Power Management working incorrectly
Powermanagement working incorecctly. After some period of inactivity i am logged out
Now that was a thorough explanation.
Please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit. To that end, some or all these links will be invaluable:
And last, but not least, the Stable Update Announcements, which you should check frequently for important update related information. Occasionally an issue might be directly related to a particular update; it’s always best to check those announcements.
I hope this helps. Cheers.
Edit:- Corrected spelling errors in Title.
