since the Plasma 5.26.* the plasmashell process is using almost 4gb of RAM memory just by turning my computer on (with no other process opened).
Not only that, but I noticed lots of freezing happening often, I’ve been using Manjaro KDE for years and its the first time ever that the system is almost unusable, is it happening only with me or is it normal on this new Plasma version?
Hello. I had the same issues on Plasma 5.25, when i login, it starts eating ram and needs some minutes to be ready to use, and then lots of freezes (every 5-6 minutes). This problem exists almost 2 months but now it’s worse. Today i upgraded the system and got Plasma 5.26. It’s a bit more stable but it still needs 3-4 minutes to start. Is there any even temporary solution?
the same i have lots of years now.
Anyway, i will reset the settings of plasmashell to check if it fixes and setup it again as i have it step by step. Which config files plashashell uses?
I just installed it, after that I logged out and on the session screen I selected to start with liquidshell.
Even after doing all this Plasmashell still startups in the background, so you will need to run:
