with build-id 90654f41d9fe91c74bef6672a8b57ab34418b27a
Module libICE.so.6 with build-id a78252e65631a98d7935f1bca668c2fe1d6bbb53
Module libSM.so.6 with build-id 66cef8ae9a7848679be78dd26fd47e05110d03b5
Module libxcb-xinput.so.0 with build-id 409ee697e2b16243bf1fc6429e672f2359033388
Module libxcb-xkb.so.1 with build-id bad7e1eb65df04a6b2d676a08f68844856edaace
Module libxcb-xinerama.so.0 with build-id 5d2ab2683447d9bb7bcc49c058dfa06bcb65560d
Module libxcb-xfixes.so.0 with build-id e231a68d00ee4cfa12a2c31e755a9e2c1e7be450
Module libxcb-sync.so.1 with build-id 13025f6de23a271636ad321c77eda98801e62e8e
Module libxcb-render.so.0 with build-id b1ca498d665807ab0ccdafbe8070853efd058173
Module libxcb-render-util.so.0 with build-id be7563af6c149b8412129d31bf3e262eb94b0efb
Module libxcb-shm.so.0 with build-id 828fec4d856e2710e732ea8d92c3f250c807b1c2
Module libxcb-image.so.0 with build-id f74049aed07d4b443711334c4d6692439c2595db
Module libxcb-icccm.so.4 with build-id 5d6f83a2aa185e59274a061f07b8a50b766445f8
Module libX11-xcb.so.1 with build-id f92352eae0a30aea89d11beb22367fa985288925
Module libQt5XcbQpa.so.5 with build-id 12d2bca39e8610215c70cfde3bfab531d34b8406
Module libqxcb.so with build-id 1fdbc58e0182862fe58a8b652b794def082a3ca0
Module libdl.so.2 with build-id 414d1d630bc04818a150b9c73e4493f3395e8869
Module libbrotlicommon.so.1 with build-id acfd597a977c8087bb6184383daae2e828a9ce42
Module libgpg-error.so.0 with build-id 470d76ceb1e53cb017f78c08936e9bafaeb4058b
Module libgmp.so.10 with build-id 26cec2ebe94cc5c4cb99e6988717347222b324fd
Module libhogweed.so.6 with build-id 5c4a99ad0aabe13bd9b517f92ab339436a2bc1f2
Module libnettle.so.8 with build-id 6a26cbe6819abc8c57668f80ca8c8160fd85e29e
Module libunistring.so.2 with build-id 617dbf3d3d6f85d6556a7a036e23845e95490158
Module libidn2.so.0 with build-id b16e7570b102789b13ff77289762dbfe3f8f46bc
Module libbrotlienc.so.1 with build-id 74adbc62e4fbb5da9d37b5aa458471f4130862ff
Module libp11-kit.so.0 with build-id cc372ea3c28c4d3dfc633b4d2e933c8584d2af16
Module libogg.so.0 with build-id ca0cae30a809f10db1f16e54a23b4e5ff7b2c54c
Module libvorbis.so.0 with build-id f4e086347f6c1a66eb73cfe13974a29bd39aabca
Module libacl.so.1 with build-id 27869ed0219ade5d2ffd50eaee11f967187faa8b
Module libresolv.so.2 with build-id 2e70cfe9f2972fb13487eeefcb10e4afafed6157
Module libkeyutils.so.1 with build-id ac405ddd17be10ce538da3211415ee50c8f8df79
Module libkrb5support.so.0 with build-id 9a22a372b2157fb05da1bad94b92d9617513af81
Module libcom_err.so.2 with build-id 3360a28740ffbbd5a5c0c21d09072445908707e5
Module libk5crypto.so.3 with build-id 47d53a3ea2b172eb3db1be0ae0272c7c045267e8
Module libkrb5.so.3 with build-id 1fc969c1f54103d87e400237751b4804569a2730
Module libbrotlidec.so.1 with build-id 66c54e9301f7e102ecc1d88547e5f0e8a056fe22
Module libexpat.so.1 with build-id a98bfab551dfa3df6889c33d5fd2ccfa6d505608
Module libpcre2-8.so.0 with build-id 917fc43d2c9f8539a3e324555c6c73886e8000a8
Module libicudata.so.72 with build-id a133b365160fc45e002163e5435f3029f4254cfa
Module liblz4.so.1 with build-id 84ea95d811dad359e94e100ebe6a746294ffe8a7
Module libcap.so.2 with build-id 9b38b08de708f439a9d0a4f8b9914151bc8d4b50
Module libgraphite2.so.3 with build-id ce58945ebb55b86d3a4e717b6eae29efc4720d8e
Module libGLX.so.0 with build-id d2c37fb8ec3bc53c67c013b0c6ac63ec086c8883
Module libGLdispatch.so.0 with build-id 7879a881271650eff97c35aff7a8674859c5ae94
Module libpthread.so.0 with build-id 3954d7fd57fa4db438d0ccdd8e2c6f7cc97c2e46
Module libusbmuxd-2.0.so.6 with build-id fd9f05e7f5b0da4e15972f75b61fd9b4b9f06dbe
Module libgcrypt.so.20 with build-id 8bf3cb884124273640de797a3e77d86c98434ea4
Module libtasn1.so.6 with build-id fa2f7a5bfbcda1481ab5875d5744730ea1be8fb1
Module libgnutls.so.30 with build-id e849ad24d363553f5ddc88d43926e1ab2601ada9
Module libblkid.so.1 with build-id fb2c5d3c17aac74758a3eb80a2bc1c16bcf183b1
Module libXext.so.6 with build-id d7f3b1c9d5be6574b5faf83b74f8bba3d0dfa3c6
Module libltdl.so.7 with build-id 6a619e7b85ea9702e595881863bc9e599565e8a0
Module libtdb.so.1 with build-id f2bdb5ac97b6addf2026d93b08c8d15defcd9bb8
Module libvorbisfile.so.3 with build-id 45d2551167a616d448beb033ba49394831992887
Module libKF5AuthCore.so.5 with build-id e8c3961a260b70043d5543749b7ce3bd144709d7
Module libKF5Codecs.so.5 with build-id 0b578cfe76a2b39f96ba7bc6df0ddd9be7c22ac7
Module liblzma.so.5 with build-id 8a7334fec02fef6a82ff641a68b3e3200a44a702
Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
Module libKF5Completion.so.5 with build-id 6c0702106cae7afb0e5bbeede714d3d526358fd4
Module libKF5JobWidgets.so.5 with build-id 0c31576fdf79ff7e39ed60db7566fddde770e5e1
Module libKF5KIOCore.so.5 with build-id c1468f75ae5f45203c5abacab49b92a351b781e6
Module libcrypto.so.1.1 with build-id 7981ea3d69f3c28e46ee312a815af96eab93775c
Module libssl.so.1.1 with build-id e6b1f97a5b60b4248c49dfc5b11f53f281b507d0
Module libgssapi_krb5.so.2 with build-id a10eaeef6e9969e80048d247666a3af155716afc
Module libxkbcommon.so.0 with build-id 6cf66eead3fcc20fe5df10162bfbcdcdc8b2a183
Module libfreetype.so.6 with build-id f89dd5502e75aca28fb5c3ccd0dbd26fe822bfef
Module libfontconfig.so.1 with build-id 9e856b5b37a3f4f7176ad8f92b2123508c95406e
Module libwayland-cursor.so.0 with build-id 46a637dbcbb02d6712a201f177377b66598b9121
Module ld-linux-x86-64.so.2 with build-id 22bd7a2c03d8cfc05ef7092bfae5932223189bc1
Module libglib-2.0.so.0 with build-id 49826f5cd4f784c8050176991d46fd93a5fcee9f
Module libzstd.so.1 with build-id ab54c2881f53ab314e134f3e08c76d504376dd5d
Module libpcre2-16.so.0 with build-id 8ad49680a3f743a5241632a400d0de30aeaa54dd
Module libicuuc.so.72 with build-id c2e0249a038bd0fe76e681ecd2b73951c65a0866
Module libicui18n.so.72 with build-id aec148964d10586dae138df84f087835382396f2
Module libdouble-conversion.so.3 with build-id 74bfa78f70f9ae1f759f0ae383fbc7f6f7faf6f8
Module libsystemd.so.0 with build-id 461d1674a5e4c71184837ae7a6a827c9570ada42
Module libmd4c.so.0 with build-id 2151dba72cdc9960097e6e960a58a2f03c8bb96e
Module libharfbuzz.so.0 with build-id 181bbb0db2bce74b6bd5ed66ee7dcbed96323d8b
Module libz.so.1 with build-id 5340199d53cb95e609028ce1143675c742ff4218
Module libpng16.so.16 with build-id 14d3b3cc9d61ec1b7c1f86bdf108218a99364945
Module libGL.so.1 with build-id 6f65953140bc8a2aba47c9d492658dc61891393e
Module libdbus-1.so.3 with build-id 6d6e4846c8e56903b4fe7d992ae6bb30c8a20a9c
Module libxcb-keysyms.so.1 with build-id bc0fb833936f8065a75216318f4d4fb7c51a8b00
Module libgcc_s.so.1 with build-id 85db482c4585a328d95ec41124337a967bb24d8f
Module libQt5QmlModels.so.5 with build-id 75ac4ba2a588a639d18be70e47f2b106930ac1a5
Module libKF5WidgetsAddons.so.5 with build-id a9a32bb7b20a4b655c7b984ec4e7285816386971
Module libKF5ItemViews.so.5 with build-id da9ae9155b462b4622737b62445d6a5ee4a4e2f4
Module libQt5PrintSupport.so.5 with build-id 9fa154675ddc5fbbb81c273ceb2dc49eaa03fdb3
Module libplist-2.0.so.3 with build-id f16bdd42b3d750ba0a150d286248f5dc50cc76cb
Module libimobiledevice-1.0.so.6 with build-id bc258677480403cc2df4f0efcfc97e06af826ddc
Module libmount.so.1 with build-id 9064fc3620c42e6f7aed38119f0a3ec39fca9a37
Module libudev.so.1 with build-id 239ca4dad8e4e0711b19826feabd72d58270942e
Module libQt5Xml.so.5 with build-id f67bcabb5df91d3dd74fb54fd53421bcd089b9f4
Module libdbusmenu-qt5.so.2 with build-id 346cd54093968d3de9e61cc329e9512d248dce18
Module libXtst.so.6 with build-id eaf941ac9100f7854ebc0d512979d2fc6e87d461
Module libX11.so.6 with build-id 21e886e968772b7964d646f54c1faecc56734de9
Module libQt5TextToSpeech.so.5 with build-id 593099f8617753c871f48e5951f368c3a863e1cf
Module libcanberra.so.0 with build-id 8ddef69c9b84a86062c88a59510639cd908fc6d3
Module libKF5GuiAddons.so.5 with build-id 500f3ce625ec0405128077cfd2ff1b03e301aaf0
Module libKF5ConfigWidgets.so.5 with build-id 7dc07957cb9e0b1c8b4f94cc4706132aca8a65d9
Module libKF5Archive.so.5 with build-id 784b900eebadfb900b9f958788fb5c1f99cec2b8
Module libQt5Svg.so.5 with build-id 7db0284946e4871e7f9effc797f1dee6b7cb1be6
Module libKF5KIOGui.so.5 with build-id 39d267ba908cd0c25c0f29483778f34c34aa477e
Module libKF5KIOWidgets.so.5 with build-id 822db0cc4c0ddebe052b89f6a3a27d5a35a01574
Module libQt5Sql.so.5 with build-id 612004f5350b4b351ff572542b62824ff96a23cb
Module libXdmcp.so.6 with build-id d864159ab0008415667db8d5f251696d75c90df2
Module libQt5Network.so.5 with build-id e375f270860de999955dd4910b4a6bf230acd1c7
Module libffi.so.8 with build-id 5c6b22b6624dd486a0783dfe74fee085b626b573
Module libXau.so.6 with build-id d9d5e8277140f1a86d3a07d9b52b1703c0a2f9a8
Module libQt5WaylandClient.so.5 with build-id 032f7f11d4e8511b03ff65222f387e69913adfbf
Module libm.so.6 with build-id 2c8ff1d29b255da5b7371efd5caf57444d622838
Module libKF5IconThemes.so.5 with build-id 84a935d8c24609b710db56c9cbc90bbe15b990b0
Module libxcb-shape.so.0 with build-id f9aab9846b5e3523bd534f8a845f36a37d42b3fa
Module libc.so.6 with build-id 1e94beb079e278ac4f2c8bce1f53091548ea1584
Module libstdc++.so.6 with build-id 735a3d0cc7699fd69337361cba4aedb644b2a7ed
Module libQt5Core.so.5 with build-id 083f29a2d33003f77f7d03516313798698bc42af
Module libQt5Gui.so.5 with build-id b63602b780993f6ec111d5fb2c0ee187f42d14fa
Module libQt5X11Extras.so.5 with build-id 78547956b3be2e12eece7fa5e9fa9f161b022c50
Module libQt5DBus.so.5 with build-id 80839ec0184277ea0382ce3fdc7f84eaebb4dff9
Module libKF5CoreAddons.so.5 with build-id 62326905c473db19337c7e01e790490ba70df854
Module libKF5I18n.so.5 with build-id 6a91b57f66c86d2b080056c0195cf095311dad9e
Module libKF5ConfigCore.so.5 with build-id dea712f5c33eb84ced0e4dea973e8b687ae94f46
Module libQt5Widgets.so.5 with build-id c700b6b0b14c58b3d3943b2d413d6cda5e0d8975
Module libKF5WindowSystem.so.5 with build-id 8ec18b141cfc9a0ee4ffe9f352fe26c60ffa4fc4
Module libKF5ConfigGui.so.5 with build-id 3f24792ea7987b59d73fbee76297ca00e42f00a0
Module libQt5Qml.so.5 with build-id 22231cfcf29a284259109c7862fb6e72406b131a
Module libKF5DBusAddons.so.5 with build-id 03abf1c24e5a269ee395ad4099652feafb12be6f
Module libKF5Service.so.5 with build-id 48775fbc4bee84e539074c055290386ec37555a9
Module libQt5Quick.so.5 with build-id 7943b27c49d44215357f6219398a7b376dcf4cbd
Module libKF5GlobalAccel.so.5 with build-id 58892df8bbd414c674c37405b389d9e38ef904cb
Module libKF5XmlGui.so.5 with build-id b2b06c04caed2139f99b5de3cb253e3aa0b64dcb
Module libKF5Crash.so.5 with build-id 63a18381ba033fcc9d55aedcd43b520fe04b3ecc
Module libKF5Solid.so.5 with build-id 4c3b06e1896b37ac7c92f0fee714d7da425040ba
Module libKF5Package.so.5 with build-id c50734cba9d1f13eeb2edeb51242061f8f766fa8
Module libKF5Declarative.so.5 with build-id 8dd4af291129d1b2ea068ac3c5075c9e1369939a
Module libKF5Notifications.so.5 with build-id 873c11b816ee7117d21e6dcf27f364a62a37c591
Module libKF5Plasma.so.5 with build-id 1c5f32f73952a8904c68dbc3bd883c9f7614cac6
Module libxcb-randr.so.0 with build-id c914473ab7592ed5cf5c191200faaac1089c12ad
Module libxcb.so.1 with build-id 13d677412a71468381b11092915d231f664d18d3
Module libKUserFeedbackCore.so.1 with build-id 0b308e5c23a0c67e2d93d630f27b832e86582597
Module libwayland-client.so.0 with build-id 515c72111400d7bdbfbdfcec78d597e4986a5943
Module libkworkspace5.so.5 with build-id 6d133c200f70ebeaf1a533b5cd9bce1c1928173b
Module libKF5WaylandClient.so.5 with build-id 302dd5e044cf2504aaaa997d88e3772d644589b1
Module libKF5QuickAddons.so.5 with build-id 37af8eae46213a682f971f71613eb285cb3b3a7c
Module libKF5Activities.so.5 with build-id 0dc05eebb0f82fa8f014af9b94d5407fbbb8eb55
Module libKF5PlasmaQuick.so.5 with build-id f91652fc44d01d83bb083526b60dcdb7e4b7255e
Module plasmashell with build-id 6b06080ddd8c6e5285a15622634177b15cd98cc3
Stack trace of thread 1339:
#0 0x00007f2e79cac740 _ZN16QSGAreaAllocator16deallocateInNodeERK6QPointP20QSGAreaAllocatorNode (libQt5Quick.so.5 + 0x1b5740)
#1 0x00007f2e79cac7bb _ZN16QSGAreaAllocator10deallocateERK5QRect (libQt5Quick.so.5 + 0x1b57bb)
#2 0x00007f2e79cb29a4 n/a (libQt5Quick.so.5 + 0x1bb9a4)
#3 0x00007f2e79cb2a2d n/a (libQt5Quick.so.5 + 0x1bba2d)
#4 0x00007f2e680cb251 n/a (libcorebindingsplugin.so + 0x1c251)
#5 0x00007f2e79cf11eb n/a (libQt5Quick.so.5 + 0x1fa1eb)
#6 0x00007f2e79cf31ae n/a (libQt5Quick.so.5 + 0x1fc1ae)
#7 0x00007f2e782912ba n/a (libQt5Core.so.5 + 0xe42ba)
#8 0x00007f2e77e158fd n/a (libc.so.6 + 0x868fd)
#9 0x00007f2e77e97a60 n/a (libc.so.6 + 0x108a60)
Stack trace of thread 2155:
#0 0x00007f2e77e124b6 n/a (libc.so.6 + 0x834b6)
#1 0x00007f2e77e14fd4 pthread_cond_timedwait (libc.so.6 + 0x85fd4)
#2 0x00007f2e782986d4 _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt5Core.so.5 + 0xeb6d4)
#3 0x00007f2e78295537 n/a (libQt5Core.so.5 + 0xe8537)
#4 0x00007f2e782912ba n/a (libQt5Core.so.5 + 0xe42ba)
#5 0x00007f2e77e158fd n/a (libc.so.6 + 0x868fd)
#6 0x00007f2e77e97a60 n/a (libc.so.6 + 0x108a60)
Stack trace of thread 2159:
Stack trace of thread 1387:
#1 0x00007f2e77e14cd0 pthread_cond_wait (libc.so.6 + 0x85cd0)
#2 0x00007f2e78298744 _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt5Core.so.5 + 0xeb744)
#3 0x00007f2e79cf3203 n/a (libQt5Quick.so.5 + 0x1fc203)
Stack trace of thread 2153:
Stack trace of thread 1989:
Stack trace of thread 1289:
#0 0x00007f2e77e8a0bf __poll (libc.so.6 + 0xfb0bf)
#1 0x00007f2e7673e1df n/a (libglib-2.0.so.0 + 0xac1df)
#2 0x00007f2e766e6132 g_main_context_iteration (libglib-2.0.so.0 + 0x54132)
#3 0x00007f2e7848450c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d750c)
#4 0x00007f2e7843232c _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x28532c)
#5 0x00007f2e7829449f _ZN7QThread4execEv (libQt5Core.so.5 + 0xe749f)
#6 0x00007f2e79c4bcaf n/a (libQt5Quick.so.5 + 0x154caf)
Stack trace of thread 1066:
#2 0x00007f2e7a33d95e n/a (libxcb.so.1 + 0xd95e)
#3 0x00007f2e7a33e8d6 xcb_wait_for_reply (libxcb.so.1 + 0xe8d6)
#4 0x00007f2e7961253c n/a (libKF5WindowSystem.so.5 + 0x3753c)
#5 0x00007f2e796148c2 _ZN10NETWinInfo6updateE6QFlagsIN3NET8PropertyEES0_INS1_9Property2EE (libKF5WindowSystem.so.5 + 0x398c2)
#6 0x00007f2e714c47b8 n/a (KF5WindowSystemX11Plugin.so + 0x157b8)
#7 0x00007f2e795fe57b _ZN18KWindowInfoPrivate6createEy6QFlagsIN3NET8PropertyEES0_INS1_9Property2EE (libKF5WindowSystem.so.5 + 0x2357b)
#8 0x00007f2e795fe6f5 _ZN11KWindowInfoC1Ey6QFlagsIN3NET8PropertyEES0_INS1_9Property2EE (libKF5WindowSystem.so.5 + 0x236f5)
#9 0x00007f2e700a5b08 n/a (libtaskmanager.so.6 + 0x66b08)
#10 0x00007f2e700ad4ae _ZNK11TaskManager17XWindowTasksModel4dataERK11QModelIndexi (libtaskmanager.so.6 + 0x6e4ae)
#11 0x00007f2e78407376 _ZNK19QAbstractProxyModel4dataERK11QModelIndexi (libQt5Core.so.5 + 0x25a376)
#12 0x00007f2e7840b0b1 _ZNK28QConcatenateTablesProxyModel4dataERK11QModelIndexi (libQt5Core.so.5 + 0x25e0b1)
#13 0x00007f2e7007d064 _ZNK11TaskManager20TaskFilterProxyModel10acceptsRowEi (libtaskmanager.so.6 + 0x3e064)
#14 0x00007f2e78418cc1 n/a (libQt5Core.so.5 + 0x26bcc1)
#15 0x00007f2e7846a530 n/a (libQt5Core.so.5 + 0x2bd530)
#16 0x00007f2e783f2981 _ZN18QAbstractItemModel11dataChangedERK11QModelIndexS2_RK7QVectorIiE (libQt5Core.so.5 + 0x245981)
#17 0x00007f2e7840f47e n/a (libQt5Core.so.5 + 0x26247e)
#18 0x00007f2e7846a530 n/a (libQt5Core.so.5 + 0x2bd530)
#19 0x00007f2e783f2981 _ZN18QAbstractItemModel11dataChangedERK11QModelIndexS2_RK7QVectorIiE (libQt5Core.so.5 + 0x245981)
#20 0x00007f2e78410491 n/a (libQt5Core.so.5 + 0x263491)
#21 0x00007f2e7846a530 n/a (libQt5Core.so.5 + 0x2bd530)
#22 0x00007f2e783f2981 _ZN18QAbstractItemModel11dataChangedERK11QModelIndexS2_RK7QVectorIiE (libQt5Core.so.5 + 0x245981)
#23 0x00007f2e700a4b5f n/a (libtaskmanager.so.6 + 0x65b5f)
#24 0x00007f2e700a9812 n/a (libtaskmanager.so.6 + 0x6a812)
#25 0x00007f2e7846a381 n/a (libQt5Core.so.5 + 0x2bd381)
#26 0x00007f2e700a0d88 n/a (libtaskmanager.so.6 + 0x61d88)
#27 0x00007f2e7846a381 n/a (libQt5Core.so.5 + 0x2bd381)
#28 0x00007f2e795f2879 _ZN13KWindowSystem13windowChangedEy6QFlagsIN3NET8PropertyEES0_INS1_9Property2EE (libKF5WindowSystem.so.5 + 0x17879)
#29 0x00007f2e714c0573 n/a (KF5WindowSystemX11Plugin.so + 0x11573)
#30 0x00007f2e7843048f _ZN24QAbstractEventDispatcher17filterNativeEventERK10QByteArrayPvPl (libQt5Core.so.5 + 0x28348f)
#31 0x00007f2e72fe5ff0 _ZN14QXcbConnection14handleXcbEventEP19xcb_generic_event_t (libQt5XcbQpa.so.5 + 0x3bff0)
#32 0x00007f2e72fea330 _ZN14QXcbConnection16processXcbEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5XcbQpa.so.5 + 0x40330)
#33 0x00007f2e7300e5e8 n/a (libQt5XcbQpa.so.5 + 0x645e8)
#34 0x00007f2e766e787b g_main_context_dispatch (libglib-2.0.so.0 + 0x5587b)
#35 0x00007f2e7673e279 n/a (libglib-2.0.so.0 + 0xac279)
#36 0x00007f2e766e6132 g_main_context_iteration (libglib-2.0.so.0 + 0x54132)
#37 0x00007f2e7848450c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d750c)
#38 0x00007f2e7843232c _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x28532c)
#39 0x00007f2e7843ce59 _ZN16QCoreApplication4execEv (libQt5Core.so.5 + 0x28fe59)
#40 0x0000557e6f1fd10f n/a (plasmashell + 0x2310f)
#41 0x00007f2e77db2290 n/a (libc.so.6 + 0x23290)
#42 0x00007f2e77db234a __libc_start_main (libc.so.6 + 0x2334a)
#43 0x0000557e6f1fd4c5 n/a (plasmashell + 0x234c5)
Stack trace of thread 2156:
Stack trace of thread 2152:
Stack trace of thread 1163:
#6 0x00007f2e7990e300 n/a (libQt5Qml.so.5 + 0x2c0300)
Stack trace of thread 1287:
#1 0x00007f2e6a692017 n/a (libnvidia-glcore.so.520.56.06 + 0x1492017)
#2 0x00007f2e6a68f90a n/a (libnvidia-glcore.so.520.56.06 + 0x148f90a)
#3 0x00007f2e77e158fd n/a (libc.so.6 + 0x868fd)
#4 0x00007f2e77e97a60 n/a (libc.so.6 + 0x108a60)
Stack trace of thread 2154:
Stack trace of thread 2161:
Stack trace of thread 2167:
Stack trace of thread 1069:
#0 0x00007f2e77e98c77 recvmsg (libc.so.6 + 0x109c77)
#1 0x00007f2e7a33c8e9 n/a (libxcb.so.1 + 0xc8e9)
#2 0x00007f2e7a33d42d n/a (libxcb.so.1 + 0xd42d)
#3 0x00007f2e7a33eccd xcb_wait_for_event (libxcb.so.1 + 0xeccd)
#4 0x00007f2e7300bf72 n/a (libQt5XcbQpa.so.5 + 0x61f72)
#5 0x00007f2e782912ba n/a (libQt5Core.so.5 + 0xe42ba)
#6 0x00007f2e77e158fd n/a (libc.so.6 + 0x868fd)
#7 0x00007f2e77e97a60 n/a (libc.so.6 + 0x108a60)
Stack trace of thread 1280:
#0 0x00007f2e77e5c6ab clock_gettime (libc.so.6 + 0xcd6ab)
#1 0x00007f2e6a686f67 n/a (libnvidia-glcore.so.520.56.06 + 0x1486f67)
#2 0x00007f2e6a79175a n/a (libnvidia-glcore.so.520.56.06 + 0x159175a)
#3 0x00007f2e6a6b6da1 n/a (libnvidia-glcore.so.520.56.06 + 0x14b6da1)
#4 0x00007f2e6a38be39 n/a (libnvidia-glcore.so.520.56.06 + 0x118be39)
#5 0x00007f2e78bf4cc9 n/a (libQt5Gui.so.5 + 0x524cc9)
#6 0x00007f2e78b68709 n/a (libQt5Gui.so.5 + 0x498709)
#7 0x00007f2e78b4697f _ZN20QOpenGLShaderProgram4linkEv (libQt5Gui.so.5 + 0x47697f)
#8 0x00007f2e79ce3bbc _ZN23QSGDefaultRenderContext13compileShaderEP17QSGMaterialShaderP11QSGMaterialPKcS5_ (libQt5Quick.so.5 + 0x1ecbbc)
#9 0x00007f2e79c8ae5e n/a (libQt5Quick.so.5 + 0x193e5e)
#10 0x00007f2e79c9a26f _ZN16QSGBatchRenderer8Renderer17renderMergedBatchEPKNS_5BatchE (libQt5Quick.so.5 + 0x1a326f)
#11 0x00007f2e79c9dd46 _ZN16QSGBatchRenderer8Renderer13renderBatchesEv (libQt5Quick.so.5 + 0x1a6d46)
#12 0x00007f2e79ca25d1 _ZN16QSGBatchRenderer8Renderer6renderEv (libQt5Quick.so.5 + 0x1ab5d1)
#13 0x00007f2e79c8a085 _ZN11QSGRenderer11renderSceneERK11QSGBindable (libQt5Quick.so.5 + 0x193085)
#14 0x00007f2e79c8a524 _ZN11QSGRenderer11renderSceneEj (libQt5Quick.so.5 + 0x193524)
#15 0x00007f2e79ce3935 _ZN23QSGDefaultRenderContext15renderNextFrameEP11QSGRendererj (libQt5Quick.so.5 + 0x1ec935)
#16 0x00007f2e79d3de51 _ZN19QQuickWindowPrivate16renderSceneGraphERK5QSizeS2_ (libQt5Quick.so.5 + 0x246e51)
#17 0x00007f2e79cedf06 n/a (libQt5Quick.so.5 + 0x1f6f06)
#18 0x00007f2e79cf2e14 n/a (libQt5Quick.so.5 + 0x1fbe14)
#19 0x00007f2e782912ba n/a (libQt5Core.so.5 + 0xe42ba)
#20 0x00007f2e77e158fd n/a (libc.so.6 + 0x868fd)
#21 0x00007f2e77e97a60 n/a (libc.so.6 + 0x108a60)
Stack trace of thread 1323:
#6 0x00007f2e3afbfbee _ZN15KCupsConnection3runEv (libkcupslib.so + 0x20bee)
Stack trace of thread 1068:
#6 0x00007f2e78d61cba n/a (libQt5DBus.so.5 + 0x23cba)
Stack trace of thread 2157:
Stack trace of thread 2162:
Stack trace of thread 1305:
#0 0x00007f2e77e8ca11 pselect (libc.so.6 + 0xfda11)
#1 0x00007f2e75b03524 n/a (libusbmuxd-2.0.so.6 + 0x2524)
#2 0x00007f2e75b048a9 n/a (libusbmuxd-2.0.so.6 + 0x38a9)
Stack trace of thread 2160:
Stack trace of thread 2158:
Stack trace of thread 2163:
Nov 03 12:38:26 rainb0w systemd[948]: plasma-plasmashell.service: Main process exited, code=killed, status=11/SEGV
Nov 03 12:38:26 rainb0w systemd[948]: plasma-plasmashell.service: Failed with result 'signal'.
Nov 03 12:38:27 rainb0w kernel: kauditd_printk_skb: 6 callbacks suppressed
Nov 03 12:38:27 rainb0w kernel: audit: type=1111 audit(1667475507.769:217): pid=655 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=statistics interface="eno1" ifindex=2 args=500 pid=2191 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Nov 03 12:38:27 rainb0w kernel: audit: type=1334 audit(1667475507.796:218): prog-id=28 op=LOAD
Nov 03 12:38:27 rainb0w kernel: audit: type=1334 audit(1667475507.796:219): prog-id=29 op=LOAD
Nov 03 12:38:27 rainb0w kernel: audit: type=1334 audit(1667475507.796:220): prog-id=30 op=LOAD
Nov 03 12:38:27 rainb0w kernel: audit: type=1130 audit(1667475507.829:221): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 03 12:38:28 rainb0w kernel: audit: type=1334 audit(1667475508.389:222): prog-id=0 op=UNLOAD
Nov 03 12:38:32 rainb0w kernel: audit: type=1131 audit(1667475512.423:223): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 03 12:38:32 rainb0w kernel: audit: type=1334 audit(1667475512.439:224): prog-id=31 op=LOAD
Nov 03 12:38:32 rainb0w kernel: audit: type=1300 audit(1667475512.439:224): arch=c000003e syscall=321 success=yes exit=28 a0=5 a1=7ffc3ffedcf0 a2=90 a3=5e items=0 ppid=1 pid=655 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="NetworkManager" exe="/usr/bin/NetworkManager" subj=unconfined key=(null)
Nov 03 12:38:32 rainb0w kernel: audit: type=1327 audit(1667475512.439:224): proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
Nov 03 12:38:37 rainb0w kernel: audit: type=1334 audit(1667475517.968:225): prog-id=0 op=UNLOAD
Nov 03 12:38:58 rainb0w kernel: audit: type=1131 audit(1667475538.473:226): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 03 12:38:58 rainb0w kernel: audit: type=1334 audit(1667475538.606:227): prog-id=0 op=UNLOAD
Nov 03 12:38:58 rainb0w kernel: audit: type=1334 audit(1667475538.606:228): prog-id=0 op=UNLOAD
Nov 03 12:38:58 rainb0w kernel: audit: type=1334 audit(1667475538.606:229): prog-id=0 op=UNLOAD
Nov 03 12:39:02 rainb0w kernel: audit: type=1100 audit(1667475542.673:230): pid=2238 uid=1000 auid=1000 ses=3 subj=unconfined msg='op=PAM:unix_chkpwd acct="ben" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
Nov 03 12:39:34 rainb0w kernel: audit: type=1130 audit(1667475574.759:231): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=getty@tty2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 03 12:40:22 rainb0w kernel: audit: type=1100 audit(1667475622.370:232): pid=2247 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:authentication grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="ben" exe="/usr/bin/login" hostname=rainb0w addr=? terminal=/dev/tty2 res=success'
Nov 03 12:40:22 rainb0w kernel: audit: type=1101 audit(1667475622.370:233): pid=2247 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="ben" exe="/usr/bin/login" hostname=rainb0w addr=? terminal=/dev/tty2 res=success'
Nov 03 12:40:22 rainb0w kernel: audit: type=1103 audit(1667475622.370:234): pid=2247 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="ben" exe="/usr/bin/login" hostname=rainb0w addr=? terminal=/dev/tty2 res=success'
Nov 03 12:40:22 rainb0w kernel: audit: type=1006 audit(1667475622.370:235): pid=2247 uid=0 subj=unconfined old-auid=4294967295 auid=1000 tty=tty2 old-ses=4294967295 ses=4 res=1
Nov 03 12:40:22 rainb0w kernel: audit: type=1300 audit(1667475622.370:235): arch=c000003e syscall=1 success=yes exit=4 a0=5 a1=7ffe1d020640 a2=4 a3=7ffe1d020354 items=0 ppid=1 pid=2247 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=1000 fsgid=0 tty=tty2 ses=4 comm="login" exe="/usr/bin/login" subj=unconfined key=(null)
Nov 03 12:40:22 rainb0w kernel: audit: type=1327 audit(1667475622.370:235): proctitle=2F62696E2F6C6F67696E002D70002D2D
Nov 03 12:40:22 rainb0w kernel: audit: type=1105 audit(1667475622.390:236): pid=2247 uid=0 auid=1000 ses=4 subj=unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_systemd_home,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="ben" exe="/usr/bin/login" hostname=rainb0w addr=? terminal=/dev/tty2 res=success'
Nov 03 12:40:22 rainb0w kernel: audit: type=1110 audit(1667475622.390:237): pid=2247 uid=0 auid=1000 ses=4 subj=unconfined msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="ben" exe="/usr/bin/login" hostname=rainb0w addr=? terminal=/dev/tty2 res=success'
Nov 03 12:41:11 rainb0w kernel: audit: type=1100 audit(1667475671.580:238): pid=2488 uid=1000 auid=1000 ses=4 subj=unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="ben" exe="/usr/bin/sudo" hostname=rainb0w addr=? terminal=/dev/tty2 res=success'
Nov 03 12:41:11 rainb0w kernel: audit: type=1101 audit(1667475671.580:239): pid=2488 uid=1000 auid=1000 ses=4 subj=unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="ben" exe="/usr/bin/sudo" hostname=rainb0w addr=? terminal=/dev/tty2 res=success'
Nov 03 12:41:11 rainb0w sudo[2488]: ben : TTY=tty2 ; PWD=/home/ben ; USER=root ; COMMAND=/usr/bin/reboot
Nov 03 12:41:11 rainb0w kernel: audit: type=1110 audit(1667475671.583:240): pid=2488 uid=1000 auid=1000 ses=4 subj=unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=rainb0w addr=? terminal=/dev/tty2 res=success'
Nov 03 12:41:11 rainb0w kernel: audit: type=1105 audit(1667475671.583:241): pid=2488 uid=1000 auid=1000 ses=4 subj=unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=rainb0w addr=? terminal=/dev/tty2 res=success'
Nov 03 12:41:11 rainb0w systemd-logind[595]: System is rebooting.
Nov 03 12:41:11 rainb0w kernel: audit: type=1106 audit(1667475671.590:242): pid=2488 uid=1000 auid=1000 ses=4 subj=unconfined msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=rainb0w addr=? terminal=/dev/tty2 res=success'
Nov 03 12:41:11 rainb0w kernel: audit: type=1104 audit(1667475671.590:243): pid=2488 uid=1000 auid=1000 ses=4 subj=unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=rainb0w addr=? terminal=/dev/tty2 res=success'
Nov 03 12:41:11 rainb0w sddm[685]: Authentication error: "Process crashed"
Nov 03 12:41:11 rainb0w sddm[685]: Auth: sddm-helper crashed (exit code 15)
Nov 03 12:41:11 rainb0w sddm[685]: Auth: sddm-helper exited with 15
Nov 03 12:41:11 rainb0w kernel: audit: type=1104 audit(1667475671.593:244): pid=2247 uid=0 auid=1000 ses=4 subj=unconfined msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="ben" exe="/usr/bin/login" hostname=rainb0w addr=? terminal=/dev/tty2 res=success'
Nov 03 12:41:11 rainb0w kernel: audit: type=1701 audit(1667475671.627:245): auid=1000 uid=1000 gid=1000 ses=3 subj=unconfined pid=1032 comm="kwin_x11" exe="/usr/bin/kwin_x11" sig=11 res=1
Nov 03 12:41:11 rainb0w polkitd[590]: Error converting subject to JS object: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Could not get UID of name ':1.44': no such name
Nov 03 12:41:11 rainb0w kernel: audit: type=1106 audit(1667475671.637:246): pid=2247 uid=0 auid=1000 ses=4 subj=unconfined msg='op=PAM:session_close grantors=? acct="ben" exe="/usr/bin/login" hostname=rainb0w addr=? terminal=/dev/tty2 res=failed'
Nov 03 12:41:11 rainb0w login[2247]: pam_systemd(login:session): Failed to release session: Interrupted system call
Nov 03 12:41:11 rainb0w polkitd[590]: Unregistered Authentication Agent for unix-session:2 (system bus name :1.60, object path /org/kde/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8) (disconnected from bus)
Nov 03 12:41:11 rainb0w systemd-coredump[2508]: Failed to connect to coredump service: Connection refused
Nov 03 12:41:11 rainb0w systemd[948]: kde-baloo.service: Killing process 1328 (QXcbEventQueue) with signal SIGKILL.
Nov 03 12:41:11 rainb0w systemd[948]: plasma-ksmserver.service: Main process exited, code=exited, status=1/FAILURE
Nov 03 12:41:11 rainb0w systemd[948]: plasma-ksmserver.service: Failed with result 'exit-code'.
Nov 03 12:41:11 rainb0w kernel: audit: type=1131 audit(1667475671.647:247): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=ModemManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 03 12:41:11 rainb0w systemd[948]: plasma-kwin_x11.service: Main process exited, code=dumped, status=11/SEGV
Nov 03 12:41:11 rainb0w systemd[948]: plasma-kwin_x11.service: Failed with result 'core-dump'.
Nov 03 12:41:11 rainb0w udisksd[841]: udisks daemon version 2.9.4 exiting
Nov 03 12:41:11 rainb0w systemd-coredump[2517]: Failed to connect to coredump service: Connection refused
Nov 03 12:41:11 rainb0w systemd[1]: udisks2.service: Main process exited, code=dumped, status=6/ABRT
Nov 03 12:41:11 rainb0w systemd[1]: udisks2.service: Failed with result 'core-dump'.
Nov 03 12:41:11 rainb0w systemd[948]: xdg-document-portal.service: Main process exited, code=exited, status=20/n/a
Nov 03 12:41:11 rainb0w systemd[948]: xdg-permission-store.service: Main process exited, code=exited, status=1/FAILURE
Nov 03 12:41:11 rainb0w systemd[948]: xdg-permission-store.service: Failed with result 'exit-code'.
Nov 03 12:41:11 rainb0w systemd[948]: obex.service: Main process exited, code=exited, status=1/FAILURE
Nov 03 12:41:11 rainb0w systemd[948]: obex.service: Failed with result 'exit-code'.
Nov 03 12:41:11 rainb0w systemd[948]: xdg-document-portal.service: Failed with result 'exit-code'.
Nov 03 12:41:11 rainb0w systemd-coredump[2523]: Failed to connect to coredump service: Connection refused
Nov 03 12:41:11 rainb0w pulseaudio[1310]: Error opening PCM device front:0: No such file or directory
Nov 03 12:41:11 rainb0w pulseaudio[1310]: Failed to create sink input: sink is suspended.
Nov 03 12:41:11 rainb0w pulseaudio[1310]: Lost I/O connection in module "module-gsettings"
Nov 03 12:41:12 rainb0w systemd[948]: plasma-kded.service: Main process exited, code=exited, status=1/FAILURE
Nov 03 12:41:12 rainb0w systemd[948]: plasma-kded.service: Failed with result 'exit-code'.
Nov 03 12:41:12 rainb0w systemd[949]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[ben] ruser=[<unknown>] rhost=[<unknown>]
Nov 03 12:41:12 rainb0w sddm[685]: Signal received: SIGTERM
Nov 03 12:41:13 rainb0w systemd[1]: Requested transaction contradicts existing jobs: Transaction for getty@tty2.service/start is destructive (shutdown.target has 'start' job queued, but 'stop' is included in transaction).
Nov 03 12:41:13 rainb0w systemd-logind[595]: Failed to start autovt@tty2.service: Transaction for getty@tty2.service/start is destructive (shutdown.target has 'start' job queued, but 'stop' is included in transaction).
Nov 03 12:41:13 rainb0w sddm[685]: QProcess: Destroyed while process ("/usr/lib/sddm/sddm-helper") is still running.
Btw: I just tried and updated an older, fully working system to newest and the very same problem happens.
Hope this helps and thank you.
