Post-update problem installing nvidia driver with mhwd
Hi y’all, is my first post here. Looking for guidance.
Updated the system with pamac gui today. After reboot, I had no nvidia kernel driver.
mhwd attempts to download linux513-nvidia-470.63.01-5-x86_64, which does not exist on the repo. I see the repo instead contains linux513-nvidia-470.63.01-7-x86_64
So something on my system is out of sync or out of date?
So far, I’ve tried the following
# refresh mirror list
pacman-mirrors -f5
# force reinstall mhwd-db
pacman -Syu mhwd-db
# install the nvidia driver
mhwd -a pci nonfree 0300
I get this output from mhwd
# mhwd -a pci nonfree 0300
> Using config 'video-nvidia' for device: 0000:08:00.0 (0300:10de:1e84) Display controller nVidia Corporation TU104 [GeForce RTX 2070 SUPER]
> Installing video-nvidia...
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/db/pci/graphic_drivers/nvidia/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
Processing classid: 0302
 core downloading...
 extra downloading...
 community downloading...
 multilib downloading...
resolving dependencies...
Packages (4) lib32-nvidia-utils-470.63.01-1  linux510-nvidia-470.63.01-5  linux513-nvidia-470.63.01-5  nvidia-utils-470.63.01-1
Total Download Size:    39.45 MiB
Total Installed Size:  638.92 MiB
:: Retrieving packages...
 linux513-nvidia-470.63.01-5-x86_64 downloading...
error: failed retrieving file 'linux513-nvidia-470.63.01-5-x86_64.pkg.tar.zst' from manjaro.re : The requested URL returned error: 404
error: failed retrieving file 'linux513-nvidia-470.63.01-5-x86_64.pkg.tar.zst' from mirror.math.princeton.edu : The requested URL returned error: 404
error: failed retrieving file 'linux513-nvidia-470.63.01-5-x86_64.pkg.tar.zst' from repo.ialab.dsu.edu : The requested URL returned error: 404
error: failed retrieving file 'linux513-nvidia-470.63.01-5-x86_64.pkg.tar.zst' from manjaro.mirrors.uk2.net : The requested URL returned error: 404
error: failed retrieving file 'linux513-nvidia-470.63.01-5-x86_64.pkg.tar.zst' from mirror.erickochen.nl : The requested URL returned error: 404
warning: failed to retrieve some files
error: failed to commit transaction (failed to retrieve some files)
Error: pacman failed!
Error: script failed!
Any advice how I could sort this out?
Hi and welcome to the forum :wave:
This should report what pamac did with your nvidia drivers:
$ cat /var/log/pacman.log |grep nvidia | tail -20
(last 20 lines of the pamac log mentioning nvidia)
I use 2 of the mirrors you have and they work perfectly for me so bit stumped what could cause this. does sudo pacman -Syu sync your database again and solve the download problem?
How do you check that the nvidia driver is not installed?
Could you provide an inxi please? and what does mhwd report ?
see: How to provide good information
edit: thak you for using the correct formatting, that makes it readable and searchable
version kernels 5.13 is EOL
you should have version 510 LTS installed and 5.14 installed
I might have (had) a similar problem, just “solved” it for now by completely removing the proprietary nvidia driver.
I would be also interested in a solution to make it work again …
https://forum.manjaro.org/t/failed-to-start-lightdm-display-manager-after-update/84016
