I am expecting a second SSD drive in a day or so. I want to use it as additional storage only for games (so no boot needed) . I have read a number of threads and tutorials, most of which seem not to address my use specifically. I suspect that is because what I want to do is too simple to require a tutorial?
I do have some questions about this process, and I would be very grateful if anyone could take a look, point out any mistakes or missing steps, and/or help with my questions.
I believe that all I need to do is connect the new storage disk to my motherboard and boot up. At that point my disk should appear and I can format it with kde partition manager. I would like to format the new disk btrfs because of the compression. Will that be a problem since my primary SSD is ext4? ALso, my new SSD is slightly faster read/write. Would it make sense to move the swap file from the old to the new SSD?
After it is formatted, I need to create a directory for it. I am following the advice of this post:
AragornModerator
And that should do it? Thanks in advance!
Here is my system info:
Kernel: 6.5.3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
root=UUID=a4677c34-08ee-4217-a8f8-04d583d29686 ro quiet apparmor=1
security=apparmor resume=UUID=54b33f09-d1e4-45c1-85ed-60965f977595
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2 dm: SDDM
Mobo: ASUSTeK model: TUF GAMING X570-PRO (WI-FI) v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 4021
date: 08/10/2021
Device-1: hidpp_battery_0 model: Logitech MX Ergo Multi-Device Trackball
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
Device-2: hidpp_battery_1 model: Logitech K800 serial: <filter>
charge: 70% (should be ignored) rechargeable: yes status: discharging
System RAM: total: 32 GiB available: 31.26 GiB used: 4.05 GiB (13.0%)
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 32 MiB
desc: 1x32 MiB
Speed (MHz): avg: 2533 high: 4200 min/max: 2200/5279 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 4200 2: 2200
3: 2200 4: 4200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200
12: 2200 bogomips: 100828
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
Type: spec_rstack_overflow mitigation: safe RET, no microcode
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: ASUSTeK
driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 05:00.0 chip-ID: 1002:73ff
class-ID: 0300
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: HF237 serial: <filter>
built: 2009 res: 1920x1080 hz: 60 dpi: 96 gamma: 1.2
size: 509x286mm (20.04x11.26") diag: 584mm (23") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
API: OpenGL v: 4.6 Mesa 23.1.7-1 renderer: AMD Radeon RX 6600 XT (navi23
LLVM 16.0.6 DRM 3.54 6.5.3-1-MANJARO) direct-render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 05:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0c:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.5.3-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.80 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl,pavucontrol
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp6s0 state: down mac: <filter>
Device-2: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 07:00.0 chip-ID: 8086:15f3
class-ID: 0200
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: wg-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
IP v4: <filter> scope: global
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:2 chip-ID: 8087:0029
class-ID: e001
Report: hciconfig ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.2
lmp-v: 11 sub-v: 20ce hci-v: 11 rev: 20ce class-ID: 7c0104
Info: acl-mtu: 1021:4 sco-mtu: 96:6 link-policy: rswitch sniff
link-mode: peripheral accept service-classes: rendering, capturing, object
transfer, audio, telephony
Local Storage: total: 1.82 TiB used: 768.55 GiB (41.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DX001-1NS164
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC41 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GH22LS50 rev: TL01
dev-links: cdrom
Features: speed: 40 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 1.81 TiB size: 1.78 TiB (98.37%) used: 768.55 GiB (42.1%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: a4677c34-08ee-4217-a8f8-04d583d29686
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: C48B-AD92
dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 54b33f09-d1e4-45c1-85ed-60965f977595
class-ID: 0900 Kernel: 6.5.3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
udev.log_priority=3
date: 08/10/2021
status: discharging
desc: 1x32 MiB
class-ID: 0300
class-ID: 0403
class-ID: 0200
class-ID: e001
dev-links: cdrom
uuid: C48B-AD92
Device-1: 1-4:2 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0029 class-ID: e001
Device-2: 1-6:3 info: Logitech Unifying Receiver type: keyboard,mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
chip-ID: 046d:c52b class-ID: 0300
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 3-4:2 info: ASUSTek AURA LED Controller type: HID
lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:1939 class-ID: 0300
serial: <filter>
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-6: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
System Temperatures: cpu: 40.8 C mobo: N/A gpu: amdgpu temp: 41.0 C
mem: 38.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
Processes: 315 Uptime: 5h 10m wakeups: 38 Init: systemd v: 254
Packages: pm: pacman pkgs: 1767 libs: 488 tools: pamac pm: flatpak pkgs: 0
Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.29
serial: <filter>
mem: 38.0 C
Moderator edit: corrected formatting
