Power management problems - Keeps Suspending
First a bit of background: I’m currently trying to breathe some new life into a 10-year-old Acer Aspire 5551 as a web-and-word machine. It’s been given more RAM, a bigger hard disk (SSD is coming soon) and a fully updated BIOS. All it needed was an OS suited for the use and age of the machine that was still supplied with security updates. I previously posted on Reddit in r/linuxquestions for help in that search (the resulting discussion also pointing me here) and I’ve settled mostly on Manjaro Xfce using a 4.9 kernel, mainly due to compatibility with my non-KMS graphics chip. It’s worth noting that I’m mainly a Windows user, and while I have used Linux sometimes, my experience with it is limited, and this is the first time I’m actively using something non-Debian based.
The last hurdle is a problem that seemingly stems from power management, and I can’t work out what exactly is causing it (or them as I’m not sure if this is two issues or one).
When the laptop boots, it hits grub and starts loading Manjaro. Shortly before it hits the login screen it’ll suspend, and I’ll have to press something to kick it into life to finish loading. Then as of this point, I have approximately 20 seconds in between it waking up and when it’ll suspend again, repeatedly regardless of input, until I manage to log in and it finishes loading my desktop. Once it has loaded, it’s fine and seems to be solid, until shutdown, where it’ll suspend once more just before the system halts and it sends the shutdown signal to actually power off.
The other issue is I can’t access the Xfce power management settings. From the Settings Manager, if I press “Power Manager” it’ll simply sit there spinning the busy cursor. I have tried reinstalling xfce4-power-manager and fully removing it and upower and installing afresh. While remove-and-install will sometimes inconsistently let me access it, it’ll be back to broken next boot, and when I can access it I can’t see any options to differentiate between AC and battery power.
If I remove xfce4-power-manager and then reboot the 20-second suspend windows become constant, which makes fixing it very frustrating, but also indicating that xfce4-power-manager was what was stopping them after hitting the desktop. I have seen there’s a similar package called xfce4-power-manager-gtk3 but I’m not sure what this does differently from the one that came with manjaro without the -gtk3, and installing it seems to only install it and not upower as a dependency, which leads me to believe it’s not a drop-in replacement.
What is going on? and what can I do to track down the culprit?
(I’m cross-posting this on StackExchange Unix and Linux, and Reddit r/linuxquestions to cast my net wider for someone who may have an idea about what the problem but can’t link to them to allow cross-pollination of answers due to what I assume is my newness to this forum)
That kernel is EOL. Please upgrade to 5.10 LTS (Long Time support) or 5.4 LTS as your machine seems to be quite old.
Please read this:
Please tell us if this aberrant behaviour is present in both 5.4 and 5.10… :innocent:
Also read this:
[HowTo] Provide System Information
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
:+1:
That post for windows users is a bit patronising in places. I may be mainly a Windows user, but I’m not a total noob to Linux, I have used Debian-based distros before on occasion. I’d never daily drive Linux, as it doesn’t do what I want for regular use as the programs and games I use are not available for Linux; but I am by no means a supremacist of any OS and understand horses for courses. That’s why I’m in this situation; I needed something lightweight, free, secure, and compatible with modern rich internet browsing for my laptop. I also run Ubuntu Server on my home multipurpose server.
However, I will admit some tidbits like the use of inxi and the log commands have eluded me until now, so that last link was super helpful to learn them and may have given me a few points towards the culprit - am I right to assume those are available on other non-Arch distros in the same way? They probably passed me by as I’d not needed those kinds of things as I’ve not had hardware-based issues before and have had success in googling a solution to any mind software-based issues I’ve hit, and I’ve comprehended what the fix is. But in this case, I can’t comprehend the problem.
inxi, grub and log outputs at end.
This is my first foray outside of Debian and android, but it’s not especially by choice. Installing using the Manjaro Architect command line and using the lowest kernel possible (4.4) got me further on this laptop than any other distro I tried, and I tried a lot form different families and sometimes different versions of the same.
That kernel is EOL. Please upgrade to 5.10 LTS (Long Time Support) or 5.4 LTS as your machine seems to be quite old.
4.9 isn’t EOL according to what I’ve read. It should be supported until 2023 as it’s an LTS itself. Or is that different per distro?
When I was trying other distros before I settled on Manjaro, I was installing with default kernels with their default kernels and the most success I had was an even older version of Ubuntu Studio as it simply installed and ran, but the version was definitely EOL, and it ran like molasses as it was too demanding.
Any live CD using a modern kernel REALLY didn’t like my graphics chip that doesn’t support KMS and seemed to give me even more issues even installing the OS - this included the straight Manjaro Xfce live CD which wouldn’t even boot to desktop. But now I’m not sure if it was the graphics thing or something else that was causing the issues.
I have tried 4.14 since posting and it seems to give more success with the xfce3-power-manager gui, but still seems to go to sleep before login and just before power off. but there are some times it gets stuck with a black screen after logon
I just installed 5.4 and 5.10 and while neither decided to sleep on boot and didn’t give me the expected graphics chip issues, they still did it just before power off and I had no network access as both my LAN and wifi seemed to be disabled and I couldn’t get them to re-enable. I’ve also had the occasional black screen after logon with 5.10
I’ve was doing some digging of my own and my current theory was that the repeated suspending is stopped by upower starting and taking over power management. As checking systemctl status upower and last has upower starting 30-60 secs after my logon. And now I know how to pull the boot log, it seemed to confirm this with systemd[1]: Failed to start Daemon for power management. and variations, and this is not present in 5.10. Doesn’t help me find out what’s causing the suspend every 20 seconds if upower isn’t present, which is likely why it suspends before power off because upower has been stopped.
I can’t see anything in the 5.10 log that points to why the network is screwed on that kernel.
Neither 4.9 or 5.10 had anything regarding the graphics problems that plagued the live CDs, which was a relief.
Grub defeult command from 4.9 and 5.10
GRUB_CMDLINE_LINUX_DEFAULT="quiet udev.log_priority=3"
Inxi from 4.9
  Kernel: 4.9.258-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
  parameters: BOOT_IMAGE=/vmlinuz-4.9-x86_64
  root=UUID=b8dba021-642a-4bad-9d61-620dd2a19374 rw quiet udev.log_priority=3
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4
  dm: LightDM 1.30.0 Distro: Manjaro Linux
  Type: Laptop System: Acer product: Aspire 5551 v: V2.14 serial: <filter>
  Chassis: type: 10 v: 2.14 serial: <filter>
  Mobo: Acer model: JE50_DN serial: <filter> BIOS: Acer v: 2.14
  date: 07/27/2011
  ID-1: BAT1 charge: 62.9 Wh condition: 62.9/71.3 Wh (88%) volts: 12.5/10.8
  model: Sanyo AS10D31 type: Li-ion serial: <filter> status: Full
  RAM: total: 15.43 GiB used: 898.8 MiB (5.7%)
  Array-1: capacity: 16 GiB slots: 2 EC: None max module size: 8 GiB
  note: est. voltage: Unknown
  Device-1: DIMM0 size: 8 GiB info: single-bank speed: 1066 MT/s type: DDR3
  detail: synchronous bus width: 8 bits total: 64 bits manufacturer: N/A
  part-no: CT102464BF160B.M16 serial: <filter>
  Device-2: DIMM1 size: 8 GiB info: single-bank speed: 1066 MT/s type: DDR3
  part-no: CT102464BF160B.M16 serial: N/A
  Info: Triple Core model: AMD Phenom II N830 socket: C32 (S1G4) note: check
  bits: 64 type: MCP arch: K10 family: 10 (16) model-id: 5 stepping: 3
  microcode: 10000C8 L1 cache: 384 KiB L2 cache: 1.5 MiB bogomips: 12573
  Speed: 800 MHz min/max: 800/2100 MHz base/boost: 2100/2100 volts: 1.1 V
  ext-clock: 200 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
  Flags: 3dnow 3dnowext 3dnowprefetch abm apic clflush cmov cmp_legacy
  constant_tsc cr8_legacy cx16 cx8 de extapic extd_apicid fpu fxsr fxsr_opt ht
  hw_pstate ibs lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor msr
  mtrr nodeid_msr nonstop_tsc nopl npt nrip_save nx osvw pae pat pdpe1gb pge
  pni popcnt pse pse36 rdtscp rep_good sep skinit sse sse2 sse4a svm svm_lock
  syscall tsc vme vmmcall wdt
  Type: spec_store_bypass status: Not affected
  Type: spectre_v2
  mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
  Device-1: AMD RS880M [Mobility Radeon HD 4225/4250]
  vendor: Acer Incorporated ALI driver: radeon v: kernel bus ID: 01:05.0
  chip ID: 1002:9712 class ID: 0300
  Device-2: Suyin 1.3M WebCam (notebook emachines E730 Acer sub-brand)
  type: USB driver: uvcvideo bus ID: 2-1:2 chip ID: 064e:a219 class ID: 0e02
  serial: <filter>
  Display: server: X.Org 1.20.10 driver: loaded: ati,radeon
  unloaded: modesetting alternate: fbdev,vesa display ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
  s-diag: 414mm (16.3")
  Monitor-1: LVDS res: 1366x768 hz: 60 dpi: 101 size: 344x194mm (13.5x7.6")
  diag: 395mm (15.5")
  OpenGL: renderer: AMD RS880 (DRM 2.49.0 / 4.9.258-1-MANJARO LLVM 11.1.0)
  v: 3.3 Mesa 20.3.4 compat-v: 3.0 direct render: Yes
  Device-1: AMD SBx00 Azalia vendor: Acer Incorporated ALI
  driver: snd_hda_intel v: kernel bus ID: 00:14.2 chip ID: 1002:4383
  class ID: 0403
  Device-2: AMD RS880 HDMI Audio [Radeon HD 4200 Series]
  vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
  bus ID: 01:05.1 chip ID: 1002:970f class ID: 0403
  Sound Server: ALSA v: k4.9.258-1-MANJARO
  Device-1: Broadcom NetLink BCM57780 Gigabit Ethernet PCIe
  vendor: Acer Incorporated ALI driver: tg3 v: 3.137 port: 6000
  bus ID: 02:00.0 chip ID: 14e4:1692 class ID: 0200
  Device-2: Broadcom BCM43225 802.11b/g/n
  vendor: Foxconn T77H103.00 Wireless Half-size Mini PCIe Card driver: wl
  v: kernel modules: bcma port: 6000 bus ID: 08:00.0 chip ID: 14e4:4357
  class ID: 0280
  IF: wlp8s0 state: up mac: <filter>
  Message: No Bluetooth data was found.
  Local Storage: total: 931.51 GiB used: 26.81 GiB (2.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10JPVX-22JC3T0
  size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
  rotation: 5400 rpm serial: <filter> rev: 1A01 scheme: MBR
  Optical-1: /dev/sr0 vendor: Slimtype model: DVD A DS8A4SH rev: CA11
  dev-links: cdrom
  Features: speed: 8 multisession: yes audio: yes dvd: yes
  ID-1: / raw size: 931.01 GiB size: 915.32 GiB (98.31%)
  used: 26.61 GiB (2.9%) fs: ext4 block size: 4096 B dev: /dev/sda2
  maj-min: 8:2 label: N/A uuid: b8dba021-642a-4bad-9d61-620dd2a19374
  ID-2: /boot raw size: 512 MiB size: 511 MiB (99.80%) used: 212.6 MiB (41.6%)
  fs: vfat block size: 512 B dev: /dev/sda1 maj-min: 8:1 label: N/A
  uuid: 06D2-2E02
  ID-1: swap-1 type: file size: 15.39 GiB used: 0 KiB (0.0%) priority: -1
  file: /swapfile
  Message: No Unmounted partitions found.
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 5 rev: 2.0
  speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 5 rev: 2.0
  Device-1: 2-1:2
  info: Suyin 1.3M WebCam (notebook emachines E730 Acer sub-brand) type: Video
  driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 064e:a219
  class ID: 0e02 serial: <filter>
  Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 5 rev: 1.1 speed: 12 Mb/s
  chip ID: 1d6b:0001 class ID: 0900
  Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 5 rev: 1.1 speed: 12 Mb/s
  Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
  System Temperatures: cpu: 54.5 C mobo: N/A
  Processes: 198 Uptime: 4m wakeups: 4 Init: systemd v: 247 Compilers:
  gcc: 10.2.0 Packages: pacman: 1116 lib: 315 flatpak: 0 Shell: Bash (sudo)
  v: 5.1.0 running in: xfce4-terminal inxi: 3.3.01 ```
dmesg from 4.9
```[    0.874408]  #2
[    0.915210] mtrr: your CPUs had inconsistent fixed MTRR settings
[    0.915211] mtrr: your CPUs had inconsistent variable MTRR settings
[    1.328548] pci 0000:00:01.0: MSI quirk detected; subordinate MSI disabled
[    2.157959] Warning! ehci_hcd should always be loaded before uhci_hcd and ohci_hcd, not after
[    6.330723] cgroup: cgroup2: unknown option "nsdelegate"
[   11.062856] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[   11.062860] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[   12.665584] systemd-journald[153]: File /var/log/journal/88c7c46b9c3b4be199d13856678c6319/system.journal corrupted or uncleanly shut down, renaming and replacing.
[   15.394634] sp5100_tco: I/O address 0x0cd6 already in use
[   15.559342] ACPI: Invalid active0 threshold
[   18.249957] CRAT table not found
[   18.306702] wl: loading out-of-tree module taints kernel.
[   18.306717] wl: module license 'MIXED/Proprietary' taints kernel.
[   18.306719] Disabling lock debugging due to kernel taint
[   18.361630] wlan0: Broadcom BCM4357 802.11 Hybrid Wireless Controller 6.30.223.271 (r587334)
[   19.436681] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[   19.928335] uvcvideo 2-1:1.0: Entity type for entity Extension 4 was not initialized!
[   19.928345] uvcvideo 2-1:1.0: Entity type for entity Processing 3 was not initialized!
[   19.928350] uvcvideo 2-1:1.0: Entity type for entity Camera 1 was not initialized!
[   32.954244] Suspending console(s) (use no_console_suspend to debug)
[   34.236931]  cache: parent cpu1 should not be sleeping
[   34.250270]  cache: parent cpu2 should not be sleeping
[   34.367887] ACPI : button: The lid device is not compliant to SW_LID.
[   63.313623] Suspending console(s) (use no_console_suspend to debug)
[   64.609743]  cache: parent cpu1 should not be sleeping
[   64.623054]  cache: parent cpu2 should not be sleeping
[   79.859568] systemd-journald[153]: File /var/log/journal/88c7c46b9c3b4be199d13856678c6319/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
[  101.151294] Suspending console(s) (use no_console_suspend to debug)
[  102.492663]  cache: parent cpu1 should not be sleeping
[  102.505980]  cache: parent cpu2 should not be sleeping
journalctl boot log from 4.9
Mar 10 00:43:59 innistrad kernel: cgroup: cgroup2: unknown option "nsdelegate"
Mar 10 00:44:04 innistrad kernel: sp5100_tco: I/O address 0x0cd6 already in use
Mar 10 00:46:43 innistrad lightdm[1154]: gkr-pam: unable to locate daemon control file
Mar 10 00:46:43 innistrad wpa_supplicant[785]: bgscan simple: Failed to enable signal strength monitoring
Mar 10 00:46:53 innistrad systemd[1677]: upower.service: Failed to set up user namespacing: Invalid argument
Mar 10 00:46:53 innistrad systemd[1677]: upower.service: Failed at step USER spawning /usr/lib/upowerd: Invalid argument
░░ Subject: Process /usr/lib/upowerd could not be executed
░░ Defined-By: systemd
░░ The process /usr/lib/upowerd could not be executed and failed.
░░ The error number returned by this process is ERRNO.
Mar 10 00:46:53 innistrad systemd[1]: Failed to start Daemon for power management.
░░ Subject: A start job for unit upower.service has failed
░░ A start job for unit upower.service has finished with a failure.
░░ The job identifier is 1196 and the job result is failed.
Mar 10 00:46:53 innistrad systemd[1688]: upower.service: Failed to set up user namespacing: Invalid argument
Mar 10 00:46:53 innistrad systemd[1688]: upower.service: Failed at step USER spawning /usr/lib/upowerd: Invalid argument
░░ The job identifier is 1264 and the job result is failed.
Mar 10 00:46:54 innistrad systemd[1692]: upower.service: Failed to set up user namespacing: Invalid argument
Mar 10 00:46:54 innistrad systemd[1692]: upower.service: Failed at step USER spawning /usr/lib/upowerd: Invalid argument
Mar 10 00:46:54 innistrad systemd[1]: Failed to start Daemon for power management.
░░ The job identifier is 1333 and the job result is failed.
Mar 10 00:46:54 innistrad systemd[1709]: upower.service: Failed to set up user namespacing: Invalid argument
Mar 10 00:46:54 innistrad systemd[1709]: upower.service: Failed at step USER spawning /usr/lib/upowerd: Invalid argument
░░ The job identifier is 1404 and the job result is failed.
Mar 10 00:46:54 innistrad systemd[1720]: upower.service: Failed to set up user namespacing: Invalid argument
Mar 10 00:46:54 innistrad systemd[1720]: upower.service: Failed at step USER spawning /usr/lib/upowerd: Invalid argument
░░ The job identifier is 1472 and the job result is failed.
░░ The job identifier is 1540 and the job result is failed.
Mar 10 00:47:20 innistrad pulseaudio[1635]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
Mar 10 00:47:21 innistrad wpa_supplicant[785]: bgscan simple: Failed to enable signal strength monitoring
Mar 10 00:47:23 innistrad systemd[2200]: upower.service: Failed to set up user namespacing: Invalid argument
Mar 10 00:47:23 innistrad systemd[2200]: upower.service: Failed at step USER spawning /usr/lib/upowerd: Invalid argument
Mar 10 00:47:23 innistrad systemd[1]: Failed to start Daemon for power management.
░░ The job identifier is 1957 and the job result is failed.
Mar 10 00:47:24 innistrad systemd[2204]: upower.service: Failed to set up user namespacing: Invalid argument
Mar 10 00:47:24 innistrad systemd[2204]: upower.service: Failed at step USER spawning /usr/lib/upowerd: Invalid argument
Mar 10 00:47:24 innistrad systemd[1]: Failed to start Daemon for power management.
░░ The job identifier is 2025 and the job result is failed.
Mar 10 00:47:24 innistrad systemd[2208]: upower.service: Failed to set up user namespacing: Invalid argument
Mar 10 00:47:24 innistrad systemd[2208]: upower.service: Failed at step USER spawning /usr/lib/upowerd: Invalid argument
░░ The job identifier is 2093 and the job result is failed.
Mar 10 00:47:24 innistrad systemd[2213]: upower.service: Failed to set up user namespacing: Invalid argument
Mar 10 00:47:24 innistrad systemd[2213]: upower.service: Failed at step USER spawning /usr/lib/upowerd: Invalid argument
░░ The job identifier is 2161 and the job result is failed.
Mar 10 00:47:25 innistrad systemd[2226]: upower.service: Failed to set up user namespacing: Invalid argument
Mar 10 00:47:25 innistrad systemd[2226]: upower.service: Failed at step USER spawning /usr/lib/upowerd: Invalid argument
Mar 10 00:47:25 innistrad systemd[1]: Failed to start Daemon for power management.
░░ The job identifier is 2229 and the job result is failed.
░░ The job identifier is 2297 and the job result is failed.
Mar 10 00:47:48 innistrad systemd[2298]: upower.service: Failed to set up user namespacing: Invalid argument
Mar 10 00:47:48 innistrad systemd[2298]: upower.service: Failed at step USER spawning /usr/lib/upowerd: Invalid argument
Mar 10 00:47:48 innistrad systemd[1]: Failed to start Daemon for power management.
░░ The job identifier is 2433 and the job result is failed.
Mar 10 00:47:49 innistrad systemd[2310]: upower.service: Failed to set up user namespacing: Invalid argument
Mar 10 00:47:49 innistrad systemd[2310]: upower.service: Failed at step USER spawning /usr/lib/upowerd: Invalid argument
Mar 10 00:47:49 innistrad systemd[1]: Failed to start Daemon for power management.
░░ The job identifier is 2501 and the job result is failed.
Mar 10 00:47:49 innistrad systemd[2314]: upower.service: Failed to set up user namespacing: Invalid argument
Mar 10 00:47:49 innistrad systemd[2314]: upower.service: Failed at step USER spawning /usr/lib/upowerd: Invalid argument
░░ The job identifier is 2569 and the job result is failed.
Mar 10 00:47:49 innistrad systemd[2322]: upower.service: Failed to set up user namespacing: Invalid argument
Mar 10 00:47:49 innistrad systemd[2322]: upower.service: Failed at step USER spawning /usr/lib/upowerd: Invalid argument
░░ The job identifier is 2637 and the job result is failed.
Mar 10 00:47:50 innistrad systemd[2326]: upower.service: Failed to set up user namespacing: Invalid argument
Mar 10 00:47:50 innistrad systemd[2326]: upower.service: Failed at step USER spawning /usr/lib/upowerd: Invalid argument
Mar 10 00:47:50 innistrad systemd[1]: Failed to start Daemon for power management.
░░ The job identifier is 2705 and the job result is failed.
░░ The job identifier is 2773 and the job result is failed.
Mar 10 00:48:13 innistrad systemd[2361]: upower.service: Failed to set up user namespacing: Invalid argument
Mar 10 00:48:13 innistrad systemd[2361]: upower.service: Failed at step USER spawning /usr/lib/upowerd: Invalid argument
Mar 10 00:48:14 innistrad systemd[1]: Failed to start Daemon for power management.
░░ The job identifier is 2841 and the job result is failed.
Mar 10 00:48:14 innistrad systemd[2386]: upower.service: Failed to set up user namespacing: Invalid argument
Mar 10 00:48:14 innistrad systemd[2386]: upower.service: Failed at step USER spawning /usr/lib/upowerd: Invalid argument
░░ The job identifier is 2909 and the job result is failed.
Mar 10 00:48:14 innistrad systemd[2392]: upower.service: Failed to set up user namespacing: Invalid argument
Mar 10 00:48:14 innistrad systemd[2392]: upower.service: Failed at step USER spawning /usr/lib/upowerd: Invalid argument
░░ The job identifier is 2977 and the job result is failed.
Mar 10 00:48:14 innistrad systemd[2396]: upower.service: Failed to set up user namespacing: Invalid argument
Mar 10 00:48:14 innistrad systemd[2396]: upower.service: Failed at step USER spawning /usr/lib/upowerd: Invalid argument
Mar 10 00:48:15 innistrad systemd[1]: Failed to start Daemon for power management.
░░ The job identifier is 3045 and the job result is failed.
Mar 10 00:48:15 innistrad systemd[2405]: upower.service: Failed to set up user namespacing: Invalid argument
Mar 10 00:48:15 innistrad systemd[2405]: upower.service: Failed at step USER spawning /usr/lib/upowerd: Invalid argument
░░ The job identifier is 3113 and the job result is failed.
░░ The job identifier is 3181 and the job result is failed.
Mar 10 00:48:41 innistrad systemd[2477]: upower.service: Failed to set up user namespacing: Invalid argument
Mar 10 00:48:41 innistrad systemd[2477]: upower.service: Failed at step USER spawning /usr/lib/upowerd: Invalid argument
Mar 10 00:48:41 innistrad systemd[1]: Failed to start Daemon for power management.
░░ The job identifier is 3249 and the job result is failed.
Mar 10 00:48:42 innistrad systemd[2490]: upower.service: Failed to set up user namespacing: Invalid argument
Mar 10 00:48:42 innistrad systemd[2490]: upower.service: Failed at step USER spawning /usr/lib/upowerd: Invalid argument
Mar 10 00:48:42 innistrad systemd[1]: Failed to start Daemon for power management.
░░ The job identifier is 3317 and the job result is failed.
Mar 10 00:48:42 innistrad systemd[2494]: upower.service: Failed to set up user namespacing: Invalid argument
Mar 10 00:48:42 innistrad systemd[2494]: upower.service: Failed at step USER spawning /usr/lib/upowerd: Invalid argument
░░ The job identifier is 3385 and the job result is failed.
Mar 10 00:48:42 innistrad systemd[2498]: upower.service: Failed to set up user namespacing: Invalid argument
Mar 10 00:48:42 innistrad systemd[2498]: upower.service: Failed at step USER spawning /usr/lib/upowerd: Invalid argument
░░ The job identifier is 3453 and the job result is failed.
Mar 10 00:48:42 innistrad systemd[2502]: upower.service: Failed to set up user namespacing: Invalid argument
Mar 10 00:48:42 innistrad systemd[2502]: upower.service: Failed at step USER spawning /usr/lib/upowerd: Invalid argument
Mar 10 00:48:43 innistrad systemd[1]: Failed to start Daemon for power management.
░░ The job identifier is 3521 and the job result is failed.
░░ The job identifier is 3589 and the job result is failed.
Mar 10 00:49:06 innistrad systemd[2513]: upower.service: Failed to set up user namespacing: Invalid argument
Mar 10 00:49:06 innistrad systemd[2513]: upower.service: Failed at step USER spawning /usr/lib/upowerd: Invalid argument
Mar 10 00:49:06 innistrad systemd[1]: Failed to start Daemon for power management.
░░ The job identifier is 3657 and the job result is failed.
Mar 10 00:49:07 innistrad systemd[2523]: upower.service: Failed to set up user namespacing: Invalid argument
Mar 10 00:49:07 innistrad systemd[2523]: upower.service: Failed at step USER spawning /usr/lib/upowerd: Invalid argument
Mar 10 00:49:07 innistrad systemd[1]: Failed to start Daemon for power management.
░░ The job identifier is 3725 and the job result is failed.
Mar 10 00:49:07 innistrad systemd[2528]: upower.service: Failed to set up user namespacing: Invalid argument
Mar 10 00:49:07 innistrad systemd[2528]: upower.service: Failed at step USER spawning /usr/lib/upowerd: Invalid argument
░░ The job identifier is 3793 and the job result is failed.
Mar 10 00:49:07 innistrad systemd[2535]: upower.service: Failed to set up user namespacing: Invalid argument
Mar 10 00:49:07 innistrad systemd[2535]: upower.service: Failed at step USER spawning /usr/lib/upowerd: Invalid argument
░░ The job identifier is 3861 and the job result is failed.
Mar 10 00:49:08 innistrad systemd[2539]: upower.service: Failed to set up user namespacing: Invalid argument
Mar 10 00:49:08 innistrad systemd[2539]: upower.service: Failed at step USER spawning /usr/lib/upowerd: Invalid argument
Mar 10 00:49:08 innistrad systemd[1]: Failed to start Daemon for power management.
░░ The job identifier is 3929 and the job result is failed.
░░ The job identifier is 3997 and the job result is failed.
Inxi from 5.10
  Kernel: 5.10.19-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
  parameters: BOOT_IMAGE=/vmlinuz-5.10-x86_64
  date: 07/27/2011
  RAM: total: 15.39 GiB used: 801.8 MiB (5.1%)
  microcode: 10000C8 L1 cache: 384 KiB L2 cache: 1.5 MiB bogomips: 12571
  ext-clock: 200 MHz Core speeds (MHz): 1: 800 2: 1200 3: 800
  constant_tsc cpuid cr8_legacy cx16 cx8 de extapic extd_apicid fpu fxsr
  fxsr_opt ht hw_pstate ibs lahf_lm lbrv lm mca mce misalignsse mmx mmxext
  monitor msr mtrr nodeid_msr nonstop_tsc nopl npt nrip_save nx osvw pae pat
  pdpe1gb pge pni popcnt pse pse36 rdtscp rep_good sep skinit sse sse2 sse4a
  svm svm_lock syscall tsc vme vmmcall wdt
  Type: spectre_v2
  serial: <filter>
  diag: 395mm (15.5")
  OpenGL: renderer: AMD RS880 (DRM 2.50.0 / 5.10.19-1-MANJARO LLVM 11.1.0)
  class ID: 0403
  Sound Server: ALSA v: k5.10.19-1-MANJARO
  vendor: Acer Incorporated ALI driver: tg3 v: kernel port: 6000
  class ID: 0280
  IP v6: <filter> scope: link
  WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
  Local Storage: total: 931.51 GiB used: 26.83 GiB (2.9%)
  dev-links: cdrom
  used: 26.62 GiB (2.9%) fs: ext4 block size: 4096 B dev: /dev/sda2
  uuid: 06D2-2E02
  ID-1: swap-1 type: file size: 15.39 GiB used: 0 KiB (0.0%) priority: -2
  file: /swapfile
  Device-1: 2-1:2
  System Temperatures: cpu: 51.5 C mobo: N/A
  Processes: 162 Uptime: 3m wakeups: 1 Init: systemd v: 247 Compilers:
dmesg from 5.10
[    0.468465]  #2
[    0.003791] __common_interrupt: 2.55 No irq handler for vector
[    0.478851] mtrr: your CPUs had inconsistent fixed MTRR settings
[    0.478852] mtrr: your CPUs had inconsistent variable MTRR settings
[    0.753405] pci 0000:00:01.0: MSI quirk detected; subordinate MSI disabled
[    1.203699] ACPI: Invalid active0 threshold
[   11.536823] systemd-journald[192]: File /var/log/journal/88c7c46b9c3b4be199d13856678c6319/system.journal corrupted or uncleanly shut down, renaming and replacing.
[   14.826523] ioremap error for 0xfed80000-0xfed81000, requested 0x2, got 0x0
[   14.826529] sp5100-tco sp5100-tco: failed to get tcobase address
[   14.826537] sp5100-tco: probe of sp5100-tco failed with error -12
[   15.598932] wl: loading out-of-tree module taints kernel.
[   15.598941] wl: module license 'MIXED/Proprietary' taints kernel.
[   15.598942] Disabling lock debugging due to kernel taint
[   15.643281] wlan0: Broadcom BCM4357 802.11 Hybrid Wireless Controller 6.30.223.271 (r587334)
[   15.706123] resource sanity check: requesting [mem 0x000c0000-0x000dffff], which spans more than PCI Bus 0000:00 [mem 0x000c0000-0x000c3fff window]
[   15.706129] caller pci_map_rom+0x68/0x190 mapping multiple BARs
[   16.144168] kauditd_printk_skb: 5 callbacks suppressed
[   17.766258] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[   21.151992] kauditd_printk_skb: 3 callbacks suppressed
[   26.660795] kauditd_printk_skb: 3 callbacks suppressed
[   41.728952] kauditd_printk_skb: 2 callbacks suppressed
[   46.992643] systemd-journald[192]: File /var/log/journal/88c7c46b9c3b4be199d13856678c6319/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
journalctl boot log from 5.10
Mar 10 01:15:06 innistrad kernel: __common_interrupt: 1.55 No irq handler for vector
Mar 10 01:15:06 innistrad kernel: __common_interrupt: 2.55 No irq handler for vector
Mar 10 01:15:10 innistrad kernel: ioremap error for 0xfed80000-0xfed81000, requested 0x2, got 0x0
Mar 10 01:15:10 innistrad kernel: sp5100-tco sp5100-tco: failed to get tcobase address
Mar 10 01:15:42 innistrad lightdm[797]: gkr-pam: unable to locate daemon control file
Mar 10 01:16:15 innistrad pulseaudio[893]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
:man_facepalming:
Urgh! i misread that as 5.9! (too many people on EOL kernel)
So when you shut down the machine it goes to sleep??? :thinking:
try TLP instead of upower: tlp is in constant development. (but take a System Backup first before trying that!
Upowrr wasn’t installed manually by me, it’s a dependency of xfce3-power-managment which was a default package in the xfce desktop setup in the architect installer.
If Upower isn’t running, the laptop suspends every 20 seconds. When it originally fails to start when using a 4.x kernel, this 20 second suspend cycle happens before i log on and upower manages to start successfully.
On all kernels I’ve observed the behaviour that when i tell it to shut down it’ll go most of the way, suspend, then when i wake it up it’ll finish off and power off. My suspicion is that this happens when upower is stopped.
TLP is apparently installed by default too. And I tried editing the config file at one point, assuming it was the reason, but either i changed the wrong bits or TLP is not the problem. Thinking about it i need to check if it’s running and what it’s doing.
I do lament potentially losing GUI access to these settings, but then power management is generally a set-once-and-forget thing so it’s not that bad.
In that case, remove TLP because 2 power managers is a recipe for weird problems like this…
:wink:
So they’re both independent things? I wasn’t sure if upower enabled controlling TLP or some other power management in a friendly way.
But if that’s the case it’s very odd that both would be installed by default in a new installation.
removed TLP, it’s still doing the same weird stuff with suspending. so while upower seems to stop the oddness when that service is started, there’s still something happening to trigger a suspend on shutdown, (and still occasionally before logon, this is apparently intermittent)
What logs can i check for events like this?
I would do a:
 journalctl --system --priority=4 | grep power
Anything interesting there?
I tried a few different greps (“sleep” “power” “S3” “suspend”) as well as restricting the time as well as i didn’t realise that kept logs so far back.
so “power” got me the following logs from the last two and previous boots. This is so inconsistent. 2 boots ago boot i got a ton of upower.service errors of varying kinds but on previous boot i didn’t get any of those and got a few Could not acquire inhibitor lock: GDBus.Error:org.freedesktop.login1.OperationInProgress: The operation inhibition has been requested for is already running instead. This boot, nada. All the logs were stating success or status in some form, yet the sodding thing went to sleep three times before i logged on.
grepping “sleep”, “suspend” and “S3” gave nothing useful except “i’m going to sleep” and “I’m waking up” but not what’s causing it
So i’m seeing nothing super usful as to the reason due to the inconsistency and especially this boot showing nothing wrong but it still suspending. but i am seeing some bits that make me go “why isn’t upower starting?”
greps for power (extracts from some days, not full)
Mar 10 00:49:06 innistrad systemd[1]: upower.service: Failed with result 'exit-code'.
Mar 10 00:49:07 innistrad systemd[1]: upower.service: Failed with result 'exit-code'.
Mar 10 00:49:08 innistrad systemd[1]: upower.service: Failed with result 'exit-code'.
Mar 10 00:49:08 innistrad systemd[1]: upower.service: Start request repeated too quickly.
Mar 10 01:12:35 innistrad upowerd[930]: Could not acquire inhibitor lock: GDBus.Error:org.freedesktop.login1.OperationInProgress: The operation inhibition has been requested for is already running
Mar 10 01:15:51 innistrad upowerd[935]: Could not acquire inhibitor lock: GDBus.Error:org.freedesktop.login1.OperationInProgress: The operation inhibition has been requested for is already running
Mar 12 01:40:35 innistrad upowerd[966]: Could not acquire inhibitor lock: GDBus.Error:org.freedesktop.login1.OperationInProgress: The operation inhibition has been requested for is already running
Mar 12 01:45:35 innistrad upowerd[631]: Could not acquire inhibitor lock: GDBus.Error:org.freedesktop.login1.OperationInProgress: The operation inhibition has been requested for is already running
Mar 12 02:17:11 innistrad upowerd[587]: Could not acquire inhibitor lock: GDBus.Error:org.freedesktop.login1.OperationInProgress: The operation inhibition has been requested for is already running
Mar 13 16:08:25 innistrad kernel: thermal_sys: Registered thermal governor 'power_allocator'
Mar 13 16:08:25 innistrad kernel: pci 0000:01:05.1: D0 power state depends on 0000:01:05.0
Mar 13 16:08:35 innistrad kernel: [drm] radeon: power management initialized
Mar 13 16:10:48 innistrad dbus-daemon[307]: [system] Activating via systemd: service name='org.freedesktop.UPower' unit='upower.service' requested by ':1.37' (uid=1000 pid=658 comm="/usr/lib/xfce4/panel/wrapper-2.0 /usr/lib/xfce4/pa")
Mar 13 16:10:48 innistrad systemd[1]: Starting Daemon for power management...
Mar 13 16:10:51 innistrad audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 13 16:10:51 innistrad kernel: audit: type=1130 audit(1615651851.666:97): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 13 16:10:51 innistrad systemd[1]: Started Daemon for power management.
greps for “sleep” - this boot only
Mar 13 16:08:45 innistrad NetworkManager[308]: <info>  [1615651725.7239] manager: sleep: sleep requested (sleeping: no  enabled: yes)
Mar 13 16:08:45 innistrad NetworkManager[308]: <info>  [1615651725.7242] device (wlp8s0): state change: unavailable -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Mar 13 16:08:45 innistrad systemd-sleep[386]: Suspending system...
Mar 13 16:09:19 innistrad kernel: ACPI: Preparing to enter system sleep state S3
Mar 13 16:09:19 innistrad kernel: ACPI: Waking up from system sleep state S3
Mar 13 16:09:20 innistrad systemd-sleep[386]: System resumed.
Mar 13 16:09:20 innistrad systemd-logind[313]: Operation 'sleep' finished.
Mar 13 16:09:20 innistrad NetworkManager[308]: <info>  [1615651760.2803] manager: sleep: wake requested (sleeping: yes  enabled: yes)
Mar 13 16:09:20 innistrad NetworkManager[308]: <info>  [1615651760.2804] device (enp2s0): state change: unavailable -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Mar 13 16:09:39 innistrad NetworkManager[308]: <info>  [1615651779.0661] manager: sleep: sleep requested (sleeping: no  enabled: yes)
Mar 13 16:09:39 innistrad ModemManager[390]: <info>  [sleep-monitor] system is about to suspend
Mar 13 16:09:39 innistrad NetworkManager[308]: <info>  [1615651779.0663] device (wlp8s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Mar 13 16:09:39 innistrad systemd-sleep[468]: Suspending system...
Mar 13 16:09:58 innistrad kernel: ACPI: Preparing to enter system sleep state S3
Mar 13 16:09:58 innistrad kernel: ACPI: Waking up from system sleep state S3
Mar 13 16:09:59 innistrad systemd-sleep[468]: System resumed.
Mar 13 16:09:59 innistrad systemd-logind[313]: Operation 'sleep' finished.
Mar 13 16:09:59 innistrad ModemManager[390]: <info>  [sleep-monitor] system is resuming
Mar 13 16:09:59 innistrad NetworkManager[308]: <info>  [1615651799.2678] manager: sleep: wake requested (sleeping: yes  enabled: yes)
Mar 13 16:09:59 innistrad NetworkManager[308]: <info>  [1615651799.2680] device (enp2s0): state change: unavailable -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Mar 13 16:10:32 innistrad kernel: ACPI: Preparing to enter system sleep state S3
Mar 13 16:10:32 innistrad kernel: ACPI: Waking up from system sleep state S3
Mar 13 16:10:17 innistrad ModemManager[390]: <info>  [sleep-monitor] system is about to suspend
Mar 13 16:10:17 innistrad NetworkManager[308]: <info>  [1615651817.1935] manager: sleep: sleep requested (sleeping: no  enabled: yes)
Mar 13 16:10:17 innistrad NetworkManager[308]: <info>  [1615651817.1944] device (wlp8s0): state change: ip-config -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
Mar 13 16:10:17 innistrad NetworkManager[308]: <info>  [1615651817.6087] device (wlp8s0): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
Mar 13 16:10:17 innistrad NetworkManager[308]: <info>  [1615651817.6521] device (wlp8s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Mar 13 16:10:17 innistrad systemd-sleep[536]: Suspending system...
Mar 13 16:10:33 innistrad ModemManager[390]: <info>  [sleep-monitor] system is resuming
Mar 13 16:10:33 innistrad systemd-sleep[536]: System resumed.
I’m sorry: I’m at a loss too. Last ditch effort: can you disable the laptop power buttons as it seems to be intermittent, so maybe it’s one of the buttons.
fab-root@fab-manjaro:~
$ grep --ignore-case lid /etc/systemd/logind.conf
#HandleLidSwitch=suspend
#HandleLidSwitchExternalPower=suspend
#HandleLidSwitchDocked=ignore
#LidSwitchIgnoreInhibited=yes
$ grep --ignore-case power /etc/systemd/logind.conf
#HandlePowerKey=poweroff
#PowerKeyIgnoreInhibited=no
Set both IgnoreInhibited to no and set all the others to ignore
:crossed_fingers:
Warning! This, obviously means you can only shut down your system using the menu system or terminal!
So I’ve not done your suggestion yet, mainly as i believe theres more underlying issues.
Starting it a few times today, I’ve had some times it suspended, sometimes it didn’t. Not once did i have network when i hit the desktop. And on some occasions it actually froze just after the logon prompt.
I’m starting to think this is actually a bad hard disk due to age and these are manifestations of bad reads. So I’m going to buy a replacement SSD (which was on the cards anyway) and see if a re-install will do the trick.
New SSD arrived today. Nice and cheap, this only needed a 120GB disk, could’ve likely gotten away with less.
Installed Manjaro using the architect ISO like last tike, and initially only installed the known-good 4.4 kernel.
Installed and booted nice and quickly. And with no issues.
So i installed kernel 5.4, updated grub so i could swap, and booted to that.
And it all seems to ‘just work’ not hit anything yet, but we’ll see if that lasts.
If it does, it was a Hard Disk issue.
